[Testing Update] 2021-05-12 - Kernels, KDE Frameworks, Plasma, Systemd, Mesa, LibreOffice, KDE Gear Mobile, FF, TB
Hello community,
Another testing branch update with some usual updates for you.
Find out more about the new Starbook by Starlabs!
  • Most of our Kernels got updated
  • We added Plasma Mobile Gear Apps. More info about them here.
  • Gnome Apps got mostly updated to 40.1. We are still shipping 3.38 shell!
  • Maui Apps are now at 1.2.2
  • We updated Systemd to 248.2
  • Firefox 88.0.1 and Thunderbird 78.10.1 got updated.
  • LibreOffice is at 7.1.3
  • Mesa got updated to 21.1.0
  • KDE Frameworks got updated to 5.82.0
  • KDE Plasma is now at 5.21.5
  • Lot of KDE-git package updates
  • Other regular upstream updates including python and haskell
Get our latest daily developer images now from Github: Plasma, Gnome, XFCE. You get the latest stable releases of Manjaro from CDN77.
Our current supported kernels
  • linux44 4.4.268
  • linux49 4.9.268
  • linux414 4.14.232
  • linux419 4.19.190
  • linux54 5.4.118
  • linux510 5.10.36
  • linux511 5.11.19
  • linux512 5.12.2
  • linux513 5.13-rc1
  • linux54-rt 5.4.106_rt54
  • linux59-rt 5.9.1_rt19
Packages Changes (Wed May 12 09:56:17 CEST 2021)
  • testing community x86_64: 1189 new and 1155 removed package(s)
  • testing core x86_64: 34 new and 33 removed package(s)
  • testing extra x86_64: 627 new and 830 removed package(s)
  • testing kde-unstable x86_64: 360 new and 358 removed package(s)
  • testing multilib x86_64: 23 new and 24 removed package(s)
A detailed list of all package changes can be found here.
0 voters
Known issues and solutions
New issues:
  • OS prober does not run and add other operating systems
    Please click the â–ş at the beginning of this line to view this solution
    To restore, please execute: echo GRUB_DISABLE_OS_PROBER=false|sudo tee -a /etc/default/grub && sudo update-grub
    For more information, see opening post in [Stable Update] 2021-03-08.
Recent Arch Linux news:
PHP 8.0 and PHP 7 legacy packages are available
2021-01-28 - Pierre Schmitz
The php package has been updated to version 8.0. Please refer to the upstream migration guide. As some applications are not compatible with PHP 8 yet we provide a php7 package which can be installed alongside version 8. Packages that depend on PHP reflect this update and will require php7 if needed. You might need to update your configuration accordingly. PHP 7 binaries and configuration have the “7” suffix:
  • /usr/bin/php → /usr/bin/php7
  • /etc/php → /etc/php7
  • /usr/bin/php-fpm → /usr/bin/php-fpm7
  • /usr/lib/systemd/system/php-fpm.service → /usr/lib/systemd/system/php-fpm7.service
  • /run/php-fpm → /run/php-fpm7
We also provide third party modules compiled for PHP 7:
Note that support for php7 will be limited and likely be dropped in about a year depending on how soon the majority of applications will be compatible with version 8.
https://archlinux.org/news/php-80-and-php-7-legacy-packages-are-available/
Chromium losing Sync support in early March
2021-02-03 - Evangelos Foutras
Google has announced that they are going to block everything but Chrome from accessing certain Google features (like Chrome sync) starting on March 15. This decision by Google is going to affect Arch’s chromium package a bit earlier, on March 2, when Chromium 89 gets released.
We know for sure that data syncing will stop working (passwords, bookmarks, etc.). Other features such as geolocation or enhanced spell check might continue to function for a bit longer. Extensions integrating with Google Drive might misbehave and LibreOffice will lose access to documents stored there.
Other distros such as openSUSE and Fedora have already removed the soon-to-be-limited API keys from their Chromium 88 packages. Fedora’s advisory provides a great deal of perspective on this and I also found this Hackaday post to be quite informative.
https://archlinux.org/news/chromium-losing-sync-support-in-early-march/
Older Issues
Nvidia card owners
  • We simplified nVidia driver installation. This means we dropped legacy drivers.
    • We recommend to switch over to Nouveau drivers if your card is mentioned here and the feature you need is not in red TO DO here for your particular card.
    • If you however still need proprietary drivers, you may want to execute the following to ensure all parts of the nVidia drivers get installed properly:
      sudo mhwd -a pci nonfree 0300
      If proprietary drivers don't fix everything, please click the â–ş at the beginning of this line to view more info
      1. try installing kernel 5.4 LTS (Long Term Support)
      2. If that doesn’t fix it, take a full system backup, go to a console using Ctrl+Alt+F2 and:
      • Backup /etc/X11/mhwd.d/nvidia.conf if you ever edited that manually
      • remove all nVidia related drivers and applications:
        pacman --remove nvidia*
      • Note which applications are being removed and keep them handy in a list
      • Install the driver first:
        mhwd --install video-hybrid-XXX-nvidia-prime
        (Where XXX is amd or intel if you have hybrid graphics or the whole thing is video-nvidia if you’re on an nVidia-only system)
      • reboot and see if you at least get a screen.
      • Install all the other applications from your handy list that you still need one by one.
      • Restore /etc/X11/mhwd.d/nvidia.conf if you ever edited that manually
      • If that wouldn’t solve the issue open a new issue here referring to this update and posting at a minimum the full output of:
      If you however still have issues with your Nvidia card, you may open a new thread in our forum: Graphics & Display - Manjaro Linux Forum or look at our tutorial on compiling old Nvidia drivers.
For AMD GPU users having a black screen with kernel 5.10
Please click the â–ş at the beginning of this line to view more info
Due to a bug in the AMD drivers, please try the following first:
For GRUB:
  1. Open a terminal or a TTY
  2. Open /etc/default/grub in your favourite CLI editor (nano vi, emacs`)
  3. Find the line: GRUB_CMDLINE_LINUX_DEFAULT="
  4. Add amdgpu.dc=0
  5. Save
  6. Execute sudo update-grub and reboot
For systemd-boot:
  2. Open /boot/loader/entries/manjarolinux5.10.conf in your favourite CLI editor (nano vi, emacs`)
  3. Add amdgpu.dc=0 to the end of the line options
  4. Save & reboot
For rEFInd:
  2. Open /boot/refind_linux.conf in your favourite CLI editor (nano vi, emacs`)
  3. Find the line: "Boot using default options" "root=
  4. Add amdgpu.dc=0
  5. Save & reboot
Possible 2 Min delay on shutdown with Gnome
  • If you got the problem with shutdown delay (about 2min) on Gnome, here is a workaround:
    • Edit /usr/lib/systemd/user/gnome-session-restart-dbus.service in your favourite editor as root and add Slice=-.slice as a line all by itself like this:
      [Service]
      Type=notify
      Slice=-.slice
      ExecStart=/usr/lib/gnome-session-ctl --restart-dbus
    • Click this link For more information
Touchpad on a ThinkPad stops working
  • Restart again, please.
You get [PKGNAME] warning: directory permissions differ on [Directory name]
followed by:
Filesystem: NNN package MMM
  • The solution:
    sudo chmod MMM DirectoryName
Where obviously MMM is the second number you see (the correct one)
  • The explanation:
    Your package expects the security permissions to be MMM but your system is set to NNN. This is just a warning (today) but to ensure you remain up-to-date with the latest and greatest security rules it’s advised to execute the above command.
Systemd error message: .slice: Failed to migrate controller cgroups
If you have a similar error message like this:
systemd[1004]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
… you may need to add this Grub parameter to your /etc/default/grub file in line GRUB_CMDLINE_LINUX_DEFAULT: systemd.unified_cgroup_hierarchy=true. To update your grub menu, call: sudo update-grub. For more information on that issue, see also Arch Forum.
Python 3.9 Requires Rebuilds
Instructions for quickly and easily rebuilding affected AUR packages:
# Install yay
sudo pacman -S --needed --noconfirm yay
# Rebuild AUR python packages
yay -S --noconfirm $(pacman -Qqo "/usr/lib/python3.8/site-packages")
libtraceevent>=5.9-1 update requires manual intervention
2020-10-23 - Sébastien Luttringer
The libtraceevent package prior to version 5.9-1 was missing a soname link. This has been fixed in 5.9-1, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
libtraceevent: /usr/lib/libtraceevent.so.1 exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/libtraceevent.so.1
to perform the upgrade.
Arch Linux - News: libtraceevent>=5.9-1 update requires manual intervention
OpenVPN connection times out.
Workaround: donwgrade openvpn (2.5.0-1 => 2.4.9-2).
For a proper solution follow this bug report on Arch Linux: FS#68480 : [openvpn] running unprivileged with iproute no longer working
PAM and PAMBASE got updated, which might prevent you from login
Due to updates from pambase and pam you might take care about any .pacnew files in /etc/pam.d as for example pam_tally, pam_tally2 and pam_cracklib got deprecated. Read in the ArchWiki about managing those files.
Typical issue:
For recovery, it is enough to boot with kernel option “systemd.unit=rescue.target”, then proceed into /etc/pam.d and merge “system-auth” and “system-auth.pacnew”
System takes a long time to boot
If you’ve got errors like Failed to start Network Manager Wait Online. you can try removing systemd from passwd and group in /etc/nsswitch.conf as described here
Update: If you can see the line
dbus-daemon[1453]: [system] Connection has not authenticated soon enough, closing it (auth_timeout=30000ms, elapsed: 45146ms)
in in your dbus log ( journalctl -b -u dbus ), the new/better workaround is to switch cups from service to socket as described here:
systemctl disable cups.service
systemctl enable cups.socket
I think I’ve some font problems
With the update of fontconfig some major rules how fonts get applied changed. Make sure that your system has ttf-dejavu installed. A more in depth explanation can be found here.
Gnome-shell-extension-pop-shell is currently incompatible with wayland
… and causes the system to freeze when the first window is tiled and can render it unbootable. Solution is a hard reset and disabling either pop shell or wayland. If the system becomes unbootable, use a live USB to edit /etc/gdm/custom.conf to disable wayland and reboot.
Did anyone forget about informing about the next update on the forum? I just got an info that 1,4 GB of packages are waiting to get downloaded but nothing about it on the forum… And I already had installed the update this thread is actually about.
I tried updating but it throws an error at install.
yeah there’s a new update without a thread - happens sometimes ^^
only issue i have with it is btrfs-progs - so if you don’t use btrfs i can’t report any issues :wink:
with me… it doesn’t even finish the update.
you should always report indeed!
what’s the issue exactly?
I am using btrfs since the early days, I’m particularly interested…
I’ve noted it in the unstable thread for the time being (till the correct thread appears ^^).
btrfs-progs 5.12 has a bug (fixed in 5.12.1 already, should release soon) - so maybe skip that while updating :slight_smile:
Open a support thread then I guess?
This is expected, the announcement thread is made when many of the mirrors are updated, and/or when the thread is actually written.
It is pointless to announce an update if people can not update or if everyone update from the one or to up to date mirrors. If you feel like you need to wait for the announcement to do the update, then wait for it it will come in due time.
I use BTRFS. Does this mean I should not update until btrfs-progs 5.12.1 reaches testing?
only if you use snap, it seems.
Error updating:
conflicting files:
  • plasma-workspace: /usr/share/locale/ta/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
    To fix it I moved kcm_autostart.mo to kcm_autostart.mo-bak and then did the update.
Unless you have a reason for using plasma-desktop-primex, why not just replace it with regular plasma-desktop?
What does plasma-desktop-primex offer in comparison with the regular one? I just replaced it with the regular one and the update applied itself flawlessly. Did I lose anything important by doing it?
I actually got my performance back in steam proton with most games by swapping to regular plasma-desktop. I don’t even know what the change made, but all my games were lagging a lot with plasma-desktop-primex.
I updated one machine. There is an update for protobuf and while the last few times it somehow wasn’t necessary, this time we need a rebuild of compiz-easy-patch again.
i’ve not encountered any immediate issues, mainly around snapper (snapper-gui and snap-pac-grub). If you automated your snapshots in another way that doesn’t use btrfs-progs (or is not affected from the bug), you should be fine
That got fixed via btrfs-progs 5.12-2
