Nice, seems to be ok on my side - thank you!
Installed kernel 5.12 again. Still the same issue. No big problem so far though. When I want i3, I start with kernel 5.11, otherwise I have sway.
A few minutes ago I did the btrfs update
I receive this warnings
warning: manjaro-gdm-theme: local (20210429-1) is newer than community (20210326-1)
warning: manjaro-gnome-settings: local (20210429-1) is newer than community (20210403-1)
warning: pamac-cli: local (10.1.1-2) is newer than extra (10.0.6-2)
warning: pamac-common: local (10.1.1-2) is newer than extra (10.0.6-2)
warning: pamac-flatpak-plugin: local (10.1.1-2) is newer than extra (10.0.6-2)
warning: pamac-gnome-integration: local (10.1.1-2) is newer than extra (10.0.6-2)
warning: pamac-gtk: local (10.1.1-2) is newer than extra (10.0.6-2)
warning: pamac-snap-plugin: local (10.1.1-2) is newer than extra (10.0.6-2)
Any idea?
Edit:
The message shows in the GUI, so I did a re-check of the branch and mirrors
After posting I did the branding check (testing)
sudo pacman-mirrors --api --set-branch testing
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
The error was the same
The xfce4-clipman-plugin
has an issue where the Primary selection is not truncated, making the popup stretch the entire screen if you previously selected a huge chunk of text with your mouse. Iāve opened an issue upstream:
@riggs see here branch-compare:
pamac-gtk repository : extra
Stable : 10.0.6-2
Testing : 10.0.6-2
Unstable : 10.1.1-2
I have issue with KDE, plasma-desktop cannot loaded. I got black screen and nothing donāt happen after login. I can only move mouse pointer.
Also In SDDM I got error:
The current theme cannot be loaded due to the errors below, please select another theme.
file:///usr/share/sddm/themes/breath2Main.qml:26:1: plugin cannot be loaded for module āorg.kde.plasma.coreā. Cannot load library /usr/lib/qt/qml/org/kde/plasma/core/libcorebindingsplugin.so: (/usr/lib/libKF5PlasmaQuick.so.5: undefinded symbol: _ZN14KWindowEffects11slideWindowEP7QWindowNS_17SlideFromLocationEi)
I tried select anothere theme changing parameter in config file /etc/sddm.conf, clean up cache folder but it donāt help me.
After so I removed package plasma-framework and all its dependencies, change branch to stable and install all packages from that branch.
sudo pacman -Rcs plasma-framework
sudo pacman-mirrors -aB stable
sudo pacman -Syyu
sudo pacman -S plasma-desktop plasma-disks sddm-kcm kgamma5 systemsettings powerdevil plasma-pa ....
My branch is testing, not unstable.
pamac install pamac-gtk ī² 127 ā
Preparingā¦
Warning: installing pamac-cli (10.0.6-2) breaks dependency āpamac-cli=10.1.1-2ā required by pamac-flatpak-plugin
Add pamac-flatpak-plugin to remove
Warning: installing pamac-gtk (10.0.6-2) breaks dependency āpamac-gtk=10.1.1-2ā required by pamac-gnome-integration
Add pamac-gnome-integration to remove
Error: Failed to prepare transaction:
could not satisfy dependencies:
- installing pamac-cli (10.0.6-2) breaks dependency āpamac-cli=10.1.1-2ā required by pamac-snap-plugin,
- if possible, remove pamac-snap-plugin and retry
Warning: downgrading package pamac-gtk (10.1.1-2 => 10.0.6-2)
Resolving dependenciesā¦
Checking inter-conflictsā¦
could not satisfy dependencies: - installing pamac-cli (10.0.6-2) breaks dependency āpamac-cli=10.1.1-2ā required by pamac-snap-plugin,
The pamac redesign was reverted in testing, for some reason. I just downgraded with the update (sudo pacman -Syyuu
), and everything works fine.
Then there is an issue with branch compare again.
Pamac is on 10.1 since previous update on Testing branch. [Testing Update] 2021-05-03 - Kernels, Mesa, Nvidia 465.27, VirtualBox, LxQt 0.17, Deepin, Gnome Apps 40.1
//EDIT: no there has been a rollback on Testing branch actually. I forced refresh my database and see:
[omano@omano-nvme ~]$ sudo pacman -Syyu
core 165,4 KiB 710 KiB/s 00:00 [----------------------------------------------------------] 100%
extra 1909,7 KiB 1232 KiB/s 00:02 [----------------------------------------------------------] 100%
community 6,6 MiB 1241 KiB/s 00:05 [----------------------------------------------------------] 100%
multilib 178,9 KiB 994 KiB/s 00:00 [----------------------------------------------------------] 100%
resolving dependencies...
Packages (1) btrfs-progs-5.12-2
Total Download Size: 0,86 MiB
Total Installed Size: 5,09 MiB
Net Upgrade Size: 0,00 MiB
Seems that wait is the best option 'cause -Syyuu will going back the branch to stableā¦
So and quote:
Be aware that after switching to a more stable branch you will receive messages from pacman, informing about newer packages installed than available in the repo. Donāt be alarmed as the situation will resolve itself when the packages reaches your current branch.
From branches wiki questions roll back
Downgrading doesnāt change the branch youāre on. It just brings packages to the same versions theyāre at in the repos for your branch.
My bad, I learn something new today, thanks to you, really appreciated
sudo pacman -Syyuu ī² :heavy_check_mark:
[sudo] password for riggs:
:: Synchronizing package databasesā¦
core 165.4 KiB 815 KiB/s 00:00 [######################] 100%
extra 1909.7 KiB 4.30 MiB/s 00:00 [######################] 100%
community 6.6 MiB 3.14 MiB/s 00:02 [######################] 100%
multilib 178.9 KiB 58.2 MiB/s 00:00 [######################] 100%
:: Starting full system upgradeā¦
warning: manjaro-gdm-theme: downgrading from version 20210429-1 to version 20210326-1
warning: manjaro-gnome-settings: downgrading from version 20210429-1 to version 20210403-1
warning: pamac-cli: downgrading from version 10.1.1-2 to version 10.0.6-2
warning: pamac-common: downgrading from version 10.1.1-2 to version 10.0.6-2
warning: pamac-flatpak-plugin: downgrading from version 10.1.1-2 to version 10.0.6-2
warning: pamac-gnome-integration: downgrading from version 10.1.1-2 to version 10.0.6-2
warning: pamac-gtk: downgrading from version 10.1.1-2 to version 10.0.6-2
warning: pamac-snap-plugin: downgrading from version 10.1.1-2 to version 10.0.6-2
resolving dependenciesā¦
looking for conflicting packagesā¦
Packages (8) manjaro-gdm-theme-20210326-1 manjaro-gnome-settings-20210403-1
pamac-cli-10.0.6-2 pamac-common-10.0.6-2
pamac-flatpak-plugin-10.0.6-2 pamac-gnome-integration-10.0.6-2
pamac-gtk-10.0.6-2 pamac-snap-plugin-10.0.6-2
Total Download Size: 0.08 MiB
Total Installed Size: 15.18 MiB
Net Upgrade Size: 0.22 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packagesā¦
manjaro-gdm-them⦠61.9 KiB 0.00 B/s 00:00 [######################] 100%
manjaro-gnome-se⦠19.3 KiB 0.00 B/s 00:00 [######################] 100%
(8/8) checking keys in keyring [######################] 100%
(8/8) checking package integrity [######################] 100%
(8/8) loading package files [######################] 100%
(8/8) checking for file conflicts [######################] 100%
(8/8) checking available disk space [######################] 100%
:: Processing package changesā¦
(1/8) downgrading manjaro-gdm-theme [######################] 100%
(2/8) downgrading manjaro-gnome-settings [######################] 100%
(3/8) downgrading pamac-common [######################] 100%
(4/8) downgrading pamac-cli [######################] 100%
(5/8) downgrading pamac-flatpak-plugin [######################] 100%
(6/8) downgrading pamac-gtk [######################] 100%
(7/8) downgrading pamac-gnome-integration [######################] 100%
(8/8) downgrading pamac-snap-plugin [######################] 100%
:: Running post-transaction hooksā¦
(1/9) Reloading system manager configurationā¦
(2/9) Arming ConditionNeedsUpdateā¦
(3/9) Reloading system bus configurationā¦
(4/9) Manjaro GDM theme install
(5/9) Compiling GSettings XML schema filesā¦
(6/9) Updating icon theme cachesā¦
(7/9) Collection of usefull scripts for Manjaro Gnome
==> Printing support installed
(8/9) Updating the desktop file MIME type cacheā¦
(9/9) Updating the MIME type databaseā¦
ļ ī° ļ ~ ī° sudo pacman-mirrors --get-branch ī² :heavy_check_mark: ī² 24s ļ
testing
Edit: Fixed preformated text. Thanks @omano
You should use the </> button instead of creating a quote when you share terminal output so that it doesnāt create a fat block of text without proper formatting. Edit your post (and select terminal output, click the button) to make it good.
The Starcraft 2 game in wine shows empty black screen after update. I am using amdgpu. Downgraded to stable for now.
Got blank screen after latest update.
3 conflicts:
- plasma-dekstop & plasma-desktop-primex
-Ksysguard & ksysguard-git
-libksysguard & libksysguard-git
If I remove Ksysguard-git breaks dependency with plasma-systemmonitor-git
Whenever I try removing those git and primex files⦠the command stops for my removing order will also affect another -git files in my system⦠Any help to bypass this issue and to restate my Testing branch system will be happily welcomed
Just to note, reverting Pamac to repo packages also throws new orphan libhandy
which can be removed also.
Manjaro KDE testing, kernel 5.12. All went fine, no problems.
Hm, I think you miss-understood. Sway is what is working with all kernels. The problem is the other way around, itās i3 that is crashing everytime after the startup as soon as I login to the session.
EDIT: BTW, here is the log-file of my last attempt to use i3 with kernel 5.12.
