System Update problem,often
hello,
I’m very often have problems updating the software and sometimes even firmware of my manjaro build.
even trying to install a new software became a problem.
very often there are dependeces which are not respected and it block all.
can you please help me update my computer?
  Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=6e4d6b98-0184-495c-91cc-99242bb55fd2 rw quiet
    udev.log_priority=3
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 20351 v: Lenovo G50-70
    serial: <superuser required> Chassis: type: 10 v: Lenovo G50-70
  Mobo: LENOVO model: Lancer 5A2 v: 31900058STD serial: <superuser required>
    UEFI-[Legacy]: LENOVO v: 9ACN25WW date: 04/02/2014
  ID-1: BAT0 charge: 13.8 Wh (55.4%) condition: 24.9/31.7 Wh (78.7%)
    power: 15.2 W volts: 15.3 min: 14.4 model: Lenovo IdeaPad type: Unknown
    serial: <filter> status: charging
  Device-1: hidpp_battery_0 model: Logitech M510 serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  Info: model: Intel Core i3-4010U bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1000 high: 1600 min/max: 800/1600 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1600 2: 800 3: 800 4: 800
    bogomips: 13573
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
    class-ID: 0300
  Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo
    driver: radeon v: kernel alternate: amdgpu arch: GCN-1 code: Southern Islands
    process: TSMC 28nm built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4
    link-max: lanes: 8 bus-ID: 03:00.0 chip-ID: 1002:666f class-ID: 0380
    temp: 35.0 C
  Device-3: Microdia Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-6:4 chip-ID: 0c45:6513
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting,radeon
    alternate: fbdev,vesa dri: crocus,radeonsi gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: LG Display 0x044b built: 2013 res: 1366x768 hz: 60
    dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1366x768
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Lenovo 8 driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
  Server-1: JACK v: 0.125.0 status: off tools: N/A
  Server-2: PipeWire v: 0.3.80 status: off with: wireplumber status: off
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 5000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
    vendor: Lenovo Z50-75 driver: rtl8723be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:b723
    class-ID: 0280
  Device-1: Realtek RTL8723B Bluetooth driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:5 chip-ID: 0bda:b728
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled
  Local Storage: total: 465.76 GiB used: 171.63 GiB (36.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: LVM1 scheme: MBR
  ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 171.63 GiB (37.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 36.0 C mobo: N/A gpu: radeon temp: 35.0 C
  Fan Speeds (rpm): N/A
  Processes: 190 Uptime: 53m wakeups: 6 Memory: total: 4 GiB
  available: 3.73 GiB used: 2.37 GiB (63.7%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1431 libs: 402 tools: pamac pm: flatpak pkgs: 0
  Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.30
Hi @Jakobz,
This isn’t your first time here, so you should know this, but in order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Not without details:
system information (inxi)
command output
The usual procedure is to update/refresh the mirror list and then to use pamac or pacman to update - this will give feedback as to what happens and why something might have failed.
You can see that - we cant, unless you show it.
sorry everyone i always forgetting about basic info.
here is the system info:
    udev.log_priority=3
    bogomips: 13573
    class-ID: 0300
    temp: 35.0 C
    class-ID: 0e02
    screens: 1
    tools: pw-cli,wpctl
    class-ID: 0280
after using “sudo pacman -Syu”
the output is the following after many question
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Replace onevpl with extra/libvpl? [Y/n]
:: Replace plasma-framework with extra/plasma-framework5? [Y/n]
:: Replace purpose with extra/purpose5? [Y/n]
:: removing kxmlgui breaks dependency 'kxmlgui' required by libkipi
:: removing kservice breaks dependency 'kservice' required by libkipi
done…sorry i forget about basics
That is very diffuse
Because Manjaro Linux is rolling release - you need your current system in sync before getting new software
That is normal - if you have answered No when you should have answered Yes
There may be times when you need to manually intervene to be able to update.
libkipi was a custom script which is now breaking your update
Remove libkipi and all other packages depending on libkipi
sudo pacman -Rns libkipi
Cool. I think you have an outdated mirror pool, or outdated package list. Run the following to update them:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Sy
Afterwards, try the update again:
sudo pacman -Syu
Since it has been a log time for the rename since the KDE packages have been renamed to the -5 packages that you’re struggling with, it suggests you haven’t updated in some time. Which means you’ve been a bad, bad boy. You need to keep updated.
This has been answered so many times already I stopped counting. Did it ever occur to you to insert a line with an error into search engine?
thats the output
sudo: manjaro-mirrors: command not found
didn’t thought about searching this line here. will try now
Sorry, my bad! Try:
i wasn’t sure this was something important or not for the system. there are any safe way to remove all the old packages which are no longer needed for the system?
pamac remove --orphans
i’m not working on computer very often do to my job, as you ccan probably ccan read from the system info it’s also a pretty old machine… i will be more diligent and update system more often
No - there is no method - you will have to look at the output (if any) and append packages depending on libkipi to the command and rerun - it may take a few tries to succeed or you may succeed a first go.
i don’t understand what you mean here. i usually answer yes to this trusting the process. what i have to do to check when i need to intervene manually?
That is the best way to do it, yes.
Each stable update there are announcements on this forum. Read them! Everything is mentioned there.
if it’s something important for the system there will be no similar output as here, right? i’m afraid to delete somethig useful
now i’m not sure what to do…
Preparing...
Checking dependencies...
To remove (142):
  zeitgeist                    1.0.4-2                                                       extra
  telepathy-glib               0.24.2-2             (Orphan Of: zeitgeist)                   extra
  xapian-core                  1:1.4.23-1           (Orphan Of: zeitgeist)                   extra
  jre-openjdk-headless         21.u35-3                                                      extra
  libnet                       1:1.1.6-1            (Orphan Of: jre-openjdk-headless)        extra
  mupdf-tools                  1.23.3-4                                                      extra
  libmupdf                     1.23.3-4             (Orphan Of: mupdf-tools)                 extra
  gumbo-parser                 0.12.1-1             (Orphan Of: mupdf-tools)                 extra
  gtest                        1.14.0-1                                                      extra
  unzip                        6.0-19                                                        extra
  lib32-gstreamer              1.22.6-1                                                      multilib
  pyside2-tools                5.15.10-2                                                     extra
  python-pivy                  0.6.8-2                                                       extra
  soqt                         1.6.0-4              (Orphan Of: python-pivy)                 extra
  coin                         4.0.0.04c190-4       (Orphan Of: python-pivy)                 extra
  qt5-webkit                   5.212.0alpha4-16
  alsa-card-profiles           1:0.3.80-1                                                    extra
  js52                         52.9.0-4
  deepin-qt5platform-plugins   5.6.16-2                                                      extra
  dwayland                     5.25.0-1             (Orphan Of: deepin-qt5platform-plugins)  extra
  python-distlib               0.3.7-1                                                       extra
  gnome-desktop                1:44.0-1                                                      extra
  libopenaptx                  0.2.0-1
  mbedtls                      3.4.1-1                                                       extra
  python-gitpython             3.1.40-1                                                      extra
  python-gitdb                 1:4.0.11-1           (Orphan Of: python-gitpython)            extra
  python-smmap                 1:5.0.1-1            (Orphan Of: python-gitpython)            extra
  python-beaker                1.12.0-3                                                      extra
  libcddb                      1.3.2-7                                                       extra
  lib32-libinstpatch           1.1.6-2                                                       multilib
  pepper-flash                 32.0.0.453-1
  metis                        5.1.0.p10-2
  xcursor-breeze               5.27.6-1                                                      extra
  lib32-sdl2                   2.28.3-1                                                      multilib
  lib32-alsa-oss               1.1.8-4                                                       multilib
  med-openmpi                  4.1.1-4                                                       extra
  deepin-wayland               1.0.0-1
  opencascade                  1:7.6.3-3                                                     extra
  geocode-glib                 3.26.4-3                                                      extra
  geocode-glib-common          3.26.4-3             (Orphan Of: geocode-glib)                extra
  cmake                        3.27.6-1                                                      extra
  rhash                        1.4.3-1              (Orphan Of: cmake)                       extra
  cppdap                       1.58.0-1             (Orphan Of: cmake)                       extra
  gcab                         1.6-1                                                         extra
  asciidoc                     10.2.0-3                                                      extra
  docbook-xsl                  1.79.2-7             (Orphan Of: asciidoc)                    extra
  docbook-xml                  4.5-9                (Orphan Of: asciidoc)                    extra
  xorg-xwininfo                1.1.6-1                                                       extra
  openshadinglanguage          1.12.13.0-3                                                   extra
  openimageio                  2.4.15.0-1           (Orphan Of: openshadinglanguage)         extra
  pybind11                     2.11.1-1             (Orphan Of: openshadinglanguage)         extra
  opencolorio                  2.2.1-13             (Orphan Of: openshadinglanguage)         extra
  yaml-cpp                     0.8.0-1              (Orphan Of: openshadinglanguage)         extra
  minizip-ng                   4.0.1-1              (Orphan Of: openshadinglanguage)         extra
  tinyxml                      2.6.2-10             (Orphan Of: openshadinglanguage)         extra
  pystring                     1.1.4-1              (Orphan Of: openshadinglanguage)         extra
  clang15                      15.0.7-2             (Orphan Of: openshadinglanguage)         extra
  compiler-rt15                15.0.7-1             (Orphan Of: openshadinglanguage)         extra
  llvm15-libs                  15.0.7-1             (Orphan Of: openshadinglanguage)         extra
  lib32-libnsl                 2.0.0-2                                                       multilib
  gendesk                      1.0.9-3                                                       extra
  re2                          1:20230901-2                                                  extra
  libgit2                      1:1.7.1-1                                                     extra
  http-parser                  2.9.4-1              (Orphan Of: libgit2)                     extra
  libsidplay                   1.36.59-10
  python-protobuf              24.3-1                                                        extra
  python-progress              1.6-5
  cython                       3.0.2-1                                                       extra
  python-importlib-metadata    5.0.0-5                                                       extra
  python-zipp                  3.16.2-1             (Orphan Of: python-importlib-metadata)   extra
  lib32-attr                   2.5.1-1                                                       multilib
  ant                          1.10.14-1                                                     extra
  jdk8-openjdk                 8.382.u05-1          (Orphan Of: ant)                         extra
  java-environment-common      3-5                  (Orphan Of: ant)                         extra
  lib32-lz4                    1.9.4-1                                                       multilib
  python-sip4                  4.19.25-1
  crypto++                     8.8.0-1                                                       extra
  libindicator-gtk3            12.10.1-10                                                    extra
  lib32-readline               8.2.001-2                                                     multilib
  sof-firmware                 2.2.6-1                                                       extra
  python-asn1crypto            1.5.1-2                                                       extra
  qt-gstreamer                 1.2.0-4
  deepin-qt-dbus-factory       6.0.0-5                                                       extra
  aria2                        1.36.0-1                                                      extra
  python-toml                  0.10.2-9                                                      extra
  appstream-glib               0.8.2-3                                                       extra
  libvisual                    0.4.2-1                                                       extra
  lib32-rest                   0.8.1-4                                                       multilib
  lib32-libsoup                2.74.3-1             (Orphan Of: lib32-rest)                  multilib
  lib32-sqlite                 3.43.1-1             (Orphan Of: lib32-rest)                  multilib
  lib32-glib-networking        1:2.78.0-1           (Orphan Of: lib32-rest)                  multilib
  lib32-libproxy               0.5.3-1              (Orphan Of: lib32-rest)                  multilib
  lib32-duktape                2.7.0-6              (Orphan Of: lib32-rest)                  multilib
  rest                         0.8.1+r4+ge5ee6ef-1  (Orphan Of: lib32-rest)                  extra
  gtkspell3                    3.0.10-2                                                      extra
  lua53                        5.3.6-2                                                       extra
  ncurses5-compat-libs         6.3-1
  opensubdiv                   3.5.0-2                                                       extra
  ptex                         2.4.2-2              (Orphan Of: opensubdiv)                  extra
  python-colorama              0.4.6-2                                                       extra
  lib32-json-glib              1.8.0-1                                                       multilib
  gperf                        3.1-5                                                         extra
  elfutils                     0.189-3                                                       core
  embree                       4.2.0-4                                                       extra
  python-contextlib2           21.6.0-2                                                      extra
  lua52                        5.2.4-6                                                       extra
  js68                         68.12.0-1
  xerces-c                     3.2.4-3                                                       extra
  python-pep517                0.13.0-1
  lib32-openal                 1.23.1-1                                                      multilib
  attica                       5.110.0-1
  gptfdisk                     1.0.9-2                                                       extra
  alembic                      1.8.6-1                                                       extra
  gdl                          3.40.0-1                                                      extra
  python-resolvelib            1.0.1-1                                                       extra
  libspnav                     1.1-1                                                         extra
  python-retrying              1.3.3-16                                                      extra
  deepin-qt5integration        5.6.16-1                                                      extra
  dtkwidget                    5.6.16-1             (Orphan Of: deepin-qt5integration)       extra
  dtkgui                       1:5.6.16-1           (Orphan Of: deepin-qt5integration)       extra
  libqtxdg                     3.11.0-2             (Orphan Of: deepin-qt5integration)       extra
  freeimage                    3.18.0-21            (Orphan Of: deepin-qt5integration)       extra
  jxrlib                       0.2.4-2              (Orphan Of: deepin-qt5integration)       extra
  dtkcore                      1:5.6.16-1           (Orphan Of: deepin-qt5integration)       extra
  uchardet                     0.0.8-2              (Orphan Of: deepin-qt5integration)       extra
  spdlog                       1.12.0-1             (Orphan Of: deepin-qt5integration)       extra
  deepin-desktop-base          2:2023.09.04-1       (Orphan Of: deepin-qt5integration)       extra
  gsettings-qt                 0.2-1                (Orphan Of: deepin-qt5integration)       extra
  lshw                         B.02.19.2-6          (Orphan Of: deepin-qt5integration)       extra
  dtkcommon                    5.6.16-1             (Orphan Of: deepin-qt5integration)       extra
  libibus                      1.5.28-4                                                      extra
  libmagick6                   6.9.11.45-1
  js78                         78.15.0-4
  software-center-web-jak      1.0.3-1
  python-jade-application-kit  3.5.7-7              (Orphan Of: software-center-web-jak)     extra
  python-pyqt5-webengine       5.15.6-2             (Orphan Of: software-center-web-jak)     extra
  python-pyhamcrest            2.0.4-3                                                       extra
  mhwd-nvidia-340xx            340.108-1
  opencollada                  1:1.6.68-3                                                    extra
  ttf-ubuntu-font-family       1:0.83-1                                                      extra
  gstreamer-vaapi              1.22.6-1                                                      extra
  lib32-pcre                   8.45-3                                                        multilib
Total removed size: 1,7 GB
Apply transaction ? [y/N]
