My laptop has an HDMI hard wired to NVIDIA card. I couldn’t get it working on dual mode and thus switched to NVIDIA for both primary and external. However, since last few days, this setup has become extremely slow and laggy. I can’t seem to run even simple tasks. Can someone help with this?
I am running i3wm
nvidia-smi
Wed Sep 28 11:55:28 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 Off | N/A |
| N/A 41C P8 N/A / N/A | 1MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=54e0495f-71f5-4922-a37e-2055e714e5d1 rw quiet apparmor=1
security=apparmor udev.log_priority=3 nvidia_drm.modeset=1
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Acer product: Nitro AN515-52 v: V1.28
serial: <superuser required>
Mobo: CFL model: Freed_CFS v: V1.28 serial: <superuser required>
UEFI: Insyde v: 1.28 date: 08/05/2019
RAM: total: 7.61 GiB used: 3.85 GiB (50.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1850 high: 2200 min/max: 800/2200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 800 7: 2200 8: 2200 9: 2200 10: 800 11: 800 12: 2200
bogomips: 52815
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Acer
Incorporated ALI driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm
built: 2016-20 ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Acer
Incorporated ALI driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm
non-free: 515.xx+ status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0300
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568
driver: X: loaded: modesetting unloaded: intel alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x05d8 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Acer Incorporated
ALI driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: enp6s0f1 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.03 TiB used: 739.56 GiB (70.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS128G39TND-N210A
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1P10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%) used: 73.13 GiB
(62.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 54e0495f-71f5-4922-a37e-2055e714e5d1
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 292 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 5AF8-F547
ID-3: /run/media/naveed/D raw-size: 296.02 GiB size: 296.02 GiB (100.00%)
used: 164.33 GiB (55.5%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: D
uuid: 82D2A4F6D2A4F019
ID-4: /run/media/naveed/E raw-size: 342.52 GiB size: 342.52 GiB (100.00%)
used: 273.44 GiB (79.8%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: E
uuid: 8444F7B644F7A956
ID-5: /run/media/naveed/F raw-size: 192.34 GiB size: 192.34 GiB (100.00%)
used: 192.15 GiB (99.9%) fs: ntfs dev: /dev/sdb7 maj-min: 8:23
label: New Volume uuid: 065C6E8D5C6E7779
ID-6: /run/media/naveed/G raw-size: 100 GiB size: 100 GiB (100.00%)
used: 36.52 GiB (36.5%) fs: ntfs dev: /dev/sdb6 maj-min: 8:22 label: N/A
uuid: C08AED308AED241E
ID-1: /dev/sdb3 maj-min: 8:19 size: 529 MiB fs: ntfs label: N/A
uuid: 96C25E7CC25E6113
ID-2: /dev/sdb4 maj-min: 8:20 size: 100 MiB fs: vfat label: N/A
uuid: F2DA-AC74
ID-3: /dev/sdb5 maj-min: 8:21 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
Device-2: 1-5:3 info: Quanta HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:a060
Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.0 C pch: 50.0 C mobo: N/A
Processes: 301 Uptime: 1h 5m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1425 pm: pacman pkgs: 1419 libs: 369 tools: pamac,yay pm: snap
pkgs: 6 Shell: Bash v: 5.1.16 running-in: kitty inxi: 3.3.21
mhwd --list
> 0000:01:00.0 (0300:10de:1c8c) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.26 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
> 0000:06:00.1 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
mhwd --listinstalled
> Installed PCI configs:
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
