I know, and it’s OK. If you don’t want to continue, that’s fine. But you can’t expect someone to automagically know you have an old, EOL and thus unsupported kernel still installed. Especially when your info shows kernel 5.19:
I understand that you are trying to help, but it really hasn’t moved one bit towards solution. Till now i have deleted the drivers, deleted conky and it’s dependencies, and also stuck in tty. Now i am typing this from my phone
Now i tried switching kernels even then i am getting same errors. Previously my kernel was 519. Now i switched to 515, still getting not found linux513-nvidia.
How can i now get the xserver started and install the drivers? Nvidia-smi is working and outputs driver Version 515.65
As I said, if you’ve got a relatively new USB thumb drive available, you can chroot, from where you can more easily work.
Provide the output of:
ls /boot
Please. And doing it from a chroot environment would make it that much easier.
To enter a chroot environment
Ensure you’ve got a preferably relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/dd the ISO to a USB thumb drive.
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the chroot environment:
manjaro-chroot -a
If you have more than one Linux installation, select the correct one to use from the list provided.
If sucessfully done, you should now be in the chroot environment.
But, be careful, as you’re now in an actualroot environment oon your computer, so any changes you make will persist after a restart and can cause damage.
Hmmm…OK, honestly? I’m becoming s little lost here. The only other thing I can think of is that maybe xorg-server didn’t do anything because it wasn’t really uninstalled. In which case, this command might be better:
pamac reinstall --overwrite='*' xorg-server
If this doesn’t work, I’ll have to call in reinforcements.
Did this, doesn’t work.
No problem, i have already texted one guy who i think can help. Waiting for his reply.
I also have a dual boot system, will have to use windows for now
