Steam games won't launch
I was doing something with nvidia, but when i installed optimus manager steam games does not appear to launch, uninstalling doesn’t work, neither does answers to related questions. Although steam marks it as running
When run through terminal i get this
GameAction [AppID 322170, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
wine: Unhandled page fault on execute access to 00007F2785BFD430 at address 00007F2785BFD430 (thread 00cc), starting debugger...
GameAction [AppID 322170, ActionID 1] : LaunchApp changed task to SynchronizingControllerConfig with ""
GameAction [AppID 322170, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 322170, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 322170, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 322170, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/samc/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=322170 -- /home/samc/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/home/samc/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/samc/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/samc/.local/share/Steam/steamapps/common/Geometry Dash/GeometryDash.exe'\0
Game process added : AppID 322170 "/home/samc/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=322170 -- /home/samc/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/home/samc/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/samc/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/samc/.local/share/Steam/steamapps/common/Geometry Dash/GeometryDash.exe'", ProcID 4880, IP 0.0.0.0:0
chdir /home/samc/.local/share/Steam/steamapps/common/Geometry Dash
ERROR: ld.so: object '/home/samc/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/samc/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
GameAction [AppID 322170, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
pid 4884 != 4881, skipping destruction (fork without exec?)
GameAction [AppID 322170, ActionID 1] : LaunchApp changed task to Completed with ""
Installing breakpad exception handler for appid(steam)/version(1669935987)
ThreadGetProcessExitCode: no such process 5003
ThreadGetProcessExitCode: no such process 5001
ThreadGetProcessExitCode: no such process 5000
ThreadGetProcessExitCode: no such process 4999
ThreadGetProcessExitCode: no such process 4882
ThreadGetProcessExitCode: no such process 5006
Game process updated : AppID 322170 "/home/samc/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=322170 -- /home/samc/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/home/samc/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/samc/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/samc/.local/share/Steam/steamapps/common/Geometry Dash/GeometryDash.exe'", ProcID 5002, IP 0.0.0.0:0
Setting breakpad minidump AppID = 322170
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561199219655198 [API loaded no]
wine: Unhandled page fault on execute access to 00007F9877612430 at address 00007F9877612430 (thread 00cc), starting debugger...
wine: Unhandled page fault on execute access to 00007F167111A380 at address 00007F167111A380 (thread 00d4), starting debugger...
Game process updated : AppID 322170 "/home/samc/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=322170 -- /home/samc/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/home/samc/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/samc/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/samc/.local/share/Steam/steamapps/common/Geometry Dash/GeometryDash.exe'", ProcID 5059, IP 0.0.0.0:0
wine: Unhandled stack overflow at address 01446157 (thread 00f4), starting debugger...
I hope someone can help me with this. If you need more info i will be happy to give it. :grinning:
OS: Manjaro Unstable
edit: should clarify pc is asus tuf laptop
Welcome to the forum! :wave:
Such as…?
Why?
Please do. Please post your system info as outlined here:
Right, sorry for asking badly,
my cpu is AMD ryzen 7
gpu: integrated Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
dedicated: GeForce GTX 1650 Mobile
the thing i was doing was trying to make steam games use my nvidia gpu and someone on a forum post said to install optimus manager, looking back im not sure if i was using the nvidia or not with steam, but now i cant launch steam games.
You did not provide the information I asked, please try again. You didn’t even click the link above let alone read it.
Please help us help you.
I did read it, I am unsure what you mean i have not sufficiently answered, May you clarify what it is i did not make clear.
Right from the link I posted:
Oh sorry, I was unsure of the meaning of system info,
drivers:
           video-linux            2018.05.04                true            PCI
video-hybrid-amd-nvidia-prime            2021.11.04               false            PCI
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1f91) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-470xx-prime            2021.11.04               false            PCI
          video-nvidia            2021.11.04               false            PCI
    video-nvidia-470xx            2021.11.04               false            PCI
> 0000:05:00.0 (0300:1002:15d8) Display controller ATI Technologies Inc:
i think drivers is relevent info for this problem.
Please also post the output of this command as outlined:
Sorry, here is the output from that command
  Kernel: 6.0.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
    root=UUID=b5089fca-1558-4628-b8ce-be93a4357c01 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
  ID-1: BAT0 charge: 36.3 Wh (95.0%) condition: 38.2/48.1 Wh (79.4%)
    volts: 11.8 min: 11.7 model: FX50442 type: Li-ion serial: N/A
    status: not charging
  RAM: total: 7.2 GiB used: 5.79 GiB (80.4%)
  Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
    built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
    stepping: 1 microcode: 0x8108102
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1923 high: 2945 min/max: 1400/2300 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1178 2: 1400
    3: 2945 4: 2945 5: 2944 6: 1400 7: 1178 8: 1400 bogomips: 36744
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Turing code: TUxxx process: TSMC 12nm
    built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
  Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
    temp: 61.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Najing CEC Panda 0x0036 built: 2018 res: 1920x1080
    hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon Vega 10 Graphics
    (raven LLVM 14.0.6 DRM 3.48 6.0.11-1-MANJARO) direct render: Yes
  Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Sound API: ALSA v: k6.0.11-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-3: PipeWire v: 0.3.61 running: yes
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
    chip-ID: 10ec:c822 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-4:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
  Local Storage: total: 596.18 GiB used: 81.01 GiB (13.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK
    lanes: 4 type: SSD serial: <filter> rev: P1MA0V4 temp: 36.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SX900 size: 119.24 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
    serial: <filter> rev: 2a scheme: GPT
  ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
    used: 81.01 GiB (69.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: b5089fca-1558-4628-b8ce-be93a4357c01
    used: 316 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: F58C-AECD
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
    uuid: AAEA-60E5
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 476.03 GiB fs: ntfs label: OS
    uuid: F4ECEC87ECEC4588
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 650 MiB fs: ntfs label: RECOVERY
    uuid: D26E88386E88177F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-4:2 info: IMC Networks Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-2: 3-2:3 info: Logitech Mouse type: Mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 046d:c077
    class-ID: 0301
  Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 60.5 C mobo: N/A gpu: amdgpu temp: 60.0 C
  Fan Speeds (RPM): cpu: 2400
  Processes: 306 Uptime: 4h 23m wakeups: 3 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11
  clang: 14.0.6 Packages: pm: pacman pkgs: 1816 libs: 451 tools: pamac,paru
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.2.0
  running-in: konsole inxi: 3.3.23
I apologize for not giving sufficient information.
Thank you for posting that info. You have the proper video drivers installed. Now back to my original questions…
Speaking of video games, I’m going to play a bit before dinner so I’ll be off the forum until tomorrow. :wave:
Thank you for trying to help me.
I think I provided the requested info in a previous reply
but I will say again
I was trying to get steam games to use my nvidia driver, and multiple forum posts suggested installing optimus manager.
Thank you.
There is one thing only to do to use the Nvidia card on an hybrid laptop in Manjaro (of course if you have installed Manjaro’s hybrid profile/driver in MHWD), add the startup option prime-run %command% in the launch option in your game properties in Steam, as outlined in the various posts and articles about it everywhere.
https://forum.manjaro.org/search?q=nvidia%20hybrid%20steam
Yes but now I do not care about getting it to run in Nvidia now I just want to launch my games.
Then do the basics
  • Verify your game files through Steam Verify Integrity of Game Files - How To’s - Knowledge Base - Steam Support
  • Delete (or rename for backup) the Proton prefix for this game, located at ~/.local/share/Steam/steamapps/compatdata/{APP_ID}/ where {APP_ID} is the Steam application ID (find it in the store page URL for the game, or in ProtonDB site, or in SteamDB site, and so on…)
  • Select the Proton 7.0 version in Steam Settings globally (not the Experimental, not an external one), and do not force another Proton version in the game Properties → Compatibility tab
  • Make sure you have the system and video drivers up to date
  • Add the proper launch option in the game properties to use Nviia card, so the prefix is initialized with the Nvidia card used, like you eventually want to achieve
  • Reboot (to discard issues which would have been solve by rebooting), and test
Works now, thanks for help.
