[Stable Update] 2026-07-23 - Kernels, Mesa, VirtualBox, Gambas3, COSMIC, Plasma, KDE Frameworks
Hello Manjaro user community, here we have another set of package updates. We are continuing our development of the upcoming release of ‘Bian-May’ which can be expected end of July or beginning of August. Development speed may be a little slower the upcoming weeks. However, still let us know any issues you may found thus far.
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-580xx, or related DKMS packages.
  • Manjaro 26.1 Bian-May - Preview released
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.19.14, the 6.19 series is now EOL (End Of Life). Please install 7.0, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 7.0.14, the 7.0 series is now EOL (End Of Life). Please install 7.1, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux61 6.1.177
  • linux66 6.6.144
  • linux612 6.12.96
  • linux618 6.18.39
  • linux71 7.1.4
  • linux72 7.2.0-rc4
  • linux61-rt 6.1.167_rt62
  • linux66-rt 6.6.135_rt74
  • linux612-rt 6.12.89_rt18
Package Changes (7/22/26 05:45 CEST)
  • stable core x86_64: 71 new and 71 removed package(s)
  • stable extra x86_64: 1982 new and 2071 removed package(s)
  • stable multilib x86_64: 32 new and 32 removed package(s)
A list of all package changes can be found here.
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Known issues and solutions
:warning: Prepare the update beforehand
Preparation steps
From [INFO] Stable branch - BIG update BEST practice
If it has been a long time since your last update, you may want to refresh your pacman-keyring before running the actual update.
  1. Create a list of custom packages for later reference
    pamac list --foreign > ~/alien-pkgs.txt
  2. Remove all foreign packages
    pamac remove $(pamac list --foreign --quiet)
  3. Remove all orphans and other unneeded packages
    pamac remove --orphans --unneeded
  4. Optional: ensure the keyrings are up-to-date
    sudo pacman -Syy manjaro-keyring archlinux-keyring
  5. Optional: Run a simulated update
    pamac update --dry-run
  6. Looking good? Repeat the above without --dry-run
    reboot
  7. Consult the list of packages created in the first step and rebuild only those you really need
Important Note: Users of Plasma and GNOME may lose their X11 session support. Checkout our guides below before restarting your systems!
Important Note: Users of Pascal, Maxwell, or older cards will fail to load the NVIDIA driver when they were using 580xx series earlier, because the 590xx doesn’t support the older hardware anymore. Only Turing series and newer are still supported.
:arrow_right: 2026-07-23
Plasma Users - updating spectacle will pull tesseract
If you are using Plasma - spectacle has new dependency on tesseract for OCR extraction of text in your screenshot.
The long choice list is languages supported by tesseract - so look more closely you will find e.g. 25 - tesseract-data-deu for German.
The part you will be looking for is the last three (3) characters of the package name.
Removing spectale
If you don’t want or need OCR capabilities, remove spectacle prior to updating your system.
sudo pacman -Rns spectacle
GitHub - tesseract-ocr/tesseract: Tesseract Open Source OCR Engine (main repository) · GitHub
About
This package contains an OCR engine - libtesseract and a command line program - tesseract.
Tesseract 4 adds a new neural net (LSTM) based OCR engine which is focused on line recognition, but also still supports the legacy Tesseract OCR engine of Tesseract 3 which works by recognizing character patterns. Compatibility with Tesseract 3 is enabled by using the Legacy OCR Engine mode (–oem 0). It also needs traineddata files which support the legacy engine, for example those from the tessdata repository.
Brief history
Tesseract was originally developed at Hewlett-Packard Laboratories Bristol UK and at Hewlett-Packard Co, Greeley Colorado USA between 1985 and 1994, with some more changes made in 1996 to port to Windows, and some C++izing in 1998. In 2005 Tesseract was open sourced by HP. From 2006 until August 2017 it was developed by Google.
Major version 5 is the current stable version and started with release 5.0.0 on November 30, 2021. Newer minor versions and bugfix versions are available from GitHub.
ASUS users - update stuck on asusctl
If update is stuck on something like
[2026-07-23T17:39:39+0200] [ALPM] upgraded asusctl (6.3.8-1 -> 6.3.9-1)
[2026-07-23T17:39:39+0200] [ALPM-SCRIPTLET] ^[[0;34m
[2026-07-23T17:39:39+0200] [ALPM-SCRIPTLET] /tmp/alpm_Jlmhss/.INSTALL: line 30: printf: ->: invalid option
[2026-07-23T17:39:39+0200] [ALPM-SCRIPTLET] printf: usage: printf [-v var] format [arguments]
[2026-07-23T17:39:39+0200] [ALPM-SCRIPTLET] ^[[0m
[2026-07-23T17:39:39+0200] [ALPM-SCRIPTLET] Warning: The unit file, source configuration file or drop-ins of asusd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
open another tty or terminal and run sudo systemctl daemon-reload
Virtualbox-ext-vnc
virtualbox-ext-vnc >= 7.2.12-2 requires manual intervention
2026-07-21 - Christian Hesse
Previously, we installed its contents in a way that made pacman not aware of the files (using VBoxManage extpack install … from an install script). To mitigate issues during upgrade, you can use one of the following methods:
  • Uninstall virtualbox-ext-vnc before upgrading the system, then installing it again.
  • Run VBoxManage extpack uninstall 'VNC' as root before upgrading the system.
  • Instruct pacman once to overwrite the existing files:
    sudo pacman -Syu --overwrite '/usr/lib/virtualbox/ExtensionPacks/VNC/*'
2026-07-11
keyboard layout in the terminal changed from de/fr/fi/etc.... back to us
Possible Manual Intervention Required After xkeyboard-config 2.48-1 Update - Important notifications - EndeavourOS
Update failed because conflicting files in /usr/lib/python3.14/site-packages/lightdm_gtk_greeter_settings
There was a little problem with
error: failed to commit transaction (conflicting files)
lightdm-gtk-greeter-settings: /usr/lib/python3.14/site-packages/lightdm_gtk_greeter_settings/__pycache__/installation_config.cpython-314.pyc exists in filesystem
I think this is some packaging mistake upstream. But since this only affects the pycache, the folder /usr/lib/python3.14/site-packages/lightdm_gtk_greeter_settings/__pycache__/ can be deleted (i backed it up) before the update. Alternately one has to update with
sudo pacman -Syu --overwrite="/usr/lib/python3.14/site-packages/lightdm_gtk_greeter_settings/__pycache__/*"
2026-05-27
Attention users with encryption - read before updating!
Several months ago upstream switched the mkinitcpio hooks from udev to systemd. There was a pacnew file which in theory everybody has seen and merged (right? Shame on you, yes you, who forgot :sweat_smile:). Until now it was kind of optional, because the udev hooks will not stop working overnight. Well, with this update it seems the new systemd hooks are forced upon at least on some users without them noticing. It should’t happen but in some cases it looks like it happened. The result is a system that throws a cryptic error about device not found on boot and nonbooting.
You either have to restore the udev hooks, or adapt the kernel boot line for the systemd.
The easiest is to not reboot after update (otherwise you will have to chroot). Check the hooks and cmdline:
grep HOOKS /etc/mkinitcpio.conf
cat /proc/cmdline
The right combination is either similar to the old one with udev
HOOKS=(base UDEV autodetect microcode kms modconf block keyboard keymap consolefont plymouth encrypt filesystems)
AND the following syntax on the boot line
cryptdevice=UUID=device
OR
the new systemd hooks, similar to
HOOKS=(SYSTEMD autodetect microcode modconf kms keyboard sd-vconsole block sd-encrypt filesystems fsck)
AND
rd.luks.uuid=XXXXXXXX-XXXX-XXXX
ANY MIX BETWEEN THE TWO WILL NOT BOOT!
The currently reported situation is usually systemd hook + cryptdevice= boot line.
If that happend, you have to change either one of those two places. Preferably go to systemd and rd.luks.uuid. The boot line is changed in /etc/default/grub
After that you need to sudo mkinitcpio -P and
sudo update-grub
Now you can reboot.
Some reading (pretty much obligatory)
mkinitcpio - ArchWiki
dm-crypt/System configuration - ArchWiki
Note: the hooks above are an example! Do not blindly replace your hooks with the examples above. Also, the capitalization of some hooks is to put a focus here, in reality all hooks are with small letters.
Mesa problems on some Intel GPUs (lines on screen, fuzzy fonts)
Intel ix-2xxx CPUs (Core i 2nd Generation aka Sandy Bridge, from 2011 and all earlier CPUs)
Either wait with the update, or downgrade mesa.
For some chome browsers a workaround can be to disable the hardware acceleration.
Alternative workarounds: manually upgrade to the patched version from unstable branch
sudo pacman -U https://mirrors2.manjaro.org/unstable/extra/x86_64/mesa-1:26.1.2-1-x86_64.pkg.tar.zst
Or install (replace) mesa with mesa-amber for those old gpus. Note that this is the only workaround which doesn’t put you in an unsupported state!
2026-05-19
Yet another vulnerability - local privilege escalation
TLDR: And yet another one
Until patches arrive (should be soon), a mitigation:
sudo sh -c "printf 'kernel.yama.ptrace_scope=2' > /etc/sysctl.d/10-ptrace.conf"
More vulnerabilities - Pintheft, Dirtydecrypt
More vulnerabilities were discovered. Until patches hit your mirror and update, the mitigation is as always to block the modules:
rmmod rds_tcp rds
sudo su -
printf 'install rds /bin/false\ninstall rds_tcp /bin/false\n' > /etc/modprobe.d/pintheft.conf
exit
Note that a good Samaritan created a script, proactively blocking all modules not currently loaded from automatic loading. Which mitigates all current and future vulnerabilities connected with modules. If you are interested - here is the script:
GitHub - jnuyens/modulejail: Proactively shrink a Linux host's kernel-module attack surface by blacklisting every module not currently in use. · GitHub
Please read the description and way of function carefully. If you decide to use that script, check if you have any of the vulnerable modules loaded first:
lsmod | grep -E "esp4|esp6|rxrpc|rds|rds_tcp|algif_aead"
If it returns nothing, you are all good, you can run modulejail with profile desktop.
You do not need to remove other blocking .conf files if you already installed something (unless you want the logging feature).
You might also be interested in the following tutorial which should proactively help:
[HowTo] modulejail
Kernels 5x removed - change kernel before updating!
Although kernel series 5x are still maintained upstream, they are pretty old. To simplify maintenance, Manjaro drops support for those kernels. Note that this change is still not updated in the graphical Manjaro-settings-manager (but mhwd-kernel shows the correct list). Please, if you are still running a 5x kernel, install a newer LTS one first, preferably the latest 6.18 before attempting to update. Then reboot and after that you can update. If linux-latest is blocking the update, remove it too.
2026-05-08
NTFS partitions or usb drives cannot be mounted anymore after update
The explanation:
Concerning NTFS3 and NTFS-3G - #15 by Ben
Note that forcing the system to use the old ntfs-3g driver to mount the drive/partition, although the dirty bit is set, means you will be mounting a potentially damaged filesystem. It is your decision and the responsibility for potential data loss is yours.
The only recommended solution is to check the filesystem from windows. If you don’t have windows anymore, you can get one designed for such repairs free and legal here:
https://www.hirensbootcd.org/
DIRTY FRAG VULNERABILITY (also read if scared from Fragnesia)
[ALERT] Dirty Frag (CVE-2026-43284, CVE-2026-43500) - Root Privilege Vulnerability
Note that the newly discovered vulnerability Fragnesia is still not patched, it is however in the same modules as Dirty frag and the described mitigation works for it too. Just apply the mitigation and you will be ok.
refind - booting problem
The currently shipped version of refind breaks booting on both ext4 and btrfs. Upstream cooks a fix, but until it comes there are several workarounds:
  • Downgrade refind before rebooting or from chroot with manjaro-downgrade
  • Make a backup of the refind_x64.efi file on the ESP partition and restore it after the update before rebooting or from chroot
  • Search for the hook that updates the .efi on package update and remove it
  • Remove the package refind before updating the system which will also remove the hook, but will leave the efi file on the ESP (not tested)
In any case be sure to have live usb at hand.
P.S. refind is alternative boot loader. It is not part of the default installation. If you don’t know what it is (you didn’t install it yourself) - you don’t have it and this doesn’t concern you.
2026-05-02
Issues with updating Kernels due to Nvidia drivers
We know that some of our users still use either 570xx or 575xx drivers from Nvidia. Both of these drivers are unsupported since several months: Current graphics driver releases - Linux - NVIDIA Developer Forums
The current legacy driver 580xx is still supporting older graphic cards by Nvidia, as in Maxwell, Pascal, and Volta GPUs. 470xx is unsupported by Nvidia, however the community is still patching that driver for newer kernels so GKxxx “Kepler” GPUs still work. Same goes for the 390xx driver series, which has the support of GF1xx “Fermi” GPUs.
With linux619+ there is no support for 570xx and 575xx. Our kernel-team had no time to look into this issue further, as backporting patches takes a lot of effort. Since we dropped driver support for these series in recent mhwd-db updates, you may still want to stay on linux618 kernel series, if you still need those drivers. To check if newer drivers support your hardware, please use 26.1x install medias and choose proprietary drivers on boot selection. No changes are performed on your installed system. It is a save environment to test new drivers before changing stuff on your OS.
It would be good to remove installed drivers by mhwd before using it to reinstall supported drivers for your system: Configure Graphics Cards - Manjaro
Also look for known issues within drivers at the Nvidia developer forum:
2026-05-01
COPY FAIL VULNERABILITY
On 29 April 2026, a high local privilege escalation vulnerability in the Linux kernel, tracked as CVE-2026-31431 and named “Copy Fail”, was publicly disclosed. The vulnerability affects Manjaro Linux since 2017. A public proof-of-concept exploit has been released.
We have patched most of our kernels and released them to our testing and unstable branches:
  • patched kernels are: 5.10.254+, 5.15.204+, 6.1.170+, 6.6.137+, 6.12.85+, 6.18.22+, 6.19.12+, 7.0-rc7+
  • affected kernels are: 6.1.167_rt62, 6.6.133_rt73, 6.12.79_rt17, 6.17.5_rt7 and lower
Temporary Mitigation for non-patched kernels/systems
Disable the algif_aead kernel module persistently on all affected systems until a patched kernel is available:
echo "install algif_aead /bin/false" > /etc/modprobe.d/disable-algif.conf
    rmmod algif_aead 2>/dev/null || true
More Information: CERT-EU - High Vulnerability in the Linux Kernel ("Copy Fail")
2026-03-23
pamac-manager gui (Add/Remove Programs) does not start or starts very slow
For now, disable flatpak support (you can just browse flathub.org and install and update from terminal)
sudo nano /etc/pamac.conf
scroll to the end and put # before EnableFlatpak
press ctrl+q , y to save and exit
`plasma-applet-window-buttons` is broken
The plasma-applet-window-buttons package included in this update is version 0.14.0-3, which looks for /usr/lib/libPlasma.so.7, but this library does not exist — the version of the library included in this Stable Update is /usr/lib/libPlasma.so.6.5.6.
The solution is to downgrade plasma-applet-window-buttons to version 0.14.0-2. You do this by way of manjaro-downgrade. :backhand_index_pointing_down:
sudo manjaro-downgrade plasma-applet-window-buttons
Update: In the meantime, the faulty package has been replaced in the repository by the working one already, but if you had updated your system and you have version 0.14.0-3 while you did not downgrade the package yet, run… :backhand_index_pointing_down:
sudo pacman -Syuu
… just once. It will downgrade the faulty package back to the working one.
2026-02-23
Possible signature validity issues with packages taken over from Arch
Do this before updating!
Edited by @linux-aarhus 2026-02-26T06:35:00Z
Before you jump to the big :hammer_and_wrench: and wipe the pacman gnupg folder
sudo pacman -Syy archlinux-keyring manjaro-keyring
Optionally
sudo pacman-key --populate archlinux manjaro
Original suggestion
The problem… :backhand_index_pointing_down:
https://www.reddit.com/r/archlinux/comments/1rafluf/pacman_and_keyring_issues/
The solution… :backhand_index_pointing_down:
 sudo rm -rf /etc/pacman.d/gnupg
 sudo pacman-key --init && sudo pacman-key --populate archlinux manjaro && sudo pacman -Syu
Unreliability of the `pamac` package manager
Rationale
There recently appears to be a high incidence of pamac crashing in the middle of a system update, be it only in the form of the pamac-manager crashing with the update process continuing in the background, or in the form of a complete crash of the pamac infrastructure, leading to a non-bootable system.
Advice
Until the Manjaro Team has managed to correct this issue, we would advise our users…
  • to either (install and) use octopi — see the screenshot below :backhand_index_pointing_down: — as a graphical package manager
  • …or to use the tried-and-trusted pacman from the command line for updating the repository packages, and to use the pamac command-line utility and flatpak command-line utility afterwards for updating the AUR packages and the FlatPaks, respectively, as follows… :backhand_index_pointing_down:
    sudo pacman-mirrors -f && sudo pacman -Syu && pamac update --aur --devel && flatpak update
Stable Updates
ISOs including this update: Bian-May 26.1.0-rc3 (2026-07-23)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.pkgs
Just ran this update and it broke part-way through.
It also weirdly enough wanted to install some stuff I never used before like tesseract and tessdata?!?
After a reboot the Kernel image was broken.
Luckily, timeshift restore worked.
This never happened in 3+ years Manjaro. Anyone know how to procees and cleanly update from here?
When you are using Plasma - spectacle has now dependency on tesseract for OCR.
As for the crash mid-flight - I have heard of it - but I have never experienced this myself…
Why does this happen - I don’t know
Just tried again and the update just crashes midway-through.
After reboot: no kernel image available.
I’ll try to debug this with CLI next.
UPDATE; CLI went through w/o issues and system was able to boot cleanly. No idea why pamac-manager crashed twice and left the system in a broken state…
I’ll change my vote above.
Thank god I use btrfs for root tho and have timeshift set-up. :stuck_out_tongue:
When pamac-manager crashes, doesn’t the update continue in the background?
resolving dependencies...
:: There are 128 providers available for tessdata:
:: Repository extra
   1) tesseract-data-afr  2) tesseract-data-amh  3) tesseract-data-ara  4) tesseract-data-asm  5) tesseract-data-aze  6) tesseract-data-aze_cyrl
   7) tesseract-data-bel  8) tesseract-data-ben  9) tesseract-data-bod  10) tesseract-data-bos  11) tesseract-data-bre  12) tesseract-data-bul
   13) tesseract-data-cat  14) tesseract-data-ceb  15) tesseract-data-ces  16) tesseract-data-chi_sim  17) tesseract-data-chi_sim_vert
   18) tesseract-data-chi_tra  19) tesseract-data-chi_tra_vert  20) tesseract-data-chr  21) tesseract-data-cos  22) tesseract-data-cym  23) tesseract-data-dan
   24) tesseract-data-dan_frak  25) tesseract-data-deu  26) tesseract-data-deu_frak  27) tesseract-data-div  28) tesseract-data-dzo  29) tesseract-data-ell
   30) tesseract-data-eng  31) tesseract-data-enm  32) tesseract-data-epo  33) tesseract-data-equ  34) tesseract-data-est  35) tesseract-data-eus
   36) tesseract-data-fao  37) tesseract-data-fas  38) tesseract-data-fil  39) tesseract-data-fin  40) tesseract-data-fra  41) tesseract-data-frk
   42) tesseract-data-frm  43) tesseract-data-fry  44) tesseract-data-gla  45) tesseract-data-gle  46) tesseract-data-glg  47) tesseract-data-grc
   48) tesseract-data-guj  49) tesseract-data-hat  50) tesseract-data-heb  51) tesseract-data-hin  52) tesseract-data-hrv  53) tesseract-data-hun
   54) tesseract-data-hye  55) tesseract-data-iku  56) tesseract-data-ind  57) tesseract-data-isl  58) tesseract-data-ita  59) tesseract-data-ita_old
   60) tesseract-data-jav  61) tesseract-data-jpn  62) tesseract-data-jpn_vert  63) tesseract-data-kan  64) tesseract-data-kat  65) tesseract-data-kat_old
   66) tesseract-data-kaz  67) tesseract-data-khm  68) tesseract-data-kir  69) tesseract-data-kmr  70) tesseract-data-kor  71) tesseract-data-kor_vert
   72) tesseract-data-lao  73) tesseract-data-lat  74) tesseract-data-lav  75) tesseract-data-lit  76) tesseract-data-ltz  77) tesseract-data-mal
   78) tesseract-data-mar  79) tesseract-data-mkd  80) tesseract-data-mlt  81) tesseract-data-mon  82) tesseract-data-mri  83) tesseract-data-msa
   84) tesseract-data-mya  85) tesseract-data-nep  86) tesseract-data-nld  87) tesseract-data-nor  88) tesseract-data-oci  89) tesseract-data-ori
   90) tesseract-data-pan  91) tesseract-data-pol  92) tesseract-data-por  93) tesseract-data-pus  94) tesseract-data-que  95) tesseract-data-ron
   96) tesseract-data-rus  97) tesseract-data-san  98) tesseract-data-sin  99) tesseract-data-slk  100) tesseract-data-slk_frak  101) tesseract-data-slv
   102) tesseract-data-snd  103) tesseract-data-spa  104) tesseract-data-spa_old  105) tesseract-data-sqi  106) tesseract-data-srp  107) tesseract-data-srp_latn
   108) tesseract-data-sun  109) tesseract-data-swa  110) tesseract-data-swe  111) tesseract-data-syr  112) tesseract-data-tam  113) tesseract-data-tat
   114) tesseract-data-tel  115) tesseract-data-tgk  116) tesseract-data-tgl  117) tesseract-data-tha  118) tesseract-data-tir  119) tesseract-data-ton
   120) tesseract-data-tur  121) tesseract-data-uig  122) tesseract-data-ukr  123) tesseract-data-urd  124) tesseract-data-uzb  125) tesseract-data-uzb_cyrl
   126) tesseract-data-vie  127) tesseract-data-yid  128) tesseract-data-yor
what? why? I mean I don’t have even any tesseract installed… and I don’t want it in the first place. at all.
Please see the comment above
A post was merged into an existing topic: I fear spectacle is turning into spyware with its newly added OCR capability
3 posts were split to a new topic: I fear spectacle is turning into spyware with its newly added OCR capability
I’m having trouble updating libffi :thinking:
warning: cannot resolve "libffi=3.7.1", a dependency of "lib32-libffi"
:: The following package cannot be upgraded due to unresolvable dependencies:
      lib32-libffi
Edit:
Resolved. Probably mirror was not fully synced, thanks @cfinnberg :slight_smile:
The update packages have not been installed due to file conflicts:
File conflicts
error: no se pudo realizar la operación (archivos en conflicto)
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/ExtPack-license.html existe en el sistema de archivos
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/ExtPack-license.rtf existe en el sistema de archivos
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/ExtPack-license.txt existe en el sistema de archivos
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/ExtPack.manifest existe en el sistema de archivos
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/ExtPack.signature existe en el sistema de archivos
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/ExtPack.xml existe en el sistema de archivos
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/linux.amd64/VBoxVNC.so existe en el sistema de archivos
virtualbox-ext-vnc: /usr/lib/virtualbox/ExtensionPacks/VNC/linux.amd64/VBoxVNCMain.so existe en el sistema de archivos
Ocurrieron errores, por lo que no se actualizarán los paquetes
inxi -zv8
Kernel: 6.18.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
root=UUID=37a9efe6-9c59-460d-8a0e-283b7417385d rw quiet splash apparmor=1
security=apparmor resume=UUID=1f9ee171-0982-4156-9dfd-1aa522729784
udev.log_priority=3
Desktop: GNOME v: 50.3 tk: GTK v: 3.24.52 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 50.1 Distro: Manjaro
base: Arch Linux
Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
serial:
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial:
uuid:  Firmware: UEFI vendor: American Megatrends v: F22
date: 06/12/2017
System RAM: total: 16 GiB available: 15.5 GiB used: 3.44 GiB (22.2%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Crucial part-no: CT8G4DFS824A.M8FE
serial:
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
data: 64 total: 64 manufacturer: 0000 part-no: N/A serial: N/A
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt:  cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3478 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 3478 2: 3478 3: 3478 4: 3478 bogomips: 24000
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
disabled
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
Device-1: Intel Kaby Lake-S GT2 [HD Graphics 630] vendor: Gigabyte
ports: active: DP-1,HDMI-A-1 empty: HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:5912 class-ID: 0300
 Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-1 model: HP 22f serial:  built: 2019 res: 1920x1080
dpi: 102 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green: x: 0.322 y: 0.612
blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
size: 476x267mm (18.74x10.51") diag: 546mm (21.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 640x480, 720x400
Monitor-2: HDMI-A-1 model: HP M22f FHD serial:  built: 2024
res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
x: 0.325 y: 0.612 blue: x: 0.153 y: 0.063 white: x: 0.314 y: 0.329
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
drv: iris x11: drv: iris
API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:5912 memory: 15.14 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 26.1.4-arch1.1
device-ID: 8086:5912 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo x11: xprop,xrandr
Device-1: Intel 100/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
API: ALSA v: k6.18.38-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.7 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4:  type: noprefixroute scope: global broadcast:
IP v6:  type: noprefixroute scope: link
WAN IP:
Device-1: TP-Link Bluetooth USB Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 2357:0604
class-ID: e001 serial:
Local Storage: total: 1.47 TiB used: 529.47 GiB (35.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial:  fw-rev: 71E0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD G5 BICS4
tech: SSD serial:  fw-rev: 00WD scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD My Passport 264F size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: N/A serial:  fw-rev: 2007 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LG00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 102.7 GiB size: 100.52 GiB (97.89%)
used: 65.35 GiB (65.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 37a9efe6-9c59-460d-8a0e-283b7417385d
used: 328 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 7D49-8055
ID-3: /run/media raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 164.35 GiB (35.9%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: homeMX
uuid: ec731955-4f0e-4a37-985f-aaf5aa11c41f
ID-4: /run/media/alfredo/MisCosillas2 raw-size: 931.48 GiB
size: 915.78 GiB (98.32%) used: 299.78 GiB (32.7%) fs: ext4 dev: /dev/sdc1
maj-min: 8:33 label: MisCosillas
uuid: 78ad0896-6469-4736-82cc-6de23cf9bbef
ID-1: swap-1 type: partition size: 8.8 GiB used: 52 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 1f9ee171-0982-4156-9dfd-1aa522729784
Device-1: 1-2:6 info: Western Digital My Passport 264F type: mass storage
driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 1058:264f class-ID: 0806 serial:
Device-2: 1-3:2 info: TP-Link Bluetooth USB Adapter type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 2357:0604 class-ID: e001 serial:
Device-3: 1-7:3 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
Device-4: 1-8:4 info: Logitech Keyboard K120 type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
chip-ID: 046d:c31c class-ID: 0300
Hub-2: 1-10:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 37.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1565 pm: pacman pkgs: 1541 libs: 414 tools: gnome-software,pamac
pm: flatpak pkgs: 24
 1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
 2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
 3: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
 4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
 5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
 6: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
 7: https://mirror.fcix.net/manjaro/stable/$repo/$arch
 8: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 260
1: cpu: 11.8% command: firefox pid: 24196 mem: 417.4 MiB (2.6%)
2: cpu: 10.5% command: thunderbird pid: 23713 mem: 688.5 MiB (4.3%)
3: cpu: 10.3% command: firefox pid: 23993 mem: 758.8 MiB (4.7%)
4: cpu: 4.8% command: firefox pid: 24366 mem: 375.1 MiB (2.3%)
5: cpu: 4.1% command: gnome-shell pid: 1986 mem: 288.7 MiB (1.8%)
Memory top: 5 of 260
1: mem: 758.8 MiB (4.7%) command: firefox pid: 23993 cpu: 10.3%
2: mem: 688.5 MiB (4.3%) command: thunderbird pid: 23713 cpu: 10.5%
3: mem: 417.4 MiB (2.6%) command: firefox pid: 24196 cpu: 11.8%
4: mem: 375.1 MiB (2.3%) command: firefox pid: 24366 cpu: 4.8%
5: mem: 288.7 MiB (1.8%) command: gnome-shell pid: 1986 cpu: 4.1%
Processes: 260 Power: uptime: 3h 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.13 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: gcc: 16.1.1 Shell: Zsh v: 5.9.1 running-in: kgx inxi: 3.3.41
Oops :roll_eyes:
I restarted the PC and instead of updating in the terminal I used Pamac and everything was updated without any further problems.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Try again. Probably your mirror was not fully synced.
Good update on one of two machines. I always update ctl+alt+f3 and the terminal. Confronted with “128 providers of tessdata” so rebooted and found that Spectacle uses tessdata. I dont use Spectacle so uninstalled it. then back to the terminal for the update and the 128 providers thing disappeared. FWTW. Thanks devs for the update.
Always happy to see a new update in Manjaro. Especially when there’s a new major KDE plasma version :blush:
Upgrade got stuck on an asus laptop with this text:
Was stuck waiting for minutes until I went to another terminal and did sudo systemctl daemon-reload
Same here, removing package virtualbox-ext-vnc allows the update to be processed without issues, removed package can be reinstalled afterwards.
Ayup.
Ah, it got stuck on printf so it never ran systemctl restart asusd.service. It will be fixed with asusctl 6.3.9-2 later on.
