[ALERT] Dirty Frag (CVE-2026-43284, CVE-2026-43500) - Root Privilege Vulnerability
A week after Copy Fail, researcher Hyunwoo Kim disclosed a second Linux kernel flaw in the same broad area — IPsec ESP and rxrpc — that they have named Dirty Frag. The bug lives in the in-place decryption fast paths of esp4, esp6, and rxrpc: when a socket buffer carries paged fragments that are not privately owned by the kernel (e.g. pipe pages attached via splice(2)/sendfile(2)/MSG_SPLICE_PAGES), the receive path decrypts directly over those externally-backed pages, exposing or corrupting plaintext that an unprivileged process still holds a reference to.
Like the previous Copy Fail vulnerability, Dirty Frag immediately yields root on all major distributions. Every supported Manjaro release is affected. Dirty Frag chains two distinct kernel bugs, each with its own CVE: CVE-2026-43284 covers the IPsec ESP half (esp4 / esp6), and CVE-2026-43500 (NVD entry pending) covers the rxrpc half. Per Hyunwoo Kim’s public disclosure on oss-security (2026-05-07), the responsible-disclosure embargo was broken before distributions could coordinate, and a working exploit is publicly available. A second public exploit, Copy Fail 2: Electric Boogaloo, targets the same vulnerability under a different name; both reach root through the same esp4/esp6/rxrpc code paths and are blocked by the same fix.
More information about the vulnerability:
Temporary mitigation
You can neutralize the attack surface by blacklisting the affected modules. None of esp4, esp6, or rxrpc are loaded on a typical workload that does not use IPsec transport mode or AFS, so on most systems this is safe to apply immediately:
sudo sh -c "printf 'install esp4 /bin/false\ninstall esp6 /bin/false\ninstall rxrpc /bin/false\n' > /etc/modprobe.d/dirtyfrag.conf; rmmod esp4 esp6 rxrpc 2>/dev/null; true"
This writes a modprobe config that prevents the three modules from loading, and unloads them if they happen to be loaded already (the rmmod is best-effort and silent if the module isn’t present). To revert, remove /etc/modprobe.d/dirtyfrag.conf.
The Dirty Frag exploit works by corrupting page-cache pages of sensitive files (such as /etc/passwd or /usr/bin/su). If you suspect the system may have already been targeted before you applied the mitigation, drop the page cache so any tampered pages are evicted and the next read comes fresh from disk:
sudo sh -c 'echo 3 > /proc/sys/vm/drop_caches'
This is safe to run on a live system — it only frees clean cache and dentry/inode entries — and pairs well with the blacklist above.
Upcoming Fixes
We are currently building some kernels with early patches applied:
You may want to switch to unstable branch as soon as they hit our repos or get them directly from our Github pages:
All current kernels are vulnerable to this exploit, unless communicated otherwise!
Update 2026-05-09
Upstream partly patched some kernel series against ESP vulnerability:
Hi,
Thanks a lot for the reactivity.
Is a Manjaro kernel update planned ? I mean a kernel update apply with pacman, pamac.
well, guess … There was already a section for it … @nl.smart
Upstream released 6.6.138, 6.12.87, 6.18.28 and 7.0.5 to fix the first part of the vulnerability in ESP modules … Kernels are currently building on our end on Github CI.
thanks for your fast action @philm ! unfortunally this part of the kernel will cause many more issues in the upcoming days and weeks, so stay alerted. copy-fail was just a first climpse of the problem that was detected via this ai-slop. dirty-frag is a deeper examination that shows up much more intrusion-bugs related to copy-fail but it seems that the whole mechanism isn’t safe.
Buen dia, pregunta, es necesario escribir la sentencia que fue enviada para mitigar el efecto de Dirty Frag o es solo para servidores, empresas, etc.?
Muchas gracias
  Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
    root=UUID=0fb091fc-3271-483e-818a-5dc21ccbd08d rw quiet apparmor=1
    security=apparmor resume=UUID=e4ab7b14-ec9e-4155-b5eb-28717df67c17
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
    wm: kwin_wayland tools: avail: xscreensaver vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: Latitude 3420 v: N/A
  Mobo: Dell model: 0KMD3M v: A00 serial: <superuser required> part-nu: 0A7B
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.3.1
    date: 04/23/2021
  ID-1: BAT0 charge: 30.9 Wh (89.1%) condition: 34.7/41 Wh (84.7%) volts: 11.34
    min: 11.25 model: SMP DELL MGCM514 type: Li-poly serial: <filter> charging:
    status: discharging type: adaptive
    avail: adaptive,custom,fast,standard,trickle cycles: N/A
  System RAM: total: 12 GiB available: 11.42 GiB used: 2.91 GiB (25.5%)
  Device-1: DIMM 1 type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 0198000080AD part-no: 9905700-053.A00G serial: <filter>
  Device-2: DIMM 2 type: DDR4 detail: synchronous size: 4 GiB
    manufacturer: 01980000802C part-no: KCDT82-MIE serial: <filter>
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBE
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 22118
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
    pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
    sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
    class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0c45:6d1a
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x07e8 built: 2019 res: mode: 1366x768
    hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 11.16 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 6 device: 0 type: integrated-gpu name: Intel
    Iris Xe Graphics (TGL GT2) driver: mesa intel v: 26.0.6-arch1.1
    device-ID: 8086:9a49 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 500 Series Family On-Package High Definition Audio
    vendor: Dell driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active
    tools: pactl,pw-cat,pw-cli
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp44s0 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 1.36 TiB used: 100.22 GiB (7.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0N01 temp: 28.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 01 scheme: GPT
  ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 66.73 GiB (87.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 0fb091fc-3271-483e-818a-5dc21ccbd08d
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
    used: 348 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 1C6D-8153
  ID-3: /home raw-size: 381.48 GiB size: 374.43 GiB (98.15%)
    used: 33.5 GiB (8.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: ae4fdda7-02c7-4b07-847d-0ca5d01636a3
  ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -1
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: e4ab7b14-ec9e-4155-b5eb-28717df67c17
  ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: vfat label: N/A
    uuid: 7616-A725
  ID-2: /dev/sda2 maj-min: 8:2 size: 921.73 GiB fs: ext4 label: endeavouros
    uuid: c5836b3c-5bb7-4d47-8d49-56202845d398
  ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: swap
    uuid: 0a93cecb-4ed9-4925-aff6-72849d60ff7e
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-4:2 info: Logitech Nano Receiver type: mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c52f class-ID: 0300
  Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:6d1a class-ID: 0e02
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: 34.0 C mobo: 30.0 C
  Fan Speeds (rpm): fan-1: 0
  Processes: 269 Power: uptime: 29m states: freeze,mem,disk suspend: s2idle
    image: 4.51 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 260
  Packages: 1716 pm: pacman pkgs: 1683 libs: 466 tools: pamac,yay pm: flatpak
    pkgs: 33 Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: konsole inxi: 3.3.40
English translation:
Good morning, question, is it necessary to write the sentence that was sent to mitigate the effect of
Dirty Frag or is it only for servers, companies, etc.?
Thank you so much
It allows everybody that runs as a user on your system, including programs (!), to become root!
My recommendation is: Yes, apply the Temporary Mitigation to every system that you plan to use until the Kernel Updates are available unless you take the utmost care that nothing potentially exploiting it is coming onto your system!
Good morning, and thank you for writing; ok I will do what you recommend.
Thank you very much again!!!
Thank you, @philm
Yet again amazing response. This is why i love linux. And thanks to all manjaro contributors. Mitigation applied.
Thanks for the update and for the quick work on getting these kernels built! Since this is my first post here, I wanted to say hello and also ask: will there be a follow-up post in this thread once the fixes are available in the repositories?
Well, it is super simple. This issue is complex and even upstream can’t provide a proper fix for this yet. Kernels are complex by nature. And with AI a lot of stuff can be done faster than before. Hence, the issue was so long undetected but present for several years. So if you have a Linux-box and internet enabled and know about this, well you can become root on any machine by opening the console and download the exploit with a one-liner.
Since this is in the public already, I try to cover it from our end as needed. The first post gets updated on a regular basis.
To be save, apply the mitigation. If you want to help: switch to unstable branch and keep updating your system and give feedback.
You can be sure that a lot of kernel updates will follow the upcoming days …
Copy Fail 2: Electric Boogaloo is most likely patched with the already applied ESP patches on most kernels we now ship in our unstable branch.
well running a server with manjaro-unstable sounds stupid but it works !!! thanks @philm . i wish debian would act as fast as you cause i’m lost that debian-support isn’t delivering so quick. credits to manjaro :love_you_gesture:
For what it’s worth, I was speaking with a friend last night who uses LMDE. It seems the kernels are being patched, but maybe not quite as fast as we’re getting used to being the case here. :wink:
Naturally, thanks @philm for these efforts. It is really appreciated.
i’m curious about the different sources on which kernels are already patched, especially about the kernel 6.12… phil’s list point out that only 6.12.87 is patched while debian’s sources declare 6.12.86 (which they are using now) as patched. i have no clue what kernel to use when everyone submits different opinions.
No, none of the 6.12.x are completely patched. The rxrpc half only applies to 6.18.x and 7.0.x and is still under review: oss-security - Re: Dirty Frag: Universal Linux LPE as seen here: Making sure you're not a bot!
thanks, i’ll trust your word. what a mess, weekends should get officially renamed to ‘patch-days’.
These AI discovered exploits are only strengthening Linux Kernel ultimately… I think this will be a temporary phase we go through as white hat security researchers catch up with AI tools.
Hoping no such embargo breakages happen again and are handled like Copy Fail (the first one), which I am sure will be precautions in place to avoid such incidents, I understand it’s hard to avoid because of GPL rules… Surely there will be a way to handle it.
Ultimately this is much better than closed source OS, who knows what kind of backdoors are in place on those systems…
