[HowTo] modulejail
modulejail
This is a Wiki-Post !
  • Please do edit this post instead of suggesting changes !
  • If you need support, please create your own thread, and link to this thread.
Modulejail is a script writing a blocklist, preventing unused kernel modules from automatic loading. Thus a malicious app cannot use a vulnerability in some little used module which significantly reduces the attack surface.
Installing modulejail:
You can install it from AUR - AUR (en) - modulejail . Note that there is also unofficial aur package, ending with -git
pamac build modulejail
Please follow the links for more information about modulejail
Usage (as of v1.6.1)
sudo modulejail -p {none|minimal|conservative|desktop|firewall}
The profile you choose is important:
Profile Modules Kept Available
none Only lsmod + --whitelist-file entries
minimal Core filesystems + essential kernel modules only
conservative Minimal ↑ + common server/VM drivers (default)
desktop Conservative ↑ + WiFi, Bluetooth, audio, video drivers
firewall Conservative ↑ + the whole netfilter toolkit (approx 240 modules)
For desktop users sudo modulejail -p desktop is recommended.
Special instructions for desktop users running a firewall
Desktop users running a firewall should use the following command to add the firewall rules:
sudo modulejail -p desktop --whitelist-file examples/whitelist-firewall.conf
Adding --dry-run to the command simulates the full pipeline but writes nothing under /etc/modprobe.d/. For example:
sudo modulejail -p desktop --dry-run
All modulejail options can be viewed by running the following command:
modulejail --help
Find out which modules are on the blacklist but are actually required
Modulejail may block some modules that you need. However you can see which modules attempted to load but were blocked.
journalctl -t modulejail
How do I get these modules off the blacklist?
You can add specific modules to /etc/modulejail/whitelist.conf and then run modulejail again.
sudo mkdir /etc/modulejail
sudo touch /etc/modulejail/whitelist.conf
Append everything blocked today to the whitelist
last updated 2026-06-12
journalctl -t modulejail | grep -Eo 'blocked: [^ "]+' | grep -Eo '[^ :]+$' | sort | uniq | sudo tee -a /etc/modulejail/whitelist.conf
Note that the above oneliner is “quick and dirty” and only given as an example. Running it several times a day will create duplicates and more importantly adding just everything defeats the purpose of the tool. It is recommended to edit the whitelist manually (for example with sudo nano or sudo micro /etc/modulejail/whitelist.conf and only add what you need, like for example if a needed program doesn’t start. In that case please leave feedback for our database (see below).
example whitelist.conf:
# whitelist for modulejail
# one module per line
# comments starting with #
exfat
acpi_cpufreq
# bad_module
fjes
fmpm
kheaders
kvm_amd
intel_pmc_core_pltdrv
A better solution may be [HowTo] Whitelist blocked modules for modulejail
Note that as of version 1.6.1 from 27.8.2026 there are whitelists for Firewalls, there is also whitelist for people using external encrypted drives.
Then run modulejail to create the blacklist. Restart is not needed.
Realtime notification with popup when a module gets blocked
If you start a program and something does not work, but at the same time you see a notification a modue is blocked, you will know that program needs that module and it has to be whitelisted.
You can add the following to your startup scripts (do not forget to make executable):
#!/usr/bin/env bash
# Monitor the journal for modules, blocked with modulejail and show popup
# optional - initial sleep so that a bunch of blocked modules at boot are not showed
sleep 37
journalctl -f -t modulejail --since "1 sec ago" -o cat | while read -r LINE; do
        notify-send "Modulejail" "$LINE" --icon=dialog-warning
done
To run at startup, you can create a systemd service for example.
Here is a sample systemd service:
make the service as ~/.local/share/systemd/user/modulejailpopup.service
[Unit]
Description=modulejailpopup
Wants=network-online.target graphical-session.target
After=network-online.target graphical-session.target
[Service]
Type=simple
ExecStart=/bin/bash -c "/home/$USER/.local/bin/modulejailpopup.sh"
modulejailpopup.sh is where you saved the notification script and made it executable.
After that:
systemctl --user start modulejailpopup.service
systemctl --user enable modulejailpopup.service
Dependencies
Some modules, just like the packages, are dependent on other modules and try to load them when they themselves load. Automatic dependency resolution will be added in future version of modulejail. For now you either have to use the trial and error method (you whitelist a module and see another popup for another blockage and your program still does not start) OR before adding a module to the whitelist you can proactively check its dependencies and add everything:
modprobe --show-depends MODULE_NAME
Note that this will not work with --verbose-logging switch (you can temporarily disable modulejail while looking for dependencies)
What is the following module necessary for?[1]
acpi_cpufreq
:+1: ACPI-based CPU frequency governor/driver (manages CPU clocks via ACPI P‑states for power management).
Note: acpi_cpufreq has been added to the conservative and desktop profiles from v1.3.2 of modulejail. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
ccm
CCM mode (counter with cipher block chaining message authentication code; counter with CBC-MAC) is a mode of operation for cryptographic block ciphers. It is an authenticated encryption algorithm designed to provide both authentication and confidentiality. CCM mode is only defined for block ciphers with a block length of 128 bits. CCM mode - Wikipedia
This module may be required for authenticating connections to WiFi devices, such as Android cellphone hotspots.
cdrom
ISO 9660 and optical-media support (also see isofs)
Note: cdrom & isofs have been included in the desktop profile of modulejail since v1.3.2. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
dummy
:+1: Network dummy driver: creates virtual, non-physical network interfaces (useful for testing or bridge setups).
exfat
:+1: Driver for the exFAT filesystem (read/write support for exFAT-formatted media like SD cards/USB sticks).
Note: exfat (Windows-formatted flash drives) is included in the desktop profile from v1.3.1 of modulejail. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.1
f2fs
Modern flash-friendly filesystem (partition tools, external drives)
Note: f2fs has been included in the desktop profile of modulejail since v1.3.2. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
fmpm
AMD FMPM (FRU Memory Poisoning / FRU memory poison manager): part of AMD/RAS telemetry and fault-management stack that handles FRU memory-poison records and related RAS features on supported AMD platforms (server-grade/ATL-equipped CPUs); safe to ignore on unsupported/mobile CPUs
hv_sock
Hyper-V socket transport: provides AF_HYPERV or “vsock”-like socket interface for bidirectional communication between host and guests.
hv_vmbus
Hyper-V VMBus core driver: provides the communication channel between Hyper-V host and Linux guest (transport for Hyper-V synthetic devices).
inet_diag
Netlink module for monitoring INET transport protocols sockets. Netlink is used to transfer information between kernel and user-space processes. It consists of a standard sockets-based interface for user space processes and an internal kernel API for kernel modules.
More information: netlink(7) — Arch manual pages
Note: inet_diag, tcp_diag & udp_diag (inet socket diagnostics auto-loaded by ss and most system-monitor tools (KDE, GNOME, btop, glances)) have been added to the conservative and desktop profiles from v1.3.2 of modulejail. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
isofs
ISO 9660 and optical-media support (also see cdrom)
it87
This driver implements support for the IT8603E, IT8620E, IT8623E, IT8628E, IT8689E, IT8705F, IT8712F, IT8716F, IT8718F, IT8720F, IT8721F, IT8726F, IT8728F, IT8732F, IT8758E, IT8771E, IT8772E, IT8781F, IT8782F, IT8783E/F, IT8786E, IT8790E, IT8792E/IT8795E, IT87952E and SiS950 chips.
These chips are ‘Super I/O chips’, supporting floppy disks, infrared ports, joysticks and other miscellaneous stuff. For hardware monitoring, they include an ‘environment controller’ with 3 temperature sensors, 3 fan rotation speed sensors, 8 voltage sensors, associated alarms, and chassis intrusion detection.
More information: Kernel driver it87 — The Linux Kernel documentation
kheaders
:+1: Provides runtime kernel header/signature information needed by out-of-tree builds, BPF, or debugging tools (exposes kernel header data from the running kernel).
kvm_amd
KVM hypervisor support for AMD CPUs (AMD SVM virtualization support for guest VMs).
nbd
network block device, used in virtualization context (needed for mounting .qcow2 images for example)
nft_fib_ipv6
:+1: nftables expression/module for FIB (Forwarding Information Base) lookups for IPv6 (allows routing/next-hop decisions inside nftables rules).
nls_ucs2_utils
This is supposed to provide support for international characters in filenames for some filesystems (according to google and the kernel documentation - fat, jffs, smb - mostly Microsoft stuff but still, if one uses network shares it is relevant)
ntfs3
Read/write NTFS driver (in-tree since Linux 5.15)
Note: ntfs3 has been included in the desktop profile of modulejail since v1.3.2. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
ntsync
Module introduced in kernel 6.14 mimicing windows primitives. Significantly improves performance in windows apps and games run on linux via wine, proton or steam.
phy_package
Support/management code for a hardware “PHY package” (physical layer) used by some devices to handle low-level communication (e.g., network/link PHY features).
realtek
Driver code for Realtek hardware, most commonly network (Ethernet/Wi‑Fi) devices, providing device-specific functionality.
rfcomm
:+1: Bluetooth RFCOMM protocol driver (serial-port emulation over Bluetooth for serial communication).
snd_seq_device
ALSA sequencer device helper: registers/handles sequencer clients for MIDI/event routing between user-space and kernel sequencer drivers
tap
VPN clients (WireGuard, OpenVPN), VirtualBox / VMware, qemu / KVM bridge
Note: tap was added to the desktop profile of modulejail in v1.3.4. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.4
tcp_diag
Please refer to the entry for inet_diag
tls
kernel TLS (kTLS), increasingly load-on-demand for HTTPS-heavy daemons and modern package managers
Note: tls has been added to the conservative and desktop profiles from v1.3.2 of modulejail. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
tun
Note: tun was added to the desktop profile of modulejail in v1.3.4. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.4
udp_diag
yogafan
New module as of kernel 7.1. - Lenovo Yoga/Legion Fan Monitor Driver. However, it tries to load also on Ideapads.
amd
amd64_edac
AMD EDAC Linux driver for Error Detection And Correction of AMD x86_64 CPU/memory errors.
Note: amd64_edac has been included in the desktop profile of modulejail since v1.3.2. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
amd_pstate
CPU Performance Scaling Driver for AMD processors.
Note: amd_pstate was added to the desktop profile of modulejail in v1.3.4. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.4
intel
i7core_edac
Intel EDAC Linux driver for Error Detection And Correction of CPU/memory errors
Note: i7core_edac has been included in the desktop profile of modulejail since v1.3.2. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
ie31200_edac
Note: ie31200_edac has been included in the desktop profile of modulejail since v1.3.2. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.2
intel_cstate
Intel C‑state driver: manages CPU idle states (C‑states) for power management on Intel processors.
Note: intel_cstate was added to the desktop profile of modulejail in v1.3.4. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.4
intel_pstate
Intel P‑state driver: CPU Performance Scaling Driver for Intel processors.
Note: intel_pstate was added to the desktop profile of modulejail in v1.3.4. Ref: https://github.com/jnuyens/modulejail/releases/tag/v1.3.4
intel_telemetry_debugfs
Exposes Intel telemetry/debug data via debugfs for diagnostic/telemetry consumers (used for collecting hardware/system telemetry).
Intel Platform Controller (PMC) core platform driver: handles power-management controller core functions and platform-specific power features on Intel systems.
intel_tcc_cooling
Intel TCC (Thermal Control Circuit) cooling driver: exposes thermal/cooling controls tied to Intel TCC for thermal throttling/cooling integration.
intel_uncore
Intel uncore monitoring/support: handles non-core CPU subsystems (uncore) like memory controllers, ring interconnects, and provides performance/event monitoring interfaces.
vendor-specific:
fujitsu
fjes
FUJITSU Extended Socket (FJES) network device driver: supports Fujitsu Primequest/enterprise platform-specific extended-socket network devices; :face_with_raised_eyebrow: occasionally auto-loads on non-Fujitsu hardware due to generic modalias matches
toshiba
toshiba_wmi
Toshiba WMI hotkeys driver: handles WMI-based hotkey events and exposes input/ACPI interfaces for some Toshiba laptop functions (brightness/hotkeys); experimental and model-specific.
Known programs and devices, requiring specific modules
Please add alphabetically. Users below TL3 that cannot edit the wiki, write a post with your experience and explanation in this open to all topic and some TL3+ will summarize and add it here.
Bluetooth headphones (Pixel Buds, Samsung Buds and similar)
Connecting my pixel buds tried to start those 3 modules. There was sound, so i am unsure how important are those. The name of the modules suggest input device, so maybe they are more important for headsets with buttons and microphone.
uinput
hid_sensor_hub
hid_sensor_custom
Bluetooth mouse / keyboard (reported Logitech, affected probably others too)
uhid
From v1.5.1 of modulejail, released 2026-07-31T23:00:00Z, uhid is included in the desktop profile. Reference: Release modulejail v1.5.1 · jnuyens/modulejail
CD/DVD mounting (already included in desktop profile whitelist)
isofs
cdrom
Filesystem detection and mounting / OS-Prober in update-grub
exfat (already included in desktop profile whitelist)
jfs
msdos
ntfs3 (already included in desktop profile whitelist)
minix
hfs
hfsplus
ufs
Note that on UEFI systems in pure EFI mode OS-Prober does not really need to access anything else than the fat/vfat formatted ESP partition so you do not need to allow any of those modules for this purpose, your update or detecting other OS won’t be blocked in that case.
For the filesystem mounting:
You can probably skip whitelisting HFS± unless you are dual-booting an Apple computer, those are Apple filesystems. And minix is a very very old filesystem and you do not have it, unless you operate a computer with a hard drive bought about 40 years ago.
Firewall
ipt_recent
ip6t_recent
xt_recent
*modulejail v1.6.1 (release notes), released 2026-08-27T15:00:00Z, has a new firewall profile (modulejail -p firewall):
Gaming - Wine, Steam, Proton
They now need kernel 6.14 or newer and the new kernel module ntsync
Lenovo - no fan speed info
yogafan
MMC / SD cards usage (already included in desktop profile whitelist)
mmc_core
mmc_block
rpmb-core
Notes:
As of v1.4.0 (released 2026-06-07T22:00:00Z), mmc_core + mmc_block have been included in the desktop profile of modulejail. Reference: modulejail/CHANGELOG.md at v1.4.0 · jnuyens/modulejail
rpmb_core was added to the desktop profile in v1.4.1 of modulejail, as it was split from mmc_core into its own module after linux612. Due to it being a declared hard dependency for mmc_block, a blacklisted rpmb_core will result in a failure to load a whitelisted mmc_block on recent kernels. Details: Release modulejail v1.4.1 · jnuyens/modulejail · GitHub
Network share problems, non-english characters in filenames not displaying
You might need to whitelist the new as of kernel 7 module for unicode support in the filenames for some filesystems:
nls_ucs2_utils
No network connectivity with wired or wireless Realtek card
realtek
phy_package
NordVPN (wireguard)
tun (already included in desktop profile whitelist)
wireguard
udp_tunnel
libcurve25519
ip6_udp_tunnel
Ventoy (or other large USB sticks)
Virtual machines (QEMU etc.)
tap (already included in desktop profile whitelist)
vhost_iotlb
vhost
vhost_net
Remember to always check the changelog for new features and fixes on a new release of modulejail, since this tutorial cannot cover everything.
Footnotes
1: An AI assisted in gathering some of the descriptions for kernel modules.
  1. Footnotes ↩︎
