Manjaro 26.1 Bian-May - Preview released
Note: This is a preview release of the upcoming Manjaro 26.1 “Bian-May”! We are looking for your feedback on these install medias …
Manjaro 26.1 (Preview)
Since we released Anh-Linh in January 2026 we worked hard to get the next release of Manjaro out there. We call it Bian-May.
The GNOME edition has received several updates to Gnome 50 series. This includes a lot of fixes and polish when Gnome 50 originally was released in March 2026. You can find find release dates of each upcoming point-release here: Release Calendar. Weekly updates around GNOME can be found here.
Highlights of 50 release series are:
GNOME’s parental controls have made a massive leap forward in GNOME 50. For the first time it is now possible for parents and guardians to monitor screen time and set limits for child accounts, including bedtime schedules. The new features allow automatically locking the screen when a screen limit or bedtime is reached. Parents and guardians also have the ability to extend screen time past the limit when needed. We also ship Big Parental Controls 1.0 from our sister-project Big Linux from Brazil, to comply with recent laws there.
GNOME’s built-in remote desktop capabilities have seen significant improvements in version 50. A major performance boost comes from new hardware acceleration support (using Vulkan and VA-API). By using your computer’s graphics processor to stream video, remote sessions are now significantly smoother with much less lag and lower power consumption. Compatibility has also been improved for a wider range of hardware with the integration of explicit sync, which provides a more stable experience for those using NVIDIA drivers.
GNOME’s display technologies have received a massive set of stability and performance updates in GNOME 50.
Improved Variable Refresh Rate (VRR) and Fractional Scaling Support: VRR and fractional scaling have both been improved for GNOME 50, with bug fixes, stability, and user experience improvements. For users with compatible monitors, VRR provides a tear-free experience where the display’s refresh rate matches the application’s frame rate, resulting in significantly smoother motion. Fractional scaling allows what is displayed on screen to be scaled in increments, to better suit a range of display densities. When it is enabled, users can natively select scales like 125% or 150% in the display settings.
Low-Latency Cursor in VRR: The mouse cursor now operates independently of the application’s frame rate while VRR is active. This ensures the cursor remains fluid and responsive at the monitor’s maximum refresh rate (e.g., 144Hz) even if a game or professional app is running at a lower frame rate.
NVIDIA Performance Boosts: Workarounds for NVIDIA driver quirks have been implemented, targeting stuttering and frame-timing issues. The result is noticeably smoother window animations and general desktop fluidity for users with NVIDIA GPUs.
Next-Gen Color Management: Support for version 2 of the Wayland color management protocol has landed. This provides the technical foundation for creative professionals to achieve higher color accuracy across different apps and hardware.
HDR Screen Sharing: Building on GNOME’s modern color pipeline, it’s now possible to screen share monitors displaying High Dynamic range (HDR) content. This allows screen recording software to record the screen content with the same vivid colors as displayed on the physical screen.
The Plasma edition comes with the latest Plasma 6.6 series, Frameworks 6.25 and KDE Gear 26.04. It brings exciting new improvements to your desktop.
Plasma 6.6 includes a number of highly-requested features:
Plasma makes your life as easy as possible, without sacrificing the flexibility or features that have made Plasma the most versatile desktop in the known universe. With that in mind, Plasma’s usability and accessibility got improved, and practical new features were added into the mix.
Those who like tailoring the look and feel of their environment can now turn their current setup into a new global theme! This custom global theme can be used for the day and night theme switching feature.
If you have colorblindness, check out the filters on System Settings’ Accessibility page, under Color Blindness Correction. Plasma 6.6 adds a new grayscale filter, bringing the total to four filters that account for different kinds of colorblindness.
Speaking of accessibility, Spectacle can now recognize and extract text from images it scans. Among other use cases, this makes it easy to write alt texts for visually-impaired users.
With Plasma Setup, the technical steps of operating system installation and disk partitioning can be handled separately from user-facing steps like setting up an account, connecting to a network, and so on.
With our XFCE edition, we have now Xfce 4.20. Here some highlights: A new file highlighting feature (accessed from the file properties dialog) in Thunar file manager lets you set a custom colour background and a custom foreground text colour – an effective way to call attention to specific file(s) in a directory laden with similar-looking mime types. On the subject of finding files, Thunar includes recursive search.
The panel picks up a pair of new preferences. First, panel length is now configured in pixels rather than percentages, as before. Second, there’s a new “keep panel above windows” option. This allows maximised app windows to fill the area behind the panel rather than maximise its bottom or top edge to sit flush against it.
Control Centre groups all of the desktop’s various modules for managing the system into one easy-to-use window. New options are present in many of these. For example you can disable header bars in dialogs from the Appearance module; show or hide a ‘delete’ option in file context menus from Desktop; and pick a default multi-monitor behaviour before you attach an additional screen – dead handy, that.
Kernel 7.0 is used for this release, such as the latest drivers available to date. With 6.18 LTS and 6.12 LTS we offer additional support for older hardware as needed.
We hope you enjoy this release and let us know what you think of Bian-May.
Bian-May 26.1.0-rc4 (2026-08-07)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-260807-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-260807-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-260807-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-260807-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-260807-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-260807-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux618.iso
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux612.iso
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc4/manjaro-xfce-26.1.0-rc4-minimal-260807-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-260807-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-260807-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-260807-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-260807-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-260807-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-260807-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux618.iso
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux612.iso
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc4/manjaro-gnome-26.1.0-rc4-minimal-260807-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-260807-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-260807-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-260807-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-260807-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-260807-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-260807-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux618.iso
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux612.iso
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc4/manjaro-kde-26.1.0-rc4-minimal-260807-linux612.iso.pkgs
Bian-May 26.1.0-rc3 (2026-07-23)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-260723-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc3/manjaro-xfce-26.1.0-rc3-minimal-260723-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-260723-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc3/manjaro-gnome-26.1.0-rc3-minimal-260723-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-260723-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc3/manjaro-kde-26.1.0-rc3-minimal-260723-linux612.iso.pkgs
Bian-May 26.1.0-rc2 (2026-07-22)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-260722-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-260722-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-260722-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-260722-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-260722-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-260722-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux618.iso
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux612.iso
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc2/manjaro-xfce-26.1.0-rc2-minimal-260722-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-260722-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-260722-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-260722-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-260722-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-260722-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-260722-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux618.iso
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux612.iso
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc2/manjaro-gnome-26.1.0-rc2-minimal-260722-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-260722-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-260722-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-260722-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-260722-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-260722-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-260722-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux618.iso
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux612.iso
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc2/manjaro-kde-26.1.0-rc2-minimal-260722-linux612.iso.pkgs
Bian-May 26.1.0-rc1 (2026-07-10)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-260710-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-260710-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-260710-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-260710-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-260710-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-260710-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux71.iso
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux618.iso
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux612.iso
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-rc1/manjaro-xfce-26.1.0-rc1-minimal-260710-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-260710-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-260710-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-260710-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-260710-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-260710-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-260710-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux71.iso
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux618.iso
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux612.iso
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-rc1/manjaro-gnome-26.1.0-rc1-minimal-260710-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-260710-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-260710-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-260710-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-260710-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-260710-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-260710-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux71.iso
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux618.iso
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux612.iso
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-rc1/manjaro-kde-26.1.0-rc1-minimal-260710-linux612.iso.pkgs
Bian-May 26.1.0-pre (2026-06-26)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260626-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260626-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260626-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260626-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260626-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260626-linux70.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux618.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux612.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260626-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260626-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260626-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260626-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260626-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260626-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260626-linux70.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux618.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux612.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260626-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260626-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260626-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260626-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260626-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260626-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260626-linux70.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux618.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux612.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260626-linux612.iso.pkgs
Bian-May 26.1.0-pre (2026-05-27)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260527-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260527-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260527-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260527-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260527-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260527-linux70.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux618.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux612.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260527-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260527-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260527-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260527-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260527-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260527-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260527-linux70.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux618.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux612.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260527-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260527-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260527-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260527-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260527-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260527-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260527-linux70.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux618.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux612.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260527-linux612.iso.pkgs
Bian-May 26.1.0-pre (2026-05-23)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260523-linux70.iso.torrent
Minimal
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260523-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260523-linux70.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260523-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260523-linux70.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260523-linux612.iso.pkgs
Bian-May 26.1.0-pre (2026-05-05)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260505-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260505-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260505-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260505-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260505-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-260505-linux70.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux70.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux70.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux70.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux70.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux70.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux618.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux612.iso
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0-pre/manjaro-xfce-26.1.0-pre-minimal-260505-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260505-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260505-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260505-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260505-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260505-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-260505-linux70.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux70.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux70.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux70.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux70.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux70.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux618.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux612.iso
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0-pre/manjaro-gnome-26.1.0-pre-minimal-260505-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260505-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260505-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260505-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260505-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260505-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-260505-linux70.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux70.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux70.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux70.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux70.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux70.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux70.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux618.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux612.iso
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0-pre/manjaro-kde-26.1.0-pre-minimal-260505-linux612.iso.pkgs
[Testing Update] 2026-05-23 - Blender, Nvidia, Firefox, Thunderbird, Qt5
[Testing Update] 2026-05-11 - Kernels, COSMIC, Firefox, Thunderbird, KDE
[Stable Update] 2026-05-19 - Kernels, Plasma 6, KDE Gear, KDE Frameworks, COSMIC, Vulkan
[Testing Update] 2026-05-16 - Kernels, Firefox, Qt, Pipewire, COSMIC, Vulkan
[Testing Update] 2026-05-18 - Kernels, Heroic Games Launcher, Certbot, Python
[Stable Update] 2026-06-26 - Kernels, Systemd, PipeWire, NVIDIA, KDE, LibreOffice
[Testing Update] 2026-08-20 - Kernels, KDE Framework, Firefox, Thunderbird, Qemu, Mesa, VirtualBox
[Stable Update] 2026-08-23 - Kernels, KDE Framework, Firefox, Thunderbird, Qemu, Mesa, VirtualBox
[Testing Update] 2026-09-07 - Kernels, CardWire, LibreOffice, Firefox
[Testing Update] 2026-08-24 - Kernels, KDE Gear 26.08, Mesa, QT6, Cosmic
[Testing Update] 2026-07-04 - Kernels, Firefox, Thunderbird, KDE Gear, COSMIC, QEmu
Update ISO request, stable iso are above 3month old
Steam error, fails to launch
[Stable Update] 2026-08-12 - Kernels, Firefox, GStreamer, Python, Deepin, Haskell, Bazaar
[Testing Update] 2026-07-09 - Kernels, Firefox, Xorg-Server, XWayland, Bluez, OpenSearch
[Testing Update] 2026-07-17 - Plasma, KDE Framework, COSMIC, Pipewire, Firefox
[Stable Update] 2026-07-11 - Kernels, COSMIC 1.2, Xorg, Firefox, Thunderbird, KDE Gear
Troubleshooting launching xfce/any session on live ISO
[Testing Update] 2026-07-22 - Kernels, Mesa, VirtualBox, Gambas3, Qemu
[Testing Update] 2026-08-10 - Kernels, Firefox, GStreamer, Python, Deepin, Haskell
[Testing Update] 2026-09-01 - Kernels, MSM Qt6, COSMIC, LibreOffice, QEMU
Why isn't the latest official .ISO built with the current updates?
[Testing Update] 2026-05-13 - Plasma, LibreOffice, Gstreamer, ROCm
[Testing Update] 2026-08-04 - Kernels, Mesa, Nvidia, COSMIC, Deepin, Firefox, QEmu, Vulkan
[Testing Update] 2026-08-05 - Plasma 6.7.4, NerdFonts 3.5.0, Firefox, GNOME
[Testing Update] 2026-05-26 - Kernels, Thunderbird, Firefox, Pipewire, Gstreamer
[Stable Update] 2026-08-06 - Kernels, Plasma, Mesa, COSMIC, LibreOffice
[Testing Update] 2026-08-08 - Kernels, Bazzar, Firefox, OpenSearch, SyncThing
[Testing Update] 2026-09-05 - Kernels, Mesa, Firefox, Deepin, Haskell
[Stable Update] 2026-05-27 - Kernels, NVIDIA, Firefox, Thunderbird, Mesa, Blender
[Stable Update] 2026-07-23 - Kernels, Mesa, VirtualBox, Gambas3, COSMIC, Plasma, KDE Frameworks
[Testing Update] 2026-07-27 - Kernels, Systemd, LibreOffice, Firefox, Thunderbird
I3 Manjaro dead?
Error on booting Live USB
[Testing Update] 2026-05-29 - Systemd, COSMIC, NVIDIA, Firefox, Pipewire, VLC
[Testing Update] 2026-06-23 - Kernels, KDE Frameworks, KDE Gear, Xorg-Server
I think it could be relevant to prevent users to not use NTFS drives with kernel 7.0 as it has been several reports of malfunction. All the issues seems solved in kernel 7.1.
Therefore I would advise to hold until 7.1 for final release.
EDIT: Its also relevant to say there are no reports of malfunctions with LTS kernels
EDIT: There is a bug report too, also here
EDIT: This is getting to Manjaro users already [Stable Update] 2026-05-02 - Kernels, Plasma, GNOME, Mesa, Systemd, VirtualBox, LibreOffice - #137 by alexsantee
manjaro-kde-26.1.0-pre-minimal-260505 difficult to reach live environment on HP Elitebook 820 G1
My HP Elitebook 820 G1 is in EFI mode and has a Haswell chipset.
I have tried manjaro-kde-26.1.0-pre-minimal-260505-linux618.iso and manjaro-kde-26.1.0-pre-minimal-260505-linux700.iso , and neither comes up with a live environment. However, they both work as expected in VirtualBox.
On the Elitebook I boot the iso from an USB stick, and the GRUB menu comes. I choose tz=Europe/Copenhagen and keytable=dk and leave lang=en_US and boot with open source drivers. The screen turns black, then shows some boot messages and then the graphical Manjaro wait animation. Then the screen turns black with a single underscore in the top left corner, and then - nothing!
Ctrl+Alt+F1 - no change
Ctrl+Alt+F2 - login screen for user manjaro. I write manjaro as password and press Enter and the mouse cursor disappears and then - nothing. No response to keyboard or mouse. Does not change to screen saver picture.
Ctrl+Alt+F1 - black screen
Ctrl+Alt+F2 - login screen for user manjaro, and the mouse cursor is back. I write manjaro as password and press Enter. The mouse cursor disappears and then - nothing. After a while, it changes to screen saver picture with a mouse cursor. Move the mouse and the login screen for user manjaro comes back.
I write manjaro as password and press Enter, and now the live desktop appears and works, but the key table is not dk. System Settings works, and I can set DK layout and activate it.
Open konsole and run + journalctl --boot --priority=err --output=with-unit --no-pager
No journal files were found.
-- No entries --```
I know the BIOS has a problem with ACPI, once manjaro-kde-26.1.0-pre-minimal-260505-linux700.iso is installed and booted on harddisk, the journal says
Thu 2026-05-07 11:45:28 CEST freddy-hpelitebook820g1 kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Index (0x000000032) is beyond end of object (length 0x32) (20251212/exoparg2-393)
Thu 2026-05-07 11:45:28 CEST freddy-hpelitebook820g1 kernel: ACPI Error: Aborting method \_SB.WMID.WQBE due to previous error (AE_AML_BUFFER_LIMIT) (20251212/psparse-529)
Thu 2026-05-07 11:45:28 CEST freddy-hpelitebook820g1 kernel: Error expected type 2 for elem 13, but got type 1 instead
inxi -zv8
  Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
    root=UUID=9a11cd4c-9631-4546-8e23-d713a147cd8c rw nowatchdog
    mitigations=off security=none "dyndbg=func fw_log_firmware_info +p"
    udev.log_priority=3 noresume nohibernate
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 820 G1
    v: A3009DD10203 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 1991 v: KBC Version 15.59
    serial: <superuser required> part-nu: J2A91AV uuid: <superuser required>
    Firmware: UEFI vendor: Hewlett-Packard v: L71 Ver. 01.49 date: 02/24/2020
  ID-1: BAT0 charge: 38.4 Wh (92.1%) condition: 41.7/41.7 Wh (100%)
    volts: 12.54 min: 11.25 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> charging: status: charging cycles: N/A
  System RAM: total: 16 GiB available: 15.05 GiB used: 1.07 GiB (7.1%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Bottom-Slot 1(left) type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: 99U5428-073.A00G serial: <filter>
  Device-2: Bottom-Slot 2(right) type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1300 min/max: 800/2700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1300 2: 1300 3: 1300 4: 1300 bogomips: 19156
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdtscp rep_good
    sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave
    xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: Vulnerable
  Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
  Type: mds status: Vulnerable; SMT vulnerable
  Type: meltdown status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Type: srbds status: Vulnerable
  Type: vmscape status: Vulnerable
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:0a16 class-ID: 0300
  Device-2: Chicony HP HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 04f2:b3ed
    alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x206c built: 2012 res:
    mode: 1366x768 hz: 60 scale: 100% (1) dpi: 125 gamma: 1.2 chroma: red:
    x: 0.573 y: 0.333 green: x: 0.329 y: 0.573 blue: x: 0.157 y: 0.145 white:
    x: 0.314 y: 0.329 size: 277x156mm (10.91x6.14") diag: 318mm (12.5")
    ratio: 16:9 modes: 1366x768
  EDID-Warnings: 1: parse_edid: unknown flag 2
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
    drv: crocus x11: drv: crocus
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW
    GT2) device-ID: 8086:0a16 memory: 1.46 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4400 (HSW GT2) driver: mesa intel v: 26.0.6-arch1.1
    device-ID: 8086:0a16 surfaces: N/A
  Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
    class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
    class-ID: 0403
  API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
  IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM43228 802.11a/b/g/n driver: wl v: kernel
    modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
    chip-ID: 14e4:4359 class-ID: 0280
  IF: wlo1 state: dormant mac: <filter>
  Device-1: Broadcom HP Portable Bumble Bee driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0a5c:21f1
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 232.89 GiB used: 26.47 GiB (11.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: DB6Q scheme: GPT
  ID-1: / raw-size: 223.79 GiB size: 219.22 GiB (97.96%)
    used: 26.47 GiB (12.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: frelroot
    uuid: 9a11cd4c-9631-4546-8e23-d713a147cd8c
    used: 328 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: A863-3D95
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -1
    dev: /dev/dm-0 maj-min: 253:0 mapped: swap label: swap
    uuid: b23f9682-b5bf-47bf-ab58-e443d31d7342
  ID-1: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: ext2 label: cryptswap
    uuid: ea85d742-300b-4e3f-8eeb-43081d8cac11
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
  Hub-2: 1-3:2 info: Microchip (formerly SMSC) Hub ports: 3 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:2134
  Device-1: 1-4:3 info: Broadcom HP Portable Bumble Bee type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 chip-ID: 0a5c:21f1 class-ID: fe01 serial: <filter>
  Device-2: 1-5:4 info: Validity Sensors VFS495 Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 138a:003f class-ID: ff00 serial: <filter>
  Device-3: 1-7:5 info: Chicony HP HD Webcam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b3ed class-ID: 0e02 serial: <filter>
  Hub-3: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-5: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-6: 3-3:2 info: Microchip (formerly SMSC) Hub ports: 3 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0424:5534
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1148 libs: 280 tools: pamac
    1: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 174
  1: cpu: 0.7% command: plasmashell pid: 992 mem: 287.9 MiB (1.8%)
  2: cpu: 0.5% command: konsole pid: 1153 mem: 103.0 MiB (0.6%)
  3: cpu: 0.3% command: systemd pid: 1 mem: 14.2 MiB (0.0%)
  4: cpu: 0.3% command: kwin_wayland pid: 836 mem: 175.3 MiB (1.1%)
  5: cpu: 0.1% command: pipewire pid: 890 mem: 14.5 MiB (0.0%)
  Memory top: 5 of 174
  1: mem: 287.9 MiB (1.8%) command: plasmashell pid: 992 cpu: 0.7%
  2: mem: 175.3 MiB (1.1%) command: kwin_wayland pid: 836 cpu: 0.3%
  3: mem: 103.0 MiB (0.6%) command: konsole pid: 1153 cpu: 0.5%
  4: mem: 94.6 MiB (0.6%) command: kded6 pid: 967 cpu: 0.0%
  5: mem: 76.2 MiB (0.4%) command: kdeconnectd pid: 1152 cpu: 0.0%
  Processes: 174 Power: uptime: 12m states: freeze,mem suspend: deep
    avail: s2idle wakeups: 0 hibernate: disabled image: 5.96 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 260 default: graphical tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: konsole
    inxi: 3.3.40
Gave it a shot using a USB key. XFCE end up with a message “cannot contact settings server” and lock up. KDE end up with a black screen.
Computer :AMD B550 - RX 5500- AMD RX570 8GB
manjaro-kde-26.1.0-pre-minimal-260505 difficult to reach live environment on AMD-system too.
The same behaviour on my desktop PC with AMD Ryzen 5 3600 CPU and Radeon RX 590 graphics. The automatic login to live environment fails.
inxi -zv8
  Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=f3904944-7f28-4603-975d-69a3043ccbfa ro nowatchdog
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
    Firmware: BIOS vendor: American Megatrends v: 4631 date: 01/14/2025
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 16 GiB available: 15.53 GiB used: 1.95 GiB (12.5%)
  Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3000 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-3000C16-16GISB serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: no module installed
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3599 min/max: 558/4208 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3599 2: 3599 3: 3599
    4: 3599 5: 3599 6: 3599 7: 3599 8: 3599 9: 3599 10: 3599 11: 3599 12: 3599
    bogomips: 86400
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: retbleed status: Vulnerable
  Type: spec_rstack_overflow status: Vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Gigabyte driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
    empty: DP-1,DP-2,DVI-D-1 bus-ID: 08:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 49.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4480x2640
    display-ID: 0
  Monitor-1: DP-3 pos: bottom-r model: Denon DENON-AVR serial: <filter>
    built: 2014 res: mode: 640x480 hz: 60 scale: 100% (1) dpi: 61 gamma: 1.2
    chroma: red: x: 0.627 y: 0.341 green: x: 0.278 y: 0.596 blue: x: 0.153
    y: 0.071 white: x: 0.282 y: 0.298 size: 800x450mm (27.87x15.67")
    diag: 918mm (36.1") ratio: 16:9 modes: 1920x1080, 2880x576, 2880x480,
    1280x720, 1440x576, 1440x480, 720x576, 720x480, 640x480
  Monitor-2: HDMI-A-1 pos: primary,top-left model: Philips FTV
    serial: <filter> built: 2017 res: mode: 3840x2160 hz: 60 scale: 200% (2)
    to: 1920x1080 dpi: 34 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green:
    x: 0.325 y: 0.588 blue: x: 0.145 y: 0.051 white: x: 0.278 y: 0.290
    size: 1440x810mm (56.69x31.89") diag: 1652mm (65") ratio: 16:9
    modes: 1920x1080, 3840x2160, 1600x1200, 1680x1050, 1400x1050, 1280x1024,
    1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 590 Series (radeonsi
    polaris10 ACO DRM 3.64 6.18.26-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX 590 Series (RADV POLARIS10) driver: mesa radv v: 26.0.6-arch1.1
    device-ID: 1002:67df surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 08:00.1 chip-ID: 1002:aaf0 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: aoss
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Local Storage: total: 5.25 TiB used: 428.63 GiB (8.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-00L5B1
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: N/A serial: <filter> fw-rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EADS-00L5B1 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
    scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Micron model: MTFDDAK256MAY-1AH12ABHA
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: M5T4 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU800NS38
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 8B scheme: MBR
  ID-5: /dev/sde maj-min: 8:64 vendor: Toshiba model: MQ03UBB300
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 5438 scheme: GPT
  ID-1: / raw-size: 476.94 GiB size: 468.38 GiB (98.21%)
    used: 23.78 GiB (5.1%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: statroot
    uuid: f3904944-7f28-4603-975d-69a3043ccbfa
  ID-2: /data/ssd200 raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
    used: 87.34 GiB (37.4%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: ssd200
    uuid: 90a6ed92-904a-458e-90e7-427c598d9337
  ID-3: /data/swdisk raw-size: 923.5 GiB size: 907.93 GiB (98.31%)
    used: 317.01 GiB (34.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: swdisk
    uuid: ed96f3d3-edea-43bc-8418-2223e4ec312d
  ID-4: /home/<filter>/cryptomount.fredox.vol raw-size: 650 MiB
    size: 622.5 MiB (95.77%) used: 515.7 MiB (82.8%) fs: ext4 dev: /dev/dm-1
    maj-min: 253:1 mapped: loop0 label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-0 maj-min: 253:0 mapped: swap label: swap
    uuid: 40bf81c1-d636-4245-9601-b69157142abb
  ID-1: /dev/sda2 maj-min: 8:2 size: 8.01 GiB fs: ext2 label: cryptswap
    uuid: 01319864-7821-48aa-a580-240abe298ed6
  ID-2: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ext4 label: hd1Tb
    uuid: a0f67169-c4c3-48e9-bafe-a73dc0983560
  ID-3: /dev/sde1 maj-min: 8:65 size: 2.73 TiB fs: exfat label: u3T-VENTOY
    uuid: 1AEA-1EB6
  ID-4: /dev/sde2 maj-min: 8:66 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: EA6C-95B2
  Device-1: 1-7:2 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 1-9:3 info: NZXT Smart Device V2 type: HID
    driver: nzxt-smart2,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2006 class-ID: 0300
    serial: <filter>
  Device-1: 2-1:2 info: Toshiba America Canvio Ready type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0480:b207 class-ID: 0806
    serial: <filter>
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-1:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0617
  System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 764
  Packages: pm: pacman pkgs: 1204 libs: 293 tools: pamac
    2: https://mirror.23m.com/manjaro/stable/$repo/$arch
    3: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    5: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    6: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    7: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    8: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    9: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 479
  1: cpu: 5.2% command: firefox pid: 2289 mem: 514.1 MiB (3.2%)
  2: cpu: 3.5% command: firefox pid: 3047 mem: 285.8 MiB (1.7%)
  3: cpu: 1.7% command: firefox pid: 2774 mem: 206.7 MiB (1.3%)
  4: cpu: 1.5% command: kwin_wayland pid: 1162 mem: 274.3 MiB (1.7%)
  5: cpu: 0.8% command: plasmashell pid: 1402 mem: 317.3 MiB (1.9%)
  Memory top: 5 of 479
  1: mem: 514.1 MiB (3.2%) command: firefox pid: 2289 cpu: 5.2%
  2: mem: 317.3 MiB (1.9%) command: plasmashell pid: 1402 cpu: 0.8%
  3: mem: 285.8 MiB (1.7%) command: firefox pid: 3047 cpu: 3.5%
  4: mem: 274.3 MiB (1.7%) command: kwin_wayland pid: 1162 cpu: 1.5%
  5: mem: 232.4 MiB (1.4%) command: qbittorrent pid: 2242 cpu: 0.6%
  Processes: 479 Power: uptime: 5m states: freeze,mem suspend: deep
    avail: s2idle wakeups: 0 hibernate: disabled image: 6.18 GiB
    inxi: 3.3.40
I perhaps have the same issue with the installation media booting to a blank, black, screen. Simply trying to switch to a tty screen (eg. ctrl+alt+F4) brought up the graphical login screen in my case. I had the same problem with the Anh-Linh release too.
Cannot login to manjaro account. Requiem login to root and use password manjaro.
After install plasma desktop i change animation close windows and after restart return to previous setting.
I have successfully performed a trial install of 26.1.0-pre KDE Plasma to a spare 250GB hard disk on a Toshiba NB550D netbook (circa 2012) upgraded to 2GB RAM. It was necessary to add extra swap via USB storage for the install. I installed to encrypted swap of 5GB, encrypted root and unencrypted /boot partition. The install was smooth and without problems.
Majaro KDE Plasma has performed well on the NB550D for several years but for the first time a Linux Kernel: Memory Shortage Avoided... message appears and the culprit program is shutdown.
I don’t know if this is because it is a preview release and still having some refinement or if Bian May is potentially going to bring the NB550D to the end of its useful life :cry:
Same here on XFCE: black screen with message box:
AMD Ryzen 9 7940HS
AMD Radeon 780M Graphics
manjaro-kde-26.1.0-pre-minimal-260523-linux618.iso does not reach live environment without the difficulties I described above. It works in VirtualBox 7.2.8 , but it fails on my HP Elitebook 820 G1, and on my desktop PC with AMD Ryzen 5 3600 CPU and Radeon RX 590 graphics.
HP Elitebook 820 G1
login on tty3 , no graphics inxi -zv8
  Kernel: 6.18.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1 clocksource: tsc
    avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    lang=en_US keytable=us tz=Europe/Copenhagen lang=en_US keytable=dk tz=Europe/Copenhagen
    misobasedir=manjaro misolabel=MANJARO_KDEM_2610PRE systemd.show_status=1 driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 rdinit=/vtoy/vtoy
  Console: pty pts/0 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 820 G1 v: A3009DD10203
    serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Hewlett-Packard model: 1991 v: KBC Version 15.59 serial: <filter> part-nu: J2A91AV
    uuid: c7c1a6ff-11ca-11e3-a9bd-a7372c76291a Firmware: UEFI vendor: Hewlett-Packard
  ID-1: BAT0 charge: 41.5 Wh (100%) condition: 41.5/41.5 Wh (100%) volts: 12.49 min: 11.25
    model: Hewlett-Packard Primary type: Li-ion serial: <filter> charging: status: full cycles: N/A
  System RAM: total: 16 GiB available: 15.05 GiB used: 1.11 GiB (7.4%) igpu: 512 MiB
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None max-module-size: 8 GiB note: est.
  Device-1: Bottom-Slot 1(left) type: DDR3 detail: synchronous size: 8 GiB speed: N/A volts: N/A
    width (bits): data: 64 total: 64 manufacturer: Kingston part-no: 99U5428-073.A00G
    serial: <filter>
  Device-2: Bottom-Slot 2(right) type: DDR3 detail: synchronous size: 8 GiB speed: N/A
    volts: N/A width (bits): data: 64 total: 64 manufacturer: Kingston part-no: 99U5428-073.A00G
    serial: <filter>
  Slot: 1 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
  Info: model: Intel Core i5-4210U socket: BGA1168 (U3E1) note: check bits: 64 type: MT MCP
    arch: Haswell gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2 smt: enabled cache:
    L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 800 min/max: 800/2700 base/boost: 1700/2400 scaling: driver: intel_cpufreq
    governor: schedutil volts: 0.7 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800
    bogomips: 19155
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est
    f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: conditional; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard driver: i915 v: kernel
    arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1,
    HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
  Device-2: Chicony HP HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 2-7:5 chip-ID: 04f2:b3ed class-ID: 0e02 serial: <filter>
  Display: server: X.org v: 1.21.1.22 with: Xwayland v: 24.1.11 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: crocus gpu: i915 tty: 170x48
  Monitor-1: eDP-1 model: AU Optronics 0x206c built: 2012 res: 1366x768 dpi: 125 gamma: 1.2
    chroma: red: x: 0.573 y: 0.333 green: x: 0.329 y: 0.573 blue: x: 0.157 y: 0.145 white: x: 0.314
    y: 0.329 size: 277x156mm (10.91x6.14") diag: 318mm (12.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus device: 1 drv: swrast
    gbm: drv: crocus surfaceless: drv: crocus inactive: wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 26.0.6-arch1.1 note: console (EGL sourced)
    renderer: Mesa Intel HD Graphics 4400 (HSW GT2), llvmpipe (LLVM 22.1.3 256 bits)
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu name: Intel HD Graphics 4400
    (HSW GT2) driver: mesa intel v: 26.0.6-arch1.1 device-ID: 8086:0a16 surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
  Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  API: ALSA v: k6.18.32-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-3: PipeWire v: 1.6.5 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: 3080
  IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
  Device-2: Broadcom BCM43228 802.11a/b/g/n driver: bcma-pci-bridge v: N/A modules: bcma pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4359 class-ID: 0280
  Device-1: Broadcom HP Portable Bumble Bee driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 2-4:3 chip-ID: 0a5c:21f1 class-ID: fe01 serial: <filter>
  Local Storage: total: 248.17 GiB used: 1.5 MiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB family: based SSDs
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: DB6Q temp: 31 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 178d 22h cycles: 4719 written: 26.34 TiB
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra size: 14.32 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 model: VBTM Store n Go size: 983 MiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 5.00 scheme: MBR
  ID-1: /mnt raw-size: 982 MiB size: 980 MiB (99.80%) used: 1.5 MiB (0.2%) fs: vfat
    block-size: 512 B dev: /dev/sdc1 maj-min: 8:33 label: VERB980M uuid: 06E1-F7E2
  ID-1: /dev/dm-0 maj-min: 253:0 mapped: ventoy size: 4.18 GiB fs: iso9660
  ID-2: /dev/dm-1 maj-min: 8:17 mapped: sdb1 size: 14.29 GiB fs: exfat label: SAN14600M
    uuid: E256-BE39
  ID-3: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: N/A uuid: A863-3D95
  ID-4: /dev/sda2 maj-min: 8:2 size: 223.79 GiB fs: ext4 label: frelroot
  ID-5: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: ext2 label: cryptswap
  ID-6: /dev/sdb1 maj-min: 8:17 size: 14.29 GiB fs: exfat label: SAN14600M uuid: E256-BE39
  ID-7: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI uuid: EA6C-95B2
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000 class-ID: 0900
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Hub-4: 2-3:2 info: Microchip (formerly SMSC) Hub ports: 3 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:2134 class-ID: 0900
  Device-1: 2-3.1:6 info: M-Systems Flash Disk Pioneers TravelDrive 2C type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 200mA chip-ID: 08ec:0008 class-ID: 0806 serial: <filter>
  Device-2: 2-4:3 info: Broadcom HP Portable Bumble Bee type: Bluetooth driver: btusb
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a5c:21f1
  Device-3: 2-5:4 info: Validity Sensors VFS495 Fingerprint Reader type: <vendor specific>
    driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Device-4: 2-7:5 info: Chicony HP HD Webcam type: video driver: uvcvideo interfaces: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b3ed class-ID: 0e02
    serial: <filter>
  Hub-5: 3-0:1 info: super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 chip-ID: 1d6b:0003 class-ID: 0900
  Device-1: 3-2:2 info: SanDisk Ultra type: mass storage driver: usb-storage interfaces: 1
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5581
  Hub-6: 3-3:3 info: Microchip (formerly SMSC) Hub ports: 3 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0424:5534 class-ID: 0900
  System Temperatures: cpu: 41.0 C mobo: N/A
  Packages: pm: pacman pkgs: 1228 libs: 335 tools: pamac
    1: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    2: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    4: https://manjaro.nic.cz/stable/$repo/$arch
    5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    6: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    7: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    8: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    9: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    10: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    11: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    13: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    14: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    15: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    16: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    17: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    18: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    19: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    20: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    22: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    23: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    24: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    25: https://linorg.usp.br/manjaro/stable/$repo/$arch
    26: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    27: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    29: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://manjaro.mirror.ac.za/stable/$repo/$arch
    31: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    32: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    33: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    34: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    35: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    36: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    38: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    39: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    40: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    41: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    42: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    43: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    44: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    45: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    46: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    47: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    48: https://mirrors2.manjaro.org/stable/$repo/$arch
    49: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    50: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    51: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    52: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    53: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    54: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    55: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    56: https://mirror.init7.net/manjaro/stable/$repo/$arch
    57: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    58: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    59: https://mirror.23m.com/manjaro/stable/$repo/$arch
    60: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    61: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    62: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    63: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    64: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    65: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    66: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    67: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    68: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    69: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    70: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    71: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    72: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    73: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    74: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    75: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    76: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    78: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    79: https://manjaro.grena.ge/stable/$repo/$arch
    80: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    81: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    82: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    83: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    84: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    85: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    86: https://manjaro.ynh.ovh/stable/$repo/$arch
    87: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    88: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    89: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    90: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    91: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    92: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    93: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    94: https://manjaro.kurdy.org/stable/$repo/$arch
    95: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    96: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    97: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    98: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    99: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    100: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    101: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    102: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    103: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    104: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    105: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    106: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    107: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    108: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    109: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    110: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    111: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    112: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    113: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    114: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    115: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    116: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    117: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    118: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    119: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    120: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    121: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    122: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    123: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    124: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    125: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 144
  1: cpu: 0.7% command: -zsh pid: 1619 mem: 8.59 MiB (0.0%)
  2: cpu: 0.6% command: init pid: 1 mem: 15.6 MiB (0.1%)
  3: cpu: 0.5% command: [kworker/u16:0-loop1] pid: 12 mem: 0.00 MiB (0.0%)
  4: cpu: 0.5% command: gpg-agent pid: 889 mem: 4.55 MiB (0.0%)
  5: cpu: 0.5% command: sddm-greeter-qt6 pid: 1586 mem: 216.3 MiB (1.4%)
  Memory top: 5 of 144
  1: mem: 216.3 MiB (1.4%) command: sddm-greeter-qt6 pid: 1586 cpu: 0.5%
  2: mem: 66.0 MiB (0.4%) command: Xorg pid: 1576 cpu: 0.0%
  3: mem: 25.4 MiB (0.1%) command: NetworkManager pid: 696 cpu: 0.1%
  4: mem: 24.7 MiB (0.1%) command: sddm pid: 1294 cpu: 0.0%
  5: mem: 21.4 MiB (0.1%) command: sddm-helper pid: 1585 cpu: 0.0%
  Processes: 144 Power: uptime: 6m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 5.89 GiB
    services: upowerd Init: systemd v: 260 default: graphical tool: systemctl
  Compilers: N/A Shell: Bash (su) v: 5.3.9 running-in: pty pts/0 inxi: 3.3.40
login on tty3 , no graphics ps -fe
UID          PID    PPID  C STIME TTY          TIME CMD
root           1       0  0 11:21 ?        00:00:02 /sbin/init
root           2       0  0 11:21 ?        00:00:00 [kthreadd]
root           3       2  0 11:21 ?        00:00:00 [pool_workqueue_release]
root           4       2  0 11:21 ?        00:00:00 [kworker/R-rcu_gp]
root           5       2  0 11:21 ?        00:00:00 [kworker/R-sync_wq]
root           6       2  0 11:21 ?        00:00:00 [kworker/R-kvfree_rcu_reclaim]
root           7       2  0 11:21 ?        00:00:00 [kworker/R-slub_flushwq]
root           8       2  0 11:21 ?        00:00:00 [kworker/R-netns]
root          10       2  0 11:21 ?        00:00:00 [kworker/0:0H-events_highpri]
root          13       2  0 11:21 ?        00:00:00 [kworker/R-mm_percpu_wq]
root          15       2  0 11:21 ?        00:00:00 [ksoftirqd/0]
root          16       2  0 11:21 ?        00:00:00 [rcu_preempt]
root          17       2  0 11:21 ?        00:00:00 [rcub/0]
root          18       2  0 11:21 ?        00:00:00 [rcu_exp_par_gp_kthread_worker/0]
root          19       2  0 11:21 ?        00:00:00 [rcu_exp_gp_kthread_worker]
root          20       2  0 11:21 ?        00:00:00 [migration/0]
root          21       2  0 11:21 ?        00:00:00 [idle_inject/0]
root          22       2  0 11:21 ?        00:00:00 [cpuhp/0]
root          23       2  0 11:21 ?        00:00:00 [cpuhp/2]
root          24       2  0 11:21 ?        00:00:00 [idle_inject/2]
root          25       2  0 11:21 ?        00:00:00 [migration/2]
root          26       2  0 11:21 ?        00:00:00 [ksoftirqd/2]
root          28       2  0 11:21 ?        00:00:00 [kworker/2:0H-events_highpri]
root          29       2  0 11:21 ?        00:00:00 [cpuhp/1]
root          30       2  0 11:21 ?        00:00:00 [idle_inject/1]
root          31       2  0 11:21 ?        00:00:00 [migration/1]
root          32       2  0 11:21 ?        00:00:00 [ksoftirqd/1]
root          34       2  0 11:21 ?        00:00:00 [kworker/1:0H-events_highpri]
root          35       2  0 11:21 ?        00:00:00 [cpuhp/3]
root          36       2  0 11:21 ?        00:00:00 [idle_inject/3]
root          37       2  0 11:21 ?        00:00:00 [migration/3]
root          38       2  0 11:21 ?        00:00:00 [ksoftirqd/3]
root          39       2  0 11:21 ?        00:00:00 [kworker/3:0-events]
root          40       2  0 11:21 ?        00:00:00 [kworker/3:0H-events_highpri]
root          41       2  0 11:21 ?        00:00:00 [kdevtmpfs]
root          42       2  0 11:21 ?        00:00:00 [kworker/R-inet_frag_wq]
root          43       2  0 11:21 ?        00:00:00 [rcu_tasks_kthread]
root          44       2  0 11:21 ?        00:00:00 [rcu_tasks_rude_kthread]
root          45       2  0 11:21 ?        00:00:00 [rcu_tasks_trace_kthread]
root          46       2  0 11:21 ?        00:00:00 [kauditd]
root          47       2  0 11:21 ?        00:00:00 [khungtaskd]
root          48       2  0 11:21 ?        00:00:00 [oom_reaper]
root          49       2  0 11:21 ?        00:00:00 [kworker/u16:2-events_unbound]
root          50       2  0 11:21 ?        00:00:00 [kworker/R-writeback]
root          51       2  0 11:21 ?        00:00:00 [kcompactd0]
root          52       2  0 11:21 ?        00:00:00 [ksmd]
root          53       2  0 11:21 ?        00:00:00 [khugepaged]
root          54       2  0 11:21 ?        00:00:00 [kworker/R-kblockd]
root          55       2  0 11:21 ?        00:00:00 [kworker/R-blkcg_punt_bio]
root          56       2  0 11:21 ?        00:00:00 [kworker/R-kintegrityd]
root          57       2  0 11:21 ?        00:00:00 [irq/9-acpi]
root          58       2  0 11:21 ?        00:00:00 [kworker/1:1-events]
root          59       2  0 11:21 ?        00:00:00 [kworker/3:1-cgroup_free]
root          60       2  0 11:21 ?        00:00:00 [kworker/R-tpm_dev_wq]
root          61       2  0 11:21 ?        00:00:00 [kworker/R-ata_sff]
root          62       2  0 11:21 ?        00:00:00 [kworker/R-edac-poller]
root          63       2  0 11:21 ?        00:00:00 [kworker/R-devfreq_wq]
root          64       2  0 11:21 ?        00:00:00 [watchdogd]
root          65       2  0 11:21 ?        00:00:00 [kworker/R-quota_events_unbound]
root          66       2  0 11:21 ?        00:00:00 [kworker/2:1-events]
root          67       2  0 11:21 ?        00:00:00 [kworker/1:1H-kblockd]
root          68       2  0 11:21 ?        00:00:00 [kswapd0]
root          69       2  0 11:21 ?        00:00:00 [kworker/R-kthrotld]
root          70       2  0 11:21 ?        00:00:00 [irq/42-pciehp]
root          71       2  0 11:21 ?        00:00:00 [kworker/R-acpi_thermal_pm]
root          72       2  0 11:21 ?        00:00:00 [hwrng]
root          73       2  0 11:21 ?        00:00:00 [scsi_eh_0]
root          74       2  0 11:21 ?        00:00:00 [kworker/R-scsi_tmf_0]
root          75       2  0 11:21 ?        00:00:00 [scsi_eh_1]
root          76       2  0 11:21 ?        00:00:00 [kworker/R-scsi_tmf_1]
root          79       2  0 11:21 ?        00:00:00 [kworker/0:2-events]
root          80       2  0 11:21 ?        00:00:00 [kworker/u16:5-events_unbound]
root          81       2  0 11:21 ?        00:00:00 [kworker/R-mld]
root          82       2  0 11:21 ?        00:00:00 [kworker/0:1H-kblockd]
root          83       2  0 11:21 ?        00:00:00 [kworker/R-ipv6_addrconf]
root          84       2  0 11:21 ?        00:00:00 [kworker/R-kstrp]
root          92       2  0 11:21 ?        00:00:00 [kworker/R-zswap-shrink]
root          93       2  0 11:21 ?        00:00:00 [kworker/u17:0-hci0]
root          94       2  0 11:21 ?        00:00:00 [kworker/2:1H-kblockd]
root         246       2  0 11:21 ?        00:00:00 [kworker/3:1H-kblockd]
root         249       2  0 11:21 ?        00:00:00 [kworker/R-dm_bufio_cache]
root         283       2  0 11:21 ?        00:00:00 [scsi_eh_2]
root         284       2  0 11:21 ?        00:00:00 [kworker/R-scsi_tmf_2]
root         285       2  0 11:21 ?        00:00:00 [usb-storage]
root         286       2  0 11:21 ?        00:00:00 [kworker/R-uas]
root         288       2  0 11:21 ?        00:00:00 [kworker/1:2-cgroup_free]
root         291       2  0 11:21 ?        00:00:00 [kworker/R-ttm]
root         292       2  0 11:21 ?        00:00:00 [card1-crtc0]
root         293       2  0 11:21 ?        00:00:00 [card1-crtc1]
root         294       2  0 11:21 ?        00:00:00 [card1-crtc2]
root         440       2  0 11:21 ?        00:00:00 [kworker/R-kdmflush/253:0]
root         457       2  0 11:21 ?        00:00:00 [kworker/R-kdmflush/253:1]
root         590       1  0 11:21 ?        00:00:00 /usr/lib/systemd/systemd-journald
root         619       1  0 11:21 ?        00:00:00 /usr/lib/systemd/systemd-userdbd
root         628       2  0 11:21 ?        00:00:00 [psimon]
systemd+     631       1  0 11:21 ?        00:00:00 /usr/lib/systemd/systemd-timesyncd
root         637       1  0 11:22 ?        00:00:00 /usr/lib/systemd/systemd-udevd
root         652       2  0 11:22 ?        00:00:00 [psimon]
dbus         661       1  0 11:22 ?        00:00:00 /usr/bin/dbus-broker-launch --scope system --audit
dbus         686     661  0 11:22 ?        00:00:00 dbus-broker --log 10 --controller 9 --machine-id 7dd8b3e711c24ec1bc16fe0f851f860a --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
root         690       1  0 11:22 ?        00:00:00 /usr/bin/NetworkManager --no-daemon
polkitd      696       1  0 11:22 ?        00:00:00 /usr/lib/polkit-1/polkitd --no-debug --log-level=notice
root         697       1  0 11:22 ?        00:00:00 /usr/lib/systemd/systemd-logind
root         790       1  0 11:22 ?        00:00:00 /usr/bin/ModemManager
root         796       2  0 11:22 ?        00:00:00 [irq/48-mei_me]
root         799       2  0 11:22 ?        00:00:00 [kworker/0:3-mm_percpu_wq]
root         905       1  0 11:22 ?        00:00:02 /usr/bin/gpg-agent --homedir /etc/pacman.d/gnupg --supervised
root         916       2  0 11:22 ?        00:00:00 [kworker/u17:2-hci0]
root         940       1  0 11:22 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
root         960       2  0 11:22 ?        00:00:00 [kworker/R-cfg80211]
root         990       1  0 11:22 ?        00:00:00 /usr/lib/iio-sensor-proxy
root        1204       1  0 11:22 ?        00:00:00 /usr/sbin/crond -n
root        1347       1  0 11:22 ?        00:00:00 /usr/bin/sddm
manjaro     1450       1  0 11:22 ?        00:00:00 dbus-daemon --nofork --print-address 4 --session
root        1631       2  0 11:36 ?        00:00:00 [kworker/2:0-rcu_gp]
root        1638       2  0 11:37 ?        00:00:00 [kworker/u16:0-events_unbound]
root        1652     619  0 11:42 ?        00:00:00 systemd-userwork: waiting...
root        1653     619  0 11:42 ?        00:00:00 systemd-userwork: waiting...
root        1654     619  0 11:42 ?        00:00:00 systemd-userwork: waiting...
root        1655       2  0 11:42 ?        00:00:00 [kworker/u16:1-events_unbound]
root        1656       2  0 11:42 ?        00:00:00 [kworker/2:2-cgroup_free]
root        1658    1347  0 11:42 tty2     00:00:00 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_ROTHjY -noreset -displayfd 17
root        1667    1347  0 11:42 ?        00:00:00 /usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth-c6e33024-fb73-4e0b-b07d-801186ffa189 --id 3 --start /usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-PemYtg --theme /usr/share/sddm/themes/breath --user sddm --greeter
root        1680       2  0 11:42 ?        00:00:00 [psimon]
sddm        1693       1  0 11:42 ?        00:00:00 /usr/lib/systemd/systemd --user
root        1695       2  0 11:42 ?        00:00:00 [kworker/3:2-events]
sddm        1698    1693  0 11:42 ?        00:00:00 (sd-pam)
sddm        1705    1667  0 11:42 ?        00:00:01 /usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-PemYtg --theme /usr/share/sddm/themes/breath
sddm        1708    1693  0 11:42 ?        00:00:00 /usr/bin/dbus-broker-launch --scope user
sddm        1709    1708  0 11:42 ?        00:00:00 dbus-broker --log 11 --controller 10 --machine-id 25bc374549c22882fa13ef616a12df5e --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
root        1714       1  0 11:42 ?        00:00:00 /usr/lib/upowerd
root        1734       1  0 11:43 ?        00:00:00 login -- manjaro
manjaro     1759       1  0 11:43 ?        00:00:00 /usr/lib/systemd/systemd --user
root        1767       2  0 11:43 ?        00:00:00 [kworker/1:0-cgroup_release]
manjaro     1769    1759  0 11:43 ?        00:00:00 (sd-pam)
manjaro     1776    1734  0 11:43 tty3     00:00:01 -zsh
manjaro     1821       1  0 11:43 tty3     00:00:00 -zsh
manjaro     1822       1  0 11:43 tty3     00:00:00 -zsh
manjaro     1825       1  0 11:43 tty3     00:00:00 -zsh
manjaro     1830    1825  0 11:43 tty3     00:00:00 /usr/share/zsh-theme-powerlevel10k/gitstatus/usrbin/gitstatusd -G v1.5.5 -s -1 -u -1 -d -1 -c -1 -m -1 -v FATAL -t 8
root        1875       2  0 11:43 ?        00:00:00 [kworker/0:0-events]
root        1903       2  0 11:43 ?        00:00:00 [scsi_eh_3]
root        1904       2  0 11:43 ?        00:00:00 [kworker/R-scsi_tmf_3]
root        1905       2  0 11:43 ?        00:00:00 [usb-storage]
root        1971    1776  0 11:44 tty3     00:00:00 sudo su -
root        1973    1971  0 11:44 pts/0    00:00:00 sudo su -
root        1974    1973  0 11:44 pts/0    00:00:00 su -
root        1976    1974  0 11:44 pts/0    00:00:00 -bash
root        2052    1976  0 11:46 pts/0    00:00:00 ps -fe
After having logged in on tty3 and run localectl set-keymap dk , tty2 now shows login screen.
If I wait long enough and switch back and forth between tty1, tty2, and tty3, I can log in on the graphical login and reach the desktop.
HP Elitebook 820 G1
login as manjaro, KDE desktop inxi -zv8
  Console: pty pts/4 DM: SDDM Distro: Manjaro base: Arch Linux
  System RAM: total: 16 GiB available: 15.05 GiB used: 1.6 GiB (10.7%) igpu: 512 MiB
    serial: <filter>
    serial: <filter>
    bogomips: 19155
  Display: unspecified server: X.org v: 1.21.1.22 with: Xwayland v: 24.1.11
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa dri: crocus
    gpu: i915 tty: 110x28
  Server-3: PipeWire v: 1.6.5 status: n/a (root, process) with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Local Storage: total: 248.17 GiB used: 1.6 MiB (0.0%)
  ID-1: /mnt raw-size: 982 MiB size: 980 MiB (99.80%) used: 1.6 MiB (0.2%) fs: vfat
    uuid: E256-BE39
    serial: <filter>
Processes:
  CPU top: 5 of 201
  1: cpu: 8.5% command: plasmashell pid: 2367 mem: 320.0 MiB (2.0%)
  2: cpu: 3.2% command: kwin_wayland pid: 2220 mem: 180.8 MiB (1.1%)
  3: cpu: 1.5% command: pamac-daemon pid: 2714 mem: 19.3 MiB (0.1%)
  4: cpu: 1.1% command: yakuake pid: 2601 mem: 117.3 MiB (0.7%)
  5: cpu: 1.0% command: systemd pid: 2152 mem: 13.4 MiB (0.0%)
  Memory top: 5 of 201
  1: mem: 320.0 MiB (2.0%) command: plasmashell pid: 2367 cpu: 8.5%
  2: mem: 180.8 MiB (1.1%) command: kwin_wayland pid: 2220 cpu: 3.2%
  3: mem: 117.3 MiB (0.7%) command: yakuake pid: 2601 cpu: 1.1%
  4: mem: 115.7 MiB (0.7%) command: konsole pid: 3033 cpu: 1.0%
  5: mem: 109.0 MiB (0.7%) command: kded6 pid: 2331 cpu: 0.8%
  Processes: 201 Power: uptime: 7m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 260
  Compilers: N/A Shell: Bash (su) v: 5.3.9 running-in: pty pts/4 inxi: 3.3.40
login as manjaro, KDE desktop ps -fe
root           1       0  0 11:21 ?        00:00:03 /sbin/init
root          66       2  0 11:21 ?        00:00:00 [kworker/2:1-pm]
root          79       2  0 11:21 ?        00:00:00 [kworker/0:2-cgroup_free]
root          93       2  0 11:21 ?        00:00:00 [kworker/u17:0-i915_flip]
root        1638       2  0 11:37 ?        00:00:00 [kworker/u16:0-loop2]
root        1656       2  0 11:42 ?        00:00:00 [kworker/2:2-events]
root        1695       2  0 11:42 ?        00:00:00 [kworker/3:2-cgroup_free]
root        2083    1347  0 11:46 ?        00:00:00 /usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth-c6e33024-fb73-4e0b-b07d-801186ffa189 --id 2 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user manjaro
manjaro     2091    2083  0 11:46 tty1     00:00:00 /usr/bin/startplasma-wayland
manjaro     2134    1759  0 11:46 ?        00:00:00 /usr/bin/dbus-broker-launch --scope user
manjaro     2135    2134  0 11:46 ?        00:00:00 dbus-broker --log 11 --controller 10 --machine-id 25bc374549c22882fa13ef616a12df5e --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
manjaro     2143    1759  0 11:46 ?        00:00:00 /usr/bin/kwin_wayland_wrapper --xwayland
manjaro     2148    1759  0 11:46 ?        00:00:00 /usr/lib/kf6/baloo_file
manjaro     2149    2143  4 11:46 ?        00:00:01 /usr/bin/kwin_wayland --wayland-fd 7 --socket wayland-0 --xwayland-fd 8 --xwayland-fd 9 --xwayland-display :1 --xwayland-xauthority /run/user/1000/xauth_qPBHAn --xwayland
manjaro     2157    1759  0 11:46 ?        00:00:00 /usr/lib/xdg-desktop-portal
root        2158       1  0 11:46 ?        00:00:00 /usr/lib/udisks2/udisksd
manjaro     2171    1759  0 11:46 ?        00:00:00 /usr/lib/xdg-permission-store
manjaro     2176    1759  0 11:46 ?        00:00:00 /usr/lib/xdg-document-portal
root        2183    2176  0 11:46 ?        00:00:00 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
manjaro     2202    1759  0 11:46 ?        00:00:00 /usr/bin/pipewire
manjaro     2204    1759  1 11:46 ?        00:00:00 /usr/bin/wireplumber
rtkit       2210       1  0 11:46 ?        00:00:00 /usr/lib/rtkit-daemon
root        2227       2  0 11:46 ?        00:00:00 [kworker/u16:3-loop3]
root        2229       2  0 11:46 ?        00:00:00 [krfcommd]
root        2230       2  0 11:46 ?        00:00:00 [kworker/u17:1]
root        2231       2  0 11:46 ?        00:00:00 [kworker/1:3-events]
manjaro     2237    2149  0 11:46 ?        00:00:00 /usr/bin/Xwayland :1 -auth /run/user/1000/xauth_qPBHAn -listenfd 8 -listenfd 9 -displayfd 68 -wm 72 -rootless -enable-ei-portal
manjaro     2254    1759  0 11:46 ?        00:00:00 /usr/lib/at-spi-bus-launcher
manjaro     2265    2254  0 11:46 ?        00:00:00 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope user
manjaro     2266    1759  0 11:46 ?        00:00:00 /usr/bin/ksmserver
manjaro     2268    1759  1 11:46 ?        00:00:00 /usr/bin/kded6
manjaro     2272    2265  0 11:46 ?        00:00:00 dbus-broker --log 10 --controller 9 --machine-id 25bc374549c22882fa13ef616a12df5e --max-bytes 100000000000000 --max-fds 6400000 --max-matches 5000000000
manjaro     2273    1759  0 11:46 ?        00:00:00 /usr/lib/at-spi2-registryd --use-gnome-session
manjaro     2298    1759 16 11:46 ?        00:00:05 /usr/bin/plasmashell --no-respawn
manjaro     2306    1759  0 11:46 ?        00:00:00 /usr/bin/pipewire-pulse
manjaro     2331    1759  0 11:46 ?        00:00:00 /usr/lib/dconf-service
manjaro     2345    1759  0 11:46 ?        00:00:00 /usr/lib/kactivitymanagerd
manjaro     2348    1759  0 11:46 ?        00:00:00 /usr/bin/gmenudbusmenuproxy
manjaro     2349    1759  0 11:46 ?        00:00:00 /usr/bin/kaccess
manjaro     2350    1759  0 11:46 ?        00:00:00 /usr/lib/polkit-kde-authentication-agent-1
manjaro     2351    1759  4 11:46 ?        00:00:01 /usr/lib/org_kde_powerdevil
manjaro     2352    1759  0 11:46 ?        00:00:00 /usr/bin/xembedsniproxy
root        2497       1  0 11:46 ?        00:00:00 /usr/lib/power-profiles-daemon
manjaro     2504    1759  0 11:46 ?        00:00:00 /usr/lib/kf6/kioworker /usr/lib/qt6/plugins/kf6/kio/desktop.so desktop  local:/run/user/1000/plasmashellvapKtn.1.kioworker.socket
manjaro     2519    1759  3 11:46 ?        00:00:00 python3 /usr/bin/manjaro-hello
manjaro     2520    1759  0 11:46 ?        00:00:00 /usr/bin/msm_kde_notifier
manjaro     2521    1759  1 11:46 ?        00:00:00 /usr/bin/kdeconnectd
manjaro     2523    1759  2 11:46 ?        00:00:00 /usr/bin/yakuake
root        2528     619  0 11:46 ?        00:00:00 systemd-userwork: waiting...
root        2529     619  0 11:46 ?        00:00:00 systemd-userwork: waiting...
manjaro     2540    1759  0 11:46 ?        00:00:00 /usr/lib/xdg-desktop-portal-gtk
root        2542     619  0 11:46 ?        00:00:00 systemd-userwork: waiting...
manjaro     2555    1759  0 11:46 ?        00:00:00 /usr/bin/pamac-tray-plasma
manjaro     2556    1759  0 11:46 ?        00:00:00 /usr/bin/xsettingsd
manjaro     2632    1759  0 11:46 ?        00:00:00 /usr/lib/xdg-desktop-portal-kde
root        2648       1  1 11:46 ?        00:00:00 /usr/bin/pamac-daemon
manjaro     2699    2519  0 11:46 ?        00:00:00 bwrap --unshare-all --die-with-parent --chdir / --ro-bind /usr /usr --dev /dev --ro-bind-try /etc/ld.so.cache /etc/ld.so.cache --ro-bind-try /nix/store /nix/store --tmpfs /tmp-home --tmpfs /tmp-run --clearenv --setenv HOME /tmp-home --setenv XDG_RUNTIME_DIR /tmp-run --setenv XDG_RUNTIME_DIR /run/user/1000 --symlink /usr/lib /lib --symlink /usr/lib /lib64 --seccomp 20 /usr/lib/glycin-loaders/2+/glycin-image-rs --dbus-fd 19
manjaro     2700    2699  0 11:46 ?        00:00:00 bwrap --unshare-all --die-with-parent --chdir / --ro-bind /usr /usr --dev /dev --ro-bind-try /etc/ld.so.cache /etc/ld.so.cache --ro-bind-try /nix/store /nix/store --tmpfs /tmp-home --tmpfs /tmp-run --clearenv --setenv HOME /tmp-home --setenv XDG_RUNTIME_DIR /tmp-run --setenv XDG_RUNTIME_DIR /run/user/1000 --symlink /usr/lib /lib --symlink /usr/lib /lib64 --seccomp 20 /usr/lib/glycin-loaders/2+/glycin-image-rs --dbus-fd 19
manjaro     2701    2700  0 11:46 ?        00:00:00 /usr/lib/glycin-loaders/2+/glycin-image-rs --dbus-fd 19
manjaro     2731    2519  0 11:46 ?        00:00:00 bwrap --unshare-all --die-with-parent --chdir / --ro-bind /usr /usr --dev /dev --ro-bind-try /etc/ld.so.cache /etc/ld.so.cache --ro-bind-try /nix/store /nix/store --tmpfs /tmp-home --tmpfs /tmp-run --clearenv --setenv HOME /tmp-home --setenv XDG_RUNTIME_DIR /tmp-run --setenv XDG_RUNTIME_DIR /run/user/1000 --symlink /usr/lib /lib --symlink /usr/lib /lib64 --ro-bind-try /etc/fonts/conf.d /etc/fonts/conf.d --ro-bind-try /etc/fonts/fonts.conf /etc/fonts/fonts.conf --ro-bind-try /var/cache/fontconfig /var/cache/fontconfig --bind-try /home/manjaro/.cache/glycin/usr/lib/glycin-loaders/2+/glycin-svg /home/manjaro/.cache/glycin/usr/lib/glycin-loaders/2+/glycin-svg --setenv XDG_CACHE_HOME /home/manjaro/.cache/glycin/usr/lib/glycin-loaders/2+/glycin-svg --seccomp 21 /usr/lib/glycin-loaders/2+/glycin-svg --dbus-fd 20
manjaro     2732    2731  0 11:46 ?        00:00:00 bwrap --unshare-all --die-with-parent --chdir / --ro-bind /usr /usr --dev /dev --ro-bind-try /etc/ld.so.cache /etc/ld.so.cache --ro-bind-try /nix/store /nix/store --tmpfs /tmp-home --tmpfs /tmp-run --clearenv --setenv HOME /tmp-home --setenv XDG_RUNTIME_DIR /tmp-run --setenv XDG_RUNTIME_DIR /run/user/1000 --symlink /usr/lib /lib --symlink /usr/lib /lib64 --ro-bind-try /etc/fonts/conf.d /etc/fonts/conf.d --ro-bind-try /etc/fonts/fonts.conf /etc/fonts/fonts.conf --ro-bind-try /var/cache/fontconfig /var/cache/fontconfig --bind-try /home/manjaro/.cache/glycin/usr/lib/glycin-loaders/2+/glycin-svg /home/manjaro/.cache/glycin/usr/lib/glycin-loaders/2+/glycin-svg --setenv XDG_CACHE_HOME /home/manjaro/.cache/glycin/usr/lib/glycin-loaders/2+/glycin-svg --seccomp 21 /usr/lib/glycin-loaders/2+/glycin-svg --dbus-fd 20
manjaro     2733    2732  0 11:46 ?        00:00:00 /usr/lib/glycin-loaders/2+/glycin-svg --dbus-fd 20
manjaro     2906    1759  0 11:46 ?        00:00:00 /usr/lib/kf6/kioworker /usr/lib/qt6/plugins/kf6/kio/tags.so tags  local:/run/user/1000/plasmashellAlsVJf.4.kioworker.socket
root        2968    1976  0 11:46 pts/0    00:00:00 ps -fe
VirtualBox 7.2.8
inxi -zv8
    avail: kvm-clock,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=dk
    tz=Europe/Copenhagen misobasedir=manjaro misolabel=MANJARO_KDEM_2610PRE quiet
    systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Console: pty pts/2 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Virtualbox System: innotek GmbH product: VirtualBox v: 1.2 serial: <filter>
    Chassis: Oracle Corporation type: 1 serial: N/A
  Mobo: Oracle model: VirtualBox v: 1.2 serial: N/A uuid: c532ae7f-2230-9848-b6a7-08ea444dfd83
    Firmware: UEFI vendor: innotek GmbH v: VirtualBox date: 12/01/2006
  System RAM: total: 4.98 GiB available: 4.78 GiB used: 1.75 GiB (36.6%)
  RAM Report: message: No RAM data found using dmidecode.
  Message: No PCI Slot data found.
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MCP arch: Zen 2 gen: 2 level: v3 note: check
    built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: <unsupported> cache: 512 KiB note: check
  Speed (MHz): avg: 3600 min/max: N/A cores: 1: 3600 2: 3600 3: 3600 4: 3600 5: 3600 6: 3600
    bogomips: 43199
  Flags: 3dnowprefetch abm adx aes apic arat avx avx2 bmi1 bmi2 clflush clflushopt cmov
    cmp_legacy constant_tsc cpuid cr8_legacy cx16 cx8 de extd_apicid f16c fma fpu fsgsbase fxsr
    fxsr_opt ht hypervisor lahf_lm lm mca mce misalignsse mmx mmxext movbe msr mtrr nonstop_tsc
    nopl nx pae pat pclmulqdq pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sha_ni
    ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 syscall tsc tsc_known_freq vme vmmcall x2apic xsave
    xtopology
  Type: spec_rstack_overflow mitigation: SMT disabled
  Type: spec_store_bypass status: Not affected
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling; PBRSB-eIBRS: Not
  Type: vmscape status: Not affected
  Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.21.0.0 ports: active: Virtual-1
    empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5, Virtual-6, Virtual-7, Virtual-8
    bus-ID: 00:02.0 chip-ID: 15ad:0405 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa,vmware gpu: vmwgfx
    tty: 110x28
  Monitor-1: Virtual-1 size-res: N/A in console modes: 1280x800, 1920x1440, 1856x1392,
    1792x1344, 2048x1152, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1400x1050, 1600x900,
    1280x1024, 1440x900, 1280x960, 1366x768, 1360x768, 1280x768, 1280x720, 1024x768, 800x600,
    848x480, 640x480
  API: EGL v: 1.5 platforms: device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast
    inactive: wayland,x11,device-0
  API: OpenGL v: 4.5 vendor: mesa v: 26.0.6-arch1.1 note: console (EGL sourced)
    renderer: llvmpipe (LLVM 22.1.3 256 bits)
  Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0 v: kernel bus-ID: 00:05.0
    chip-ID: 8086:2415 class-ID: 0401
  Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: c1a0 bus-ID: 00:03.0
    chip-ID: 8086:100e class-ID: 0200
  IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge driver: piix4_smbus v: N/A
    modules: i2c_piix4 port: N/A bus-ID: 00:07.0 chip-ID: 8086:7113 class-ID: 0680
  Local Storage: total: 0 KiB used: 0 KiB
  Optical-1: /dev/sr0 vendor: VBOX model: CD-ROM rev: 1.0  dev-links: cdrom
  Features: speed: 32 multisession: yes audio: yes dvd: yes rw: none state: running
  ID-1: /home/vshare raw-size: N/A size: 468.38 GiB used: 45.83 GiB (9.8%) fs: vboxsf
    remote: vshare
  Hub-1: 1-0:1 info: full speed or root hub ports: 12 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
  Device-1: 1-1:2 info: VirtualBox USB Tablet type: HID driver: hid-generic,usbhid interfaces: 1
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 80ee:0021
    class-ID: 0300
  Hub-2: 2-0:1 info: full speed or root hub ports: 12 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon or lm-sensors.
  Packages: pm: pacman pkgs: 1220 libs: 329 tools: pamac
    1: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    2: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    3: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    7: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    8: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    9: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    10: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    11: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    12: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    13: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    14: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    15: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    16: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    18: https://manjaro.ynh.ovh/stable/$repo/$arch
    19: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    20: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    21: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://linorg.usp.br/manjaro/stable/$repo/$arch
    23: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    24: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    25: https://mirror.init7.net/manjaro/stable/$repo/$arch
    26: https://mirror.23m.com/manjaro/stable/$repo/$arch
    27: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    28: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    29: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    30: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    31: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    33: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    34: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    36: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    37: https://manjaro.nic.cz/stable/$repo/$arch
    38: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    39: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    40: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    41: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    42: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    43: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    44: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    45: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    46: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    47: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    49: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    50: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    51: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    52: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    53: https://manjaro.kurdy.org/stable/$repo/$arch
    54: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    55: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    56: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    57: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    58: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    59: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    60: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    63: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    64: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    65: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    66: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    67: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    68: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    69: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    70: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    71: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    72: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    73: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    74: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    75: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    76: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    77: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    78: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    79: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    80: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    81: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    82: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    83: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    84: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    85: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    86: https://manjaro.grena.ge/stable/$repo/$arch
    87: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    88: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    89: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    90: https://mirrors2.manjaro.org/stable/$repo/$arch
    91: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    92: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    93: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    94: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    95: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    96: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    97: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    98: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    99: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    100: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    101: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    102: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    103: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    104: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    105: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    106: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    107: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    108: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    109: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    110: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    111: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    112: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    113: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    114: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    115: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    116: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    117: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    118: https://manjaro.mirror.ac.za/stable/$repo/$arch
    119: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    120: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    121: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    122: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    123: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    124: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    125: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 195
  1: cpu: 2.2% command: kwin_wayland pid: 1431 mem: 309.3 MiB (6.3%)
  2: cpu: 1.9% command: plasmashell pid: 1615 mem: 555.9 MiB (11.3%)
  3: cpu: 0.7% command: zsh pid: 2575 mem: 8.60 MiB (0.1%)
  4: cpu: 0.4% command: init pid: 1 mem: 14.9 MiB (0.3%)
  5: cpu: 0.4% command: [kworker/u24:1-events_unbound] pid: 13 mem: 0.00 MiB (0.0%)
  Memory top: 5 of 195
  1: mem: 555.9 MiB (11.3%) command: plasmashell pid: 1615 cpu: 1.9%
  2: mem: 309.3 MiB (6.3%) command: kwin_wayland pid: 1431 cpu: 2.2%
  3: mem: 174.0 MiB (3.5%) command: kded6 pid: 1575 cpu: 0.1%
  4: mem: 125.3 MiB (2.5%) command: yakuake pid: 1832 cpu: 0.1%
  5: mem: 124.6 MiB (2.5%) command: konsole pid: 2550 cpu: 0.3%
  Processes: 195 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: shutdown avail: reboot,suspend,test_resume image: 1.82 GiB
  Compilers: N/A Shell: Bash (su) v: 5.3.9 running-in: pty pts/2 inxi: 3.3.40
Successfully installed GNOME edition onto HP ENVY x360 Convertible 13-ar0xxx [1], but a couple of points stand out :
1. Default installation has 125% screen scaling
Post-installation, default screen scaling is set at 125%. Switched scaling to 100% in GNOME settings, but gdm still displays with scaling at 125%.
Followed Arch wiki and created drop-in file for gdm.service to automatically reconfigure monitor setup at each boot and to set 100% scaling.
Previously, default installations had 100% scaling for both the desktop and for gdm, so not sure when this changed. I think 100% default for both is better.
On a 1920 x 1080 display at 125% scaling, the GNOME windows appear too large and everything on the gdm login screen appears blurry, including the Manjaro theming.
2. Default installation no longer groups applications in GNOME application list
The GNOME applications list (Super + A) no longer shows grouped applications, so all applications now appear ungrouped. Previously, default installations grouped at least some applications, so not sure when this changed.
I think not grouping makes the list a little more cluttered than it needs to be.
  1. AMD Ryzen 3 3300U with Integrated Radeon Vega 6 Graphics. ↩︎
@rousseau thx for your feedback. Please chat with @Yochanan about it, since I’m not a GNOME user. Can be changes made to GNOME 50 series or some is missing to auto-group some applications as we had before in GNOME 49 series.
I’m not sure how that’s happening. I’ve seen no other reports.
I haven’t been able to track down what caused that, still looking into it.
It looks like this isn’t an entirely unknown issue, if the following report is any indication; however, it does require signup to access the Redhat Customer Portal and discover the documented solution;
Maybe it provides a clue:
I’ve updated manjaro-gnome-settings to reflect the new upstream changes to default XDG categories as of 20260531-1.
Not directly related to Manjaro settings, however it sounds like it may be related to the upstream changes.
I found this thread in the forum : it describes a similar problem with gdm scaling.
Thanks for the update @Yochanan : I’ll test again when I next perform a reinstall.
Hi,
I will install manjaro on my new lenovo laptop as dual-boot with windows 11. Do you think this preview release cause problem or can I install it and change the kernel then? Or do you think I must use official image? I’m just curious :slight_smile:
If you don’t touch you windows partition from linux it should be no issue. Just make sure you move to kernel 7.1 or 6.18 after installation. I would recommend 6.18 but IDK if that’s an option.
Apparently the new ntfs driver is not yet backported to 7.0, IDK if it will ever be. 6.18 is a solid proven kernel. 7.1 is still not final.
EDIT: Apparently the ntfs3 driver was patched before final release of kernel 7.0. May somebody confirm?
I may have spoken too soon. For some reason what I thought would work did not. Back to the drawing board…
