[Stable Update] 2026-03-23 - Kernels, Mesa, COSMIC, GNOME, Systemd, Plasma
Hello community, here we have another set of package updates. This might mark most likely the last update for Anh-Linh release series, as in 26.0.4 point release. Let us know if you see some issues with those package updates.
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages.
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 5.4.302, the 5.4 series is now EOL (End Of Life). Please install 5.10 LTS (Long Term Support) or 5.15 LTS.
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux510 5.10.252
  • linux515 5.15.202
  • linux61 6.1.165
  • linux66 6.6.128
  • linux612 6.12.77
  • linux618 6.18.18
  • linux619 6.19.8
  • linux70 7.0.0rc4
  • linux61-rt 6.1.166_rt61
  • linux66-rt 6.6.129_rt70
  • linux612-rt 6.12.74_rt16
  • linux617-rt 6.17.5_rt7
Package Changes (3/16/26 18:52 CET)
  • stable core x86_64: 100 new and 96 removed package(s)
  • stable extra x86_64: 3539 new and 3629 removed package(s)
  • stable multilib x86_64: 69 new and 67 removed package(s)
More details about the package changes can be found here
0 voters
Known issues and solutions
:warning: Prepare the update beforehand
Preparation steps
From [INFO] Stable branch - BIG update BEST practice
If it has been a long time since your last update, you may want to refresh your pacman-keyring before running the actual update.
  1. Create a list of custom packages for later reference
    pamac list --foreign > ~/alien-pkgs.txt
  2. Remove all foreign packages
    pamac remove $(pamac list --foreign --quiet)
  3. Remove all orphans and other unneeded packages
    pamac remove --orphans --unneeded
  4. Optional: ensure the keyrings are up-to-date
    sudo pacman -Syy manjaro-keyring archlinux-keyring
  5. Optional: Run a simulated update
    pamac update --dry-run
  6. Looking good? Repeat the above without --dry-run
    reboot
  7. Consult the list of packages created in the first step and rebuild only those you really need
Important Note: Users of Plasma and GNOME may lose their X11 session support. Checkout our guides below before restarting your systems!
Important Note: Users of Pascal, Maxwell, or older cards will fail to load the NVIDIA driver when they were using 580xx series earlier, because the 590xx doesn’t support the older hardware anymore. Only Turing series and newer are still supported.
:arrow_right: 2026-05-01
On 29 April 2026, a high local privilege escalation vulnerability in the Linux kernel, tracked as CVE-2026-31431 and named “Copy Fail”, was publicly disclosed. The vulnerability affects Manjaro Linux since 2017. A public proof-of-concept exploit has been released.
We have patched most of our kernels and released them to our testing and unstable branches:
  • patched kernels are: 5.10.254+, 5.15.204+, 6.1.170+, 6.6.137+, 6.12.85+, 6.18.22+, 6.19.12+, 7.0-rc7+
  • affected kernels are: 6.1.167_rt62, 6.6.133_rt73, 6.12.79_rt17, 6.17.5_rt7 and lower
Those who want to have a maintained Distro, may switch to testing branch and give needed feedback …
Temporary Mitigation
Disable the algif_aead kernel module persistently on all affected systems until a patched kernel is available:
echo "install algif_aead /bin/false" > /etc/modprobe.d/disable-algif.conf
    rmmod algif_aead 2>/dev/null || true
More Information: CERT-EU - High Vulnerability in the Linux Kernel ("Copy Fail")
2026-03-23
pamac-manager gui (Add/Remove Programs) does not start or starts very slow
For now, disable flatpak support (you can just browse flathub.org and install and update from terminal)
sudo nano /etc/pamac.conf
scroll to the end and put # before EnableFlatpak
press ctrl+q , y to save and exit
`plasma-applet-window-buttons` is broken
The plasma-applet-window-buttons package included in this update is version 0.14.0-3, which looks for /usr/lib/libPlasma.so.7, but this library does not exist — the version of the library included in this Stable Update is /usr/lib/libPlasma.so.6.5.6.
The solution is to downgrade plasma-applet-window-buttons to version 0.14.0-2. You do this by way of manjaro-downgrade. :backhand_index_pointing_down:
sudo manjaro-downgrade plasma-applet-window-buttons
Update: In the meantime, the faulty package has been replaced in the repository by the working one already, but if you had updated your system and you have version 0.14.0-3 while you did not downgrade the package yet, run… :backhand_index_pointing_down:
sudo pacman -Syuu
… just once. It will downgrade the faulty package back to the working one.
2026-02-23
Possible signature validity issues with packages taken over from Arch
Do this before updating!
Edited by @ManjaroDevOps 2026-02-26T06:35:00Z
Before you jump to the big :hammer_and_wrench: and wipe the pacman gnupg folder
sudo pacman -Syy archlinux-keyring manjaro-keyring
Optionally
sudo pacman-key --populate archlinux manjaro
Original suggestion
The problem… :backhand_index_pointing_down:
https://www.reddit.com/r/archlinux/comments/1rafluf/pacman_and_keyring_issues/
The solution… :backhand_index_pointing_down:
 sudo rm -rf /etc/pacman.d/gnupg
 sudo pacman-key --init && sudo pacman-key --populate archlinux manjaro && sudo pacman -Syu
Unreliability of the `pamac` package manager
Rationale
There recently appears to be a high incidence of pamac crashing in the middle of a system update, be it only in the form of the pamac-manager crashing with the update process continuing in the background, or in the form of a complete crash of the pamac infrastructure, leading to a non-bootable system.
Advice
Until the Manjaro Team has managed to correct this issue, we would advise our users…
  • to either (install and) use octopi — see the screenshot below :backhand_index_pointing_down: — as a graphical package manager
  • …or to use the tried-and-trusted pacman from the command line for updating the repository packages, and to use the pamac command-line utility and flatpak command-line utility afterwards for updating the AUR packages and the FlatPaks, respectively, as follows… :backhand_index_pointing_down:
    sudo pacman-mirrors -f && sudo pacman -Syu && pamac update --aur --devel && flatpak update
2026-01-04
problems with polkit
After a change in polkit, some users report permission problems. Different solutions are suggested:
  • rebooting
  • reinstalling polkit (with sudo pacman -S polkit, since pamac may not work in that case)
  • fixing the suid permissions manually with
sudo chmod 4755 /usr/lib/polkit-1/polkit-agent-helper-1
  • fixing the file permissions manually
    The proper permissions are:
drwxr-xr-x (755) - root:root - Directory
-rwxr-xr-x (755) - root:root - Executables
-rw-r--r-- (644) - root:root - Rules files
so to fix you use
sudo chown -R root:root /usr/lib/polkit-1/
sudo chmod 755 /usr/lib/polkit-1/
sudo chmod 755 /usr/lib/polkit-1/polkitd /usr/lib/polkit-1/polkit-agent-helper-1
sudo chmod 644 /usr/lib/polkit-1/rules.d/*
Alternatively, running the full Manjaro packages update via pacman and rebooting before updating the AUR packages withpamac might circumvent the problem from occurring in the first place.
Some users report success with masking the helper service. Please use this as a temporary or last resort solution if everything else fails as this disables an important component and cannot be officially recommended:
sudo systemctl stop polkit-agent-helper.socket
sudo systemctl mask polkit-agent-helper.socket
Another solution for the Polkit issue is to switch Kernel to version 6.6 or above if all the above does not help.
NVIDIA 590 driver drops Pascal and Maxwell support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) or Maxwell (GTX 9xx) GPUs
Impact: Updating the NVIDIA packages on systems with Pascal or Maxwell cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required: Switch to a legacy driver to maintain support:
Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages. You can use nvidia-driver-assistant to figure out which driver would support your hardware best.
pacman-mirrors 5.3
Release Notes: v5.3 · Applications / pacman-mirrors · GitLab
error: pacman-mirrors: signature from “Frede Hundewadt”
The package is not corrupted - but for unknown reasons your system does not have the manjaro-keyring that was updated early October.
2025-12-22
Users with old Nvidia cards should change the driver first
Users with older cards should check if they have the proper drivers installed on their system:
$ sudo pacman -Sy nvidia-driver-assistant
$ nvidia-driver-assistant
Detected GPUs:
  GeForce GT 740A - (pci_id 0x1292)
Detected system:
  Manjaro Linux
Please copy and paste the following command to install the legacy kernel module flavour:
  sudo pacman -S linux618-nvidia-470xx
2025-12-15
NVIDIA 580xx drivers might create issues with desktop environment
  • Current 580xx driver seems to be super unstable. Users who face issues are recommended to report to NVIDIA
  • For 580.119.02 the current workaround to avoid issues with flickering under XFCE is to disable compositing under Settings → Window Manager Tweaks → Compositor → Enable display compositing. NVIDIA is actively working on fixing this issue
  • You may also want to consult the nvidia-open driver public bug tracker
Optional switch to older Nvidia driver
For a list of possible drivers for your hardware run
mhwd -l
If your system was automagically rolled to a supported kernel you may run into conflicts with the meta package(s).
Remove the meta packages
sudo pacman -R linux-nvidia-meta linux-meta
If you are using a desktop system and you are in doubt if you are affected
  • Before you reboot - remove the current driver
    sudo mhwd -r video-nvidia
  • Use an earlier driver mhwd -i video-nvidia-{575xx or 570xx}
    Example command
    sudo mhwd -i video-nvidia-575xx
2025-12-08
Make sure to fully update grub also on MBR/EFI
On some UEFI systems the fallback EFI entry wont get updated. Hence either ignore the grub update completely and do a system reboot or make sure it got properly updated by running install-grub followed by update-grub after the system update and before a reboot to avoid issues like grub_memcpy not found.
For reinstallation the Anh-Linh ISOs are recommended, which can be found in the first post and include this update already.
Dark theming on XFCE for gtk4 apps and flatpaks (again)
The symlinking for the fixing of the dark theme for some flatpaks (which ignore the env variable) and parts of gtk4 apps might not be enough anymore. For example the graphs in gnome-system-monitor stay white.
So after
mkdir -p ~/.config/gtk-4.0/
ln -sf /usr/share/themes/Matcha-dark-sea/gtk-4.0/{assets,gtk.css,gtk-dark.css} ~/.config/gtk-4.0/
also do (it was not supposed to work anymore, but it does)
gsettings set org.gnome.desktop.interface gtk-theme Adwaita-dark
gsettings set org.gnome.desktop.interface color-scheme prefer-dark
After this you might have to go to the Appearence settings and set the theme back to Matcha dark sea to fix the xfce apps (but the gnome apps will stay dark).
mkinitcpio v40 disabled fallback image creation for new installs
mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
This is only affects new installs as we can’t change the hook files on existing installs.
To disable fallback image creation on older installed systems
  • Change PRESETS=('default' 'fallback') line to PRESETS=('default') in the respective .preset files in /etc/mkinitcpio.d/.
  • Regenerate initramfs - sudo mkinitcpio -P
  • Update boot loader - sudo update-grub
Warning
Disabling all fallback initramfs generation will deprive you of another option to boot into the system in case a default initramfs fails. Before proceeding, make sure you have a bootable installation medium for rescue purposes on hand.
waydroid >= 1.5.4-3 update may require manual intervention
The waydroid package prior to version 1.5.4-2 (including aur/waydroid) creates Python byte-code files (.pyc) at runtime which were untracked by pacman. This issue has been fixed in 1.5.4-3, where byte-compiling these files is now done during the packaging process.
As a result, the upgrade may conflict with the unowned files created in previous versions. If you encounter errors like the following during the update:
error: failed to commit transaction (conflicting files)
waydroid: /usr/lib/waydroid/tools/pycache/init.cpython-313.pyc exists in filesystem
waydroid: /usr/lib/waydroid/tools/actions/pycache/init.cpython-313.pyc exists in filesystem
waydroid: /usr/lib/waydroid/tools/actions/pycache/app_manager.cpython-313.pyc exists in filesystem
You can safely overwrite these files by running the following command:
pacman -Syu --overwrite /usr/lib/waydroid/tools/\*__pycache__/\*
dovecot >= 2.4 requires manual intervention
The dovecot 2.4 release branch has made breaking changes which result in it being incompatible with any <= 2.3 configuration file.
Thus, the dovecot service will no longer be able to start until the configuration file was migrated, requiring manual intervention.
For guidance on the 2.3-to-2.4 migration, please refer to the following upstream documentation: Upgrading Dovecot CE from 2.3 to 2.4
Furthermore, the dovecot 2.4 branch no longer supports their replication feature, it was removed.
For users relying on the replication feature or who are unable to perform the 2.4 migration right now, we provide alternative packages available in [extra]:
  • dovecot23
  • pigeonhole23
  • dovecot23-fts-elastic
  • dovecot23-fts-xapian
The dovecot 2.3 release branch is going to receive critical security fixes from upstream until stated otherwise.
zabbix >= 7.4.1-2 may require manual intervention
Starting with 7.4.1-2, the following Zabbix system user accounts (previously shipped by their related packages) will no longer be used. Instead, all Zabbix components will now rely on a shared zabbix user account (as originally intended by upstream and done by other distributions):
  • zabbix-server
  • zabbix-proxy
  • zabbix-agent (also used by the zabbix-agent2 package)
  • zabbix-web-service
This shared zabbix user account is provided by the newly introduced zabbix-common split package, which is now a dependency for all relevant zabbix-* packages.
The switch to the new user account is handled automatically for the corresponding main configuration files and systemd service units.
However, manual intervention may be required if you created custom files or configurations referencing to and / or being owned by the above deprecated users accounts, for example:
  • PSK files used for encrypted communication
  • Custom scripts for metrics collections or report generations
  • sudoers rules for metrics requiring elevated privileges to be collected
Those should therefore be updated to refer to and / or be owned by the new zabbix user account, otherwise some services or user parameters may fail to work properly, or not at all.
Once migrated, you may remove the obsolete user accounts from your system.
Plasma 6.5 will need manual intervention if you are on X11
On Plasma 6.5 the wayland session will be the only one installed when the users does not manually specify kwin-x11.
With the recent split of kwin into kwin-wayland and kwin-x11, users running the old X11 session needs to manually install plasma-x11-session after the system update completed, or they will not be able to login. Currently pacman is not able to figure out your personal setup, and it wouldn’t be ok to install plasma-x11-session for every one using Plasma.
GNOME 49 is here and wayland is the default
With GNOME 49 there is no X11 session anymore. X11 support got disabled. It will get removed with GNOME 50 anyway. You still can use X11 applications via XWayland as usual, however running GNOME under X11 is not possible anymore.
.NET packages may require manual intervention
2025-12-11 - George Rawlinson
The following packages may require manual intervention due to the upgrade from 9.0 to 10.0:
  • aspnet-runtime
  • aspnet-targeting-pack
  • dotnet-runtime
  • dotnet-sdk
  • dotnet-source-built-artifacts
  • dotnet-targeting-pack
pacman may display the following error failed to prepare transaction (could not satisfy dependencies) for the affected packages.
If you are affected by this and require the 9.0 packages, the following commands will update e.g. aspnet-runtime to aspnet-runtime-9.0:
pacman -Syu aspnet-runtime-9.0
pacman -Rs aspnet-runtime
– Arch Linux - News: .NET packages may require manual intervention
2025-10-06
Apache - hardening override configuration
/etc/systemd/system/httpd.service.d/hardening.conf
Change the values to suit your use case
To disable a hardening change a value to either off or false and restart the service
[Service]
# These are the settings from service file `httpd.service`, providing some extra
# hardening and security. If this conflicts with your use case uncomment below and
# configure as required.
#NoNewPrivileges=on
#PrivateDevices=on
#PrivateTmp=on
#ProtectHome=on
Also see → Apache HTTP Server - ArchWiki
2025-08-30
Libreoffice 25.8.0.4 crashes on opening files
In case you experience immediate crash of Libreoffice Writer ver 25.8.0.4 (or other office apps and versions too?) on opening every already saved .docx file (or other formats too?), the workaround may be to switch from the Microsoft Tabbed toolbar to the standard old look. View -> User interface... until the bug is fixed.
This might or might not be fixed in 25.8.1 since there are several similar bugs in the bugtracker, one is fixed and one not until ver. 26. I guess some input from test or unstable branch users will help here.
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
It seems on older hardware the mesa 25.2.x update created some regressions which may result in black screens or flickering. Some older Nvidia cards with nouveau driver seem to be affected.
You can try to use the 25.1.x series of Mesa via this repo. Simply place it on top of [extra] in your /etc/pacman.conf file and use sudo pacman -Syuu to downgrade.
[mesa-251]
SigLevel = PackageRequired
Server = https://download.manjaro.org/pkgs/mesa
If you have no graphical session available you can access the bootloader by pressing ESC key during boot and select the bootloader entry. Press CTRL+E for edit and search for the words quiet and splash. Delete those and add 3 to the line. Then execute CTRL+x to start your session. You will land in a text console TTY. Login with your user.
Edit the /etc/pacman.conf with nano: sudo nano /etc/pacman.conf. Perform the downgrade and reboot.
2025-08-11
Wrong default action removing phonon-qt6-vlc
:: phonon-qt6-vlc-0.12.0-5 and phonon-qt5-vlc-0.12.0-3 are in conflict. Remove phonon-qt5-vlc? [y/N] y
The default is No, which will leave the old and deprecated package. This is obviously not what we want, so answer Y here.
Grub gained security fixes. Updating it may be risky
When Manjaro updates the grub package the actual installed binaries in master boot record (MBR) or UEFI won’t get updated. This is however needed to apply recent security fixes added to grub. Therefore we created Install-grub: a new way to keep your EFI/MBR in-sync with grub package to make it easier.
A more manual approach can be found here: [root tip] [How To] Primer on handling a grub package update
We also have it documented in our wiki on how to manually install grub when a disaster happens: GRUB/Restore the GRUB Bootloader - Manjaro. So if you are not experienced with it you can either ignore that extra step or have an install media at hand to recover as needed.
See also on how to create a boot media to install Manjaro fresh: Burn an ISO File - Manjaro. Those who want to get install medias having this update included may look for 25.0 ISOs when released or here: Releases · manjaro/release-review · GitHub
Remember, update-grub only updates the boot menu and install-grub is a script helper to install or reinstall grub on most case automatically via grub-install. All grub installations can be with a risk when not done properly as the user will change low level system parts and can easily break their systems.
Note: most likely grub was initially installed by an installer and therefore the user doesn’t know how grub got installed. So if you are unsure simply skip a reinstallation of grub.
Additional information can be found here.
Grub - Error: grub_is_using_legacy_shim_lock_protocol not found
The issue Error: grub_is_using_legacy_shim_lock_protocol not found is caused when the EFI firmware is pointing to the fallback /EFI/boot/bootx64.efi which is not updated automatically.
When it happens the efi-stub /EFI/Manjaro/grubx64.efi must be copied to /EFI/boot/ as bootx64.efi and this is what the install-grub script is designed for: Install-grub: a new way to keep your EFI/MBR in-sync with grub package
Booting from a live ISO running install-grub in chroot I may result in
WARNING: EFI directory not found! Grub couldn't be installed.
You can verified your mounts for $esp and check the /sys/firmware/efi/efivars.
efibootmgr can be used to create an efi entry pointing to the efi-stub in /EFI/Manjaro/grubx64.efi and manually generated grub.cfg using grub-mkconfig.
Example run of install-grub
[manjaro user]# install-grub
[D] GRUB 2 EFI-x64 found
[D] Checking EFI-Directory: /boot/efi
[D] Found EFI Bootloader: /boot/efi/EFI/Manjaro/grubx64.efi
[D] Found EFI Fallback: /boot/efi/EFI/boot/bootx64.efi
Install command will be: grub-install --no-nvram --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --recheck --force
Do you want to proceed? (yes/no) yes
ok, we will proceed
Grub will be installed on: EFI
Installing for x86_64-efi platform.
Installation finished. No error reported.
Update Grub Menu
ok, we will proceed
Found linux image: /boot/vmlinuz-6.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.15-x86_64.img
Found initrd fallback image: /boot/initramfs-6.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Warning: GRUB bootloader at /boot/efi/EFI/Manjaro was updated,
but it seems like you are not using it by default.
Please check your EFI boot priorities!
Example
[manjaro user]# efibootmgr
BootCurrent: 000A
Timeout: 1 seconds
BootOrder: 000A,0001,0003,0008,0009,0002,0004,0000,0007,0006,0005
Boot0000  Lenovo Cloud  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)/Uri(https://download.lenovo.com/pccbbs/cdeploy/efi/boot.efi)
Boot0001* UEFI OS       HD(1,GPT,519fa53d-c862-4efb-948b-eee1a5d9c584,0x1000,0x96000)/\EFI\BOOT\BOOTX64.EFI0000424f
Boot0002  UEFI: HTTP IPv4 Marvell AQtion 10Gbit Network Adapter PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)/Uri()0000424f
Boot0003* UEFI: PXE IPv4 Marvell AQtion 10Gbit Network Adapter  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)0000424f
Boot0004  UEFI: HTTP IPv6 Marvell AQtion 10Gbit Network Adapter PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv6([::],0,Static,[::],[::],64)/Uri()0000424f
Boot0005* Generic Usb Device    VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0006* CD/DVD Device VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0007  Win VDI Boot  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)/Uri(https://download.lenovo.com/pccbbs/cdeploy/vdiboot/efi/vdi.efi)
Boot0008* UEFI: PXE IPv6 Marvell AQtion 10Gbit Network Adapter  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv6([::],0,Static,[::],[::],64)0000424f
Boot0009* UEFI: KingstonDataTraveler 3.0PMAP, Partition 2       PciRoot(0x0)/Pci(0x3,0x1)/Pci(0x0,0x0)/Pci(0x8,0x0)/Pci(0x0,0x1)/USB(7,0)/HD(2,GPT,9bea21dc-4f71-6934-996a-cdea67030e7b,0x6f6ffd8,0x10000)0000424f
Boot000A* Manjaro Linux HD(1,GPT,519fa53d-c862-4efb-948b-eee1a5d9c584,0x1000,0x96000)/\EFI\MANJARO\GRUBX64.EFI
Set boot order (example)
[manjaro user]# efibootmgr --bootorder 000A,0001,0000
BootCurrent: 000A
Timeout: 1 seconds
BootOrder: 000A,0001,0000
Potential issues with toolchain update due to glibc 2.42
Whenever the toolchain gets updated, your system more or less switches to new versions of low level basic system package, which can soft-brick your system when not updated properly.
A more static release model of the likes of Debian or Ubuntu, only update the toolchain with major release updates. With Arch and Manjaro, this happens more often without a major release announcement.
Kernels and other system relevant parts need to been updated when that happens. glibc is used by more than 4955 packages.
To add a safety net to your system, you can install pacman-static:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/pacman-static-7.0.0.r6.gc685ae6-8-x86_64.pkg.tar.xz
… and maintain the system as usual via sudo pacman-static -Syu, even when the regular pacman might trow glibc errors: With update I see glibc errors
phonon-qt5 and phonon-qt5-gstreamer packages got dropped to AUR
Those packages used to be in the repo, but they were dropped to the AUR because they’re still qt5-based and no longer required by any of the official packages — with the exception perhaps that they might be a dependency of something installed from the AUR.
2025-07-12
SDDM may crash with Nvidia drivers
In some case Nvidia drivers need the following workaround in /etc/environment to launch SDDM properly:
MESA_LOADER_DRIVER_OVERRIDE=zink
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command in order to downgrade the installed package with the higher version to the version currently in the repository… :point_down:
 sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins.
 sudo pacman -S vlc-plugins-all
linux-firmware-meta replaces linux-fimware
With the linux-firmware-meta package, all of the firmware is now split up into individual packages, which are all installed as dependencies of linux-firmware-meta.
If you wish to uninstall the firmware packages that you don’t need — e.g. linux-firmware-nvidia — including the meta package itself, then be sure to mark the firmware packages you wish to keep as explicitly installed, or else pacman will regard them as orphans, which would be dangerous when cleaning out your real orphans.
 sudo pacman -D --asexplicit <name-of-package(s)>
2025-06-23
Breaking changes to wine and wine-staging
Transition to the new WoW64 wine and wine-staging
2025-06-16
We are transitioning the wine and wine-staging package to a pure wow64 build. This change removes the dependency on the multilib repository for wine and wine-staging.
The main reason for this is to align with upstream Wine development, which simplifies packaging and the dependency chain.
Potential Issues:
  • OpenGL Performance: A known limitation of the new WoW64 mode is reduced performance for 32-bit applications that use OpenGL directly
  • Breaking Changes: Existing 32-bit prefixes needs to be recreated
    If you are facing issues with 32 bit prefixes, please recreate these and reinstall the application.
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduces a possible breaking change if you have custom scripts relying on the mirrors data file. If this is the case, then simply create a symlink from the new location under /var/lib back to the old location, i.e. /usr/share.
ln -s /var/lib/pacman-mirrors /usr/share/
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
avahi-discover python script may fail to discover services
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD – compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
Stable Updates
A couple of issues…:
  1. Lots of warnings regarding “no package information available for <name-of-package>”. These were all Breeze-related Plasma packages. But it did go well otherwise.
  2. My cursor theme was reset to Breeze cursors, but that was of course easily remedied.
  3. There a problem with the plasma-applet-window-buttons applet. Not only is it not working, but it shows as a strange icon in the panel, whereas it should normally be hidden unless the active window is maximized. :backhand_index_pointing_down:
    Clicking the applet yields the following error message… :backhand_index_pointing_down:
    file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:23:1:
    Cannot load library /usr/lib/qt6/qml/org/kde/appletdecoration/libappletdecorationplugin.so:
    libPlasma.so.7: cannot open shared object file: No such file or directory
[nx-74205:/dev/pts/5][/home/aragorn]
[aragorn] >  pacman -Qo /usr/lib/qt6/qml/org/kde/appletdecoration/libappletdecorationplugin.so
/usr/lib/qt6/qml/org/kde/appletdecoration/libappletdecorationplugin.so is owned by plasma-applet-window-buttons 0.14.0-3
[aragorn] >  pacman -Qi plasma-applet-window-buttons
Version         : 0.14.0-3
Description     : Plasma applet in order to show window buttons in your panels
Architecture    : x86_64
URL             : https://github.com/moodyhunter/applet-window-buttons6
Licenses        : GPL-2.0-or-later  LGPL-2.1-or-later
Groups          : None
Provides        : None
Depends On      : gcc-libs  glibc  kcolorscheme  kconfig  kcoreaddons  kdecoration  ki18n  kirigami  kitemmodels  ksvg  libplasma  plasma-workspace  qt6-base  qt6-declarative
Optional Deps   : None
Required By     : None
Optional For    : None
Conflicts With  : plasma5-applets-window-buttons
Replaces        : plasma5-applets-window-buttons
Installed Size  : 400.36 KiB
Packager        : Antonio Rojas <arojas@archlinux.org>
Build Date      : Tue 24 Feb 2026 23:22:40 CET
Install Date    : Mon 23 Mar 2026 23:18:13 CET
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
[nx-74205:/dev/pts/6][/home/aragorn]
[aragorn] >  pacman -Qi libplasma
Version         : 6.5.6-1
Description     : Plasma library and runtime components
URL             : https://kde.org/plasma-desktop/
Licenses        : LGPL-2.0-or-later
Groups          : plasma
Provides        : None
Depends On      : gcc-libs  glibc  plasma-activities  kcolorscheme  kconfig  kcoreaddons  kglobalaccel  kguiaddons  ki18n  kiconthemes  kio  kirigami  knotifications  kpackage  ksvg  kwidgetsaddons  kwindowsystem  libglvnd  libx11
                  libxcb  qt6-5compat  qt6-base  qt6-declarative  wayland
Required By     : bluedevil  kdeplasma-addons  knights  kscreen  kscreenlocker  kwin  milou  plasma-applet-window-buttons  plasma-desktop  plasma-login-manager  plasma-nm  plasma-pa  plasma-vault  plasma-workspace  powerdevil
                  print-manager
Optional For    : None
Conflicts With  : plasma-framework
Replaces        : plasma-framework
Installed Size  : 6.68 MiB
Packager        : Manjaro Build Server <build@manjaro.org>
Build Date      : Wed 11 Mar 2026 16:08:35 CET
Install Date    : Mon 23 Mar 2026 23:17:53 CET
Install Reason  : Installed as a dependency for another package
Install Script  : No
[aragorn] >  locate -i libPlasma.so.7
[aragorn] >  ls -l /usr/lib/libPlasma.*
lrwxrwxrwx 1 root root     14 Mar 11 16:08 /usr/lib/libPlasma.so -> libPlasma.so.6
lrwxrwxrwx 1 root root     18 Mar 11 16:08 /usr/lib/libPlasma.so.6 -> libPlasma.so.6.5.6
-rwxr-xr-x 1 root root 395104 Mar 11 16:08 /usr/lib/libPlasma.so.6.5.6
[aragorn] >  pacman -Qk libplasma
libplasma: 542 total files, 0 missing files
[aragorn] >   pacman -Ql libplasma
libplasma /usr/
libplasma /usr/include/
libplasma /usr/include/Plasma/
libplasma /usr/include/Plasma/Plasma/
libplasma /usr/include/Plasma/Plasma/Applet
libplasma /usr/include/Plasma/Plasma/Containment
libplasma /usr/include/Plasma/Plasma/ContainmentActions
libplasma /usr/include/Plasma/Plasma/Corona
libplasma /usr/include/Plasma/Plasma/Plasma
libplasma /usr/include/Plasma/Plasma/PluginLoader
libplasma /usr/include/Plasma/Plasma/Theme
libplasma /usr/include/Plasma/plasma/
libplasma /usr/include/Plasma/plasma/applet.h
libplasma /usr/include/Plasma/plasma/containment.h
libplasma /usr/include/Plasma/plasma/containmentactions.h
libplasma /usr/include/Plasma/plasma/corona.h
libplasma /usr/include/Plasma/plasma/plasma.h
libplasma /usr/include/Plasma/plasma/plasma_export.h
libplasma /usr/include/Plasma/plasma/pluginloader.h
libplasma /usr/include/Plasma/plasma/theme.h
libplasma /usr/include/Plasma/plasma_version.h
libplasma /usr/include/PlasmaQuick/
libplasma /usr/include/PlasmaQuick/PlasmaQuick/
libplasma /usr/include/PlasmaQuick/PlasmaQuick/AppletPopup
libplasma /usr/include/PlasmaQuick/PlasmaQuick/AppletQuickItem
libplasma /usr/include/PlasmaQuick/PlasmaQuick/ConfigModel
libplasma /usr/include/PlasmaQuick/PlasmaQuick/ConfigView
libplasma /usr/include/PlasmaQuick/PlasmaQuick/ContainmentView
libplasma /usr/include/PlasmaQuick/PlasmaQuick/Dialog
libplasma /usr/include/PlasmaQuick/PlasmaQuick/PlasmaShellWaylandIntegration
libplasma /usr/include/PlasmaQuick/PlasmaQuick/PlasmaWindow
libplasma /usr/include/PlasmaQuick/PlasmaQuick/PopupPlasmaWindow
libplasma /usr/include/PlasmaQuick/PlasmaQuick/QuickViewSharedEngine
libplasma /usr/include/PlasmaQuick/PlasmaQuick/SharedQmlEngine
libplasma /usr/include/PlasmaQuick/plasmaquick/
libplasma /usr/include/PlasmaQuick/plasmaquick/appletpopup.h
libplasma /usr/include/PlasmaQuick/plasmaquick/appletquickitem.h
libplasma /usr/include/PlasmaQuick/plasmaquick/configmodel.h
libplasma /usr/include/PlasmaQuick/plasmaquick/configview.h
libplasma /usr/include/PlasmaQuick/plasmaquick/containmentview.h
libplasma /usr/include/PlasmaQuick/plasmaquick/dialog.h
libplasma /usr/include/PlasmaQuick/plasmaquick/plasmaquick_export.h
libplasma /usr/include/PlasmaQuick/plasmaquick/plasmashellwaylandintegration.h
libplasma /usr/include/PlasmaQuick/plasmaquick/plasmawindow.h
libplasma /usr/include/PlasmaQuick/plasmaquick/popupplasmawindow.h
libplasma /usr/include/PlasmaQuick/plasmaquick/quickviewsharedengine.h
libplasma /usr/include/PlasmaQuick/plasmaquick/sharedqmlengine.h
libplasma /usr/lib/
libplasma /usr/lib/cmake/
libplasma /usr/lib/cmake/Plasma/
libplasma /usr/lib/cmake/Plasma/PlasmaConfig.cmake
libplasma /usr/lib/cmake/Plasma/PlasmaConfigVersion.cmake
libplasma /usr/lib/cmake/Plasma/PlasmaMacros.cmake
libplasma /usr/lib/cmake/Plasma/PlasmaTargets-noconfig.cmake
libplasma /usr/lib/cmake/Plasma/PlasmaTargets.cmake
libplasma /usr/lib/cmake/PlasmaQuick/
libplasma /usr/lib/cmake/PlasmaQuick/PlasmaQuickConfig.cmake
libplasma /usr/lib/cmake/PlasmaQuick/PlasmaQuickConfigVersion.cmake
libplasma /usr/lib/cmake/PlasmaQuick/PlasmaQuickTargets-noconfig.cmake
libplasma /usr/lib/cmake/PlasmaQuick/PlasmaQuickTargets.cmake
libplasma /usr/lib/libPlasma.so
libplasma /usr/lib/libPlasma.so.6
libplasma /usr/lib/libPlasma.so.6.5.6
libplasma /usr/lib/libPlasmaQuick.so
libplasma /usr/lib/libPlasmaQuick.so.6
libplasma /usr/lib/libPlasmaQuick.so.6.5.6
libplasma /usr/lib/qt6/
libplasma /usr/lib/qt6/plugins/
libplasma /usr/lib/qt6/plugins/kf6/
libplasma /usr/lib/qt6/plugins/kf6/kirigami/
libplasma /usr/lib/qt6/plugins/kf6/kirigami/platform/
libplasma /usr/lib/qt6/plugins/kf6/kirigami/platform/KirigamiPlasmaStyle.so
libplasma /usr/lib/qt6/plugins/kf6/packagestructure/
libplasma /usr/lib/qt6/plugins/kf6/packagestructure/plasma_applet.so
libplasma /usr/lib/qt6/plugins/kf6/packagestructure/plasma_containmentactions.so
libplasma /usr/lib/qt6/plugins/kf6/packagestructure/plasma_generic.so
libplasma /usr/lib/qt6/plugins/kf6/packagestructure/plasma_shell.so
libplasma /usr/lib/qt6/plugins/kf6/packagestructure/plasma_theme.so
libplasma /usr/lib/qt6/plugins/kf6/packagestructure/plasma_wallpaper.so
libplasma /usr/lib/qt6/qml/
libplasma /usr/lib/qt6/qml/org/
libplasma /usr/lib/qt6/qml/org/kde/
libplasma /usr/lib/qt6/qml/org/kde/kirigami/
libplasma /usr/lib/qt6/qml/org/kde/kirigami/styles/
libplasma /usr/lib/qt6/qml/org/kde/kirigami/styles/Plasma/
libplasma /usr/lib/qt6/qml/org/kde/kirigami/styles/Plasma/AbstractApplicationHeader.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/AbstractButton.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/BusyIndicator.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Button.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/CheckBox.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/CheckDelegate.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/CheckIndicator.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ComboBox.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Container.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Control.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Dial.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Dialog.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/DialogButtonBox.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Drawer.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Frame.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/GroupBox.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ItemDelegate.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Label.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Menu.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/MenuItem.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/MenuSeparator.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Page.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/PageIndicator.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Pane.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Popup.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ProgressBar.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/RadioButton.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/RadioDelegate.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/RadioIndicator.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/RangeSlider.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/RoundButton.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ScrollBar.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ScrollView.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Slider.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/SpinBox.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/StackView.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/SwipeView.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/Switch.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/SwitchDelegate.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/SwitchIndicator.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/TabBar.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/TabButton.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/TextArea.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/TextField.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ToolBar.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ToolButton.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/ToolTip.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/kde-qmlmodule.version
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/liborg_kde_plasmacomponents3.so
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/mobiletextselection/
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/mobiletextselection/MobileCursor.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/mobiletextselection/MobileTextActionsToolBar.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/mobiletextselection/MobileTextActionsToolBarImpl.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/mobiletextselection/qmldir
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/org_kde_plasmacomponents3.qmltypes
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/ButtonBackground.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/ButtonContent.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/ButtonFocus.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/ButtonHover.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/ButtonShadow.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/DefaultListItemBackground.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/FlatButtonBackground.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/IconLabel.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/RaisedButtonBackground.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/RoundShadow.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/private/TextFieldFocus.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/components/qmldir
libplasma /usr/lib/qt6/qml/org/kde/plasma/configuration/
libplasma /usr/lib/qt6/qml/org/kde/plasma/configuration/kde-qmlmodule.version
libplasma /usr/lib/qt6/qml/org/kde/plasma/configuration/libplasmaconfigplugin.so
libplasma /usr/lib/qt6/qml/org/kde/plasma/configuration/plasmaconfigplugin.qmltypes
libplasma /usr/lib/qt6/qml/org/kde/plasma/configuration/qmldir
libplasma /usr/lib/qt6/qml/org/kde/plasma/core/
libplasma /usr/lib/qt6/qml/org/kde/plasma/core/DefaultToolTip.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/core/DialogBackground.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/core/corebindingsplugin.qmltypes
libplasma /usr/lib/qt6/qml/org/kde/plasma/core/kde-qmlmodule.version
libplasma /usr/lib/qt6/qml/org/kde/plasma/core/libcorebindingsplugin.so
libplasma /usr/lib/qt6/qml/org/kde/plasma/core/qmldir
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/ActionTextField.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/BasicPlasmoidHeading.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/DescriptiveLabel.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/ExpandableListItem.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/Heading.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/Highlight.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/ListItem.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/ListSectionHeader.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/ModelContextMenu.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/PasswordField.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/PlaceholderMessage.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/PlasmoidHeading.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/Representation.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/SearchField.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/ShadowedLabel.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/animations/
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/animations/ActivateAnimation.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/animations/AppearAnimation.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/animations/DisappearAnimation.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/animations/PressedAnimation.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/animations/ReleasedAnimation.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/kde-qmlmodule.version
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/libplasmaextracomponentsplugin.so
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/plasmaextracomponentsplugin.qmltypes
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/private/
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/private/BackgroundMetrics.qml
libplasma /usr/lib/qt6/qml/org/kde/plasma/extras/qmldir
libplasma /usr/lib/qt6/qml/org/kde/plasma/plasmoid/
libplasma /usr/lib/qt6/qml/org/kde/plasma/plasmoid/kde-qmlmodule.version
libplasma /usr/lib/qt6/qml/org/kde/plasma/plasmoid/libplasmoidplugin.so
libplasma /usr/lib/qt6/qml/org/kde/plasma/plasmoid/plasmoidplugin.qmltypes
libplasma /usr/lib/qt6/qml/org/kde/plasma/plasmoid/qmldir
libplasma /usr/share/
libplasma /usr/share/kdevappwizard/
libplasma /usr/share/kdevappwizard/templates/
libplasma /usr/share/kdevappwizard/templates/cpp-plasmoid6.tar.bz2
libplasma /usr/share/kdevappwizard/templates/plasma6-wallpaper-with-qml-extension.tar.bz2
libplasma /usr/share/kdevappwizard/templates/plasma6-wallpaper.tar.bz2
libplasma /usr/share/kdevappwizard/templates/qml-plasmoid6.tar.bz2
libplasma /usr/share/locale/
libplasma /usr/share/locale/ar/
libplasma /usr/share/locale/ar/LC_MESSAGES/
libplasma /usr/share/locale/ar/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ast/
libplasma /usr/share/locale/ast/LC_MESSAGES/
libplasma /usr/share/locale/ast/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/az/
libplasma /usr/share/locale/az/LC_MESSAGES/
libplasma /usr/share/locale/az/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/be/
libplasma /usr/share/locale/be/LC_MESSAGES/
libplasma /usr/share/locale/be/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/bg/
libplasma /usr/share/locale/bg/LC_MESSAGES/
libplasma /usr/share/locale/bg/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/bs/
libplasma /usr/share/locale/bs/LC_MESSAGES/
libplasma /usr/share/locale/bs/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ca/
libplasma /usr/share/locale/ca/LC_MESSAGES/
libplasma /usr/share/locale/ca/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ca@valencia/
libplasma /usr/share/locale/ca@valencia/LC_MESSAGES/
libplasma /usr/share/locale/ca@valencia/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/cs/
libplasma /usr/share/locale/cs/LC_MESSAGES/
libplasma /usr/share/locale/cs/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/da/
libplasma /usr/share/locale/da/LC_MESSAGES/
libplasma /usr/share/locale/da/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/de/
libplasma /usr/share/locale/de/LC_MESSAGES/
libplasma /usr/share/locale/de/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/el/
libplasma /usr/share/locale/el/LC_MESSAGES/
libplasma /usr/share/locale/el/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/en_GB/
libplasma /usr/share/locale/en_GB/LC_MESSAGES/
libplasma /usr/share/locale/en_GB/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/eo/
libplasma /usr/share/locale/eo/LC_MESSAGES/
libplasma /usr/share/locale/eo/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/es/
libplasma /usr/share/locale/es/LC_MESSAGES/
libplasma /usr/share/locale/es/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/et/
libplasma /usr/share/locale/et/LC_MESSAGES/
libplasma /usr/share/locale/et/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/eu/
libplasma /usr/share/locale/eu/LC_MESSAGES/
libplasma /usr/share/locale/eu/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/fi/
libplasma /usr/share/locale/fi/LC_MESSAGES/
libplasma /usr/share/locale/fi/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/fr/
libplasma /usr/share/locale/fr/LC_MESSAGES/
libplasma /usr/share/locale/fr/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ga/
libplasma /usr/share/locale/ga/LC_MESSAGES/
libplasma /usr/share/locale/ga/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/gd/
libplasma /usr/share/locale/gd/LC_MESSAGES/
libplasma /usr/share/locale/gd/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/gl/
libplasma /usr/share/locale/gl/LC_MESSAGES/
libplasma /usr/share/locale/gl/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/he/
libplasma /usr/share/locale/he/LC_MESSAGES/
libplasma /usr/share/locale/he/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/hi/
libplasma /usr/share/locale/hi/LC_MESSAGES/
libplasma /usr/share/locale/hi/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/hu/
libplasma /usr/share/locale/hu/LC_MESSAGES/
libplasma /usr/share/locale/hu/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ia/
libplasma /usr/share/locale/ia/LC_MESSAGES/
libplasma /usr/share/locale/ia/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/id/
libplasma /usr/share/locale/id/LC_MESSAGES/
libplasma /usr/share/locale/id/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/is/
libplasma /usr/share/locale/is/LC_MESSAGES/
libplasma /usr/share/locale/is/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/it/
libplasma /usr/share/locale/it/LC_MESSAGES/
libplasma /usr/share/locale/it/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ja/
libplasma /usr/share/locale/ja/LC_MESSAGES/
libplasma /usr/share/locale/ja/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ka/
libplasma /usr/share/locale/ka/LC_MESSAGES/
libplasma /usr/share/locale/ka/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ko/
libplasma /usr/share/locale/ko/LC_MESSAGES/
libplasma /usr/share/locale/ko/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/lt/
libplasma /usr/share/locale/lt/LC_MESSAGES/
libplasma /usr/share/locale/lt/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/lv/
libplasma /usr/share/locale/lv/LC_MESSAGES/
libplasma /usr/share/locale/lv/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ml/
libplasma /usr/share/locale/ml/LC_MESSAGES/
libplasma /usr/share/locale/ml/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/mr/
libplasma /usr/share/locale/mr/LC_MESSAGES/
libplasma /usr/share/locale/mr/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/nb/
libplasma /usr/share/locale/nb/LC_MESSAGES/
libplasma /usr/share/locale/nb/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/nds/
libplasma /usr/share/locale/nds/LC_MESSAGES/
libplasma /usr/share/locale/nds/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/nl/
libplasma /usr/share/locale/nl/LC_MESSAGES/
libplasma /usr/share/locale/nl/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/nn/
libplasma /usr/share/locale/nn/LC_MESSAGES/
libplasma /usr/share/locale/nn/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/pa/
libplasma /usr/share/locale/pa/LC_MESSAGES/
libplasma /usr/share/locale/pa/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/pl/
libplasma /usr/share/locale/pl/LC_MESSAGES/
libplasma /usr/share/locale/pl/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/pt/
libplasma /usr/share/locale/pt/LC_MESSAGES/
libplasma /usr/share/locale/pt/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/pt_BR/
libplasma /usr/share/locale/pt_BR/LC_MESSAGES/
libplasma /usr/share/locale/pt_BR/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ro/
libplasma /usr/share/locale/ro/LC_MESSAGES/
libplasma /usr/share/locale/ro/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ru/
libplasma /usr/share/locale/ru/LC_MESSAGES/
libplasma /usr/share/locale/ru/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sa/
libplasma /usr/share/locale/sa/LC_MESSAGES/
libplasma /usr/share/locale/sa/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sk/
libplasma /usr/share/locale/sk/LC_MESSAGES/
libplasma /usr/share/locale/sk/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sl/
libplasma /usr/share/locale/sl/LC_MESSAGES/
libplasma /usr/share/locale/sl/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sr/
libplasma /usr/share/locale/sr/LC_MESSAGES/
libplasma /usr/share/locale/sr/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sr@ijekavian/
libplasma /usr/share/locale/sr@ijekavian/LC_MESSAGES/
libplasma /usr/share/locale/sr@ijekavian/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sr@ijekavianlatin/
libplasma /usr/share/locale/sr@ijekavianlatin/LC_MESSAGES/
libplasma /usr/share/locale/sr@ijekavianlatin/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sr@latin/
libplasma /usr/share/locale/sr@latin/LC_MESSAGES/
libplasma /usr/share/locale/sr@latin/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/sv/
libplasma /usr/share/locale/sv/LC_MESSAGES/
libplasma /usr/share/locale/sv/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ta/
libplasma /usr/share/locale/ta/LC_MESSAGES/
libplasma /usr/share/locale/ta/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/tg/
libplasma /usr/share/locale/tg/LC_MESSAGES/
libplasma /usr/share/locale/tg/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/tr/
libplasma /usr/share/locale/tr/LC_MESSAGES/
libplasma /usr/share/locale/tr/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/ug/
libplasma /usr/share/locale/ug/LC_MESSAGES/
libplasma /usr/share/locale/ug/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/uk/
libplasma /usr/share/locale/uk/LC_MESSAGES/
libplasma /usr/share/locale/uk/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/vi/
libplasma /usr/share/locale/vi/LC_MESSAGES/
libplasma /usr/share/locale/vi/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/zh_CN/
libplasma /usr/share/locale/zh_CN/LC_MESSAGES/
libplasma /usr/share/locale/zh_CN/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/locale/zh_TW/
libplasma /usr/share/locale/zh_TW/LC_MESSAGES/
libplasma /usr/share/locale/zh_TW/LC_MESSAGES/libplasma6.mo
libplasma /usr/share/plasma/
libplasma /usr/share/plasma/desktoptheme/
libplasma /usr/share/plasma/desktoptheme/breeze-dark/
libplasma /usr/share/plasma/desktoptheme/breeze-dark/colors
libplasma /usr/share/plasma/desktoptheme/breeze-dark/metadata.json
libplasma /usr/share/plasma/desktoptheme/breeze-dark/plasmarc
libplasma /usr/share/plasma/desktoptheme/breeze-light/
libplasma /usr/share/plasma/desktoptheme/breeze-light/colors
libplasma /usr/share/plasma/desktoptheme/breeze-light/metadata.json
libplasma /usr/share/plasma/desktoptheme/breeze-light/plasmarc
libplasma /usr/share/plasma/desktoptheme/default/
libplasma /usr/share/plasma/desktoptheme/default/dialogs/
libplasma /usr/share/plasma/desktoptheme/default/dialogs/background.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/
libplasma /usr/share/plasma/desktoptheme/default/icons/akonadi.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/akregator.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/amarok.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/applications.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/apport.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/audio.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/battery.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/bookmarks.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/cantata.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/computer.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/configure.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/device.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/disk.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/distribute.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/document.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/drive.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/edit.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/fcitx.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/go.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/ime.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/input.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kalarm.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kdeconnect.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/keyboard.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kget.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kgpg.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kleopatra.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/klipper.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kmail.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/konv_message.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/konversation.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kopete.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/korgac.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kpackagekit.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kruler.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kteatime.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/ktorrent.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/kup.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/list.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/mail.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/media.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/mobile.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/network.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/notification.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/osd.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/phone.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/plasmavault.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/plasmavault_error.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/preferences.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/printer.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/quassel.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/search.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/slc.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/software.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/start.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/system.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/touchpad.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/user.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/video-card.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/video.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/view.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/vlc.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/wallet.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/window.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/yakuake.svgz
libplasma /usr/share/plasma/desktoptheme/default/icons/zoom.svgz
libplasma /usr/share/plasma/desktoptheme/default/metadata.json
libplasma /usr/share/plasma/desktoptheme/default/opaque/
libplasma /usr/share/plasma/desktoptheme/default/opaque/dialogs/
libplasma /usr/share/plasma/desktoptheme/default/opaque/dialogs/background.svgz
libplasma /usr/share/plasma/desktoptheme/default/opaque/widgets/
libplasma /usr/share/plasma/desktoptheme/default/opaque/widgets/panel-background.svgz
libplasma /usr/share/plasma/desktoptheme/default/opaque/widgets/tooltip.svgz
libplasma /usr/share/plasma/desktoptheme/default/plasmarc
libplasma /usr/share/plasma/desktoptheme/default/solid/
libplasma /usr/share/plasma/desktoptheme/default/solid/dialogs/
libplasma /usr/share/plasma/desktoptheme/default/solid/dialogs/background.svgz
libplasma /usr/share/plasma/desktoptheme/default/solid/widgets/
libplasma /usr/share/plasma/desktoptheme/default/solid/widgets/background.svgz
libplasma /usr/share/plasma/desktoptheme/default/solid/widgets/panel-background.svgz
libplasma /usr/share/plasma/desktoptheme/default/solid/widgets/tooltip.svgz
libplasma /usr/share/plasma/desktoptheme/default/translucent/
libplasma /usr/share/plasma/desktoptheme/default/translucent/dialogs/
libplasma /usr/share/plasma/desktoptheme/default/translucent/dialogs/background.svgz
libplasma /usr/share/plasma/desktoptheme/default/translucent/widgets/
libplasma /usr/share/plasma/desktoptheme/default/translucent/widgets/background.svgz
libplasma /usr/share/plasma/desktoptheme/default/translucent/widgets/panel-background.svgz
libplasma /usr/share/plasma/desktoptheme/default/translucent/widgets/tooltip.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/
libplasma /usr/share/plasma/desktoptheme/default/widgets/action-overlays.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/actionbutton.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/analog_meter.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/arrows.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/background.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/bar_meter_horizontal.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/bar_meter_vertical.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/branding.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/busywidget.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/button.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/calendar.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/checkmarks.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/clock.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/configuration-icons.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/containment-controls.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/dragger.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/frame.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/glowbar.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/line.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/lineedit.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/listitem.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/margins-highlight.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/media-delegate.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/menubaritem.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/monitor.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/notes.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/pager.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/panel-background.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/picker.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/plasmoidheading.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/plot-background.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/radiobutton.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/scrollbar.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/scrollwidget.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/slider.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/switch.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/tabbar.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/tasks.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/toolbar.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/tooltip.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/translucentbackground.svgz
libplasma /usr/share/plasma/desktoptheme/default/widgets/viewitem.svgz
libplasma /usr/share/qlogging-categories6/
libplasma /usr/share/qlogging-categories6/plasma-framework.categories
libplasma /usr/share/qlogging-categories6/plasma-framework.renamecategories
Great to see a new Manjaro stable release! :blush:
Is this a typo or are both Systemd versions available?
I was hoping to switch to the 580 series again (good to see that it’s still getting updates) since i’m on a GTX970 - will there be added support by mhwd for it in the future? or is there another way that I can install this? (if it’s recommended to do so)
Is there a way to fix this via manual intervention or is this a plasma bug that will be fixed in a future release? Or might we have a second stable update that addresses this issue?
It’s a typo. The version on your system should be 259.5-1.
It looks like a packaging error to me. plasma-applet-window-buttons is looking for /usr/lib/libPlasma.so.7 but the version installed today is /usr/lib/libPlasma.so.6.5.6.
I was trying to do the “best practices” by removing my alien packages before the upgrade, but I keep getting a could not satisfy dependencies error, “removing kdsoap-qt6 breaks dependency ‘kdsoap-qt6’ required by kdsoap-ws-discovery-client”. I did some research and ran pacman -Qi kdsoap-ws-discovery-client and saw it’s required by kio-extras, which in turn, is apparently required by Dolphin and the Plasma workspace. I assume I shouldn’t remove those, should I just manually remove the others that I can remove before upgrading?
Interesting…
I’ve just completed the update on the Starlite Tablet, running Plasma, noticed no issues. Using Octopi with ‘Use Terminal for Updates’ set. The update went almost unnoticed.
We will see how my partner’s update goes on the Lenovo.
The File Server updated OK. but it took 2 attempts.
sudo pacman -Syu
The first attempt failed with, a packages missing error. Probably a local issue, as we sometimes have Starlink dropouts.
You need to replace the foreign (AUR?) kdsoap-qt6 package on your system with kdsoap from the extra repo.
The kdsoap package in the repos provides kdsoap-qt6, which will satisfy the dependency requirement of kdsoap-ws-discovery-client & kio-extras:
pamac info kdsoap
Version               : 2.3.0-1
Description           : Qt-based client-side and server-side SOAP component
URL                   : https://github.com/KDAB/KDSoap
Licenses              : GPL-3.0-or-later
Repository            : extra
Installed Size        : 1.4 MB
Groups                : --
Depends On            : glibc libgcc libstdc++ qt6-base
Optional Dependencies : --
Required By           : kdsoap-ws-discovery-client kio-extras
Optional For          : --
Provides              : kdsoap-qt6
Replaces              : kdsoap-qt6
Conflicts With        : kdsoap-qt6
Build Date            : Mon 16 Mar 2026 05:38:56
Install Date          : Tue 17 Mar 2026 08:16:01
Backup files          : --
Note: I am on Testing, not Stable branch, but the kdsoap package is the same version in all Manjaro branches
Ah I’m not sure how it ended up as a foreign package, kdsoap-ws-discovery-client seems to be installed via extra. How would I replace it properly/safely?
You might need to do it separately before the rest of the update:
sudo pacman -S kdsoap
or, to ensure your databases are synced first (if you haven’t already synced them):
sudo pacman -Sy kdsoap
The update went smoothly through pamac-manager, the kdsoap package replaced the kdsoap-qt6 package, and I don’t remember where I installed it or what it was for, but it doesn’t matter anymore. I also tried the 7.0 kernel, and everything works perfectly. Special thanks for mesa 26, I’ve been waiting for it for a long time))
KDE Plasma Version: 6.5.6
KDE Frameworks Version: 6.24.0
Qt Version: 6.10.2
Kernel Version: 7.0.0-rc4-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 3600 6-Core Processor
Memory: 16 ГиБ of RAM (15.5 ГиБ usable)
Graphics Processor: AMD Radeon RX 580 Series
Product Name: A520M Pro4
I guess we’ve found the “bug” with removing foreign packages before doing an update. A package may become foreign if it is removed from the repos and replaced by another package (in this case, kdsoap-qt6 was removed from the repos & replaced by kdsoap):
The change happened automatically on my Testing branch system in last week’s update:
paclog --grep=kdsoap
[2023-11-13T14:31:01+1100] [ALPM] removed kdsoap (2.1.1-1)
[2023-11-13T14:31:01+1100] [ALPM] installed kdsoap-qt5 (2.1.1-2)
[2023-11-13T14:31:04+1100] [ALPM] installed kdsoap-qt6 (2.1.1-2)
[2023-11-13T14:31:04+1100] [ALPM] upgraded kdsoap-ws-discovery-client (git20200927-2 -> 0.3.0-2)
[2024-01-13T13:30:38+1100] [ALPM] upgraded kdsoap-qt5 (2.1.1-2 -> 2.2.0-1)
[2024-01-13T13:30:38+1100] [ALPM] upgraded kdsoap-qt6 (2.1.1-2 -> 2.2.0-1)
[2024-03-06T20:38:01+1100] [ALPM] upgraded kdsoap-ws-discovery-client (0.3.0-2 -> 0.4.0-1)
[2024-05-19T10:27:20+1000] [ALPM] removed kdsoap-qt5 (2.2.0-1)
[2025-11-06T19:09:39+1100] [ALPM] upgraded kdsoap-ws-discovery-client (0.4.0-1 -> 0.4.0-2)
[2026-03-17T08:15:53+1100] [ALPM] removed kdsoap-qt6 (2.2.0-1)
[2026-03-17T08:16:01+1100] [ALPM] installed kdsoap (2.3.0-1)
[2026-03-17T08:16:01+1100] [ALPM] upgraded kdsoap-ws-discovery-client (0.4.0-2 -> 0.4.0-3)
I’ve found that best practice is to just update the system packages first (sudo pacman -Syu or pamac update --no-aur).
After that is done, foreign packages can then be updated/removed/checked etc.
Attempting to remove system packages that have been removed from the repos or renamed before their replacements have been installed via the system update can cause dependency issues.
Due to upgpkg: 0.14.0-3: Plasma 6.6.1 rebuild (eb1da393) · Commits · Arch Linux / Packaging / Packages / plasma-applet-window-buttons · GitLab. Downgrading to revision 2 fixes it …
After update, I’ve stumbled upon a little hiccup with Bluetooth headphones and EasyEffects. After reboot, audio output was crackling, but after turn off/on (in GUI) its working again as it should.
ISOs including this update are ready for review: Release 202603240936 · manjaro/release-review · GitHub Report any issues with them you may find …
Mesa is mentioned twice
In light of the situation discussed in the ‘Manjaro 2.0 Manifesto’ thread and the news about a developer strike, I’m concerned about the stability of the system. Is it safe to update right now? I rely on Manjaro KDE for my daily work and would like to avoid any sudden breakages.
I apologize if I have violated the rules of this section of the forum in any way. Thank you for your work.
I just updated my system (also Manjaro KDE) and no issue as far as I can tell.
Updated OK but seems like mirror.23m.com (used for mattermost app) is down. Fixed by updating the mirrors sudo pacman-mirrors -a -B stable -c <country>
Not a bug or problem as such, but possibly a poor policy decision.
pacman -Qi kwin
Optional Deps   : maliit-keyboard: virtual keyboard
When I check around maliit-keyboard is an AUR package. IMHO: AUR packages should not normally be listed as optional dependencies.
