A post was split to a new topic: Rsync problem after Stable Update 2023.08.29
The most recent update worked flawlessly on my other 2 computers as expected but sadly my Laptop crashed during the update
Now i cant upgrade past kernel 6.3
Im pretty sure i was running 6.4 without issues but i cant 100% confirm
Whenever i install something with
pamac install
i get
ldconfig: File /usr/lib/libpmix.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_sm.so.40 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_ompio.so.41 is empty, not checked.
ldconfig: File /usr/lib/libReviewboardHelpers.so.5.109.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PurposeWidgets.so.5.109.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi.so.40.30.5 is empty, not checked.
ldconfig: File /usr/lib/libompitrace.so.40 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_mpifh.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_ompio.so.41.29.4 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_monitoring.so.50 is empty, not checked.
ldconfig: File /usr/lib/libompitrace.so is empty, not checked.
ldconfig: File /usr/lib/libkaccounts.so.23.08.0 is empty, not checked.
ldconfig: File /usr/lib/libompitrace.so.40.30.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5WebEngineWidgets.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libharfbuzz-icu.so.0 is empty, not checked.
ldconfig: file /usr/lib/libQt5WebEngineCore.so is truncated
ldconfig: File /usr/lib/libKF5PurposeWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libharfbuzz-icu.so.0.60811.0 is empty, not checked.
ldconfig: file /usr/lib/libQt5WebEngineCore.so.5.15 is truncated
ldconfig: File /usr/lib/libmpi_mpifh.so.40 is empty, not checked.
ldconfig: File /usr/lib/libgwenviewlib.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Purpose.so.5.109.0 is empty, not checked.
ldconfig: File /usr/lib/libpmix.so.2 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so.40 is empty, not checked.
ldconfig: File /usr/lib/libPhabricatorHelpers.so.5 is empty, not checked.
ldconfig: file /usr/lib/libgtk-4.so.1 is truncated
ldconfig: File /usr/lib/libmpi.so.40 is empty, not checked.
ldconfig: File /usr/lib/libopen-pal.so.40.30.3 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempif08.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_cuda.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5WebEngineWidgets.so.5.15.14 is empty, not checked.
ldconfig: File /usr/lib/libQt5WebEngineWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libKF5PurposeWidgets.so.5 is empty, not checked.
ldconfig: file /usr/lib/libgtkmm-3.0.so.1.1.0 is truncated
ldconfig: File /usr/lib/libkaccounts.so is empty, not checked.
ldconfig: File /usr/lib/libmpi_mpifh.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_sm.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_cxx.so.40.30.1 is empty, not checked.
ldconfig: File /usr/lib/libKF5Purpose.so is empty, not checked.
ldconfig: File /usr/lib/libopen-rte.so.40.30.3 is empty, not checked.
ldconfig: File /usr/lib/libharfbuzz-icu.so is empty, not checked.
ldconfig: file /usr/lib/libgtk-4.so.1.1200.1 is truncated
ldconfig: File /usr/lib/libmpi.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_cuda.so is empty, not checked.
ldconfig: file /usr/lib/libQt5WebEngineCore.so.5 is truncated
ldconfig: File /usr/lib/libmca_common_monitoring.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Purpose.so.5 is empty, not checked.
ldconfig: File /usr/lib/libReviewboardHelpers.so.5 is empty, not checked.
ldconfig: File /usr/lib/libpmix.so.2.9.1 is empty, not checked.
ldconfig: File /usr/lib/libmpi_cxx.so.40 is empty, not checked.
ldconfig: file /usr/lib/libQt5WebEngineCore.so.5.15.14 is truncated
ldconfig: File /usr/lib/libmca_common_sm.so is empty, not checked.
ldconfig: file /usr/lib/libgtkmm-3.0.so.1 is truncated
ldconfig: File /usr/lib/libPhabricatorHelpers.so.5.109.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_cxx.so is empty, not checked.
ldconfig: File /usr/lib/libopen-rte.so is empty, not checked.
ldconfig: File /usr/lib/libkaccounts.so.2 is empty, not checked.
ldconfig: File /usr/lib/libopen-rte.so.40 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_cuda.so.40 is empty, not checked.
ldconfig: File /usr/lib/libgwenviewlib.so.4.97.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempif08.so.40 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_monitoring.so.50.20.0 is empty, not checked.
ldconfig: file /usr/lib/libgtk-4.so is truncated
ldconfig: File /usr/lib/libopen-pal.so.40 is empty, not checked.
ldconfig: file /usr/lib/libgtkmm-3.0.so is truncated
ldconfig: File /usr/lib/libQt5WebEngineWidgets.so.5 is empty, not checked.
ldconfig: File /usr/lib/libopen-pal.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_ompio.so is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempif08.so is empty, not checked.
but the package still installs
I cant boot kernel 6.4 or 6.5
I tried to
boot off usb
connect to internet
manjaro-chroot
sudo mhwd-kernel -i linux64 linux65
but it still didnt fix the problem
I dont want to lose my 3 year old install but it is what it is, let me know
Thanks in advance
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Two people reporting crashes in thunderbird 115.2.0 when accessing remote calendars. ![]()
It appears to be the same issue.
remove the kernel parameter. 6.5 introduced new thermal handling, and although your kernel parameter should not be causing the issue, it is unnecessary.
run sudo ldconfig, it should return nothing. If not, post the output.
Tip: Linking a users profile does nothing. However, tagging them does: @varikonniemi
2 posts were split to a new topic: Zfs support for linux 6.5
This worked until a reboot, but it seems that NetworkManager overwrites /etc/resolv.conf on every boot since this update. Can anyone suggest a more idiomatic fix than chattr +i?
Add file /etc/NetworkManager/conf.d/99-rc-manager-unmanaged:
[main]
rc-manager=unmanaged
Please see man NetworkManager.conf for details.
You should probably reboot after this.
3 posts were split to a new topic: Manjaro keeps on bugging me about needing a kernel upgrade
works fine if stick with kernel 6.4.12
but it goes “black screen” if switch to 6.5.0 (after entering password on login screen), it can be solved by reverting back to 6.4.12
After this update, my PC apparently became sluggish, even after rebooting twice. I was still running kernel 5.15. I updated to Linux 6.1, and now the system feels fluid and reactive again.
Thanks - this solved the issue of resolv.conf being overwritten, but after my laptop had been on for half an hour or so, it stopped being able to see any WiFi networks. I think I’ll just stop using MagicDNS for now, and let NetworkManager do what it wants to resolv.conf.
Final update, fingers crossed: I’ve enabled and started systemd-resolved. Tailscale still prints the “wired together incorrectly” message, but MagicDNS works again, and my connectivity hasn’t disappeared yet.
A post was split to a new topic: Virtualbox guest captures USB devices but device manager does not see them
