Hi everyone, i’m facing an issue with rsync since after the update whenever I specify that a folder should be excluded rsync completely ignores it and copies everything anyway. I’m using the same command i’ve been using to do backups since the last two years but it doesn’t work as intended.
rsync -aAXv --info=progress2 --delete-excluded --exclude=TESTFOLDER/DONOTCOPY/ TESTFOLDER/ /run/media/username/TERRA\ DRIVE/TESTFOLDERTERRA
There is a folder called DONOTCOPY inside TESTFOLDER in my home/username folder i’ve tried several different ways of writing the excluded folder path but nothing works
This is a sample command for the format I usually use, please can someone tell me what’s wrong? I’m sure that the rsync command is bugged because none of the old commands I have saved work as before.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=efbf1a2d-e596-4547-a414-d02214967460 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: LENOVO product: 20RD007XAD v: ThinkPad E15
Mobo: LENOVO model: 20RD007XAD serial: <superuser required> UEFI: LENOVO
v: R16ET30W (1.16 ) date: 01/17/2021
ID-1: BAT0 charge: 42.6 Wh (99.3%) condition: 42.9/45.0 Wh (95.2%)
volts: 11.9 min: 11.1 model: LGC 5B10W138 type: Li-poly serial: <filter>
status: not charging cycles: 67
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Device-2: hidpp_battery_0 model: Logitech Wireless Mouse M185/M225
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 8 GiB available: 7.57 GiB used: 4.73 GiB (62.4%)
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF8
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1770 high: 2100 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2100 2: 2100 3: 805
4: 2100 5: 2100 6: 2100 7: 2100 8: 761 bogomips: 33615
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: AMD Lexa [Radeon 540X/550X/630 / RX 640 E9171 MCM] vendor: Lenovo
driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm
built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 03:00.0 chip-ID: 1002:6987 class-ID: 0380
temp: 52.0 C
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 13d3:5415
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu,modesetting alternate: fbdev,vesa dri: iris,radeonsi gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: Mesa Intel UHD Graphics (CML
GT2) direct-render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.1.49-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: enp0s20f0u3c4i2 state: down mac: <filter>
Local Storage: total: 1.36 TiB used: 512.71 GiB (36.7%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 111110WD temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-08Z10
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 88.24 GiB (19.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: efbf1a2d-e596-4547-a414-d02214967460
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 8FFA-CCFC
ID-3: /run/media/username/TERRA DRIVE raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 424.47 GiB (46.3%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: TERRA DRIVE uuid: 0937e0eb-95a3-4c29-b7eb-1aad2ad9cd97
ID-1: swap-1 type: file size: 512 MiB used: 470 MiB (91.8%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
type: still imaging driver: ipheth,usbfs interfaces: 3 rev: 2.0
chip-ID: 05ac:12a8 class-ID: 0601 serial: <filter>
Device-2: 1-5:5 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Device-3: 1-8:2 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:5415 class-ID: 0e02
Device-4: 1-9:3 info: Shenzhen Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 27c6:55a4 class-ID: ef00
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 59.0 C pch: 56.0 C mobo: N/A gpu: amdgpu
temp: 52.0 C
Fan Speeds (rpm): fan-1: 2900 fan-2: 2900
Processes: 273 Uptime: 1h 12m wakeups: 14 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 1532 pm: pacman pkgs: 1516 libs: 410 tools: pamac pm: flatpak
pkgs: 16 Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.29
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
