Thunderbird freezes
I just installed the latest updates and the new Thunderbird (115.2.0) now hangs all the time. First it only hang when adding a calendar event and now it always hangs 30 seconds after launching. The only thing I can do is kill the process. Is this a known issue?
I am on Manjaro XFCE but I am using i3 as the window manager.
Running it from a terminal doesn’t show anything interesting:
$ thunderbird
ATTENTION: default value of option mesa_glthread overridden by environment.
[ImapModuleLoader] Using nsImapService.cpp
console.warn: services.settings: Failed to load last_modified.json: TypeError: NetworkError when attempting to fetch resource.
console.debug: "Found 4 public keys and 0 secret keys (0 protected, 0 unprotected)"
console.debug: "Successfully loaded optional OpenPGP library libgpgme.so from system's standard library locations"
console.debug: "gpgme version: 1.22.0"
console.debug: "Trying to load /usr/lib/thunderbird/libotr.so"
console.debug: "Trying to load libotr.so from system's standard library locations"
console.debug: "Successfully loaded OTR library libotr.so from system's standard library locations"
Well, it would appear so, because another poster just reported a similar thing… :arrow_down:
thanks! seems to be the same issue
