cbrown
30 August 2023 21:58
21
Having the same issue on a amd laptop, different param on different kernels. Latest lts breaks display also
, but that one is the only one not flooding log
WARNING: CPU: 4 PID: 1247 at include/linux/dma-fence.h:475 amdgpu_sync_keep_later+0x76/0xc0
RIP: 0010:amdgpu_sync_keep_later+0x76/0xc0 [amdgpu]
edit: apparently the display issue was a backlight append in the grub, that wasn’t necessary anymore.
and the param 0014 in 6.1 is apparently not that big of a deal? supposedly being pushed into debug
Short: Steam crashes after launch
After that last update, if you have enabled “Allow background processing of Vulkan shaders” in Steam (found in Settings → Downloads → Shader pre-caching), couple of seconds after Steam starts, the system freezes for a short duration of around a second and the steam client is killed.
As of now the solution is to disable this setting (disabled by default anyways)
Details
In the journal log I see
Process 7379 (steamwebhelper) of user 1000 dumped core.
... followed by the stack trace for the file .local/share/Steam/ubuntu12_64/libcef.so ...
In the kernel log I see an oom-kill log
onstraint=CONSTRAINT_NONE,nodemask=(null),cpuset=user.slice,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service/app.slice/app-steam\x2dnative-c60fa79dda0c49f1b0b5c3fe47d69f25.scope,task=fossilize_repla,pid=8594,uid=1000
followed by out of memory log
Killed process 8594 (fossilize_repla) total-vm:5421104kB, anon-rss:4619600kB, file-rss:868kB, shmem-rss:8256kB, UID:1000 pgtables:9376kB oom_score_adj:200
System information if anyone needs this:
Manufacturer: ASUSTeK COMPUTER INC.
Model: TUF GAMING X670E-PLUS
Form Factor: Desktop
Processor Information:
CPU Vendor: AuthenticAMD
CPU Brand: AMD Ryzen 9 7900X 12-Core Processor
Speed: 5733 MHz
24 logical processors
12 physical processors
Hyper-threading: Supported
Operating System Version:
"Manjaro Linux" (64 bit)
Kernel Name: Linux
Kernel Version: 6.5.0-1-MANJARO
X Server Vendor: The X.Org Foundation
X Server Release: 12302000
X Window Manager: KWin
Video Card:
Driver: AMD AMD Radeon RX 6800 XT (navi21, LLVM 15.0.7, DRM 3.54, 6.5.0-1-MANJARO)
Driver Version: 4.6 (Compatibility Profile) Mesa 23.1.6
OpenGL Version: 4.6
Desktop Color Depth: 24 bits per pixel
Monitor Refresh Rate: 99 Hz
Desktop Resolution: 3440 x 1440
Primary Display Size: 31.50" x 12.99" (34.06" diag), 80.0cm x 33.0cm (86.5cm diag)
Primary VRAM: 16384 MB
RAM: 31820 Mb
Kobold
31 August 2023 13:05
23
I hope so. I dont saw any problems yet, besides the error message in Journal.
Did you try installing lib32-libnm
Yes, it’s already installed (v1.42.6-1)
I am having issues with my amd-ryzen gpu using kernel 5.15.128-1
on my system:
Host: speedy Kernel: 6.4.12-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce
v: 4.18.1 Distro: Manjaro Linux
Type: Laptop System: SchenkerGmbH product: SCHENKER VIA 15 Pro v: Standard
serial: PF5NU1G2211608654
Mobo: NB02 model: PF5NU1G v: Standard serial: Standard
UEFI: American Megatrends v: N.1.07.A06 date: 08/29/2022
Info: 8-core AMD Ryzen 7 4800H with Radeon Graphics [MT MCP] speed (MHz):
avg: 2900 min/max: 1400/2900
Device-1: AMD Renoir driver: amdgpu v: kernel
Device-2: Chicony HD Webcam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu
unloaded: modesetting dri: radeonsi gpu: amdgpu resolution:
1: 2560x1440~60Hz 2: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: AMD Radeon Graphics (renoir
LLVM 15.0.7 DRM 3.52 6.4.12-1-MANJARO)
Problem is that xfce-desktop is really slow, whisker-menu opens 2-3 seconds after pressing the according shortcut.
Also resizing windows and effects are much slower than it was before the update.
Unfortunately I haven’t got any more time to investigate the problem, besides checking the logs:
sudo journalctl -b 0 -p 3
Aug 31 15:52:27 speedy kernel: amd_gpio AMDI0030:00: Invalid config param 0013
Workaround for now was using kernel 6.4.12-1-MANJARO
Are any of you experiencing the same or related problems after upgrading?
Yochanan
Split this topic
31 August 2023 17:39
26
A post was split to a new topic: Missing GNOME Control Center menu
Rmano
31 August 2023 16:56
27
I have a lot of problems with kernel 5.15.128 with:
CPU: 8-core AMD Ryzen 9 5900HX with Radeon Graphics (-MT MCP-)
speed/min/max: 4005/1200/4679 MHz Kernel: 5.15.128-1-MANJARO x86_64 Up: 1m
Mem: 2.73/30.78 GiB (8.9%) Storage: 3.64 TiB (35.7% used) Procs: 416
Shell: Zsh inxi: 3.3.29
I have a lot of oops flooding the journal like:
Aug 31 18:54:31 ramoth kernel: WARNING: CPU: 0 PID: 2243 at include/linux/dma-fence.h:478 amdgpu_sync_keep_later+0x80/0xc0 [amdgpu]
Aug 31 18:54:31 ramoth kernel: Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg hid_logitech_hidpp qrtr bnep mousedev joydev hid_logitech_dj uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev ext4 mbcache jbd2 squashfs vfat fat btusb btrtl btbcm btintel bluetooth ecdh_generic crc16 hid_cmedia snd_usb_audio amdgpu snd_usbmidi_lib snd_rawmidi snd_seq_device snd_hda_codec_hdmi mc usbhid snd_hda_intel mt7921e intel_rapl_msr intel_rapl_common snd_intel_dspcfg mt76_connac_lib snd_intel_sdw_acpi edac_mce_amd mt76 snd_hda_codec kvm_amd wmi_bmof snd_hda_core mac80211 kvm snd_hwdep irqbypass libarc4 snd_pcm snd_pci_acp5x crct10dif_pclmul crc32_pclmul cfg80211 ghash_clmulni_intel snd_timer aesni_intel gpu_sched snd_rn_pci_acp3x crypto_simd snd sp5100_tco drm_ttm_helper cryptd ccp ttm amd_sfh snd_pci_acp3x soundcore igc rapl rfkill pcspkr k10temp i2c_piix4 wmi video cm32181 tpm_crb industrialio i2c_hid_acpi i2c_hid tpm_tis tpm_tis_core acpi_cpufreq pinctrl_amd
Aug 31 18:54:31 ramoth kernel: mac_hid dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) sg fuse crypto_user dm_mod loop tpm rng_core ip_tables x_tables btrfs blake2b_generic libcrc32c crc32c_generic xor raid6_pq crc32c_intel xhci_pci
Aug 31 18:54:31 ramoth kernel: CPU: 0 PID: 2243 Comm: gnome-shel:cs0 Tainted: G W OE 5.15.128-1-MANJARO #1 c3814ba8fdf6180c9e91a6641f0d918ed8583075
Aug 31 18:54:31 ramoth kernel: Hardware name: SYSTEM_MANUFACTURER HX90/HX90, BIOS 5.19 10/11/2021
Aug 31 18:54:31 ramoth kernel: RIP: 0010:amdgpu_sync_keep_later+0x80/0xc0 [amdgpu]
Aug 31 18:54:31 ramoth kernel: Code: b8 01 00 00 00 f0 0f c1 43 38 85 c0 74 4b 8d 50 01 09 c2 78 19 48 89 5d 00 5b 5d 31 c0 31 d2 31 c9 31 f6 31 ff e9 70 b6 df cc <0f> 0b eb b2 be 01 00 00 00 e8 52 19 34 cc eb db be 03 00 00 00 e8
Aug 31 18:54:31 ramoth kernel: RSP: 0018:ffffc17847833af8 EFLAGS: 00010293
Aug 31 18:54:31 ramoth kernel: RAX: ffffffff8fdbf720 RBX: ffff9b0cb1b82dc0 RCX: 000000000000008d
Aug 31 18:54:31 ramoth kernel: RDX: 0000000000000000 RSI: ffff9b0cb1b82dc0 RDI: ffff9b0d4ee0e8f8
Aug 31 18:54:31 ramoth kernel: RBP: ffff9b0d4ee0e8f8 R08: 0000000000000000 R09: 0000000000000000
Aug 31 18:54:31 ramoth kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff9b0cd6fa3038
Aug 31 18:54:31 ramoth kernel: R13: ffff9b0cb1707000 R14: ffff9b0cb1715c00 R15: 0000000000000000
Aug 31 18:54:31 ramoth kernel: FS: 00007fce34e3e6c0(0000) GS:ffff9b136e600000(0000) knlGS:0000000000000000
Aug 31 18:54:31 ramoth kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 31 18:54:31 ramoth kernel: CR2: 00007f33d599a338 CR3: 000000013158e000 CR4: 0000000000750ef0
Aug 31 18:54:31 ramoth kernel: PKRU: 55555554
Aug 31 18:54:31 ramoth kernel: Call Trace:
Aug 31 18:54:31 ramoth kernel: <TASK>
Aug 31 18:54:31 ramoth kernel: ? __warn+0x81/0x100
Aug 31 18:54:31 ramoth kernel: ? amdgpu_sync_keep_later+0x80/0xc0 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 18:54:31 ramoth kernel: ? report_bug+0xa7/0xd0
Aug 31 18:54:31 ramoth kernel: ? handle_bug+0x34/0x90
Aug 31 18:54:31 ramoth kernel: ? exc_invalid_op+0x13/0x70
Aug 31 18:54:31 ramoth kernel: ? asm_exc_invalid_op+0x16/0x20
Aug 31 18:54:31 ramoth kernel: amdgpu_sync_vm_fence+0x1e/0x40 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 18:54:31 ramoth kernel: amdgpu_cs_ioctl+0x16e3/0x2080 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 18:54:31 ramoth kernel: ? amdgpu_cs_find_mapping+0x110/0x110 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 18:54:31 ramoth kernel: drm_ioctl_kernel+0xbf/0x110
Aug 31 18:54:31 ramoth kernel: drm_ioctl+0x248/0x420
Aug 31 18:54:31 ramoth kernel: amdgpu_drm_ioctl+0x4a/0x90 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 18:54:31 ramoth kernel: __x64_sys_ioctl+0x98/0xe0
Aug 31 18:54:31 ramoth kernel: do_syscall_64+0x5c/0x90
Aug 31 18:54:31 ramoth kernel: ? syscall_exit_to_user_mode+0x31/0x50
Aug 31 18:54:31 ramoth kernel: ? do_syscall_64+0x68/0x90
Aug 31 18:54:31 ramoth kernel: entry_SYSCALL_64_after_hwframe+0x62/0xcc
Aug 31 18:54:31 ramoth kernel: RIP: 0033:0x7fce3e3e99df
Aug 31 18:54:31 ramoth kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
Aug 31 18:54:31 ramoth kernel: RSP: 002b:00007fce34e3c510 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Aug 31 18:54:31 ramoth kernel: RAX: ffffffffffffffda RBX: 00007fce34e3c6d8 RCX: 00007fce3e3e99df
Aug 31 18:54:31 ramoth kernel: RDX: 00007fce34e3c5d0 RSI: 00000000c0186444 RDI: 000000000000000e
Aug 31 18:54:31 ramoth kernel: RBP: 00007fce34e3c5d0 R08: 00007fce34e3c740 R09: 00007fce34e3c5b0
Aug 31 18:54:31 ramoth kernel: R10: 000055c226035ab0 R11: 0000000000000246 R12: 00000000c0186444
Aug 31 18:54:31 ramoth kernel: R13: 000000000000000e R14: 0000000000000003 R15: 00007fce34e3c6d8
Aug 31 18:54:31 ramoth kernel: </TASK>
Aug 31 18:54:31 ramoth kernel: ---[ end trace 571b69ecab2d40f8 ]---
Both 6.1 and 6.4 kernel work ok.
I found the same logs in my journal:
Aug 31 16:40:37 speedy kernel: WARNING: CPU: 8 PID: 993 at include/linux/dma-fence.h:478 amdgpu_sync_keep_later+0x80/0xc0 [amdgpu]
Aug 31 16:40:37 speedy kernel: Modules linked in: qrtr cmac algif_hash algif_skcipher af_alg bnep vfat fat iwlmvm amdgpu mac80211 snd_hda_codec_realtek libarc4 snd_hda_codec_generic ledtrig_audio snd_hda_codec_>
Aug 31 16:40:37 speedy kernel: tuxedo_keyboard(OE) sparse_keymap led_class_multicolor dm_multipath vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) fuse crypto_user loop ip_tables x_tables ext4 crc32c_generic crc16 m>
Aug 31 16:40:37 speedy kernel: CPU: 8 PID: 993 Comm: Xorg:cs0 Tainted: G W OE 5.15.128-1-MANJARO #1 c3814ba8fdf6180c9e91a6641f0d918ed8583075
Aug 31 16:40:37 speedy kernel: Hardware name: SchenkerTechnologiesGmbH SCHENKER VIA 15 Pro/PF5NU1G, BIOS N.1.07.A06 08/29/2022
Aug 31 16:40:37 speedy kernel: RIP: 0010:amdgpu_sync_keep_later+0x80/0xc0 [amdgpu]
Aug 31 16:40:37 speedy kernel: Code: b8 01 00 00 00 f0 0f c1 43 38 85 c0 74 4b 8d 50 01 09 c2 78 19 48 89 5d 00 5b 5d 31 c0 31 d2 31 c9 31 f6 31 ff e9 70 d6 5d f4 <0f> 0b eb b2 be 01 00 00 00 e8 52 39 b2 f3 eb >
Aug 31 16:40:37 speedy kernel: RSP: 0018:ffffb87d817aba70 EFLAGS: 00010293
Aug 31 16:40:37 speedy kernel: RAX: ffffffffb75bf720 RBX: ffff982d838ce100 RCX: 0000000000000052
Aug 31 16:40:37 speedy kernel: RDX: 0000000000000000 RSI: ffff982d838ce100 RDI: ffff982d8d5d94f8
Aug 31 16:40:37 speedy kernel: RBP: ffff982d8d5d94f8 R08: 0000000000000000 R09: 0000000000000000
Aug 31 16:40:37 speedy kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff982d9c8d5c38
Aug 31 16:40:37 speedy kernel: R13: ffff982d8d5e8000 R14: ffff982d8a2c8b80 R15: 0000000000000000
Aug 31 16:40:37 speedy kernel: FS: 00007f00649056c0(0000) GS:ffff98346f800000(0000) knlGS:0000000000000000
Aug 31 16:40:37 speedy kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 31 16:40:37 speedy kernel: CR2: 00007f0060001008 CR3: 000000011e76e000 CR4: 0000000000350ee0
Aug 31 16:40:37 speedy kernel: Call Trace:
Aug 31 16:40:37 speedy kernel: <TASK>
Aug 31 16:40:37 speedy kernel: ? __warn+0x81/0x100
Aug 31 16:40:37 speedy kernel: ? amdgpu_sync_keep_later+0x80/0xc0 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 16:40:37 speedy kernel: ? report_bug+0xa7/0xd0
Aug 31 16:40:37 speedy kernel: ? handle_bug+0x34/0x90
Aug 31 16:40:37 speedy kernel: ? exc_invalid_op+0x13/0x70
Aug 31 16:40:37 speedy kernel: ? asm_exc_invalid_op+0x16/0x20
Aug 31 16:40:37 speedy kernel: amdgpu_sync_vm_fence+0x1e/0x40 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 16:40:37 speedy kernel: amdgpu_cs_ioctl+0x16e3/0x2080 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 16:40:37 speedy kernel: ? __switch_to_asm+0x3a/0x60
Aug 31 16:40:37 speedy kernel: ? amdgpu_cs_find_mapping+0x110/0x110 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 16:40:37 speedy kernel: drm_ioctl_kernel+0xbf/0x110
Aug 31 16:40:37 speedy kernel: drm_ioctl+0x248/0x420
Aug 31 16:40:37 speedy kernel: amdgpu_drm_ioctl+0x4a/0x90 [amdgpu 59bb2b54778d3125c1b153c1a01f9a8546f99263]
Aug 31 16:40:37 speedy kernel: __x64_sys_ioctl+0x98/0xe0
Aug 31 16:40:37 speedy kernel: do_syscall_64+0x5c/0x90
Aug 31 16:40:37 speedy kernel: ? __x64_sys_futex+0x129/0x200
Aug 31 16:40:37 speedy kernel: ? syscall_exit_to_user_mode+0x31/0x50
Aug 31 16:40:37 speedy kernel: ? do_syscall_64+0x68/0x90
Aug 31 16:40:37 speedy kernel: ? __x64_sys_ioctl+0xb0/0xe0
Aug 31 16:40:37 speedy kernel: ? exc_page_fault+0x79/0x190
Aug 31 16:40:37 speedy kernel: entry_SYSCALL_64_after_hwframe+0x62/0xcc
Aug 31 16:40:37 speedy kernel: RIP: 0033:0x7f00716879df
Aug 31 16:40:37 speedy kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 >
Aug 31 16:40:37 speedy kernel: RSP: 002b:00007f00649048e0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Aug 31 16:40:37 speedy kernel: RAX: ffffffffffffffda RBX: 00007f0064904a58 RCX: 00007f00716879df
Aug 31 16:40:37 speedy kernel: RDX: 00007f00649049a0 RSI: 00000000c0186444 RDI: 0000000000000010
Aug 31 16:40:37 speedy kernel: RBP: 00007f00649049a0 R08: 00007f0064904ac0 R09: 00007f0064904980
Aug 31 16:40:37 speedy kernel: R10: 000055c7302d2140 R11: 0000000000000246 R12: 00000000c0186444
Aug 31 16:40:37 speedy kernel: R13: 0000000000000010 R14: 0000000000000003 R15: 00007f0064904a58
Aug 31 16:40:37 speedy kernel: </TASK>
Aug 31 16:40:37 speedy kernel: ---[ end trace 64d4895efab10bf0 ]---
Now switched to 6.1.
Kobold
31 August 2023 23:46
29
Nvidia just confirmed few hours ago that they could finally repro and debug the flickering issue!
Since the newest update I can’t launch any steam games anymore.
They are all stuck on “Is running” but the actual window won’t come up.
Does someone else experience this problem?
Hardware information:
Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e3096fe0-0ca5-452a-9c5b-119d9a6f775d rw quiet splash
resume=UUID=22575598-3783-4406-aea9-152f18f4a363 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4802
date: 06/15/2023
System RAM: total: 32 GiB available: 31.25 GiB used: 8.8 GiB (28.2%)
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2988 high: 4245 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2078 2: 3737
3: 3742 4: 2194 5: 2194 6: 2195 7: 2051 8: 3787 9: 3835 10: 2109 11: 4230
12: 4245 13: 2200 14: 2200 15: 3537 16: 2195 17: 2196 18: 2196 19: 2080
20: 4216 21: 3931 22: 2119 23: 4231 24: 4234 bogomips: 182127
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2 bus-ID: 0b:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: AMD Radeon RX 5700 XT (navi10
LLVM 15.0.7 DRM 3.49 6.1.49-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.49-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.55 TiB used: 1.45 TiB (31.8%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 46.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: Force MP600
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM11.1 temp: 32.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-1: / raw-size: 896.84 GiB size: 881.69 GiB (98.31%)
used: 495.85 GiB (56.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:8
label: N/A uuid: e3096fe0-0ca5-452a-9c5b-119d9a6f775d
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:7 label: N/A
uuid: D2E3-E3D7
ID-3: /mnt/disk1 raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 985.57 GiB (52.9%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 4fded8f2-cc59-4052-9038-de20f81bc301
ID-1: swap-1 type: partition size: 34.38 GiB used: 1.57 GiB (4.6%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:9 label: swap
uuid: 22575598-3783-4406-aea9-152f18f4a363
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: A63E-26CE
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 930.25 GiB fs: ntfs label: N/A
uuid: 2402408D02406640
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 645 MiB fs: ntfs label: N/A
uuid: EEC0F6EEC0F6BC41
ID-5: /dev/nvme1n1p5 maj-min: 259:5 size: 525 MiB fs: ntfs label: N/A
uuid: E8BA2E0DBA2DD938
Device-1: 1-3:2 info: Razer USA Viper 8KHz type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:0091 class-ID: 0301
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-2:2 info: Corsair Gaming K55 RGB Keyboard type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:1b3d class-ID: 0300
serial: <filter>
Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 45.0 C mobo: 43.0 C gpu: amdgpu temp: 57.0 C
mem: 62.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1374
Processes: 468 Uptime: 58m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7 Packages: 1365
pm: pacman pkgs: 1358 libs: 448 tools: pamac pm: flatpak pkgs: 7 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
Journalctl reports the following problems:
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstmpg123.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstnavigationtest.so': /mnt/disk1/SteamLibrary/steamapps/common/Pro>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstmatroska.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstlibav.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/d>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstximagesink.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton >
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstopus.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/di>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstopengl.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgsttheora.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libprotonmediaconverter.so': /mnt/disk1/SteamLibrary/steamapps/common/>
Sep 01 08:44:25 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstvideoscale.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton >
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstvpx.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dis>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstadder.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/d>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstvorbis.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstvideobox.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstaudioresample.so': /mnt/disk1/SteamLibrary/steamapps/common/Prot>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstaudioparsers.so': /mnt/disk1/SteamLibrary/steamapps/common/Proto>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstdeinterlace.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton>ps/common/Proton 8.0/dis>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgsttypefindfunctions.so': /mnt/disk1/SteamLibrary/steamapps/common/>
Sep 01 08:44:26 NYFB rundll32.exe[16859]: Failed to load plugin '/mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0/dist/lib64/gstreamer-1.0/libgstpbtypes.so': /mnt/disk1/SteamLibrary/steamapps/common/Proton 8.0>
Sep 01 08:44:26 NYFB plasmashell[16750]: wine: configuration in L"/mnt/disk1/SteamLibrary/steamapps/compatdata/1509960/pfx" has been updated.
Sep 01 08:44:27 NYFB plasmashell[16925]: Fossilize INFO: Setting autogroup scheduling.
Sep 01 08:44:27 NYFB plasmashell[16944]: Fossilize INFO: Setting autogroup scheduling.
Sep 01 08:44:27 NYFB plasmashell[8970]: /bin/sh\0-c\0/home/jens/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1509960 -- /home/jens/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/mnt/disk1/Ste>
Sep 01 08:44:27 NYFB plasmashell[17084]: ERROR: ld.so: object '/home/jens/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Sep 01 08:44:27 NYFB plasmashell[17084]: ERROR: ld.so: object '/home/jens/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Sep 01 08:44:27 NYFB plasmashell[17085]: ERROR: ld.so: object '/home/jens/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Sep 01 08:44:27 NYFB plasmashell[17086]: ERROR: ld.so: object '/home/jens/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Sep 01 08:44:28 NYFB plasmashell[8970]: WARNING: discarding _NET_WM_PID 8 as invalid for X11 window - use specialized XCB_X11_TO_PID function!
Sep 01 08:44:28 NYFB plasmashell[17209]: fsync: up and running.
Sep 01 08:44:28 NYFB plasmashell[17209]: wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
Kobold
1 September 2023 13:23
31
Actually i had this problems temporary a few weeks ago and just restarting steam was fixing it.
But it was coming back again, on another day. Since this new stable update it didnt showed up again, but maybe i will see it soon again… who knows.
Somehow my journal didnt complained about this issues… but i find strange your rundll32.exe stuff in journal, whats going on there?
Rundll32 is a Microsoft Windows Service, is there a reason why are you using this for Steam Proton?
This is a ~2 week old system which I freshly set up and I’m just running the Steam (Runtime) edition with Proton 8.0.3. No idea why it is calling rundll32.exe, could be wine.
I’ve switched from Wayland back to X11, tested it there and switched again to Wayland and now it’s working again, weird…
KnudH
1 September 2023 18:24
33
My Thinkpad T14s with Ryzen 7 5850U and Radeon Graphics randomly freezes and capslock blinking since this update. Sometimes their a some procesees like firefox are crashing, before this happens. Already tried with live manjaro from usb-stick, same thing. Will try old version next, to be 100% sure, its about this version.
I’m really new manjaro. What should I do, do give more info for bugfix?
// Edit: no problems with the version
Desktop is KDE
KnudH:
What should I do?
Welcome to the forum!
Please create a separate Support topic for further troubleshooting.
fhins
2 September 2023 14:16
35
Are you using the 6.1.49-1 LTS kernel? If not give it a try.
Yochanan
Split this topic
2 September 2023 22:22
36
A post was split to a new topic: Diablo 4 issues
I was having problems when using Kernel 6.5. System freezes up and/or poor performance in games. I couldn’t exactly figure out why. Went back to 6.4 and everything is fine again.
Also, I use amd_pstate=active
maybe that’s related.
bena
3 September 2023 11:53
38
Tailscale’s MagicDNS stopped working after this update. Something had recreated /etc/resolv.conf
, turning it from a symlink back to a regular file.
$ tailscale status
# Health check:
# - dns-manager: systemd-resolved and NetworkManager are wired together incorrectly; MagicDNS will probably not work. For more info, see https://tailscale.com/s/resolved-nm
# - dns-os: setLinkDNS: Unit dbus-org.freedesktop.resolve1.service not found.
# - dns: setLinkDNS: Unit dbus-org.freedesktop.resolve1.service not found.
The instructions at https://tailscale.com/s/resolved-nm did resolve the issue until a reboot - see this comment to persist the fix.
The IO-wait issue is gone on kernel 6.1.49
I have/had the same problem after the latest stable update. Steam wouldn’t be able to show its main window, but I do see the login window which auto-fills in my credentials and disappears. The background/watchdog process also runs since its icon shows up on the taskbar. I see the Steam client main window borders popping up, freezing the screen for 2 or 3 seconds (apparently the new window locks the screen buffer since it’s fullscreen) after which the window immediately gets killed. A few seconds later it retries and the same behavior happens where it freezes the screen ans kills the window again; it keeps looping like this until I right-click the taskbar process and select ‘Exit Steam’.
In the pamac Package Manager GUI I clicked the ‘Steam (native) (steam-native-runtime)’ package and there clicked ‘Launch’. This starts the application without any problems and all the games run fine; I stumbled upon this by accident. The “Allow background processing of Vulkan shaders” setting is still enabled in my case.
But I still cannot start Steam from the Start Menu or via a pinned taskbar shortcut. The only way I can start Steam, since this 2023-08-29-stable-update, is via the pamac gui, clicking 'Launch".
Anybody has an idea what’s the difference of invocation between launching from pamac GUI and launching Steam from the start menu?
