So I installed it without thinking. Most things are working fine other than Civ V on Steam. It will start up fine but lock up after a couple of turns so badly that I need to switch to a virtual console to kill the process to get back to desktop
there was, didn’t had time to announce it yet: [Stable Update] 2022-07-18 - Kernels, Pipewire, Mesa, Xorg, XWayland, Gnome, KDE Gear, Plamo ($773) · Snippets · Snippets · GitLab
i tried ordering,it still charge for shipping.
Action is from 21-24th of July, which is the weekend. So you can browse now to buy later …
i just noticed it;
i got confused by the “now”.
Thanks
I rephrased it to make it more clearer …
I had to upgrade from Bauh to solve dependencies problem around wxgtk3 and extra/wxwidgets-common.
i lost sound on a USB AMP/DAC - i posted the issue here: No sound from USB DAC
I lost sound too on a PCI-Express card: Asus sonar essence stx card not detected as ouput
I’m getting same issue ![]()
you should probably post an issue in the sound forum if you haven’t already
I have an error message popping up a few times when running VeraCrypt, although it’s working fine
/build/wxwidgets/src/wxWidgets-3.2.0/src/common/sizer.cpp(2288): assert "CheckSizerFlags(!((flags) & (wxALIGN_RIGHT | wxALIGN_CENTRE_HORIZONTAL | wxALIGN_BOTTOM | wxALIGN_CENTRE_VERTICAL)))" failed in DoInsert(): wxALIGN_RIGHT | wxALIGN_CENTRE_HORIZONTAL | wxALIGN_BOTTOM | wxALIGN_CENTRE_VERTICAL will be ignored in this sizer: wxEXPAND overrides alignment flags in box sizers
DO NOT PANIC !!
If you're an end user running a program not developed by you, please ignore this message, it is harmless, and please try reporting the problem to the program developers.
You may also set WXSUPPRESS_SIZER_FLAGS_CHECK environment variable to suppress all such checks when running this program.
If you're the developer, simply remove this flag from your code to avoid getting this message. You can also call wxSizerFlags::DisableConsistencyChecks() to globally disable all such checks, but this is strongly not recommended.
I got some issues with wxgtk complaining, but after uninstalling audacity which also uninstalled some wxgtk things it worked.
5 posts were split to a new topic: I need wxwidgets-gtk3 3.2.0-3 or higher in order to compile wxmaxima 22.05.0-3
Right after the last update the following script just disappeared from the Kwin Scripts (I installed it from the System Settings before, but now I can’t even find Bismuth available when I just tried to install a new Kwin Script):
Any ideas?
Just one sneaky problem I’ve noticed. For some reason the new version of Audacious refused to play my MPD music streams:
ERROR metadata.cc:386 [read_tag]: An error occurred: FLAC__METADATA_CHAIN_STATUS_INTERNAL_ERROR
Not sure why it seems to be complaining about FLAC, as my streams were encoded using vorbis. Curiously, changing the streams to FLAC fixes the problem. As They’re only played within my LAN, the extra bandwidth of using FLAC isn’t a problem.
A post was merged into an existing topic: I need wxwidgets-gtk3 3.2.0-3 or higher in order to compile wxmaxima 22.05.0-3
the MENA mirror was not synced it gave a me “failed to retrieve some files” even tho the mirror was up to date. the Global mirror worked with me.
Related to this:
Hi there,
using
sudo pamac update
leads to some dependency warnings. May the ruby-dependency is missing in the ruby-sub-packages?
Warnung: Abhängigkeits-Zyklus entdeckt:
Warnung: ruby-bundler wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-json wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-psych wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-stringio wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-rdoc wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-stdlib wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-minitest wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-power_assert wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-rake wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-rexml wird vor seiner Abhängigkeit ruby installiert werden
Warnung: ruby-test-unit wird vor seiner Abhängigkeit ruby installiert werden
Ruby is already installed on my system. Do you have any recommendations on this?
