On KDE I wanted the green Dolphin icon back, instead of the blue one. To do this I tried to change my theme. Once I did, I got the KDE logo on the Application Launcher button rather than the Manjaro one. I’d like to get the Manjaro Logo back. The Manjaro Logo is shown in the screenshot for the theme I am on (Breath Dark).
I also would love to get the green Dolphin logo back. It made Dolphin feel like it matched the default color scheme so much better.
I decided to have a go at it. After some tinkering I could not get the audio devices to show up. Eventually I decided to rollback the ALSA update to 1.2.5.1, restarted and voila the audio devices are back.
Well the blue Dolphin logo should resolve itself with a later KDE update as the Manjaro team worked with the KDE dev team to make it color aware to the color scheme. You could reinstall Breath icon theme and use that but is depricated so no garantee it will work later on down the line. So default is now Breeze icon theme and you should use that.
To fix the Starter Icon you could rightklick on the taskbar and enter “edit mode”, then hover the mouse over the start menu and klick on settings … there you could change the icon.
i don’t think you can change the dolphin icon color from blue to green because that is the one that comes in breath dark theme. for getting back manjaro icon right click on the application launcher and select configure. there you can change the icon buy searching for manjaro.
Having an issue with steam, was playing a game before updating, updated, and now it hangs on ‘preparing to launch’.
I then checked the steam settings and the setting to enable proton for all non-linux games was unticked for some reason, I try to tick it after which steam requires a restart but it fails to restart, I get:
Thread "CJobMgr::m_WorkThreadPool:2" (ID 114032) failed to shut down
Spammed at me. Only way for me to exit steam is to kill it. No known solution.
Also to make matters worse, my GUI theme got all messed up after the update (I’m on KDE, qt applications display properly, but gtk applications seem to be using the wrong theme all of a sudden.) but that was easy to fix, just had to reapply it.
Also optimus-manager is not working
$ optimus-manager
File "/usr/bin/optimus-manager", line 33, in <module>
sys.exit(load_entry_point('optimus-manager==1.4', 'console_scripts', 'optimus-manager')())
File "/usr/bin/optimus-manager", line 22, in importlib_load_entry_point
for entry_point in distribution(dist_name).entry_points
File "/usr/lib/python3.9/importlib/metadata.py", line 524, in distribution
return Distribution.from_name(distribution_name)
File "/usr/lib/python3.9/importlib/metadata.py", line 187, in from_name
raise PackageNotFoundError(name)
importlib.metadata.PackageNotFoundError: optimus-manager
resolving dependencies...
:: libxnvctrl-390xx and libxnvctrl are in conflict. Remove libxnvctrl? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Has anybody else running nvidia-390xx drivers faced a similar issue ? TIA
1.4-3 broke it for me, i had no issues prior to that.
trying to switch to another card in optimus manager-qt brings an error:
unable to connect to optimus manager daemon:
no such file or directory.
If optimus-manager is going to be that problematic, I’ll just drop it from the repos. I do not have hardware with hybrid graphics to test. The previous maintainer did, but he is no longer on the team.
I know: Don’t post if all is good!.. Yeah, all is great here!.. Accept this post though as a way to wish all the wonderful Manjaro Team and Community merry Christmas and a prosperous new year of 2022!!!..
