Hi! Just updated and I canāt run vorta, this is what I get:
File "/usr/bin/vorta", line 33, in <module>
sys.exit(load_entry_point('vorta==0.7.1', 'gui_scripts', 'vorta')())
File "/usr/bin/vorta", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.9/importlib/metadata.py", line 77, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 790, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/lib/python3.9/site-packages/vorta/__main__.py", line 9, in <module>
from vorta.models import init_db
File "/usr/lib/python3.9/site-packages/vorta/models.py", line 17, in <module>
from vorta.utils import slugify
File "/usr/lib/python3.9/site-packages/vorta/utils.py", line 22, in <module>
from vorta.borg._compatibility import BorgCompatibility
File "/usr/lib/python3.9/site-packages/vorta/borg/_compatibility.py", line 1, in <module>
from pkg_resources import parse_version
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3239, in <module>
def _initialize_master_working_set():
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3222, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3251, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 567, in _build_master
ws.require(__requires__)
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 884, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 770, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'apscheduler' distribution was not found and is required by vorta
EDIT:
Seems to be working now, I just rebuilt the packages python-apscheduler and then vorta itself
