[Stable Update] 2020-12-30 - Kernels, KDE, Cinnamon, LibreOffice, Python 3.9, Mesa 20.3.1
So basically same as me… hope this will fixed soon. Thanks anyway.
The kernel version says 5.9.16-1. I tried uninstalling nvidia-455xx-utils but its required by lib32-nvidia-utils. Should i use the -Rdd command?
sudo mhwd -a pci nonfree 0300
Warning: config '/var/lib/mhwd/local/pci/video-nvidia-455xx/MHWDCONFIG' is invalid!
> Skipping already installed config 'video-nvidia' for device: 0000:01:00.0 (0300:10de:13c2) Display controller nVidia Corporation GM204 [GeForce GTX 970]
sudo pacman --remove nvidia*
error: target not found: nvidia*
Hi,
Sound issue with the 5.10 kernel on a laptop, solved by installed back the 5.9.16 kernel
more info see below
I removed lib32 stuff manually, and then uninstalled nvidia-455xx-utils. You will probably end without GUI, but then nvidia-utils re-instalation will work fine after reboot. At least it worked for me and fixed all the graphic problems.
[2020-12-31T…] [ALPM] upgraded linux54 (5.4.80-2 β†’ 5.4.85-1)
[2020-12-31T…] [ALPM] upgraded linux54-nvidia-390xx (390.132-88 β†’ 390.138-2)
It worked! After rebooting and running β€œmhwd -a pci nonfree 0300” the drivers started working again. I still have some problems with a window manager (bspwm), but the driver issue is fixed. Thank you!
I was able to install video-hybrid-intel-nvidia-prime but still SDDM is failing to load.
Hey @philm. Thx for quick response.
From my current pre-updated/reverted/working copy, I receive the following output:
Skipping already installed config 'video-nvidia-455xx' for device: 0000:01:00.0 (0300:10de:1c03) Display controller nVidia Corporation GP106 [GeForce GTX 1060 6GB]
linux-latest it’s still on linux59 to me :thinking:
I checked the mirror I’m using is updated!
thanks … reinstalling solved the issue
I replaced video-hybrid-intel-nvidia-prime with video-nvidia. I’m now getting Error : config 'video-hybrid-intel-nvidia-prime' conflicts with config(s): video-nvidia.
I have this warning message at every boot
I hear ya. Came from many years in Ubuntu, and prefer Manjaro/Arch (just barely, but surely). I often get tempted to go back, but tend to keep my multimedia (CG) apps at the cutting edge and Arch has helped (plus it just clicks with me more). That said, I need to be a bit more patient with these updates. At least I finally got Timeshift running (and now tested). Cheers!
Hi,
After the update I lost the configuration on my BCM43142 wifi card.
inxi -FN
System:    Host: jochoa Kernel: 5.4.85-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Machine:   Type: Laptop System: HP product: HP 255 G4 Notebook PC v: Type1ProductConfigId serial: <superuser required>
           Mobo: HP model: 80CB v: 99.46 serial: <superuser required> UEFI: Insyde v: F.20 date: 01/26/2016
Battery:   ID-1: BAT1 charge: 20.7 Wh condition: 23.3/23.3 Wh (100%)
CPU:       Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP L2 cache: 2 MiB
           Speed: 998 MHz min/max: 1000/2200 MHz Core speeds (MHz): 1: 998 2: 998 3: 998 4: 998
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics] driver: radeon v: kernel
           Device-2: Chicony HP Truevision HD type: USB driver: uvcvideo
           Display: x11 server: X.Org 1.20.10 driver: ati,radeon unloaded: modesetting resolution: 1366x768~60Hz
           OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.85-1-MANJARO LLVM 11.0.0) v: 4.5 Mesa 20.3.1
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] FCH Azalia driver: snd_hda_intel
           Sound Server: ALSA v: k5.4.85-1-MANJARO
Network:   Device-1: Broadcom BCM43142 802.11b/g/n driver: wl
           IF: wlo1 state: down mac: 44:1c:a8:ea:ee:7f
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
           IF: enp3s0 state: down mac: 70:5a:0f:c1:e3:cf
           Device-3: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
           IF: wlp0s16u2 state: up mac: c4:6e:1f:14:6e:18
Drives:    Local Storage: total: 931.51 GiB used: 133.04 GiB (14.3%)
           ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010A9E680 size: 931.51 GiB
Partition: ID-1: / size: 96.2 GiB used: 20.91 GiB (21.7%) fs: ext4 dev: /dev/sda6
           ID-2: /boot/efi size: 256 MiB used: 52.4 MiB (20.5%) fs: vfat dev: /dev/sda1
           ID-3: /home size: 335.14 GiB used: 32.34 GiB (9.6%) fs: ext4 dev: /dev/sda8
Swap:      ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) dev: /dev/sda5
Sensors:   System Temperatures: cpu: 45.6 C mobo: 20.0 C gpu: radeon temp: 45.0 C
Info:      Processes: 196 Uptime: 10m Memory: 10.67 GiB used: 1.76 GiB (16.5%) Shell: Bash inxi: 3.2.01
Additional outputs are:
0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: hp-wifi: Wireless LAN
        Soft blocked: no
        Hard blocked: no
2: hp-bluetooth: Bluetooth
        Soft blocked: no
        Hard blocked: no
3: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
4: phy1: Wireless LAN
        Soft blocked: no
        Hard blocked: no
I think this is because a wrong detection in the wifi card:
sudo dmesg | grep Broadcom
[sudo] password for jochoa:
[    2.309664] usb 1-1.4: Manufacturer: Broadcom Corp
[   14.981197] wlan0: Broadcom BCM4365 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
Although I have the proper driver installed.
sudo mhwd
> 0000:02:00.0 (0200:14e4:4365) Network controller Broadcom:
   network-broadcom-wl            2018.10.07                true            PCI
> 0000:00:01.0 (0300:1002:9851) Display controller ATI Technologies Inc:
           video-linux            2018.05.04                true            PCI
Should I have to remove the linux419-broadcom-wl and linux54-broadcom-wl and reinstall?
I restarted the laptop twice without solving the issue.
Hope it help, regards
Check out Installed > View - Orphans in Pamac, Zeitgeist probably will be there. You can delete it (if it’s orphaned) because it’s only used to install/build package, but I don’t know which one. Didn’t investigate it yet. If this doesn’t change in conflicts, on next update you’ll need to do the same. Delete Catfish before update, perform update, delete zeitgeist, install catfish.
Manjaro tools stops after installing the desktop files and doing the first 4 of twenty two configuration steps. No error messages or anything it just stops. Any way to debug this or which package to downgrade? A snippet of the output (note the log file does not get past installing root files)
( 1/22) Creating system user accounts...
Creating group adbusers with gid 975.
Creating group locate with gid 21.
Creating group ntp with gid 87.
Creating group avahi with gid 974.
Creating user avahi (Avahi mDNS/DNS-SD daemon) with uid 974 and gid 974.
Creating group colord with gid 973.
Creating user colord (Color management daemon) with uid 973 and gid 973.
Creating group cups with gid 209.
Creating user cups (cups helper user) with uid 209 and gid 209.
Creating group git with gid 972.
Creating user git (git daemon user) with uid 972 and gid 972.
Creating group lightdm with gid 971.
Creating user lightdm (Light Display Manager) with uid 971 and gid 971.
Creating user ntp (Network Time Protocol) with uid 87 and gid 87.
Creating group oidentd with gid 493.
Creating user oidentd (oidentd user) with uid 493 and gid 493.
Creating group polkitd with gid 102.
Creating user polkitd (PolicyKit daemon) with uid 102 and gid 102.
Creating group rtkit with gid 133.
Creating user rtkit (RealtimeKit) with uid 133 and gid 133.
Creating group usbmux with gid 140.
Creating user usbmux (usbmux user) with uid 140 and gid 140.
( 2/22) Reloading system manager configuration...
  Skipped: Current root is not booted.
( 3/22) Updating udev hardware database...
( 4/22) Creating temporary files...
Found it Its a bug in linux 510 just tried linux 59 and that works!
Everything works fine now, but how to get previous font?
In the OS settings
Same issue, no sound after upgrade and move to 5.10 but 5.9 is the same.
