Sound Issue - Dummy Output
I installed manjaro on my chromebook, and I only have dummy output, It is Apollo Lake, help.
Hi @saytaylor, and welcome!
In order to receive the help you so urgently requested, more information is necessary. To the end, please see [HowTo] Provide System Information and, if applicable, [HowTo] post screenshots and links.
Increase your chances of solving your issue:
Provide basic Information:
can someone just please tell me what to supply and i will
If you actually read the links me and @ishaan2479 gave you, you’d know.
These commands in the links mean nothing to me, I only know debian and thats only the package manager
If I get something to input into the terminal I can do something but all those commands are as good as a language i dont even know
If you know Debian, then you should know how to run a command. Don’t just skip to the commands, read, actually read what they do and what’s required of you.
Thatll take like an hour and i hardly know what anything means in that document, arch, im not familiar with, once i tried sudo apt-get install on here :confused:
No, it won’t. And besides, the information is invaluable. Also, always remember, while Manjaro has its roots in Arch, Manjaro != Arch.
P.S.: All the time you’ve spent arguing with me, you could have read those links multiple times by now.
Read the link, apply what you read. Nobody can do it for you, it is already short, so go ahead:
Edit:
Everyone on the forum, is here because we want, nobody’s getting paid for this, we do it for the love of it. Because we want to. The least you can do is not make it difficult forr those trying to be of assistance.
im sorry for not knowing hardly anything about linux
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=4142826c-eb1c-4e0a-bed3-da7996ca435a rw quiet splash apparmor=1
  Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
  Type: Laptop System: Google product: Coral v: rev5
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Google model: Coral v: rev5 serial: <superuser required>
    BIOS: coreboot v: N/A date: 11/18/2020
  ID-1: BAT0 charge: 23.9 Wh (67.1%) condition: 35.6/37.9 Wh (93.8%)
    volts: 8.3 min: 7.9 model: AS1GTQE C223-50 type: Li-ion serial: <filter>
    status: Charging cycles: 65
  RAM: total: 3.72 GiB used: 2.51 GiB (67.5%)
  RAM Report:
  Info: model: Intel Celeron N3350 bits: 64 type: MCP arch: Goldmont family: 6
    model-id: 0x5C (92) stepping: 9 microcode: 0x44
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
    desc: d-2x24 KiB; i-2x32 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 882 high: 969 min/max: 800/2400 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 796 2: 969
    bogomips: 4378
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
    arch_perfmon art bts cat_l2 clflush clflushopt cmov constant_tsc cpuid
    cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
    flexpriority fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt lahf_lm lm mca
    mce md_clear mmx movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq tsc_reliable vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
  Type: spec_store_bypass status: Not affected
  Device-1: Intel HD Graphics 500 driver: i915 v: kernel bus-ID: 00:02.0
    chip-ID: 8086:5a85 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-5:2 chip-ID: 13d3:56e8 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org 1.21.1.2 compositor: gnome-shell driver:
    loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
  Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Imaging Unit
    driver: N/A bus-ID: 00:03.0 chip-ID: 8086:5a88 class-ID: 0480
  Device-2: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster driver: snd_soc_skl v: kernel alternate: snd_hda_intel,snd_sof_pci_intel_apl
    bus-ID: 00:0e.0 chip-ID: 8086:5a98 class-ID: 0401
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.42 running: no
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 01:00.0
    chip-ID: 8086:095a class-ID: 0280
    bus-ID: 1-6:3 chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 29.12 GiB used: 8.32 GiB (28.6%)
  ID-1: /dev/mmcblk1 maj-min: 179:0 vendor: SanDisk model: DA4032
    size: 29.12 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 0x8 scheme: MBR
  ID-1: / raw-size: 29.12 GiB size: 28.49 GiB (97.85%) used: 8.32 GiB (29.2%)
    fs: ext4 dev: /dev/mmcblk1p1 maj-min: 179:1 label: N/A
    uuid: 4142826c-eb1c-4e0a-bed3-da7996ca435a
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 8 rev: 2.0
  Device-1: 1-5:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-2: 1-6:3 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 40.0 C mobo: N/A
  Processes: 196 Uptime: 11h 18m wakeups: 44445 Init: systemd v: 250
  tool: systemctl Compilers: gcc: N/A Packages: pacman: 1141 lib: 305
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
are you going to help me? you dont have to but itd be nice
Don’t be sorry about that. Just be willing to learn and do something. Don’t expect everything handed to you on a silver platter.
P.S.: That double-negative is really funny!
what double negative, these ` or idk what ur talking abt haha
:point_up: That is a double-negative.
You’re saying sorry for not knowing hardly anything about Linux. And if you don’t know hardly anything, you do know a lot. So it actually means you’re sorry for knowing a lot about Linux.
confused me
OK, back on track now. Please provide the output for:
pamac search manjaro-pipewire
And
systemctl list-unit-files --all | grep -i pipewire
Pamac: manjaro-pipewire 20220107-1 extra Manjaro meta package for complete PipeWire support.
SystemCTL didnt list anything.
https://paste.pics/FMTVS
In the future, when posting anything from the console, please format it like your post with the inxi output. This increases legigbility, making it easier for those trying to be of assistance.
Note:
About audio, I know absolutely nothing, zilch, 0 etc., so this is plain, plain, plain guesswork.
Try installing manjaro-pipewire and see what happens:
pamac install manjaro-pipewire
If this doesn’t help, or do anything, I’m afraid I don’t know anymore and we’ll have to wait for reinforcements.
