Screen turn black and only mouse cursor
Hi community,
I made some customization to my kde desktop environment, after that when the system feels for it the screen turn black and only mouse cursor. i have a Radeon RX550 GPU.
the system take ages to restart or shutdown. a micro seconds before shutdown or reboot a post shows and disperses. so it seems that something is wrong with the shut down and reboot process!
I have also noticed that my pci-e paralel card is not installed.
i belive all this happened after the update, what have i done wrong?
can you enter TTY by pressing on the black screen ctrl+alt+f2 if f2 doesnt work, try with f1-f6 keys
Not working
can you access grub menu and select a different kernel if you have installed, if no, try with the fallback…
If you see mouse cursor you must be able to get into different TTY…
i am in the desktop now, it happens ramdomly when it feels for it, Alt F2 gives me the search bar for get into console and chance to reboot the system. and reboot or shutdown process take long time. after reboot the system works fine and out of nowhere it happens again.
We’ll need more information.
so if youre in your system post output from:
inxi -Fazy
mhwd -l && mhwd -li
journalctl --boot=0 --priority=3 --no-pager
inxi -Fazy
inxi -Fazy         INT ✘  57s 
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_ADDRESS = "sv_SE.UTF-8",
        LC_IDENTIFICATION = "sv_SE.UTF-8",
        LC_MEASUREMENT = "sv_SE.UTF-8",
        LC_MONETARY = "sv_SE.UTF-8",
        LC_NAME = "sv_SE.UTF-8",
        LC_NUMERIC = "sv_SE.UTF-8",
        LC_PAPER = "sv_SE.UTF-8",
        LC_TELEPHONE = "sv_SE.UTF-8",
        LC_TIME = "nl_BQ.UTF-8",
        LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
  Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=a0d761d6-6e23-4ee4-98cc-0841494a4e7e rw quiet apparmor=1
    security=apparmor resume=UUID=174a421d-e5dc-4bcf-a8de-6f2770d83f7c
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: KLLISRE model: X99-B5 v: V1.1
    serial: <superuser required> UEFI: American Megatrends v: 5.11
    date: 03/04/2022
  Info: model: Intel Xeon E5-2696 v3 bits: 64 type: MT MCP arch: Haswell
    family: 6 model-id: 0x3F (63) stepping: 2 microcode: 0x49
  Topology: cpus: 1x cores: 18 tpc: 2 threads: 36 smt: enabled cache:
    L1: 1.1 MiB desc: d-18x32 KiB; i-18x32 KiB L2: 4.5 MiB desc: 18x256 KiB
    L3: 45 MiB desc: 1x45 MiB
  Speed (MHz): avg: 1243 high: 1784 min/max: 1200/3800 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1449 2: 1198 3: 1197
    4: 1197 5: 1198 6: 1198 7: 1198 8: 1197 9: 1197 10: 1723 11: 1198 12: 1198
    13: 1198 14: 1197 15: 1198 16: 1197 17: 1197 18: 1198 19: 1784 20: 1198
    21: 1198 22: 1198 23: 1198 24: 1198 25: 1198 26: 1198 27: 1198 28: 1501
    29: 1197 30: 1197 31: 1198 32: 1198 33: 1197 34: 1198 35: 1197 36: 1198
    bogomips: 165299
  Type: l1tf
  Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
    driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 ports:
    active: HDMI-A-3 empty: HDMI-A-1,HDMI-A-2,HDMI-A-4 bus-ID: 03:00.0
    chip-ID: 1002:699f class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
    alternate: fbdev,vesa gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-3 res: 1680x1050 size: N/A modes: N/A
  OpenGL: renderer: AMD Radeon RX 550 / 550 Series (polaris12 LLVM 13.0.1
    DRM 3.42 5.15.38-1-MANJARO)
    v: 4.6 Mesa 22.0.3 direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
    bus-ID: 03:00.1 chip-ID: 1002:aae0 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: N/A
    modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2725
    class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 3-11:4 chip-ID: 8087:0032 class-ID: e001
  Local Storage: total: 931.51 GiB used: 107.13 GiB (11.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: KLLISRE 1TB size: 931.51 GiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
    type: SSD serial: <filter> rev: T0709A3 temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 896.89 GiB size: 881.74 GiB (98.31%)
    used: 107.13 GiB (12.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 34.32 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Processes: 507 Uptime: 2h 27m wakeups: 1 Memory: 31.2 GiB
  used: 2.61 GiB (8.4%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1358 lib: 344 flatpak: 0
  Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
mhwd -l && mhwd -li
mhwd -l && mhwd -li         ✔
> 0000:03:00.0 (0300:1002:699f) Display controller ATI Technologies Inc:
           video-linux            2018.05.04                true            PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> Installed PCI configs:
ournalctl --boot=0 --priority=3 --no-pager                                                    ✔
May 16 15:16:52 evie-dev systemd-modules-load[528]: Failed to find module 'nvidia-uvm'
May 16 15:16:53 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 16 15:16:53 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 16 15:16:53 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
May 16 15:16:54 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 16 15:16:54 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 16 15:16:54 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
May 16 15:16:55 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 16 15:16:55 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 16 15:16:55 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
May 16 15:16:55 evie-dev systemd[969]: Failed to start Update XDG user dir configuration.
May 16 15:16:56 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 16 15:16:56 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 16 15:16:56 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
May 16 15:16:57 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 16 15:16:57 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 16 15:16:57 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
May 16 15:16:58 evie-dev systemd[1]: Failed to start pkgfile database update.
so first, fix your locales
second, dont use wayland on KDE
third, there is some nvidia drivers issue, though you dont have any nvidia
post output from:
find /etc/X11/ -name "*.conf"
find /etc/X11/ -name "*.conf"         ✔
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
open the add/remove software and search for nvidia and click on installed on the left side…is there anything listed?
Is this a log from your current session?
Have you reproduced the issue in it yet? Otherwise we’d rather need the log from a previous session during which you got the issue.
Do you also experience the issue when using X11 instead of Wayland?
I saw that the Nvidia Utils are installed, i tried to uninstall it and i get the msg
could not satisfy dependencies:
- removing nvidia-utils breaks dependency 'nvidia-utils' required by cuda
journalctl --boot=-1 --priority=3 --catalog                                                    ✔
May 15 15:39:47 evie-dev systemd-modules-load[533]: Failed to find module 'nvidia-uvm'
May 15 15:39:49 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 15 15:39:49 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 15 15:39:49 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
May 15 15:39:49 evie-dev kernel: iwlwifi 0000:07:00.0: SecBoot CPU1 Status: 0x702f, CPU2 Status: 0xb03
May 15 15:39:49 evie-dev kernel: iwlwifi 0000:07:00.0: UMAC PC: 0x8047f600
May 15 15:39:49 evie-dev kernel: iwlwifi 0000:07:00.0: LMAC PC: 0x0
May 15 15:39:49 evie-dev kernel: iwlwifi 0000:07:00.0: Loaded firmware version: 66.f1c864e0.0 ty-a0-gf-a0-66.>
...skipping...
May 15 15:39:53 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
May 15 15:39:53 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 15 15:39:53 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 15 15:39:54 evie-dev kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
May 15 15:39:54 evie-dev kernel: EDAC sbridge: Couldn't find mci handler
May 15 15:39:54 evie-dev kernel: EDAC sbridge: Failed to register device with error -19.
...skipping...
...skipping...
...skipping...
why do you have nvidia stuff installed if you have radeon graphics…
remove cuda first, then remove nvidia, then switch to x11 instead of wayland and reboot
Removed cuda and got
Warning: blender optionally requires cuda: cycles renderer cuda support
Warning: openmpi optionally requires cuda: cuda support
Removed Nvidia Util
Warning: ffmpeg optionally requires nvidia-utils: Nvidia NVDEC/NVENC support
Warning: ffmpeg4.4 optionally requires nvidia-utils: Nvidia NVDEC/NVENC support
Warning: steam-manjaro optionally requires vulkan-driver: packaged vulkan driver
Warning: vulkan-icd-loader optionally requires vulkan-driver: packaged vulkan driver
Dont know why or how
ok so now switch to x11 and try running your system with it, and see if you still get issues
for the locale errors check this link
for the Couldn't find mci handler spam check this link
also clear your cache with:
rm -rf ~/.cache/*
sudo pacman -Sc
reboot
braham i have to say, your reputation precedes you.
you got some style
