I’m seeing these in dmesg:
[ +0.000022] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ +0.000071] EDAC sbridge: Couldn't find mci handler
[ +0.000063] EDAC sbridge: Failed to register device with error -19.
I remember getting these on other distro’s as well, but never took the effort to ask about it.
Anyone any idea how to fix/prevent these?
lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DMI2 [8086:2f00] (rev 02)
Subsystem: Intel Corporation Device [8086:0000]
Flags: fast devsel, NUMA node 0, IOMMU group 12
Capabilities: [90] Express Root Port (Slot-), MSI 00
Capabilities: [e0] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
Capabilities: [144] Vendor Specific Information: ID=0004 Rev=1 Len=03c <?>
Capabilities: [1d0] Vendor Specific Information: ID=0003 Rev=1 Len=00a <?>
Capabilities: [280] Vendor Specific Information: ID=0005 Rev=3 Len=018 <?>
Capabilities: [300] Vendor Specific Information: ID=0008 Rev=0 Len=038 <?>
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 [8086:2f02] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25, NUMA node 0, IOMMU group 13
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
Capabilities: [40] Subsystem: Intel Corporation Device [8086:0000]
Capabilities: [60] MSI: Enable+ Count=1/2 Maskable+ 64bit-
Capabilities: [90] Express Root Port (Slot+), MSI 00
Capabilities: [110] Access Control Services
Capabilities: [148] Advanced Error Reporting
Capabilities: [250] Secondary PCI Express
Kernel driver in use: pcieport
00:01.1 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 [8086:2f03] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26, NUMA node 0, IOMMU group 14
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:03.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 [8086:2f08] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28, NUMA node 0, IOMMU group 15
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: fa000000-fb0fffff [size=17M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
00:05.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Address Map, VTd_Misc, System Management [8086:2f28] (rev 02)
Flags: fast devsel, NUMA node 0, IOMMU group 16
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
00:05.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Hot Plug [8086:2f29] (rev 02)
Flags: fast devsel, NUMA node 0, IOMMU group 17
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [100] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
Capabilities: [110] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
Capabilities: [120] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
Capabilities: [130] Vendor Specific Information: ID=0006 Rev=1 Len=010 <?>
00:05.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 RAS, Control Status and Global Errors [8086:2f2a] (rev 02)
Flags: fast devsel, NUMA node 0, IOMMU group 18
00:05.4 PIC [0800]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 I/O APIC [8086:2f2c] (rev 02) (prog-if 20 [IO(X)-APIC])
Flags: bus master, fast devsel, latency 0, NUMA node 0, IOMMU group 19
Memory at fb63d000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [44] Express Root Complex Integrated Endpoint, MSI 00
00:11.0 Unassigned class [ff00]: Intel Corporation C610/X99 series chipset SPSR [8086:8d7c] (rev 05)
Subsystem: ASUSTeK Computer Inc. Device [1043:8600]
Flags: fast devsel, NUMA node 0, IOMMU group 20
Capabilities: [80] Power Management version 3
00:14.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB xHCI Host Controller [8086:8d31] (rev 05) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23, NUMA node 0, IOMMU group 21
Memory at fb620000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller [0780]: Intel Corporation C610/X99 series chipset MEI Controller #1 [8086:8d3a] (rev 05)
Flags: bus master, fast devsel, latency 0, IRQ 43, NUMA node 0, IOMMU group 22
Memory at fb639000 (64-bit, non-prefetchable) [size=16]
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: mei_me
Kernel modules: mei_me
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I218-V [8086:15a1] (rev 05)
DeviceName: Onboard LAN
Subsystem: ASUSTeK Computer Inc. Device [1043:85c4]
Flags: bus master, fast devsel, latency 0, IRQ 42, NUMA node 0, IOMMU group 23
Memory at fb600000 (32-bit, non-prefetchable) [size=128K]
Memory at fb636000 (32-bit, non-prefetchable) [size=4K]
I/O ports at f000 [size=32]
Capabilities: [c8] Power Management version 2
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [e0] PCI Advanced Features
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #2 [8086:8d2d] (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18, NUMA node 0, IOMMU group 24
Memory at fb635000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1b.0 Audio device [0403]: Intel Corporation C610/X99 series chipset HD Audio Controller [8086:8d20] (rev 05)
Subsystem: ASUSTeK Computer Inc. Device [1043:8637]
Flags: bus master, fast devsel, latency 0, IRQ 44, NUMA node 0, IOMMU group 25
Memory at fb630000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #1 [8086:8d10] (rev d5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29, NUMA node 0, IOMMU group 26
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Capabilities: [40] Express Root Port (Slot-), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device [1043:8600]
Capabilities: [a0] Power Management version 3
00:1c.3 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #4 [8086:8d16] (rev d5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, NUMA node 0, IOMMU group 27
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: fb200000-fb4fffff [size=3M]
Capabilities: [40] Express Root Port (Slot+), MSI 00
00:1c.4 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #5 [8086:8d18] (rev d5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 31, NUMA node 0, IOMMU group 28
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: fb500000-fb5fffff [size=1M]
00:1d.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #1 [8086:8d26] (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 21, NUMA node 0, IOMMU group 29
Memory at fb634000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge [0601]: Intel Corporation C610/X99 series chipset LPC Controller [8086:8d47] (rev 05)
Flags: bus master, medium devsel, latency 0, NUMA node 0, IOMMU group 30
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation C610/X99 series chipset 6-Port SATA Controller [AHCI mode] [8086:8d02] (rev 05) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 32, NUMA node 0, IOMMU group 30
I/O ports at f0d0 [size=8]
I/O ports at f0c0 [size=4]
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f020 [size=32]
Memory at fb63c000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation C610/X99 series chipset SMBus Controller [8086:8d22] (rev 05)
Flags: medium devsel, IRQ 18, NUMA node 0, IOMMU group 30
Memory at fb63b000 (64-bit, non-prefetchable) [size=256]
I/O ports at 0580 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] [10de:1b06] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device [19da:4471]
Physical Slot: 4
Flags: bus master, fast devsel, latency 0, IRQ 41, NUMA node 0, IOMMU group 31
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at fb000000 [virtual] [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation GP102 HDMI Audio Controller [10de:10ef] (rev a1)
Physical Slot: 4
Flags: bus master, fast devsel, latency 0, IRQ 45, NUMA node 0, IOMMU group 31
Memory at fb080000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
05:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4352 802.11ac Wireless Network Adapter [14e4:43b1] (rev 03)
Subsystem: ASUSTeK Computer Inc. Device [1043:855c]
Flags: bus master, fast devsel, latency 0, IRQ 19, NUMA node 0, IOMMU group 32
Memory at fb400000 (64-bit, non-prefetchable) [size=32K]
Memory at fb200000 (64-bit, non-prefetchable) [size=2M]
Capabilities: [48] Power Management version 3
Capabilities: [58] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [68] Vendor Specific Information: Len=44 <?>
Capabilities: [ac] Express Endpoint, MSI 00
Capabilities: [13c] Device Serial Number 30-10-00-ff-ff-00-00-01
Capabilities: [150] Power Budgeting <?>
Capabilities: [160] Virtual Channel
Capabilities: [1b0] Latency Tolerance Reporting
Capabilities: [220] Physical Resizable BAR
Kernel driver in use: wl
Kernel modules: bcma, wl
06:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller [1b21:1242] (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Device [1043:8675]
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0, IOMMU group 33
Memory at fb500000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [68] MSI-X: Enable+ Count=8 Masked-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Endpoint, MSI 00
Capabilities: [200] Advanced Error Reporting
Capabilities: [280] Secondary PCI Express
Capabilities: [300] Latency Tolerance Reporting
ff:0b.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f81] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f81]
Flags: fast devsel, IOMMU group 0
ff:0b.1 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f36] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f36]
Kernel driver in use: hswep_uncore
ff:0b.2 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f37] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f37]
ff:0c.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe0]
Flags: fast devsel, IOMMU group 1
ff:0c.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe1] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe1]
ff:0c.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe2] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe2]
ff:0c.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe3] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe3]
ff:0c.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe4] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe4]
ff:0c.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe5] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe5]
ff:0f.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent [8086:2ff8] (rev 02)
Flags: fast devsel, IOMMU group 2
ff:0f.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent [8086:2ff9] (rev 02)
ff:0f.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers [8086:2ffc] (rev 02)
Subsystem: Intel Corporation Device [8086:2fe0]
ff:0f.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers [8086:2ffd] (rev 02)
ff:0f.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers [8086:2ffe] (rev 02)
ff:10.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f1d] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f1d]
Flags: fast devsel, IOMMU group 3
ff:10.1 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f34] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f34]
ff:10.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1e] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1e]
ff:10.6 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f7d] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f7d]
ff:10.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1f] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1f]
ff:12.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2fa0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2fa0]
Flags: fast devsel, IOMMU group 4
ff:12.1 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2f30] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2f30]
ff:13.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086... (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086:2fa8]
Flags: fast devsel, IOMMU group 5
ff:13.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086... (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086:2f71]
ff:13.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2faa] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2faa]
ff:13.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fab] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fab]
ff:13.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fac] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fac]
ff:13.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fad] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fad]
ff:13.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 0/1 Broadcast [8086:2fae] (rev 02)
ff:13.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast [8086:2faf] (rev 02)
ff:14.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control [8086:2fb0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control [8086:2fb0]
Flags: fast devsel, IOMMU group 6
ff:14.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control [8086:2fb1] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control [8086:2fb1]
ff:14.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers [8086:2fb2] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers [8086:2fb2]
ff:14.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers [8086:2fb3] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers [8086:2fb3]
ff:14.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbc] (rev 02)
ff:14.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbd] (rev 02)
ff:14.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbe] (rev 02)
ff:14.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbf] (rev 02)
ff:15.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control [8086:2fb4] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control [8086:2fb4]
Flags: fast devsel, IOMMU group 7
ff:15.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control [8086:2fb5] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control [8086:2fb5]
ff:15.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers [8086:2fb6] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers [8086:2fb6]
ff:15.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers [8086:2fb7] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers [8086:2fb7]
ff:16.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Target Address, Thermal & RAS Registers [8086... (rev 02)
Flags: fast devsel, IOMMU group 8
ff:16.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 2/3 Broadcast [8086:2f6e] (rev 02)
ff:16.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast [8086:2f6f] (rev 02)
ff:17.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Channel 0 Thermal Control [8086:2fd0] (rev 02)
Flags: fast devsel, IOMMU group 9
ff:17.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fb8] (rev 02)
ff:17.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fb9] (rev 02)
ff:17.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fba] (rev 02)
ff:17.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fbb] (rev 02)
ff:1e.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f98] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f98]
Flags: fast devsel, IOMMU group 10
ff:1e.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f99] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f99]
ff:1e.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9a] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9a]
ff:1e.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2fc0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2fc0]
I/O ports at <ignored> [disabled]
ff:1e.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9c] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9c]
ff:1f.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU [8086:2f88] (rev 02)
Flags: fast devsel, IOMMU group 11
ff:1f.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU [8086:2f8a] (rev 02)
