Hello everyone, first post for me, I guess.
I have newly installed Manjaro about 2 weeks ago from writing. In the first week everything ran ok, but after that the resolution had suddenly changed to 1280x720 from the usual 1920x1080. This was observable right at boot (the small text on the left-hand corner that usually appears at boot was larger).
There are two users on this computer, one is myself as the admin account, while the other is for my sister (normal account). The resolution change had spanned across both users and the greeter. I had tried a solution from the forum (could not find the link, but it was something about entering the “tty” and writing exec xfcedesktop).
After a shutdown, the resolution had changed back to normal. I thought that would be the end of it but the busted resolution decided to appear once again, and during the use of last week, the resolution changed back and forth inconsistently, always after a complete shutdown.
This is what it normally looks like from display settings:
And this is what it looks like on the broken resolution:
Both screenshots are at fullscreen.
Note that I could not change the resolution in the “broken res” times. I am still a bit new to Manjaro, so do keep it simple if you can.
Edit:
System Info
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=89d788bd-2090-45f0-94bc-9fa89e675e8c rw quiet apparmor=1
security=apparmor resume=UUID=acb4d482-530d-426f-8779-7d711fc61053
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 8
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-E v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 5602 date: 07/14/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M280/320/275
status: Discharging
RAM: total: 5.72 GiB used: 2.79 GiB (48.7%)
Info: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
type: MCP arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108109 cache: L2: 2 MiB bogomips: 28762
Speed: 1397 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1323 3: 1414 4: 1368
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:15d8 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,modesetting unloaded: radeon alternate: fbdev,vesa
display-ID: :1.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DP-1 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.41.0
5.13.19-2-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK PRIME B450M-A
driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8168 v: 8.049.02-NAPI modules: r8169
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.13 TiB used: 11.35 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC46 scheme: GPT
ID-1: / raw-size: 128 GiB size: 124.93 GiB (97.60%) used: 9.48 GiB (7.6%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 89d788bd-2090-45f0-94bc-9fa89e675e8c
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 5B89-C921
ID-3: /home raw-size: 91.28 GiB size: 89.28 GiB (97.82%)
used: 1.87 GiB (2.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 32c9e49f-0b95-4950-b7b1-8d2a77ac2e1a
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: acb4d482-530d-426f-8779-7d711fc61053
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 3-4:3 info: A4Tech KV-300H Isolation Keyboard type: Keyboard,HID
power: 100mA chip-ID: 09da:0260 class-ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.6 C mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 326 Uptime: 3h 39m wakeups: 366 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1125 pacman: 1120 lib: 334
flatpak: 5 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.08
