Preface I’ve been using linux for 3 days so I’m basically an expert assume I know absolutely nothing.
Timeline:
I make snapshots before everything as well as daily.
I make one just before enabling AUR
I think maybe I should reboot
Now my screen is stuck at 1024x768 I cannot change this.
Drivers appear to be fine. As far as I can tell I’m still using the open source Nvidia drivers.
So far I have tried:
Turning monitor on/off.
Several reboots.
Restored snapshot.
Restored earlier snapshot.
Swap the which port the cable is plugged in.
Swap cable from Display Port to HDMI.
I don’t believe just enabling AUR ALONE would do anything like this, that sounds absurd. But the first reboot changed SOMETHING.
I did read a post on this forum
https://forum.manjaro.org/t/resolution-sometimes-gets-set-to-1024x768/89739
Nearly identical issue involving EDID related issues with the monitor. This is likely the same, but what made it stop working to begin with?
inxi output:
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=2eb574ac-2aa1-4efa-9f14-df9ed9320f33 rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: MSI product: MS-7816 v: 1.0
serial: <superuser required>
Mobo: MSI model: Z87-G43 (MS-7816) v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: 1.11 date: 05/09/2015
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/3900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 54418
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB]
vendor: ASUSTeK DUAL-GTX1060-O6G driver: N/A alternate: nouveau
non-free: 545.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
s-diag: 338mm (13.3")
Monitor-1: Unknown-1 mapped: None-1 res: 1024x768 hz: 60 size: N/A
modes: 1024x768
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast x11: drv: swrast inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.0.2-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 15.2 GiB unified: yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio
vendor: ASUSTeK DUAL-GTX1060-O6G driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Realtek 802.11ac NIC driver: rtw_8821cu type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0bda:c811
class-ID: 0000 serial: <filter>
IF: wlp0s20u3 state: up mac: <filter>
Local Storage: total: 1.46 TiB used: 31.01 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A120G
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Kingston model: SA400S37120G
tech: SSD serial: <filter> fw-rev: B1D1 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Kingston model: SV300S37A240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 223.27 GiB size: 223.27 GiB (100.00%)
used: 31.01 GiB (13.9%) fs: btrfs dev: /dev/sde2 maj-min: 8:66
used: 584 KiB (0.2%) fs: vfat dev: /dev/sde1 maj-min: 8:65
ID-3: /home raw-size: 223.27 GiB size: 223.27 GiB (100.00%)
ID-4: /var/log raw-size: 223.27 GiB size: 223.27 GiB (100.00%)
System Temperatures: cpu: 25.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.56 GiB used: 2.59 GiB (16.6%)
Processes: 250 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1427 pm: pacman pkgs: 1420 libs: 400 tools: pamac pm: flatpak
pkgs: 7 Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh v: 5.9
default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.34
So where do I go from here? If I need an EDID file how does one acquire/make one?
