888
11 August 2022 15:48
1
There are “Recent dependency problems from changes in package updates.”
I’ve noticed strange things, like taskbar icons disappearing and replaced by other icons when i remove some packages.
I’ve noticed it via Pamac GUI (Add/Remove Software).
Last packages i removed were UFW/UFW-Extras/GUFW Firewall packages. And it removed firefox from the task manager and replaced chromium with it… That’s odd
I’m available to provide extra info and test things out, to help the devs if needed.
This will improve my knowledge in Linux anyway.
More than odd, this seems illogical…
How exactly did you remove those packages?
Strit
11 August 2022 16:13
3
Please provide the content of /var/log/pacman.log from where you removed UFW.
888
11 August 2022 16:19
4
[2022-08-05T14:28:47+0100] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / --needed -Sy xf86-video-ati xf86-video-amdgpu xf86-video-intel xf86-video-nouveau vulkan-intel vulkan-radeon libva-mesa-driver libva-vdpau-driver mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon lib32-libva-vdpau-driver lib32-mesa-vdpau'
[2022-08-05T14:28:47+0100] [PACMAN] synchronizing package lists
[2022-08-05T14:28:47+0100] [ALPM] transaction started
[2022-08-05T14:28:47+0100] [ALPM] installed xf86-video-ati (1:19.1.0.r9.g5eba006e-2)
[2022-08-05T14:28:47+0100] [ALPM] installed xf86-video-amdgpu (22.0.0-1)
[2022-08-05T14:28:47+0100] [ALPM] installed libxvmc (1.0.13-1)
[2022-08-05T14:28:47+0100] [ALPM] installed xf86-video-intel (1:2.99.917+916+g31486f40-2)
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] >>> This driver now uses DRI3 as the default Direct Rendering
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] Infrastructure. You can try falling back to DRI2 if you run
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] into trouble. To do so, save a file with the following
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] content as /etc/X11/xorg.conf.d/20-intel.conf :
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] Section "Device"
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] Identifier "Intel Graphics"
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] Driver "intel"
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] Option "DRI" "2" # DRI3 is now default
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] #Option "AccelMethod" "sna" # default
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] #Option "AccelMethod" "uxa" # fallback
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] EndSection
[2022-08-05T14:28:47+0100] [ALPM] installed xf86-video-nouveau (1.0.17-2)
[2022-08-05T14:28:47+0100] [ALPM] installed vulkan-intel (22.1.3-1)
[2022-08-05T14:28:47+0100] [ALPM] installed vulkan-radeon (22.1.3-1)
[2022-08-05T14:28:47+0100] [ALPM] installed mesa-vdpau (22.1.3-1)
[2022-08-05T14:28:47+0100] [ALPM] installed lib32-vulkan-intel (22.1.3-1)
[2022-08-05T14:28:47+0100] [ALPM] installed lib32-vulkan-radeon (22.1.3-1)
[2022-08-05T14:28:47+0100] [ALPM] installed lib32-mesa-vdpau (22.1.3-1)
[2022-08-05T14:28:47+0100] [ALPM] transaction completed
[2022-08-05T14:28:47+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T14:28:47+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T14:28:47+0100] [ALPM-SCRIPTLET] Error connecting: Could not connect: No such file or directory
[2022-08-05T14:28:47+0100] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / -D --asexplicit xf86-video-ati xf86-video-amdgpu xf86-video-intel xf86-video-nouveau vulkan-intel vulkan-radeon libva-mesa-driver libva-vdpau-driver mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon lib32-libva-vdpau-driver lib32-mesa-vdpau'
[2022-08-05T14:29:25+0100] [PACMAN] Running 'pacman -Syy'
[2022-08-05T14:29:25+0100] [PACMAN] synchronizing package lists
[2022-08-05T14:29:27+0100] [PACMAN] Running 'pacman -R --noconfirm amd-ucode'
[2022-08-05T14:29:27+0100] [ALPM] transaction started
[2022-08-05T14:29:27+0100] [ALPM] removed amd-ucode (20220610.7b71b75-1)
[2022-08-05T14:29:27+0100] [ALPM] transaction completed
[2022-08-05T14:29:27+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T14:29:27+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T14:29:27+0100] [ALPM-SCRIPTLET] Error connecting: Could not connect: No such file or directory
[2022-08-05T15:01:30+0100] [PAMAC] synchronizing package lists
[2022-08-05T15:01:44+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-05T15:01:44+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-05T15:01:44+0100] [ALPM] transaction started
[2022-08-05T15:01:44+0100] [ALPM] upgraded manjaro-keyring (20220514-1 -> 20220514-2)
[2022-08-05T15:01:44+0100] [ALPM-SCRIPTLET] ==> Appending keys from manjaro.gpg...
[2022-08-05T15:01:45+0100] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2022-08-05T15:01:45+0100] [ALPM-SCRIPTLET] -> Locally signed 1 keys.
[2022-08-05T15:01:45+0100] [ALPM-SCRIPTLET] ==> Importing owner trust values...
[2022-08-05T15:01:45+0100] [ALPM-SCRIPTLET] ==> Updating trust database...
[2022-08-05T15:01:45+0100] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2022-08-09
[2022-08-05T15:01:45+0100] [ALPM] upgraded archlinux-keyring (20220424-1 -> 20220713-2)
[2022-08-05T15:01:45+0100] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2022-08-05T15:01:48+0100] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2022-08-05T15:01:48+0100] [ALPM-SCRIPTLET] -> Locally signed 1 keys.
[2022-08-05T15:01:48+0100] [ALPM-SCRIPTLET] ==> Importing owner trust values...
[2022-08-05T15:01:48+0100] [ALPM-SCRIPTLET] gpg: setting ownertrust to 4
[2022-08-05T15:01:48+0100] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2022-08-05T15:01:49+0100] [ALPM-SCRIPTLET] -> Disabled 2 keys.
[2022-08-05T15:01:49+0100] [ALPM-SCRIPTLET] ==> Updating trust database...
[2022-08-05T15:01:49+0100] [ALPM-SCRIPTLET] gpg: marginals needed: 3 completes needed: 1 trust model: pgp
[2022-08-05T15:01:49+0100] [ALPM-SCRIPTLET] gpg: depth: 0 valid: 1 signed: 22 trust: 0-, 0q, 0n, 0m, 0f, 1u
[2022-08-05T15:01:49+0100] [ALPM-SCRIPTLET] gpg: depth: 1 valid: 22 signed: 93 trust: 0-, 0q, 0n, 22m, 0f, 0u
[2022-08-05T15:01:49+0100] [ALPM-SCRIPTLET] gpg: depth: 2 valid: 70 signed: 30 trust: 70-, 0q, 0n, 0m, 0f, 0u
[2022-08-05T15:01:49+0100] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2022-08-09
[2022-08-05T15:01:49+0100] [ALPM] installed base (3-2)
[2022-08-05T15:01:49+0100] [ALPM] upgraded manjaro-system (20220202-2 -> 20220727-1)
[2022-08-05T15:01:50+0100] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Checking for 'os-prober' setup ...e[1;0m
[2022-08-05T15:01:50+0100] [ALPM-SCRIPTLET] 'os-prober' was already enabled by the user.
[2022-08-05T15:01:50+0100] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Checking if graphic drivers need an update ...e[1;0m
[2022-08-05T15:01:50+0100] [ALPM] transaction completed
[2022-08-05T15:01:50+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T15:01:50+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T15:04:18+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-05T15:04:18+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-05T15:04:18+0100] [ALPM] running '60-mkinitcpio-remove.hook'...
[2022-08-05T15:04:18+0100] [ALPM] running 'firefox-pre.hook'...
[2022-08-05T15:04:18+0100] [ALPM] transaction started
[2022-08-05T15:04:18+0100] [ALPM] upgraded alsa-card-profiles (1:0.3.54-1 -> 1:0.3.56-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded alsa-ucm-conf (1.2.7.1-1 -> 1.2.7.2-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded alsa-lib (1.2.7.1-1 -> 1.2.7.2-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded libidn2 (2.3.2-1 -> 2.3.3-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded gcc-libs (12.1.0-2 -> 12.1.0-3)
[2022-08-05T15:04:18+0100] [ALPM] upgraded libldap (2.6.2-2 -> 2.6.3-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded libcap (2.64-1 -> 2.65-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded systemd-libs (251.2-3 -> 251.3-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded ca-certificates-mozilla (3.80-1 -> 3.81-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded sqlite (3.39.0-2 -> 3.39.1-1)
[2022-08-05T15:04:18+0100] [ALPM] upgraded pacman (6.0.1-11 -> 6.0.1-12)
[2022-08-05T15:04:18+0100] [ALPM] upgraded gcab (1.4-1 -> 1.4-2)
[2022-08-05T15:04:18+0100] [ALPM] upgraded iso-codes (4.10.0-1 -> 4.11.0-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded llvm-libs (14.0.6-1 -> 14.0.6-2)
[2022-08-05T15:04:19+0100] [ALPM] upgraded vulkan-icd-loader (1.3.217-1 -> 1.3.221-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded mesa (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded harfbuzz (4.4.1-1 -> 5.0.1-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded systemd (251.2-3 -> 251.3-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded duktape (2.7.0-2 -> 2.7.0-4)
[2022-08-05T15:04:19+0100] [ALPM] upgraded appstream-glib (0.7.18-3 -> 0.8.0-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded archlinux-appstream-data (20220618-1 -> 20220727-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded efibootmgr (17-2 -> 18-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded nss (3.80-1 -> 3.81-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded gsm (1.0.19-1 -> 1.0.20-1)
[2022-08-05T15:04:19+0100] [ALPM] upgraded lame (3.100-3 -> 3.100-4)
[2022-08-05T15:04:19+0100] [ALPM] upgraded libwebp (1.2.2-1 -> 1.2.3-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded firefox (102.0.1-1 -> 103.0-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded fluidsynth (2.2.7-1 -> 2.2.8-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded polkit (0.120-5 -> 121-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded libmm-glib (1.18.10-1 -> 1.18.10-2)
[2022-08-05T15:04:20+0100] [ALPM] upgraded protobuf (21.2-1 -> 21.4-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded protobuf-c (1.4.0-4 -> 1.4.1-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded fwupd (1.8.1-1 -> 1.8.3-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded gcc (12.1.0-2 -> 12.1.0-3)
[2022-08-05T15:04:20+0100] [ALPM] upgraded gcr (3.41.0-2 -> 3.41.1-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded git (2.37.0-1 -> 2.37.1-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded perl-uri (5.11-1 -> 5.12-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded hwinfo (21.81-1 -> 21.82-1)
[2022-08-05T15:04:20+0100] [ALPM] upgraded hwloc (2.7.1-1 -> 2.8.0-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded imagemagick (7.1.0.43-1 -> 7.1.0.44-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded imlib2 (1.9.0-3 -> 1.9.1-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded inxi (3.3.19.1-1 -> 3.3.20.1-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded jasper (3.0.4-1 -> 3.0.6-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded ldb (2:2.5.1-1 -> 2:2.5.2-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-alsa-lib (1.2.7.1-1 -> 1.2.7.2-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-gcc-libs (12.1.0-2 -> 12.1.0-3)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-libldap (2.6.2-1 -> 2.6.3-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-libcap (2.64-1 -> 2.65-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-libdrm (2.4.111-1 -> 2.4.112-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-libidn2 (2.3.2-1 -> 2.3.3-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-llvm-libs (14.0.6-1 -> 14.0.6-2)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-libva-mesa-driver (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-libxrender (0.9.10-2 -> 0.9.10-3)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-libxtst (1.2.3-2 -> 1.2.3-3)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.217-1 -> 1.3.221-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-mesa (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-mesa-vdpau (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-systemd (251.1-1 -> 251.3-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-vulkan-intel (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded lib32-vulkan-radeon (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libbpf (0.8.0-1 -> 0.8.1-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libbs2b (3.1.0-7 -> 3.1.0-8)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libimagequant (2.17.0-3 -> 4.0.0-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libnm (1.38.2-1 -> 1.38.2-2)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libnotify (0.7.12-1 -> 0.8.1-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libplacebo (4.192.1-3 -> 4.208.0-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libva-mesa-driver (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded libzip (1.8.0-1 -> 1.9.2-1)
[2022-08-05T15:04:21+0100] [ALPM] upgraded linux-firmware-whence (20220610.7b71b75-1 -> 20220708.be7798e-1)
[2022-08-05T15:04:22+0100] [ALPM] upgraded linux-firmware (20220610.7b71b75-1 -> 20220708.be7798e-1)
[2022-08-05T15:04:22+0100] [ALPM] upgraded linux515 (5.15.53-1 -> 5.15.57-2)
[2022-08-05T15:04:23+0100] [ALPM] upgraded llvm (14.0.6-1 -> 14.0.6-2)
[2022-08-05T15:04:23+0100] [ALPM] upgraded logrotate (3.19.0-1 -> 3.20.1-1)
[2022-08-05T15:04:23+0100] [ALPM] upgraded lv2 (1.18.4-2 -> 1.18.6-1)
[2022-08-05T15:04:23+0100] [ALPM] upgraded manjaro-release (21.3.3-1 -> 21.3.6-1)
[2022-08-05T15:04:23+0100] [ALPM] upgraded mesa-vdpau (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:23+0100] [ALPM] upgraded mobile-broadband-provider-info (20220511-1 -> 20220725-1)
[2022-08-05T15:04:23+0100] [ALPM] upgraded modemmanager (1.18.10-1 -> 1.18.10-2)
[2022-08-05T15:04:23+0100] [ALPM] upgraded mpg123 (1.29.3-2 -> 1.30.1-1)
[2022-08-05T15:04:23+0100] [ALPM] upgraded networkmanager (1.38.2-1 -> 1.38.2-2)
[2022-08-05T15:04:25+0100] [ALPM] upgraded onlyoffice-desktopeditors (7.1.0-1 -> 7.1.1-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded os-prober (1.79-1 -> 1.81-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded ostree (2022.4-1 -> 2022.5-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded perl-alien-build (2.49-1 -> 2.50-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded perl-file-mimeinfo (0.32-2 -> 0.33-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded sbc (1.5-2 -> 2.0-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded serd (0.30.12-2 -> 0.30.14-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded sord (0.16.10-2 -> 0.16.12-3)
[2022-08-05T15:04:25+0100] [ALPM] upgraded sratom (0.6.10-3 -> 0.6.12-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded pipewire (1:0.3.54-1 -> 1:0.3.56-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded zxing-cpp (1.3.0-1 -> 1.4.0-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded qt5-base (5.15.5+kde+r170-1 -> 5.15.5+kde+r173-1)
[2022-08-05T15:04:25+0100] [ALPM] upgraded prison (5.96.0-1 -> 5.96.0-2)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-cryptography (37.0.2-1 -> 37.0.4-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-distlib (0.3.4-1 -> 0.3.5-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-gobject (3.42.1-1 -> 3.42.2-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-more-itertools (8.13.0-1 -> 8.13.0-2)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-jaraco.functools (3.5.0-2 -> 3.5.1-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-jaraco.text (3.8.0-2 -> 3.8.1-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-trove-classifiers (2022.6.26-1 -> 2022.7.22-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-rich (12.4.4-1 -> 12.5.1-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded python-pip (22.1.2-1 -> 22.2-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded qt5-svg (5.15.5+kde+r10-1 -> 5.15.5+kde+r11-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded qt5-wayland (5.15.5+kde+r38-1 -> 5.15.5+kde+r38-3)
[2022-08-05T15:04:26+0100] [ALPM] upgraded rtkit (0.13-1 -> 0.13-2)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-bundler (2.3.18-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-json (2.6.2-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-stringio (3.0.2-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-psych (4.0.4-2)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-rdoc (6.4.0-2)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-stdlib (3.0.4-2)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-minitest (5.15.0-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-power_assert (2.0.1-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-rake (13.0.6-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-rexml (3.2.5-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-test-unit (3.5.3-1)
[2022-08-05T15:04:26+0100] [ALPM] installed ruby-bundledgems (3.0.4-2)
[2022-08-05T15:04:26+0100] [ALPM] upgraded ruby (3.0.4-1 -> 3.0.4-2)
[2022-08-05T15:04:26+0100] [ALPM] upgraded smbclient (4.16.2-1 -> 4.16.4-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded samba (4.16.2-1 -> 4.16.4-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded system-config-printer (1.5.16-1 -> 1.5.16-1.2)
[2022-08-05T15:04:26+0100] [ALPM] upgraded systemd-sysvcompat (251.2-3 -> 251.3-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded xorg-xmessage (1.0.5-3 -> 1.0.6-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded upower (0.99.19-1 -> 0.99.20-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded systemsettings (5.24.6-1 -> 5.24.6-3)
[2022-08-05T15:04:26+0100] [ALPM] upgraded xapp (2.2.12-1 -> 2.2.14-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded timeshift (22.06.3-1 -> 22.06.5-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded vlc (3.0.17.4-6 -> 3.0.17.4-7)
[2022-08-05T15:04:26+0100] [ALPM] upgraded vulkan-headers (1:1.3.217-1 -> 1:1.3.221-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded vulkan-intel (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded vulkan-radeon (22.1.3-1 -> 22.1.4-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded xdg-desktop-portal (1.14.4-1 -> 1.14.5-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded xorg-fonts-encodings (1.0.5-2 -> 1.0.6-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded xorg-server-common (21.1.3-5 -> 21.1.4-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded xorg-server (21.1.3-5 -> 21.1.4-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded xorg-xmodmap (1.0.10-3 -> 1.0.11-1)
[2022-08-05T15:04:26+0100] [ALPM] upgraded zsh-completions (0.33.0-1 -> 0.34.0-1)
[2022-08-05T15:04:26+0100] [ALPM] reinstalled base (3-2)
[2022-08-05T15:04:26+0100] [ALPM] transaction completed
[2022-08-05T15:04:27+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2022-08-05T15:04:27+0100] [ALPM] running '30-systemd-catalog.hook'...
[2022-08-05T15:04:27+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-05T15:04:27+0100] [ALPM] running '30-systemd-hwdb.hook'...
[2022-08-05T15:04:28+0100] [ALPM] running '30-systemd-sysctl.hook'...
[2022-08-05T15:04:28+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-08-05T15:04:28+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-05T15:04:28+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T15:04:28+0100] [ALPM] running '30-update-mime-database.hook'...
[2022-08-05T15:04:28+0100] [ALPM] running '40-update-ca-trust.hook'...
[2022-08-05T15:04:28+0100] [ALPM] running '60-depmod.hook'...
[2022-08-05T15:04:34+0100] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-08-05T15:04:34+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2022-08-05T15:04:34+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2022-08-05T15:04:34+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.15.57-2-MANJARO
[2022-08-05T15:04:34+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-08-05T15:04:34+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-08-05T15:04:35+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.15.57-2-MANJARO
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-08-05T15:04:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-08-05T15:04:37+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-08-05T15:04:37+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-08-05T15:04:37+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-08-05T15:04:37+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-08-05T15:04:39+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-08-05T15:04:40+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-08-05T15:04:40+0100] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-08-05T15:04:40+0100] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-08-05T15:04:40+0100] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2022-08-05T15:04:40+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-08-05T15:04:41+0100] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-08-05T15:04:42+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-08-05T15:04:42+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-08-05T15:04:46+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-08-05T15:04:46+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T15:04:46+0100] [ALPM] running '90-update-appstream-cache.hook'...
[2022-08-05T15:04:47+0100] [ALPM-SCRIPTLET] ✔ Metadata cache was updated successfully.
[2022-08-05T15:04:47+0100] [ALPM] running '99-grub.hook'...
[2022-08-05T15:04:47+0100] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2022-08-05T15:04:47+0100] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2022-08-05T15:04:47+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2022-08-05T15:04:47+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2022-08-05T15:04:48+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-08-05T15:04:48+0100] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2022-08-05T15:04:48+0100] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2022-08-05T15:04:50+0100] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
[2022-08-05T15:04:50+0100] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2022-08-05T15:04:50+0100] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-08-05T15:04:50+0100] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2022-08-05T15:04:50+0100] [ALPM-SCRIPTLET] done
[2022-08-05T15:04:50+0100] [ALPM] running 'dbus-reload.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'firefox-post.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'fontconfig.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'manjaro-printer.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'networkmanager-connectivity.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'texinfo-install.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-05T15:04:50+0100] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2022-08-05T21:06:27+0100] [PACMAN] Running 'pacman -S snapd'
[2022-08-05T21:06:34+0100] [ALPM] transaction started
[2022-08-05T21:06:34+0100] [ALPM] installed squashfs-tools (4.5.1-1)
[2022-08-05T21:06:34+0100] [ALPM] installed apparmor (3.0.4-2)
[2022-08-05T21:06:34+0100] [ALPM] installed snapd (2.56.3-1)
[2022-08-05T21:06:34+0100] [ALPM] transaction completed
[2022-08-05T21:06:34+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-05T21:06:35+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T21:06:35+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T21:06:35+0100] [ALPM] running 'dbus-reload.hook'...
[2022-08-05T21:06:35+0100] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-08-05T21:06:35+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-05T21:14:51+0100] [ALPM] transaction started
[2022-08-05T21:14:51+0100] [ALPM-SCRIPTLET] Discarding preserved snap namespaces
[2022-08-05T21:14:51+0100] [ALPM-SCRIPTLET] Removing downloaded snaps
[2022-08-05T21:14:51+0100] [ALPM-SCRIPTLET] Removing features exported from snapd to helper tools
[2022-08-05T21:14:51+0100] [ALPM-SCRIPTLET] Final directory cleanup
[2022-08-05T21:14:51+0100] [ALPM-SCRIPTLET] Removing leftover snap shared state data
[2022-08-05T21:14:51+0100] [ALPM-SCRIPTLET] Removing snapd catalog cache
[2022-08-05T21:14:51+0100] [ALPM-SCRIPTLET] Removing extra snap-confine apparmor rules
[2022-08-05T21:14:52+0100] [ALPM] removed snapd (2.56.3-1)
[2022-08-05T21:14:52+0100] [ALPM] transaction completed
[2022-08-05T21:14:52+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-05T21:14:52+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T21:14:52+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T21:14:52+0100] [ALPM] running 'dbus-reload.hook'...
[2022-08-05T21:14:52+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-05T21:15:26+0100] [PACMAN] Running 'pacman -S snapd'
[2022-08-05T21:15:29+0100] [ALPM] transaction started
[2022-08-05T21:15:29+0100] [ALPM] installed snapd (2.56.3-1)
[2022-08-05T21:15:29+0100] [ALPM] transaction completed
[2022-08-05T21:15:29+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-05T21:15:29+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T21:15:29+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T21:15:29+0100] [ALPM] running 'dbus-reload.hook'...
[2022-08-05T21:15:29+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-05T21:16:42+0100] [ALPM] transaction started
[2022-08-05T21:16:43+0100] [ALPM-SCRIPTLET] Discarding preserved snap namespaces
[2022-08-05T21:16:43+0100] [ALPM-SCRIPTLET] Removing downloaded snaps
[2022-08-05T21:16:43+0100] [ALPM-SCRIPTLET] Removing features exported from snapd to helper tools
[2022-08-05T21:16:43+0100] [ALPM-SCRIPTLET] Final directory cleanup
[2022-08-05T21:16:43+0100] [ALPM-SCRIPTLET] Removing leftover snap shared state data
[2022-08-05T21:16:43+0100] [ALPM-SCRIPTLET] Removing snapd catalog cache
[2022-08-05T21:16:43+0100] [ALPM-SCRIPTLET] Removing extra snap-confine apparmor rules
[2022-08-05T21:16:43+0100] [ALPM] removed snapd (2.56.3-1)
[2022-08-05T21:16:43+0100] [ALPM] transaction completed
[2022-08-05T21:16:43+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-05T21:16:43+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T21:16:43+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T21:16:43+0100] [ALPM] running 'dbus-reload.hook'...
[2022-08-05T21:16:43+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-05T21:18:24+0100] [PAMAC] synchronizing package lists
[2022-08-05T21:18:39+0100] [ALPM] transaction started
[2022-08-05T21:18:39+0100] [ALPM] installed tor (0.4.7.8-1)
[2022-08-05T21:18:39+0100] [ALPM] installed torsocks (2.3.0-2)
[2022-08-05T21:18:39+0100] [ALPM] transaction completed
[2022-08-05T21:18:39+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2022-08-05T21:18:39+0100] [ALPM-SCRIPTLET] Creating group 'tor' with GID 43.
[2022-08-05T21:18:39+0100] [ALPM-SCRIPTLET] Creating user 'tor' (n/a) with UID 43 and GID 43.
[2022-08-05T21:18:39+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-05T21:18:39+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-08-05T21:18:39+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T21:18:39+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T21:18:55+0100] [PAMAC] synchronizing package lists
[2022-08-05T21:19:01+0100] [ALPM] transaction started
[2022-08-05T21:19:01+0100] [ALPM] installed python-pysocks (1.7.1-7)
[2022-08-05T21:19:01+0100] [ALPM] installed python-gpgme (1.17.1-1)
[2022-08-05T21:19:01+0100] [ALPM] installed torbrowser-launcher (0.3.5-4)
[2022-08-05T21:19:01+0100] [ALPM] transaction completed
[2022-08-05T21:19:01+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T21:19:01+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T21:19:01+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-05T21:19:01+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-05T21:28:27+0100] [PAMAC] synchronizing package lists
[2022-08-05T21:28:37+0100] [ALPM] transaction started
[2022-08-05T21:28:38+0100] [ALPM] installed snapd (2.56.3-1)
[2022-08-05T21:28:38+0100] [ALPM] installed bash-completion (2.11-2)
[2022-08-05T21:28:38+0100] [ALPM] transaction completed
[2022-08-05T21:28:38+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-05T21:28:38+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-05T21:28:38+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-05T21:28:38+0100] [ALPM] running 'dbus-reload.hook'...
[2022-08-05T21:28:38+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T06:25:27+0100] [PAMAC] synchronizing package lists
[2022-08-06T06:28:00+0100] [ALPM] transaction started
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-pcre (8.45-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libnl (3.7.0-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-attr (2.5.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libpcap (1.10.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-glib2 (2.72.3-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-gmp (6.2.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-nettle (3.8-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libtasn1 (4.18.0-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-p11-kit (0.24.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-gnutls (3.7.6-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libproxy (0.4.18-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-glib-networking (2.72.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-sqlite (3.39.0-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libsoup (2.74.2-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libjpeg-turbo (2.1.3-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-acl (2.3.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libtiff (4.4.0-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-lcms2 (2.13.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-colord (1.4.6-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-v4l-utils (1.22.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-rest (0.8.1-4)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-mpg123 (1.30.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libxinerama (1.1.4-2)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libpng (1.6.37-3)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-freetype2 (2.12.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-harfbuzz (5.0.1-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-fribidi (1.0.12-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-libxslt (1.1.35-1)
[2022-08-06T06:28:00+0100] [ALPM] installed sdl12-compat (1.2.52-2)
[2022-08-06T06:28:00+0100] [ALPM] installed libmikmod (3.3.11.1-6)
[2022-08-06T06:28:00+0100] [ALPM] installed smpeg (0.4.5-5)
[2022-08-06T06:28:00+0100] [ALPM] installed sdl_sound (1.0.3-8)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-openal (1.22.2-1)
[2022-08-06T06:28:00+0100] [ALPM] installed lib32-fontconfig (2:2.14.0-1)
[2022-08-06T06:28:00+0100] [ALPM-SCRIPTLET] Rebuilding 32-bit fontconfig cache...
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-pixman (0.40.0-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-at-spi2-core (2.44.1-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-atk (2.38.0-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-at-spi2-atk (2.38.0-2)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-gdk-pixbuf2 (2.42.8-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-json-glib (1.6.6-2)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libcups (2.4.2-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libepoxy (1.5.10-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-cairo (1.17.6-2)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libdatrie (0.2.13-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libthai (0.1.29-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libxft (2.3.4-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-pango (1:1.50.8-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-librsvg (2:2.54.4-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libxcomposite (0.4.5-2)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libxcursor (1.2.1-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libxkbcommon (1.4.1-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-gtk3 (3.24.34-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-gstreamer (1.20.3-1)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-orc (0.4.32-2)
[2022-08-06T06:28:02+0100] [ALPM] installed lib32-libxv (1.0.11-3)
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-gst-plugins-base-libs (1.20.3-1)
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-ocl-icd (2.3.1-1)
[2022-08-06T06:28:03+0100] [ALPM] installed faudio (22.07-1)
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-gettext (0.21-1)
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-sdl2 (2.0.22-1)
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-faudio (22.07-1)
[2022-08-06T06:28:03+0100] [ALPM] installed wine (7.13-1)
[2022-08-06T06:28:03+0100] [ALPM-SCRIPTLET] Run 'systemctl restart systemd-binfmt' in order to make the wine binfmt available on your system.
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-alsa-plugins (1.2.7.1-1)
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-giflib (5.2.1-1)
[2022-08-06T06:28:03+0100] [ALPM] installed lib32-vkd3d (1.4-1)
[2022-08-06T06:28:03+0100] [ALPM] installed sdl_net (1.2.8-5)
[2022-08-06T06:28:03+0100] [ALPM] installed dosbox (0.74.3-2)
[2022-08-06T06:28:03+0100] [ALPM] installed ocl-icd (2.3.1-1)
[2022-08-06T06:28:03+0100] [ALPM] installed vkd3d (1.4-1)
[2022-08-06T06:28:03+0100] [ALPM] transaction completed
[2022-08-06T06:28:03+0100] [ALPM] running '30-systemd-binfmt.hook'...
[2022-08-06T06:28:03+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T06:28:03+0100] [ALPM] running '40-fontconfig-config.hook'...
[2022-08-06T06:28:03+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T06:28:03+0100] [ALPM] running 'fontconfig.hook'...
[2022-08-06T06:28:03+0100] [ALPM] running 'fontconfig-32.hook'...
[2022-08-06T06:28:03+0100] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2022-08-06T06:28:04+0100] [ALPM] running 'gio-querymodules-32.hook'...
[2022-08-06T06:28:04+0100] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2022-08-06T06:28:04+0100] [ALPM] running 'texinfo-install.hook'...
[2022-08-06T06:28:04+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T06:40:10+0100] [PACMAN] Running 'pacman -Syu'
[2022-08-06T06:40:10+0100] [PACMAN] synchronizing package lists
[2022-08-06T06:40:12+0100] [PACMAN] starting full system upgrade
[2022-08-06T06:40:43+0100] [PACMAN] Running 'pacman -S wine winetricks wine-mono wine_gecko'
[2022-08-06T07:01:58+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-06T07:01:58+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-06T07:01:58+0100] [ALPM] transaction started
[2022-08-06T07:01:59+0100] [ALPM] reinstalled wine (7.13-1)
[2022-08-06T07:01:59+0100] [ALPM] installed cabextract (1.9.1-2)
[2022-08-06T07:01:59+0100] [ALPM] installed unzip (6.0-18)
[2022-08-06T07:01:59+0100] [ALPM] installed winetricks (20220411-1)
[2022-08-06T07:02:00+0100] [ALPM] installed wine-mono (7.3.0-1)
[2022-08-06T07:02:00+0100] [ALPM] installed wine-gecko (2.47.3-1)
[2022-08-06T07:02:00+0100] [ALPM] transaction completed
[2022-08-06T07:02:00+0100] [ALPM] running '30-systemd-binfmt.hook'...
[2022-08-06T07:02:00+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T07:02:00+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T07:02:00+0100] [ALPM] running 'fontconfig.hook'...
[2022-08-06T07:02:00+0100] [ALPM] running 'fontconfig-32.hook'...
[2022-08-06T07:02:00+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T07:02:00+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T07:06:15+0100] [PACMAN] Running 'pacman -S wine-staging'
[2022-08-06T07:16:05+0100] [PACMAN] Running 'pacman -U https://manjaro.moson.eu/unstable/multilib/x86_64/winetricks-20220411-1-x86_64.pkg.tar.zst'
[2022-08-06T07:16:12+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-06T07:16:12+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-06T07:16:12+0100] [ALPM] transaction started
[2022-08-06T07:16:12+0100] [ALPM] reinstalled winetricks (20220411-1)
[2022-08-06T07:16:12+0100] [ALPM] transaction completed
[2022-08-06T07:16:12+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T07:16:12+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T07:16:12+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T07:16:12+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T07:20:45+0100] [PACMAN] Running 'pacman -U https://manjaro.moson.eu/unstable/multilib/x86_64/winetricks-'
[2022-08-06T07:22:00+0100] [PACMAN] Running 'pacman -U https://manjaro.moson.eu/unstable/multilib/x86_64/winetricks'
[2022-08-06T07:29:05+0100] [PACMAN] Running 'pacman -U https://manjaro.moson.eu/unstable/multilib/x86_64/winetricks-20220411-1-x86_64.pkg.tar.zst'
[2022-08-06T07:29:12+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-06T07:29:12+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-06T07:29:12+0100] [ALPM] transaction started
[2022-08-06T07:29:12+0100] [ALPM] reinstalled winetricks (20220411-1)
[2022-08-06T07:29:12+0100] [ALPM] transaction completed
[2022-08-06T07:29:12+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T07:29:12+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T07:29:12+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T07:29:12+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T07:30:01+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-06T07:30:01+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-06T07:30:01+0100] [ALPM] transaction started
[2022-08-06T07:30:01+0100] [ALPM] reinstalled winetricks (20220411-1)
[2022-08-06T07:30:01+0100] [ALPM] transaction completed
[2022-08-06T07:30:01+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T07:30:01+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T07:30:01+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T07:30:01+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T07:31:15+0100] [ALPM] transaction started
[2022-08-06T07:31:15+0100] [ALPM] removed winetricks (20220411-1)
[2022-08-06T07:31:15+0100] [ALPM] transaction completed
[2022-08-06T07:31:15+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T07:31:15+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T07:31:15+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T07:31:15+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T07:32:39+0100] [PAMAC] synchronizing package lists
[2022-08-06T07:34:34+0100] [ALPM] transaction started
[2022-08-06T07:34:34+0100] [ALPM] installed winetricks (20220411-1)
[2022-08-06T07:34:34+0100] [ALPM] installed kdialog (22.04.3-1)
[2022-08-06T07:34:34+0100] [ALPM] transaction completed
[2022-08-06T07:34:34+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T07:34:34+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T07:34:34+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T07:34:34+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T07:47:14+0100] [PACMAN] Running 'pacman -Rsn wine wine-gecko wine-mono winetricks'
[2022-08-06T07:47:17+0100] [ALPM] transaction started
[2022-08-06T07:47:17+0100] [ALPM] removed winetricks (20220411-1)
[2022-08-06T07:47:17+0100] [ALPM] removed unzip (6.0-18)
[2022-08-06T07:47:17+0100] [ALPM] removed cabextract (1.9.1-2)
[2022-08-06T07:47:17+0100] [ALPM] removed wine-mono (7.3.0-1)
[2022-08-06T07:47:17+0100] [ALPM] removed wine-gecko (2.47.3-1)
[2022-08-06T07:47:17+0100] [ALPM] removed wine (7.13-1)
[2022-08-06T07:47:17+0100] [ALPM-SCRIPTLET] binfmt binary formats will be updated at reboot
[2022-08-06T07:47:17+0100] [ALPM] removed lib32-libpcap (1.10.1-1)
[2022-08-06T07:47:17+0100] [ALPM] removed lib32-libnl (3.7.0-1)
[2022-08-06T07:47:17+0100] [ALPM] removed lib32-gettext (0.21-1)
[2022-08-06T07:47:17+0100] [ALPM] removed lib32-acl (2.3.1-1)
[2022-08-06T07:47:17+0100] [ALPM] removed lib32-faudio (22.07-1)
[2022-08-06T07:47:17+0100] [ALPM] removed lib32-sdl2 (2.0.22-1)
[2022-08-06T07:47:17+0100] [ALPM] removed faudio (22.07-1)
[2022-08-06T07:47:17+0100] [ALPM] transaction completed
[2022-08-06T07:47:17+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T07:47:17+0100] [ALPM] running '40-fontconfig-config.hook'...
[2022-08-06T07:47:17+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T07:47:17+0100] [ALPM] running 'fontconfig.hook'...
[2022-08-06T07:47:17+0100] [ALPM] running 'fontconfig-32.hook'...
[2022-08-06T07:47:17+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T07:47:17+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T07:55:54+0100] [PACMAN] Running 'pacman -Syyu'
[2022-08-06T07:55:54+0100] [PACMAN] synchronizing package lists
[2022-08-06T07:55:57+0100] [PACMAN] starting full system upgrade
[2022-08-06T09:45:39+0100] [PACMAN] Running 'pacman -S wine'
[2022-08-06T09:46:00+0100] [ALPM] transaction started
[2022-08-06T09:46:00+0100] [ALPM] installed lib32-acl (2.3.1-1)
[2022-08-06T09:46:00+0100] [ALPM] installed lib32-gettext (0.21-1)
[2022-08-06T09:46:00+0100] [ALPM] installed lib32-libnl (3.7.0-1)
[2022-08-06T09:46:00+0100] [ALPM] installed lib32-libpcap (1.10.1-1)
[2022-08-06T09:46:00+0100] [ALPM] installed faudio (22.07-1)
[2022-08-06T09:46:00+0100] [ALPM] installed lib32-sdl2 (2.0.22-1)
[2022-08-06T09:46:00+0100] [ALPM] installed lib32-faudio (22.07-1)
[2022-08-06T09:46:00+0100] [ALPM] installed wine (7.13-1)
[2022-08-06T09:46:00+0100] [ALPM-SCRIPTLET] Run 'systemctl restart systemd-binfmt' in order to make the wine binfmt available on your system.
[2022-08-06T09:46:00+0100] [ALPM] transaction completed
[2022-08-06T09:46:00+0100] [ALPM] running '30-systemd-binfmt.hook'...
[2022-08-06T09:46:00+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T09:46:00+0100] [ALPM] running '40-fontconfig-config.hook'...
[2022-08-06T09:46:00+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T09:46:00+0100] [ALPM] running 'fontconfig.hook'...
[2022-08-06T09:46:00+0100] [ALPM] running 'fontconfig-32.hook'...
[2022-08-06T09:46:00+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T09:48:23+0100] [PACMAN] Running 'pacman -S winetricks'
[2022-08-06T09:48:25+0100] [ALPM] transaction started
[2022-08-06T09:48:25+0100] [ALPM] installed cabextract (1.9.1-2)
[2022-08-06T09:48:25+0100] [ALPM] installed unzip (6.0-18)
[2022-08-06T09:48:25+0100] [ALPM] installed winetricks (20220411-1)
[2022-08-06T09:48:25+0100] [ALPM] transaction completed
[2022-08-06T09:48:25+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T09:48:25+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T09:48:25+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T09:48:25+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-06T09:48:50+0100] [PACMAN] Running 'pacman -S wine-mono'
[2022-08-06T09:48:54+0100] [ALPM] transaction started
[2022-08-06T09:48:54+0100] [ALPM] installed wine-mono (7.3.0-1)
[2022-08-06T09:48:54+0100] [ALPM] transaction completed
[2022-08-06T09:48:54+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T09:48:54+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T09:51:21+0100] [PACMAN] Running 'pacman -S wine_gecko'
[2022-08-06T09:51:27+0100] [ALPM] transaction started
[2022-08-06T09:51:27+0100] [ALPM] installed wine-gecko (2.47.3-1)
[2022-08-06T09:51:27+0100] [ALPM] transaction completed
[2022-08-06T09:51:27+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T09:51:27+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T10:08:25+0100] [PACMAN] Running 'pacman -S plasma kio-extras'
[2022-08-06T12:44:35+0100] [PACMAN] Running 'pacman -Syu playonlinux'
[2022-08-06T12:44:35+0100] [PACMAN] synchronizing package lists
[2022-08-06T12:45:55+0100] [PACMAN] Running 'pacman -Syu'
[2022-08-06T12:45:55+0100] [PACMAN] synchronizing package lists
[2022-08-06T12:45:56+0100] [PACMAN] starting full system upgrade
[2022-08-06T12:46:43+0100] [PACMAN] Running 'pacman -S playonlinux'
[2022-08-06T12:57:02+0100] [PACMAN] Running 'pacman -Syu playonlinux'
[2022-08-06T12:57:02+0100] [PACMAN] synchronizing package lists
[2022-08-06T12:57:43+0100] [PACMAN] Running 'pacman -Syu playonlinux'
[2022-08-06T12:57:43+0100] [PACMAN] synchronizing package lists
[2022-08-06T13:12:56+0100] [PACMAN] Running 'pacman -Sy playonlinux'
[2022-08-06T13:12:56+0100] [PACMAN] synchronizing package lists
[2022-08-06T17:05:12+0100] [PACMAN] Running 'pacman -Sy playonlinux'
[2022-08-06T17:05:12+0100] [PACMAN] synchronizing package lists
[2022-08-06T20:55:42+0100] [PAMAC] synchronizing package lists
[2022-08-06T20:56:11+0100] [ALPM] transaction started
[2022-08-06T20:56:11+0100] [ALPM] installed libcdio-paranoia (10.2+2.0.1-2)
[2022-08-06T20:56:11+0100] [ALPM] installed cinnamon-desktop (5.4.2-1)
[2022-08-06T20:56:11+0100] [ALPM] installed gvfs (1.50.2-1)
[2022-08-06T20:56:11+0100] [ALPM] installed exempi (2.6.2-1)
[2022-08-06T20:56:11+0100] [ALPM] installed nemo (5.4.2-1)
[2022-08-06T20:56:11+0100] [ALPM] transaction completed
[2022-08-06T20:56:11+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running '30-update-mime-database.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running 'gio-querymodules.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running 'gvfsd.hook'...
[2022-08-06T20:56:11+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-07T11:32:04+0100] [PACMAN] Running 'pacman -S libldac pipewire pipewire-pulse'
[2022-08-07T11:34:13+0100] [PACMAN] Running 'pacman -S libldac pipewire pipewire-pulse'
[2022-08-07T11:34:52+0100] [PACMAN] Running 'pacman -S pipewire-pulse'
[2022-08-07T11:46:50+0100] [PAMAC] synchronizing package lists
[2022-08-07T11:47:14+0100] [PACMAN] Running 'pacman -S pipewire-pulse'
[2022-08-07T11:47:49+0100] [PAMAC] synchronizing package lists
[2022-08-07T11:53:04+0100] [ALPM] transaction started
[2022-08-07T11:53:04+0100] [ALPM] removed jack2 (1.9.21-1)
[2022-08-07T11:53:04+0100] [ALPM] removed manjaro-pulse (20220217-2)
[2022-08-07T11:53:04+0100] [ALPM] removed pulseaudio-zeroconf (16.1-1)
[2022-08-07T11:53:04+0100] [ALPM] removed pulseaudio-bluetooth (16.1-1)
[2022-08-07T11:53:04+0100] [ALPM-SCRIPTLET] Removed "/etc/systemd/user/sockets.target.wants/pulseaudio.socket".
[2022-08-07T11:53:04+0100] [ALPM] removed pulseaudio (16.1-1)
[2022-08-07T11:53:04+0100] [ALPM] installed pipewire-v4l2 (1:0.3.56-1)
[2022-08-07T11:53:04+0100] [ALPM] installed rnnoise (0.4.1-1)
[2022-08-07T11:53:04+0100] [ALPM] installed tbb (2021.5.0-2)
[2022-08-07T11:53:04+0100] [ALPM] installed pipewire-x11-bell (1:0.3.56-1)
[2022-08-07T11:53:04+0100] [ALPM] installed lsp-plugins (1.2.2-1)
[2022-08-07T11:53:04+0100] [ALPM] installed realtime-privileges (4-1)
[2022-08-07T11:53:04+0100] [ALPM-SCRIPTLET] The 'realtime' group has been created. Add your user to it and re-login to use realtime privileges.
[2022-08-07T11:53:04+0100] [ALPM] installed rubberband (3.0.0-2)
[2022-08-07T11:53:04+0100] [ALPM] installed gtk2 (2.24.33-2)
[2022-08-07T11:53:04+0100] [ALPM] installed pipewire-jack (1:0.3.56-1.0)
[2022-08-07T11:53:04+0100] [ALPM] installed calf (0.90.3-5)
[2022-08-07T11:53:04+0100] [ALPM] installed gtk4 (1:4.6.6-1)
[2022-08-07T11:53:04+0100] [ALPM] installed libebur128 (1.2.6-1)
[2022-08-07T11:53:04+0100] [ALPM] installed libsigc++-3.0 (3.2.0-1)
[2022-08-07T11:53:04+0100] [ALPM] installed pipewire-pulse (1:0.3.56-1.0)
[2022-08-07T11:53:04+0100] [ALPM-SCRIPTLET] Created symlink /etc/systemd/user/sockets.target.wants/pipewire-pulse.socket → /usr/lib/systemd/user/pipewire-pulse.socket.
[2022-08-07T11:53:04+0100] [ALPM] installed zita-convolver (4.0.3-2)
[2022-08-07T11:53:04+0100] [ALPM] installed libadwaita (1:1.1.3-1)
[2022-08-07T11:53:04+0100] [ALPM] installed easyeffects (6.2.8-1)
[2022-08-07T11:53:04+0100] [ALPM] installed gst-plugin-pipewire (1:0.3.56-1)
[2022-08-07T11:53:04+0100] [ALPM] installed pipewire-alsa (1:0.3.56-1.0)
[2022-08-07T11:53:04+0100] [ALPM] installed pipewire-zeroconf (1:0.3.56-1)
[2022-08-07T11:53:04+0100] [ALPM] installed manjaro-pipewire (20220217-2)
[2022-08-07T11:53:04+0100] [ALPM] transaction completed
[2022-08-07T11:53:04+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2022-08-07T11:53:04+0100] [ALPM-SCRIPTLET] Creating group 'realtime' with GID 963.
[2022-08-07T11:53:04+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-07T11:53:04+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T11:53:04+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T11:53:05+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-07T11:53:05+0100] [ALPM] running 'gtk-query-immodules-2.0.hook'...
[2022-08-07T11:53:05+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-07T11:53:05+0100] [ALPM] running 'gtk4-querymodules.hook'...
[2022-08-07T11:53:05+0100] [ALPM] running 'realtime-privileges.hook'...
[2022-08-07T11:53:05+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-07T12:38:01+0100] [PACMAN] Running 'pacman -R pipewire-pulse'
[2022-08-07T12:38:18+0100] [PACMAN] Running 'pacman -R manjaro-pulse'
[2022-08-07T12:38:23+0100] [PACMAN] Running 'pacman -R pulseaudio'
[2022-08-07T12:38:35+0100] [PACMAN] Running 'pacman -R pulseaudio'
[2022-08-07T12:38:40+0100] [PACMAN] Running 'pacman -Rdd pulseaudio pulseaudio-alsa pulseaudio-bluetooth pulseaudio-ctl pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-equalizer-ladspa'
[2022-08-07T12:39:19+0100] [PACMAN] Running 'pacman -S manjaro-pipewire gst-plugin-pipewire pulseeffects'
[2022-08-07T16:05:18+0100] [PACMAN] Running 'pacman -S'
[2022-08-07T16:06:20+0100] [PACMAN] Running 'pacman -S pulseaudio-bluetooth'
[2022-08-07T16:11:19+0100] [ALPM] transaction started
[2022-08-07T16:11:19+0100] [ALPM] installed python-prctl (1.8.1-3)
[2022-08-07T16:11:19+0100] [ALPM] installed m4 (1.4.19-1)
[2022-08-07T16:11:19+0100] [ALPM] installed pkgconf (1.8.0-1)
[2022-08-07T16:11:19+0100] [ALPM] installed gc (8.2.0-3)
[2022-08-07T16:11:19+0100] [ALPM] installed autoconf (2.71-1)
[2022-08-07T16:11:19+0100] [ALPM] installed guile (2.2.7-2)
[2022-08-07T16:11:19+0100] [ALPM] installed make (4.3-3)
[2022-08-07T16:11:19+0100] [ALPM] installed bison (3.8.2-4)
[2022-08-07T16:11:19+0100] [ALPM] installed patch (2.7.6-8)
[2022-08-07T16:11:19+0100] [ALPM] installed flex (2.6.4-3)
[2022-08-07T16:11:19+0100] [ALPM] installed automake (1.16.5-1)
[2022-08-07T16:11:19+0100] [ALPM] transaction completed
[2022-08-07T16:11:19+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T16:11:19+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T16:11:19+0100] [ALPM] running 'texinfo-install.hook'...
[2022-08-07T16:11:26+0100] [ALPM] transaction started
[2022-08-07T16:11:26+0100] [ALPM] installed bluetooth-autoconnect (1.3-1)
[2022-08-07T16:11:26+0100] [ALPM] transaction completed
[2022-08-07T16:11:26+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-07T16:11:26+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T16:11:26+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T16:12:11+0100] [PACMAN] Running 'pacman -S pulseaudio-modules-bt-git'
[2022-08-07T16:36:37+0100] [PACMAN] Running 'pacman -S yaourt'
[2022-08-07T16:36:52+0100] [PACMAN] Running 'pacman -S yaourt'
[2022-08-07T17:24:34+0100] [PAMAC] synchronizing package lists
[2022-08-07T17:26:49+0100] [PAMAC] synchronizing package lists
[2022-08-07T17:27:47+0100] [ALPM] transaction started
[2022-08-07T17:27:47+0100] [ALPM] installed hyphen (2.8.8-4)
[2022-08-07T17:27:47+0100] [ALPM] installed woff2 (1.0.2-4)
[2022-08-07T17:27:47+0100] [ALPM] installed qt5-webkit (5.212.0alpha4-15)
[2022-08-07T17:27:47+0100] [ALPM] installed smtube (21.10.0-3)
[2022-08-07T17:27:47+0100] [ALPM] installed uchardet (0.0.7-1)
[2022-08-07T17:27:47+0100] [ALPM] installed luajit (2.1.0.beta3.r431.g5677985d-1)
[2022-08-07T17:27:47+0100] [ALPM] installed mujs (1.2.0-2)
[2022-08-07T17:27:47+0100] [ALPM] installed mpv (1:0.34.1-5)
[2022-08-07T17:27:47+0100] [ALPM] installed youtube-dl (2021.12.17-1)
[2022-08-07T17:27:47+0100] [ALPM] installed smplayer (22.7.0-1)
[2022-08-07T17:27:47+0100] [ALPM] transaction completed
[2022-08-07T17:27:47+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T17:27:48+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T17:27:48+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-07T17:27:48+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-07T17:40:14+0100] [PAMAC] synchronizing package lists
[2022-08-07T17:41:09+0100] [ALPM] transaction started
[2022-08-07T17:41:09+0100] [ALPM] installed element-web (1.11.1-1)
[2022-08-07T17:41:09+0100] [ALPM] installed c-ares (1.18.1-1)
[2022-08-07T17:41:09+0100] [ALPM] installed electron (19.0.9-2)
[2022-08-07T17:41:09+0100] [ALPM] installed element-desktop (1.11.1-1)
[2022-08-07T17:41:10+0100] [ALPM] transaction completed
[2022-08-07T17:41:10+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T17:41:10+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T17:41:10+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-07T17:41:10+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-07T18:43:51+0100] [PAMAC] synchronizing package lists
[2022-08-07T18:45:21+0100] [ALPM] transaction started
[2022-08-07T18:45:21+0100] [ALPM] installed flameshot (12.1.0-1)
[2022-08-07T18:45:21+0100] [ALPM] transaction completed
[2022-08-07T18:45:21+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T18:45:21+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T18:45:21+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-07T18:45:21+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-07T23:22:34+0100] [PACMAN] Running 'pacman -S --needed --noconfirm base-devel unzip zip'
[2022-08-07T23:22:35+0100] [ALPM] transaction started
[2022-08-07T23:22:35+0100] [ALPM] installed zip (3.0-10)
[2022-08-07T23:22:35+0100] [ALPM] transaction completed
[2022-08-07T23:22:35+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T23:22:35+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T23:31:17+0100] [PAMAC] synchronizing package lists
[2022-08-07T23:44:08+0100] [ALPM] transaction started
[2022-08-07T23:44:09+0100] [ALPM] removed smplayer (22.7.0-1)
[2022-08-07T23:44:09+0100] [ALPM] transaction completed
[2022-08-07T23:44:09+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T23:44:09+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T23:44:09+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-07T23:44:09+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-07T23:44:23+0100] [ALPM] transaction started
[2022-08-07T23:44:23+0100] [ALPM] removed mpv (1:0.34.1-5)
[2022-08-07T23:44:23+0100] [ALPM] removed uchardet (0.0.7-1)
[2022-08-07T23:44:23+0100] [ALPM] removed mujs (1.2.0-2)
[2022-08-07T23:44:23+0100] [ALPM] removed luajit (2.1.0.beta3.r431.g5677985d-1)
[2022-08-07T23:44:24+0100] [ALPM] transaction completed
[2022-08-07T23:44:24+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T23:44:24+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T23:44:24+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-07T23:44:24+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-07T23:44:57+0100] [PAMAC] synchronizing package lists
[2022-08-07T23:45:36+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-07T23:45:36+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-07T23:45:36+0100] [ALPM] transaction started
[2022-08-07T23:45:36+0100] [ALPM] upgraded archlinux-keyring (20220713-2 -> 20220727-1)
[2022-08-07T23:45:36+0100] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2022-08-07T23:45:38+0100] [ALPM-SCRIPTLET] ==> Updating trust database...
[2022-08-07T23:45:38+0100] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2022-08-09
[2022-08-07T23:45:38+0100] [ALPM] transaction completed
[2022-08-07T23:45:38+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T23:45:38+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T23:50:15+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-07T23:50:15+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-07T23:50:15+0100] [ALPM] running '60-mkinitcpio-remove.hook'...
[2022-08-07T23:50:15+0100] [ALPM] running 'firefox-pre.hook'...
[2022-08-07T23:50:15+0100] [ALPM] transaction started
[2022-08-07T23:50:15+0100] [ALPM] upgraded linux-api-headers (5.17.5-2 -> 5.18.15-1)
[2022-08-07T23:50:15+0100] [ALPM] warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
[2022-08-07T23:50:15+0100] [ALPM] upgraded glibc (2.35-6 -> 2.36-1)
[2022-08-07T23:50:15+0100] [ALPM-SCRIPTLET] Generating locales...
[2022-08-07T23:50:17+0100] [ALPM-SCRIPTLET] en_US.UTF-8... done
[2022-08-07T23:50:17+0100] [ALPM-SCRIPTLET] Generation complete.
[2022-08-07T23:50:17+0100] [ALPM] upgraded gcc-libs (12.1.0-3 -> 12.1.1-4)
[2022-08-07T23:50:17+0100] [ALPM] upgraded python (3.10.5-1 -> 3.10.5-2)
[2022-08-07T23:50:17+0100] [ALPM] upgraded apparmor (3.0.4-2 -> 3.0.6-1)
[2022-08-07T23:50:17+0100] [ALPM] upgraded lib32-glibc (2.35-6 -> 2.36-1)
[2022-08-07T23:50:17+0100] [ALPM] upgraded libelf (0.187-1 -> 0.187-2)
[2022-08-07T23:50:17+0100] [ALPM] upgraded binutils (2.38-6 -> 2.38-7)
[2022-08-07T23:50:18+0100] [ALPM] upgraded llvm-libs (14.0.6-2 -> 14.0.6-3)
[2022-08-07T23:50:18+0100] [ALPM] upgraded mpfr (4.1.0.p13-2 -> 4.1.0.p13-3)
[2022-08-07T23:50:18+0100] [ALPM] upgraded gcc (12.1.0-3 -> 12.1.1-4)
[2022-08-07T23:50:18+0100] [ALPM] upgraded clang (14.0.6-1 -> 14.0.6-2)
[2022-08-07T23:50:18+0100] [ALPM] upgraded cryptsetup (2.4.3-2 -> 2.5.0-1)
[2022-08-07T23:50:18+0100] [ALPM] upgraded gsm (1.0.20-1 -> 1.0.21-1)
[2022-08-07T23:50:18+0100] [ALPM] upgraded opencore-amr (0.1.5-5 -> 0.1.6-1)
[2022-08-07T23:50:18+0100] [ALPM] upgraded iptables (1:1.8.8-1 -> 1:1.8.8-2)
[2022-08-07T23:50:18+0100] [ALPM] upgraded libsysprof-capture (3.44.0-1 -> 3.44.0-2)
[2022-08-07T23:50:18+0100] [ALPM] upgraded harfbuzz (5.0.1-1 -> 5.1.0-1)
[2022-08-07T23:50:18+0100] [ALPM] upgraded libtiff (4.4.0-1 -> 4.4.0-3)
[2022-08-07T23:50:19+0100] [ALPM] upgraded electron (19.0.9-2 -> 19.0.10-1)
[2022-08-07T23:50:19+0100] [ALPM] upgraded element-web (1.11.1-1 -> 1.11.2-1)
[2022-08-07T23:50:19+0100] [ALPM] upgraded element-desktop (1.11.1-1 -> 1.11.2-1)
[2022-08-07T23:50:19+0100] [ALPM] upgraded firefox (103.0-1 -> 103.0.1-1)
[2022-08-07T23:50:19+0100] [ALPM] upgraded libtool (2.4.7-2 -> 2.4.7-3)
[2022-08-07T23:50:20+0100] [ALPM] upgraded imagemagick (7.1.0.44-1 -> 7.1.0.45-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded iproute2 (5.18.0-1 -> 5.19.0-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded tevent (1:0.12.1-1 -> 1:0.13.0-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded ldb (2:2.5.2-1 -> 2:2.5.2-2)
[2022-08-07T23:50:20+0100] [ALPM] upgraded lib32-gcc-libs (12.1.0-3 -> 12.1.1-4)
[2022-08-07T23:50:20+0100] [ALPM] upgraded lib32-libxcrypt (4.4.28-1 -> 4.4.28-2)
[2022-08-07T23:50:20+0100] [ALPM] upgraded lib32-harfbuzz (5.0.1-1 -> 5.1.0-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded lib32-libtiff (4.4.0-1 -> 4.4.0-3)
[2022-08-07T23:50:20+0100] [ALPM] upgraded lib32-wayland (1.20.0-2 -> 1.21.0-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded lib32-libva (2.14.0-1 -> 2.15.0-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded mpg123 (1.30.1-1 -> 1.30.2-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded lib32-mpg123 (1.30.1-1 -> 1.30.2-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded libarchive (3.6.1-1 -> 3.6.1-2)
[2022-08-07T23:50:20+0100] [ALPM] upgraded libupnp (1.14.12-3 -> 1.14.13-1)
[2022-08-07T23:50:20+0100] [ALPM] upgraded linux515 (5.15.57-2 -> 5.15.59-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded llvm (14.0.6-2 -> 14.0.6-3)
[2022-08-07T23:50:21+0100] [ALPM] upgraded mhwd-nvidia (515.57-1 -> 515.65.01-2)
[2022-08-07T23:50:21+0100] [ALPM] upgraded mhwd-nvidia-390xx (390.151-2 -> 390.154-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded mhwd-nvidia-470xx (470.129.06-1 -> 470.141.03-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded networkmanager-l2tp (1.20.0-3 -> 1.20.4-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded ostree (2022.5-1 -> 2022.5-2)
[2022-08-07T23:50:21+0100] [ALPM] upgraded perl-alien-build (2.50-1 -> 2.51-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded perl-libwww (6.60-2 -> 6.67-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded python-chardet (4.0.0-5 -> 5.0.0-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded python-platformdirs (2.5.1-1 -> 2.5.2-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded python-requests (2.27.1-1 -> 2.28.1-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded python-pip (22.2-1 -> 22.2.2-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded python-reportlab (3.6.10-1 -> 3.6.11-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded qt5-base (5.15.5+kde+r173-1 -> 5.15.5+kde+r174-1)
[2022-08-07T23:50:21+0100] [ALPM] upgraded smbclient (4.16.4-1 -> 4.16.4-2)
[2022-08-07T23:50:22+0100] [ALPM] upgraded samba (4.16.4-1 -> 4.16.4-2)
[2022-08-07T23:50:22+0100] [ALPM] upgraded snapd (2.56.3-1 -> 2.57-2)
[2022-08-07T23:50:22+0100] [ALPM] upgraded wavpack (5.4.0-1 -> 5.5.0-1)
[2022-08-07T23:50:22+0100] [ALPM] upgraded wayland-protocols (1.25-1 -> 1.26-1)
[2022-08-07T23:50:23+0100] [ALPM] upgraded wine (7.13-1 -> 7.14-1)
[2022-08-07T23:50:23+0100] [ALPM] upgraded xdg-desktop-portal (1.14.5-1 -> 1.14.6-1)
[2022-08-07T23:50:23+0100] [ALPM] installed luajit (2.1.0.beta3.r431.g5677985d-1)
[2022-08-07T23:50:23+0100] [ALPM] installed mujs (1.2.0-2)
[2022-08-07T23:50:23+0100] [ALPM] installed uchardet (0.0.7-1)
[2022-08-07T23:50:23+0100] [ALPM] installed mpv (1:0.34.1-5)
[2022-08-07T23:50:23+0100] [ALPM] installed smplayer (22.7.0-1)
[2022-08-07T23:50:23+0100] [ALPM] transaction completed
[2022-08-07T23:50:23+0100] [ALPM] running '30-systemd-binfmt.hook'...
[2022-08-07T23:50:23+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-07T23:50:24+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-08-07T23:50:24+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-07T23:50:24+0100] [ALPM] running '60-depmod.hook'...
[2022-08-07T23:50:30+0100] [ALPM] running '60-glibc-locales.hook'...
[2022-08-07T23:50:31+0100] [ALPM] running '80-cronie.hook'...
[2022-08-07T23:50:31+0100] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.15.59-1-MANJARO
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2022-08-07T23:50:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-08-07T23:50:32+0100] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-08-07T23:50:32+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-08-07T23:50:32+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.15.59-1-MANJARO
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-08-07T23:50:33+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-08-07T23:50:34+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-08-07T23:50:35+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-08-07T23:50:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-08-07T23:50:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-08-07T23:50:36+0100] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-08-07T23:50:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2022-08-07T23:50:36+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-08-07T23:50:37+0100] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-08-07T23:50:38+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-08-07T23:50:38+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-08-07T23:50:42+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-08-07T23:50:42+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-07T23:50:42+0100] [ALPM] running '99-grub.hook'...
[2022-08-07T23:50:44+0100] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2022-08-07T23:50:44+0100] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2022-08-07T23:50:45+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2022-08-07T23:50:45+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2022-08-07T23:50:45+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-08-07T23:50:45+0100] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2022-08-07T23:50:45+0100] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2022-08-07T23:50:48+0100] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
[2022-08-07T23:50:48+0100] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2022-08-07T23:50:48+0100] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-08-07T23:50:48+0100] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2022-08-07T23:50:48+0100] [ALPM-SCRIPTLET] done
[2022-08-07T23:50:48+0100] [ALPM] running 'dbus-reload.hook'...
[2022-08-07T23:50:48+0100] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-08-07T23:50:48+0100] [ALPM] running 'firefox-post.hook'...
[2022-08-07T23:50:48+0100] [ALPM] running 'fontconfig.hook'...
[2022-08-07T23:50:48+0100] [ALPM] running 'fontconfig-32.hook'...
[2022-08-07T23:50:48+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-07T23:50:48+0100] [ALPM] running 'locale-gen.hook'...
[2022-08-07T23:50:48+0100] [ALPM] running 'texinfo-install.hook'...
[2022-08-07T23:50:49+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T10:18:33+0100] [PAMAC] synchronizing package lists
[2022-08-08T10:19:35+0100] [ALPM] transaction started
[2022-08-08T10:19:35+0100] [ALPM] installed squashfuse (0.1.105-1)
[2022-08-08T10:19:35+0100] [ALPM] installed libappimage (1.0.4.5-2)
[2022-08-08T10:19:35+0100] [ALPM] installed appimagelauncher (2.2.0-9)
[2022-08-08T10:19:35+0100] [ALPM] transaction completed
[2022-08-08T10:19:35+0100] [ALPM] running '30-systemd-binfmt.hook'...
[2022-08-08T10:19:35+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T10:19:35+0100] [ALPM] running '30-update-mime-database.hook'...
[2022-08-08T10:19:35+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T10:19:35+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T10:19:35+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T10:23:30+0100] [ALPM] transaction started
[2022-08-08T10:23:30+0100] [ALPM] removed appimagelauncher (2.2.0-9)
[2022-08-08T10:23:30+0100] [ALPM] transaction completed
[2022-08-08T10:23:30+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T10:23:30+0100] [ALPM] running '30-update-mime-database.hook'...
[2022-08-08T10:23:30+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T10:23:30+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T10:23:30+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T11:32:17+0100] [PAMAC] synchronizing package lists
[2022-08-08T11:36:29+0100] [ALPM] transaction started
[2022-08-08T11:36:29+0100] [ALPM] removed easyeffects (6.2.8-1)
[2022-08-08T11:36:29+0100] [ALPM] transaction completed
[2022-08-08T11:36:29+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T11:36:29+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T11:36:29+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-08T11:36:29+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T11:36:29+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T11:37:20+0100] [PAMAC] synchronizing package lists
[2022-08-08T11:38:05+0100] [PAMAC] synchronizing package lists
[2022-08-08T11:38:50+0100] [PAMAC] synchronizing package lists
[2022-08-08T11:39:01+0100] [PAMAC] synchronizing package lists
[2022-08-08T11:42:59+0100] [ALPM] transaction started
[2022-08-08T11:42:59+0100] [ALPM] removed smplayer (22.7.0-1)
[2022-08-08T11:42:59+0100] [ALPM] transaction completed
[2022-08-08T11:42:59+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T11:42:59+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T11:42:59+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T11:42:59+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T11:43:06+0100] [ALPM] transaction started
[2022-08-08T11:43:06+0100] [ALPM] removed mpv (1:0.34.1-5)
[2022-08-08T11:43:06+0100] [ALPM] transaction completed
[2022-08-08T11:43:06+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T11:43:06+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T11:43:06+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T11:43:06+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T11:43:33+0100] [ALPM] transaction started
[2022-08-08T11:43:33+0100] [ALPM] removed smtube (21.10.0-3)
[2022-08-08T11:43:33+0100] [ALPM] transaction completed
[2022-08-08T11:43:33+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T11:43:33+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T11:43:33+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T11:43:33+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T11:50:14+0100] [PAMAC] synchronizing package lists
[2022-08-08T11:52:44+0100] [ALPM] transaction started
[2022-08-08T11:52:44+0100] [ALPM] installed linux515-virtualbox-host-modules (6.1.36-7)
[2022-08-08T11:52:44+0100] [ALPM-SCRIPTLET] ===> You must load vboxdrv module before starting VirtualBox:
[2022-08-08T11:52:44+0100] [ALPM-SCRIPTLET] ===> # modprobe vboxdrv
[2022-08-08T11:52:51+0100] [ALPM] installed linux419 (4.19.254-2)
[2022-08-08T11:52:51+0100] [ALPM] installed linux419-virtualbox-host-modules (6.1.36-4)
[2022-08-08T11:52:51+0100] [ALPM-SCRIPTLET] ===> You must load vboxdrv module before starting VirtualBox:
[2022-08-08T11:52:51+0100] [ALPM-SCRIPTLET] ===> # modprobe vboxdrv
[2022-08-08T11:52:55+0100] [ALPM] installed virtualbox (6.1.36-1)
[2022-08-08T11:52:55+0100] [ALPM] transaction completed
[2022-08-08T11:52:55+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2022-08-08T11:52:55+0100] [ALPM-SCRIPTLET] Creating group 'vboxusers' with GID 108.
[2022-08-08T11:52:55+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-08T11:52:56+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-08T11:52:56+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T11:52:56+0100] [ALPM] running '30-update-mime-database.hook'...
[2022-08-08T11:52:56+0100] [ALPM] running '60-depmod.hook'...
[2022-08-08T11:53:00+0100] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] ==> Starting build: 4.19.254-2-MANJARO
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-08-08T11:53:00+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-08-08T11:53:01+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] ==> Starting build: 4.19.254-2-MANJARO
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-08-08T11:53:02+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-08-08T11:53:03+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-08-08T11:53:03+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-08-08T11:53:03+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-08-08T11:53:03+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-08-08T11:53:05+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-08-08T11:53:05+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-08-08T11:53:06+0100] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-08-08T11:53:06+0100] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-08-08T11:53:06+0100] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2022-08-08T11:53:06+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-08-08T11:53:06+0100] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-08-08T11:53:08+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-08-08T11:53:08+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
[2022-08-08T11:53:11+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-08-08T11:53:11+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T11:53:11+0100] [ALPM] running '99-grub.hook'...
[2022-08-08T11:53:11+0100] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2022-08-08T11:53:12+0100] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2022-08-08T11:53:12+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2022-08-08T11:53:12+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2022-08-08T11:53:12+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-08-08T11:53:13+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.19-x86_64
[2022-08-08T11:53:13+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
[2022-08-08T11:53:13+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
[2022-08-08T11:53:13+0100] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2022-08-08T11:53:13+0100] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2022-08-08T11:53:15+0100] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
[2022-08-08T11:53:16+0100] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2022-08-08T11:53:16+0100] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-08-08T11:53:16+0100] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2022-08-08T11:53:16+0100] [ALPM-SCRIPTLET] done
[2022-08-08T11:53:16+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T11:53:16+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T12:06:27+0100] [PACMAN] Running 'pacman -R libldac'
[2022-08-08T12:06:44+0100] [PACMAN] Running 'pacman -R pipewire'
[2022-08-08T12:06:53+0100] [PACMAN] Running 'pacman -R pipewire-pulse'
[2022-08-08T13:44:55+0100] [PAMAC] synchronizing package lists
[2022-08-08T13:47:23+0100] [PACMAN] Running 'pacman -Rdd pipewire-pulse'
[2022-08-08T13:47:28+0100] [ALPM] transaction started
[2022-08-08T13:47:28+0100] [ALPM-SCRIPTLET] Removed "/etc/systemd/user/sockets.target.wants/pipewire-pulse.socket".
[2022-08-08T13:47:28+0100] [ALPM] removed pipewire-pulse (1:0.3.56-1.0)
[2022-08-08T13:47:28+0100] [ALPM] transaction completed
[2022-08-08T13:47:28+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T13:47:28+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T13:48:03+0100] [PACMAN] Running 'pacman -S manjaro-pulse'
[2022-08-08T13:48:18+0100] [ALPM] transaction started
[2022-08-08T13:48:18+0100] [ALPM] removed manjaro-pipewire (20220217-2)
[2022-08-08T13:48:18+0100] [ALPM] removed pipewire-zeroconf (1:0.3.56-1)
[2022-08-08T13:48:18+0100] [ALPM] installed pulseaudio (16.1-1)
[2022-08-08T13:48:18+0100] [ALPM-SCRIPTLET] Created symlink /etc/systemd/user/sockets.target.wants/pulseaudio.socket → /usr/lib/systemd/user/pulseaudio.socket.
[2022-08-08T13:48:18+0100] [ALPM] installed pulseaudio-bluetooth (16.1-1)
[2022-08-08T13:48:18+0100] [ALPM] installed pulseaudio-zeroconf (16.1-1)
[2022-08-08T13:48:18+0100] [ALPM] installed manjaro-pulse (20220217-2)
[2022-08-08T13:48:18+0100] [ALPM] transaction completed
[2022-08-08T13:48:18+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-08T13:48:18+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T13:48:18+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T13:48:18+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-08T14:04:49+0100] [ALPM] transaction started
[2022-08-08T14:04:49+0100] [ALPM] removed pipewire-x11-bell (1:0.3.56-1)
[2022-08-08T14:04:49+0100] [ALPM] transaction completed
[2022-08-08T14:04:49+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T14:04:49+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T14:05:42+0100] [ALPM] transaction started
[2022-08-08T14:05:42+0100] [ALPM] removed pipewire-v4l2 (1:0.3.56-1)
[2022-08-08T14:05:42+0100] [ALPM] transaction completed
[2022-08-08T14:05:42+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T14:05:42+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T14:19:57+0100] [PAMAC] synchronizing package lists
[2022-08-08T14:20:12+0100] [ALPM] transaction started
[2022-08-08T14:20:12+0100] [ALPM] installed lensfun (1:0.3.3-1)
[2022-08-08T14:20:12+0100] [ALPM] installed libspiro (1:20220722-1)
[2022-08-08T14:20:12+0100] [ALPM] installed blas (3.10.1-1)
[2022-08-08T14:20:12+0100] [ALPM] installed babl (0.1.92-1)
[2022-08-08T14:20:12+0100] [ALPM] installed libgexiv2 (0.14.0-3)
[2022-08-08T14:20:12+0100] [ALPM] installed metis (5.1.0.p10-2)
[2022-08-08T14:20:12+0100] [ALPM] installed lapack (3.10.1-1)
[2022-08-08T14:20:12+0100] [ALPM] installed suitesparse (5.12.0-1)
[2022-08-08T14:20:12+0100] [ALPM] installed gegl (0.4.38-1)
[2022-08-08T14:20:12+0100] [ALPM] installed netpbm (10.73.37-1)
[2022-08-08T14:20:12+0100] [ALPM] installed gts (0.7.6.121130-2)
[2022-08-08T14:20:12+0100] [ALPM] installed libmypaint (1.6.1-1)
[2022-08-08T14:20:12+0100] [ALPM] installed libwmf (0.2.12-2)
[2022-08-08T14:20:12+0100] [ALPM] installed mypaint-brushes1 (1.3.1-1)
[2022-08-08T14:20:12+0100] [ALPM] installed graphviz (5.0.0-1)
[2022-08-08T14:20:13+0100] [ALPM] installed gimp (2.10.32-1)
[2022-08-08T14:20:13+0100] [ALPM] transaction completed
[2022-08-08T14:20:13+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T14:20:13+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T14:20:13+0100] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-08-08T14:20:13+0100] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2022-08-08T14:20:13+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T14:20:13+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T14:31:36+0100] [PACMAN] Running 'pacman -R manjaro-pipewire'
[2022-08-08T14:31:43+0100] [PACMAN] Running 'pacman -R manjaro-pipewire'
[2022-08-08T14:33:18+0100] [PACMAN] Running 'pacman -Rsn pipewire'
[2022-08-08T14:33:28+0100] [PACMAN] Running 'pacman -Rsn pipewire'
[2022-08-08T14:40:38+0100] [PAMAC] synchronizing package lists
[2022-08-08T14:40:44+0100] [ALPM] transaction started
[2022-08-08T14:40:44+0100] [ALPM] installed libmaxminddb (1.6.0-3)
[2022-08-08T14:40:44+0100] [ALPM] installed libuv (1.44.2-1)
[2022-08-08T14:40:44+0100] [ALPM] installed jemalloc (1:5.3.0-1)
[2022-08-08T14:40:44+0100] [ALPM] installed bind (9.18.5-1)
[2022-08-08T14:40:44+0100] [ALPM] transaction completed
[2022-08-08T14:40:44+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2022-08-08T14:40:44+0100] [ALPM-SCRIPTLET] Creating group 'named' with GID 40.
[2022-08-08T14:40:44+0100] [ALPM-SCRIPTLET] Creating user 'named' (BIND DNS Server) with UID 40 and GID 40.
[2022-08-08T14:40:44+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-08T14:40:44+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-08-08T14:40:45+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T14:40:45+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T14:42:50+0100] [PAMAC] synchronizing package lists
[2022-08-08T14:42:55+0100] [PAMAC] synchronizing package lists
[2022-08-08T14:43:02+0100] [PAMAC] synchronizing package lists
[2022-08-08T15:28:01+0100] [PAMAC] synchronizing package lists
[2022-08-08T15:28:59+0100] [PAMAC] synchronizing package lists
[2022-08-08T15:29:57+0100] [ALPM] transaction started
[2022-08-08T15:29:57+0100] [ALPM] installed harfbuzz-icu (5.1.0-1)
[2022-08-08T15:29:57+0100] [ALPM] installed libwpe (1.12.2-1)
[2022-08-08T15:29:57+0100] [ALPM] installed wpebackend-fdo (1.12.0-2)
[2022-08-08T15:29:57+0100] [ALPM] installed enchant (2.3.3-1)
[2022-08-08T15:29:57+0100] [ALPM] installed libmanette (0.2.6-3)
[2022-08-08T15:29:58+0100] [ALPM] installed webkit2gtk (2.36.5-2)
[2022-08-08T15:29:58+0100] [ALPM] installed ufw (0.36.1-1)
[2022-08-08T15:29:58+0100] [ALPM] installed ufw-extras (0.7.0-2)
[2022-08-08T15:29:58+0100] [ALPM] installed gufw (22.04-1)
[2022-08-08T15:29:58+0100] [ALPM] transaction completed
[2022-08-08T15:29:58+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-08T15:29:58+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T15:29:58+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T15:29:58+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T15:29:58+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-08T20:16:52+0100] [PAMAC] synchronizing package lists
[2022-08-08T20:17:07+0100] [ALPM] transaction started
[2022-08-08T20:17:07+0100] [ALPM] installed lua53 (5.3.6-1)
[2022-08-08T20:17:07+0100] [ALPM] installed nmap (7.92-1)
[2022-08-08T20:17:07+0100] [ALPM] installed vulscan (2.0-4)
[2022-08-08T20:17:07+0100] [ALPM] transaction completed
[2022-08-08T20:17:07+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T20:17:07+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T22:00:01+0100] [PACMAN] Running 'pacman -Syu'
[2022-08-08T22:00:01+0100] [PACMAN] synchronizing package lists
[2022-08-08T22:00:04+0100] [PACMAN] starting full system upgrade
[2022-08-08T22:19:08+0100] [PAMAC] synchronizing package lists
[2022-08-08T22:19:32+0100] [ALPM] transaction started
[2022-08-08T22:19:33+0100] [ALPM] removed pipewire-jack (1:0.3.56-1.0)
[2022-08-08T22:19:33+0100] [ALPM] installed jack2 (1.9.21-1)
[2022-08-08T22:19:33+0100] [ALPM] transaction completed
[2022-08-08T22:19:33+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T22:19:33+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T22:22:58+0100] [ALPM] transaction started
[2022-08-08T22:22:58+0100] [ALPM] removed pipewire-alsa (1:0.3.56-1.0)
[2022-08-08T22:22:59+0100] [ALPM] transaction completed
[2022-08-08T22:22:59+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T22:22:59+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T22:53:25+0100] [PACMAN] Running '/usr/bin/pacman -S --asdeps python-xdg python-distutils-extra libkeybinder3 libwnck3'
[2022-08-08T22:53:29+0100] [ALPM] transaction started
[2022-08-08T22:53:29+0100] [ALPM] installed python-pyxdg (0.28-1)
[2022-08-08T22:53:29+0100] [ALPM] installed intltool (0.51.0-6)
[2022-08-08T22:53:29+0100] [ALPM] installed python-distutils-extra (2.39-10)
[2022-08-08T22:53:29+0100] [ALPM] installed libkeybinder3 (0.3.2-3)
[2022-08-08T22:53:29+0100] [ALPM] installed startup-notification (0.12-7)
[2022-08-08T22:53:29+0100] [ALPM] installed libwnck3 (40.1-1)
[2022-08-08T22:53:29+0100] [ALPM] transaction completed
[2022-08-08T22:53:29+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T22:53:29+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T22:53:35+0100] [PACMAN] Running '/usr/bin/pacman -U /home/user/Applications/kazam/kazam-1.4.5-9-any.pkg.tar.zst'
[2022-08-08T22:53:47+0100] [ALPM] transaction started
[2022-08-08T22:53:47+0100] [ALPM] installed kazam (1.4.5-9)
[2022-08-08T22:53:48+0100] [ALPM] transaction completed
[2022-08-08T22:53:48+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-08T22:53:48+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-08T22:53:48+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-08T22:53:48+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-09T22:46:48+0100] [PACMAN] Running '/usr/bin/pacman -S --asdeps uasm'
[2022-08-09T22:48:54+0100] [PACMAN] Running 'pacman -R uasm'
[2022-08-09T22:58:58+0100] [PACMAN] Running '/usr/bin/pacman -U /home/user/Applications/7-zip-full/uasm/uasm-2.55-1-x86_64.pkg.tar.zst'
[2022-08-09T22:59:01+0100] [ALPM] transaction started
[2022-08-09T22:59:01+0100] [ALPM] installed uasm (2.55-1)
[2022-08-09T22:59:01+0100] [ALPM] transaction completed
[2022-08-09T22:59:01+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-09T22:59:01+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-09T23:03:57+0100] [PACMAN] Running '/usr/bin/pacman -U /home/user/Applications/7-zip-full/7-zip-full-22.01-1-x86_64.pkg.tar.zst'
[2022-08-09T23:04:08+0100] [ALPM] transaction started
[2022-08-09T23:04:09+0100] [ALPM] removed p7zip (1:17.04-3)
[2022-08-09T23:04:09+0100] [ALPM] installed 7-zip-full (22.01-1)
[2022-08-09T23:04:09+0100] [ALPM] transaction completed
[2022-08-09T23:04:09+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-09T23:04:09+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-09T23:09:18+0100] [PAMAC] synchronizing package lists
[2022-08-09T23:09:46+0100] [ALPM] transaction started
[2022-08-09T23:09:46+0100] [ALPM] removed 7-zip-full (22.01-1)
[2022-08-09T23:09:46+0100] [ALPM] transaction completed
[2022-08-09T23:09:46+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-09T23:09:46+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-09T23:13:06+0100] [PACMAN] Running 'pacman -Syu'
[2022-08-09T23:13:06+0100] [PACMAN] synchronizing package lists
[2022-08-09T23:13:06+0100] [PACMAN] starting full system upgrade
[2022-08-09T23:19:12+0100] [ALPM] transaction started
[2022-08-09T23:19:12+0100] [ALPM] removed uasm (2.55-1)
[2022-08-09T23:19:12+0100] [ALPM] transaction completed
[2022-08-09T23:19:12+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-09T23:19:12+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-09T23:21:18+0100] [PAMAC] synchronizing package lists
[2022-08-09T23:37:56+0100] [PAMAC] synchronizing package lists
[2022-08-09T23:42:34+0100] [ALPM] transaction started
[2022-08-09T23:42:35+0100] [ALPM] installed chromium (104.0.5112.79-1)
[2022-08-09T23:42:35+0100] [ALPM] transaction completed
[2022-08-09T23:42:35+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-09T23:42:35+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-09T23:42:35+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-09T23:42:35+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T00:40:37+0100] [PACMAN] Running 'pacman -U package.pkg.tar.zst'
[2022-08-10T00:41:03+0100] [PACMAN] Running 'pacman -U megasync-x86_64.pkg.tar.zst'
[2022-08-10T00:41:06+0100] [ALPM] transaction started
[2022-08-10T00:41:06+0100] [ALPM] installed megasync (4.6.7-2)
[2022-08-10T00:41:06+0100] [ALPM-SCRIPTLET] ==> Updating trust database...
[2022-08-10T00:41:06+0100] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2022-09-22
[2022-08-10T00:41:06+0100] [ALPM-SCRIPTLET] -> Locally signed 1 keys.
[2022-08-10T00:41:07+0100] [ALPM-SCRIPTLET] gpg: marginals needed: 3 completes needed: 1 trust model: pgp
[2022-08-10T00:41:07+0100] [ALPM-SCRIPTLET] gpg: depth: 0 valid: 1 signed: 23 trust: 0-, 0q, 0n, 0m, 0f, 1u
[2022-08-10T00:41:07+0100] [ALPM-SCRIPTLET] gpg: depth: 1 valid: 23 signed: 92 trust: 1-, 0q, 0n, 22m, 0f, 0u
[2022-08-10T00:41:07+0100] [ALPM-SCRIPTLET] gpg: depth: 2 valid: 72 signed: 28 trust: 72-, 0q, 0n, 0m, 0f, 0u
[2022-08-10T00:41:07+0100] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2022-09-22
[2022-08-10T00:41:07+0100] [ALPM-SCRIPTLET] fs.inotify.max_user_watches = 524288
[2022-08-10T00:41:07+0100] [ALPM] transaction completed
[2022-08-10T00:41:07+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T00:41:07+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T00:41:07+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T00:41:07+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T00:41:47+0100] [PACMAN] Running 'pacman -U dolphin-megasync-x86_64.pkg.tar.xz'
[2022-08-10T00:41:51+0100] [ALPM] transaction started
[2022-08-10T00:41:51+0100] [ALPM] installed dolphin-megasync (3.6.6-2)
[2022-08-10T00:41:51+0100] [ALPM] transaction completed
[2022-08-10T00:41:51+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T00:41:51+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T00:41:51+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T00:59:46+0100] [PACMAN] Running 'pacman -U dolphin-megasync-x86_64.pkg.tar.xz exit'
[2022-08-10T08:36:46+0100] [ALPM] transaction started
[2022-08-10T08:36:46+0100] [ALPM] removed dolphin-megasync (3.6.6-2)
[2022-08-10T08:36:46+0100] [ALPM] removed megasync (4.6.7-2)
[2022-08-10T08:36:46+0100] [ALPM] transaction completed
[2022-08-10T08:36:46+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T08:36:46+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T08:36:46+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T08:36:46+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T15:10:57+0100] [ALPM] transaction started
[2022-08-10T15:10:57+0100] [ALPM] removed wine-gecko (2.47.3-1)
[2022-08-10T15:10:57+0100] [ALPM] removed wine-mono (7.3.0-1)
[2022-08-10T15:10:57+0100] [ALPM] removed winetricks (20220411-1)
[2022-08-10T15:10:57+0100] [ALPM] removed wine (7.14-1)
[2022-08-10T15:10:57+0100] [ALPM-SCRIPTLET] binfmt binary formats will be updated at reboot
[2022-08-10T15:10:57+0100] [ALPM] transaction completed
[2022-08-10T15:10:57+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T15:10:57+0100] [ALPM] running '40-fontconfig-config.hook'...
[2022-08-10T15:10:57+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T15:10:57+0100] [ALPM] running 'fontconfig.hook'...
[2022-08-10T15:10:57+0100] [ALPM] running 'fontconfig-32.hook'...
[2022-08-10T15:10:57+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T15:10:57+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T15:20:24+0100] [PAMAC] synchronizing package lists
[2022-08-10T15:30:02+0100] [PACMAN] Running 'pacman -R manjaro-pipewire'
[2022-08-10T15:30:09+0100] [PACMAN] Running 'pacman -R pipewire'
[2022-08-10T15:32:39+0100] [PACMAN] Running 'pacman -S pulseaudio'
[2022-08-10T15:32:52+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-10T15:32:52+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-10T15:32:52+0100] [ALPM] transaction started
[2022-08-10T15:32:52+0100] [ALPM] reinstalled pulseaudio (16.1-1)
[2022-08-10T15:32:52+0100] [ALPM] transaction completed
[2022-08-10T15:32:52+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-10T15:32:52+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T15:32:52+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T15:32:52+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-10T15:33:57+0100] [PACMAN] Running 'pacman -S pulseaudio pulseaudio-alsa pulseaudio-jack pulseaudio-bluetooth'
[2022-08-10T15:34:04+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-10T15:34:04+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-10T15:34:04+0100] [ALPM] transaction started
[2022-08-10T15:34:04+0100] [ALPM] reinstalled pulseaudio (16.1-1)
[2022-08-10T15:34:04+0100] [ALPM] reinstalled pulseaudio-alsa (1:1.2.7.1-1)
[2022-08-10T15:34:04+0100] [ALPM] installed pulseaudio-jack (16.1-1)
[2022-08-10T15:34:04+0100] [ALPM] reinstalled pulseaudio-bluetooth (16.1-1)
[2022-08-10T15:34:04+0100] [ALPM] transaction completed
[2022-08-10T15:34:04+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-10T15:34:04+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T15:34:04+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T15:34:04+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-10T15:38:45+0100] [PACMAN] Running 'pacman -R pipewire-session-manager'
[2022-08-10T15:38:55+0100] [PACMAN] Running 'pacman -R pipewire'
[2022-08-10T15:40:14+0100] [ALPM] transaction started
[2022-08-10T15:40:15+0100] [ALPM] removed gst-plugin-pipewire (1:0.3.56-1)
[2022-08-10T15:40:15+0100] [ALPM] transaction completed
[2022-08-10T15:40:15+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T15:40:15+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T16:15:23+0100] [ALPM] transaction started
[2022-08-10T16:15:24+0100] [ALPM] removed calf (0.90.3-5)
[2022-08-10T16:15:24+0100] [ALPM] transaction completed
[2022-08-10T16:15:24+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T16:15:24+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T16:15:24+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T16:15:24+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T16:15:42+0100] [ALPM] transaction started
[2022-08-10T16:15:42+0100] [ALPM] removed elisa (22.04.3-1)
[2022-08-10T16:15:42+0100] [ALPM] transaction completed
[2022-08-10T16:15:42+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T16:15:42+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T16:15:42+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T16:15:42+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T16:17:27+0100] [ALPM] transaction started
[2022-08-10T16:17:27+0100] [ALPM] removed vlc (3.0.17.4-7)
[2022-08-10T16:17:27+0100] [ALPM] transaction completed
[2022-08-10T16:17:27+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T16:17:27+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T16:17:27+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T16:17:27+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T17:12:54+0100] [PACMAN] Running 'pacman -S pulseaudio'
[2022-08-10T17:12:58+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-10T17:12:58+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-10T17:12:58+0100] [ALPM] transaction started
[2022-08-10T17:12:58+0100] [ALPM] reinstalled pulseaudio (16.1-1)
[2022-08-10T17:12:58+0100] [ALPM] transaction completed
[2022-08-10T17:12:58+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-10T17:12:58+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T17:12:58+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T17:12:58+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-10T17:16:55+0100] [PACMAN] Running 'pacman -S pulseaudio pulseaudio-bluetooth'
[2022-08-10T17:16:58+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-08-10T17:16:58+0100] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-08-10T17:16:58+0100] [ALPM] transaction started
[2022-08-10T17:16:58+0100] [ALPM] reinstalled pulseaudio (16.1-1)
[2022-08-10T17:16:58+0100] [ALPM] reinstalled pulseaudio-bluetooth (16.1-1)
[2022-08-10T17:16:58+0100] [ALPM] transaction completed
[2022-08-10T17:16:58+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-08-10T17:16:58+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T17:16:58+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T17:16:58+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2022-08-10T17:17:21+0100] [PACMAN] Running 'pacman -R pipewire-media-session pipewire-jack'
[2022-08-10T17:17:29+0100] [PACMAN] Running 'pacman -R pipewire-media-session'
[2022-08-10T18:58:27+0100] [PAMAC] synchronizing package lists
[2022-08-10T18:58:34+0100] [ALPM] transaction started
[2022-08-10T18:58:34+0100] [ALPM] installed calf (0.90.3-5)
[2022-08-10T18:58:34+0100] [ALPM] transaction completed
[2022-08-10T18:58:34+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T18:58:34+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T18:58:34+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T18:58:34+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T18:59:12+0100] [PAMAC] synchronizing package lists
[2022-08-10T18:59:16+0100] [ALPM] transaction started
[2022-08-10T18:59:17+0100] [ALPM] installed vlc (3.0.17.4-7)
[2022-08-10T18:59:17+0100] [ALPM] installed elisa (22.04.3-1)
[2022-08-10T18:59:17+0100] [ALPM] transaction completed
[2022-08-10T18:59:17+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T18:59:17+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T18:59:17+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T18:59:17+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T18:59:17+0100] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2022-08-10T21:55:02+0100] [PAMAC] synchronizing package lists
[2022-08-10T21:57:11+0100] [ALPM] transaction started
[2022-08-10T21:57:11+0100] [ALPM] installed lynis (3.0.8-1)
[2022-08-10T21:57:11+0100] [ALPM] installed net-tools (2.10-1)
[2022-08-10T21:57:11+0100] [ALPM] transaction completed
[2022-08-10T21:57:11+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-10T21:57:11+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T21:57:11+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T21:58:07+0100] [PAMAC] synchronizing package lists
[2022-08-10T22:15:45+0100] [ALPM] transaction started
[2022-08-10T22:15:45+0100] [ALPM] removed calf (0.90.3-5)
[2022-08-10T22:15:45+0100] [ALPM] transaction completed
[2022-08-10T22:15:45+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T22:15:45+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T22:15:45+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T22:15:45+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-10T22:24:10+0100] [PAMAC] synchronizing package lists
[2022-08-10T22:26:51+0100] [ALPM] transaction started
[2022-08-10T22:26:51+0100] [ALPM] installed libsigc++ (2.10.8-1)
[2022-08-10T22:26:51+0100] [ALPM] installed glibmm (2.66.4-1)
[2022-08-10T22:26:51+0100] [ALPM] installed cairomm (1.14.3-2)
[2022-08-10T22:26:51+0100] [ALPM] installed pangomm (2.46.2-1)
[2022-08-10T22:26:51+0100] [ALPM] installed atkmm (2.28.3-1)
[2022-08-10T22:26:51+0100] [ALPM] installed gtkmm3 (3.24.6-1)
[2022-08-10T22:26:51+0100] [ALPM] installed gsmartcontrol (1.1.4-1)
[2022-08-10T22:26:51+0100] [ALPM] installed luit (20220111-1)
[2022-08-10T22:26:51+0100] [ALPM] installed xbitmaps (1.1.2-3)
[2022-08-10T22:26:51+0100] [ALPM] installed xterm (372-2)
[2022-08-10T22:26:51+0100] [ALPM] transaction completed
[2022-08-10T22:26:51+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-10T22:26:51+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-10T22:26:51+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-10T22:26:51+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-11T10:57:18+0100] [ALPM] transaction started
[2022-08-11T10:57:18+0100] [ALPM] removed gufw (22.04-1)
[2022-08-11T10:57:18+0100] [ALPM] removed ufw-extras (0.7.0-2)
[2022-08-11T10:57:18+0100] [ALPM] warning: /etc/ufw/user6.rules saved as /etc/ufw/user6.rules.pacsave
[2022-08-11T10:57:18+0100] [ALPM] warning: /etc/ufw/user.rules saved as /etc/ufw/user.rules.pacsave
[2022-08-11T10:57:18+0100] [ALPM] warning: /etc/ufw/ufw.conf saved as /etc/ufw/ufw.conf.pacsave
[2022-08-11T10:57:18+0100] [ALPM] removed ufw (0.36.1-1)
[2022-08-11T10:57:18+0100] [ALPM] transaction completed
[2022-08-11T10:57:18+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-11T10:57:18+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-11T10:57:18+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-11T10:57:18+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-11T10:57:18+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-11T11:02:30+0100] [PACMAN] Running 'pacman -R ufw'
[2022-08-11T11:02:34+0100] [PACMAN] Running 'pacman -R gufw'
[2022-08-11T11:02:58+0100] [PAMAC] synchronizing package lists
[2022-08-11T11:03:01+0100] [ALPM] transaction started
[2022-08-11T11:03:01+0100] [ALPM] installed ufw (0.36.1-1)
[2022-08-11T11:03:01+0100] [ALPM] installed ufw-extras (0.7.0-2)
[2022-08-11T11:03:01+0100] [ALPM] installed gufw (22.04-1)
[2022-08-11T11:03:01+0100] [ALPM] transaction completed
[2022-08-11T11:03:01+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-08-11T11:03:01+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-11T11:03:01+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-11T11:03:01+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-11T11:03:01+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-08-11T11:39:42+0100] [ALPM] transaction started
[2022-08-11T11:39:42+0100] [ALPM] removed lsp-plugins (1.2.2-1)
[2022-08-11T11:39:42+0100] [ALPM] transaction completed
[2022-08-11T11:39:42+0100] [ALPM] running '30-systemd-update.hook'...
[2022-08-11T11:39:42+0100] [ALPM] running '90-packagekit-refresh.hook'...
[2022-08-11T11:39:42+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-08-11T11:39:42+0100] [ALPM] running 'update-desktop-database.hook'...
888
11 August 2022 16:23
5
How exactly did you remove those packages?
Via the pamac GUI.
Next manjaro issue will have the context you mentioned!
“sudo ufw enable” to make ufw auto start “On” (after a reboot), is not working.
I must mention Hibernate is also not working for me, as it wakes after a few seconds.
I followed this steps but it did not work - https://www.youtube.com/watch?v=AorzS-FxFww
1. Look in /etc/fstab and make sure the following line is there:
UUID=[UUID_of_the_swap_partition] none swap defaults 0 0
Copy the [UUID_of_the_swap_partition] before moving on to the next step.
2. In /etc/default/grub add: resume=UUID=[UUID_of_the_swap_partition] to GRUB_CMDLINE_LINUX
3. In /etc/mkinitcpio.conf add resume to HOOKS (after udev)
Then :x to edit out of the vim editor.
4. Reload the configurations by running:
sudo mkinitcpio -P && sudo update-grub
5. Hibernate and log back in to see if that fixed the problems.
I continue to research on it.
Are you sure that icon change didn’t occur back then?
Or that you haven’t changed your default Internet browser since then?
As in, it does nothing? Or you get errors?
888
11 August 2022 17:03
7
I did not notice it happening before.
I did not change the default browser. I just confirmed it is still Firefox.
What happened after i removed the 3 ufw packages is that firefox icon disappeared from system tray and chromium appeared instead. It was today.
Yesterday i also noticed system settings icon and a kde.desktop… white file without icon image there.
And i removed them from the tray. I did not delete them .
It does nothing! It does not autostart on it’s own as it should. I have to start it every time i reboot.
So is it the tray or the taskbar? Don’t start confusing us now…
Start and enable ufw.service to make it available at boot.
Uncomplicated Firewall - ArchWiki
sudo systemctl enable ufw
Did it get back on its own – for instance after a reboot – or did you have to replace it yourself?
888
12 August 2022 14:32
11
@maycne.sonahoz
I replaced it by myself.
If happens again i will reboot and report
