Yesterday I had problem with starting manjaro and since that I cant load system.
[FAILED] to start pkgfile database update
I cant enter the system after the deb1 clean and blocks info.
All that shows up is a blinking
_
_
I’m guessing your system somehow ended up in a partially updated state. I’m thinking you’ll have to rerun the update from a chroot
environment.
chroot
Ensure you’ve got a relatively new ISO or at least one with an LTS kernel.
Write/copy/dd
the ISO to a USB thumb drive.
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the chroot
encironment:
manjaro-chroot -a
When done, you should now be in the chroot
environment.
But, be careful, as you’re now in an actual root environment oon your computer, so any changes you make will persist after a restart.
Once in the chroot
environment, re-run the update:
pamac upgrade --enable-downgrade --aur --devel
Once successful and done, reboot and test. If not, enter the chroot
environment again, and provide the following information:
Hope you manage!
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
ist not very likely that the pkgfile is the issue …
boot into manjaro usb, just like when you were installing it - thats live enviroment, and from this you can repair your installation …
a Live environment is simply the Manjaro you work on/use when you boot from a USB. (Or a CDE, but that old and probably irrelevant.)
The ISO is simply the ISO image you downloaded and used to install Manjaro. If you really don’t have the knowledge to know how to proceed, it might be better if you get someone to assist you with this.
Yes, and then extract/copy/burn it for use to the USB thumb drive on that computer as well.
Please see
The process doesn’t touch the files. In fact, that whole live environment is temporary, that’s why the chroot
is necessary. To make some of the changes on your actual system and so that they’ll persist.
In.Deed.
The live environment doesn’t touch your system It’s entirely run from RAM. That’s why nothing’s persisted, except in the chroot
environment, as I mentioned above.
Obviously just make sure you don’t delete stuff of you hard disk when in the live environment. Because, that’s gonna leave a mark.
Here’s what I’ve got with manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sdb1]
--> mount: [/mnt]
--> mount: [/mnt/home]
Mirdarthos
Looks good!
Now try the update and so on.
edit: after the update in chroot, I’ve got the same issue:
it has no error, but everything that shows up is a
_
Looks good!
Well, that’s no fun. So let’s try and find out why:
chroot
environment, as previously.chroot
environment, execute the following:journalctl --boot --priority=3 --no-pager
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
-- No entries --
OK, so try:
journalctl --boot=-1 --priority=3 --no-pager
And
journalctl --boot=-2 --priority=3 --no-pager
And
journalctl --boot=-3 --priority=3 --no-pager
Aug 20 11:18:13 flordeibez kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Aug 20 11:18:13 flordeibez kernel: ACPI Error: Needed type [Reference], found [Integer] 00000000e338065e (20210730/exresop-66)
Aug 20 11:18:13 flordeibez kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20210730/dswexec-431)
Aug 20 11:18:13 flordeibez kernel: ACPI Error: Aborting method \_PR.CPU0._PDC due to previous error (AE_AML_OPERAND_TYPE) (20210730/psparse-529)
Aug 20 11:18:18 flordeibez kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Aug 20 11:18:38 flordeibez systemd[1]: Failed to start Light Display Manager.
Aug 20 10:40:28 flordeibez kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Aug 20 10:40:49 flordeibez systemd[1]: Failed to start Light Display Manager.
do you have nvidia?
No, I have a intel hd graphics. I have a thinkpad laptop.
i thought you were affected with the recent nvidia update…
so post output from:
mhwd-kernel -li && mhwd -l && mhwd -li
Currently running: 5.15.55-1-MANJARO (linux515)
* linux515
> 0000:00:02.0 (0300:8086:1616) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
reinstall your kernel and graphic driver:
reinstall kernel:
pacman -S linux515
uninstall video:
mhwd -r pci video-linux
install video:
mhwd -i pci video-linux
exit
reboot
if you end up again in stuck screen enter into tty - press ctrl+alt+f2
in the blinking cursor screen - if f2 doesnt work, try f1-f6 keys, then enter your username/password, and type:
startx
reinstalling my kernel won’t affect the system, right?
no it wont, dont worry … if you get again stuck enter into tty as outlined above …
I did startx, but nothing’s changed.
I’m still in stuck screen.
The last line says
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
