ok, so there should be a line where a xorg.log file was saved in your home directory … tak a picture of it, then chroot again and post the output of the xorg log with:
cat /path/to/the/file/xorg.0.log
of course not, you should have run the actual path to the xorg.log like this:
cat /home/edicao/.local/share/xorg/Xorg.0.log
i’m still learning about the path files, sorry.
what’s the line we’re looking for?
[ 2937.952]
X.Org X Server 1.21.1.4
[ 2937.953] Current Operating System: Linux flordeibez 5.15.60-1-MANJARO #1 SMP PREEMPT Thu Aug 11 13:14:05 UTC 2022 x86_64
[ 2937.953] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=cbe28747-87cf-4f32-adf1-a21d19ca3735 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 2937.953]
[ 2937.953] Current version of pixman: 0.40.0
[ 2937.953] Before reporting problems, check http://wiki.x.org
[ 2937.953] Markers: (--) probed, (**) from config file, (==) default setting,
[ 2937.953] (==) Log file: "/home/edicao/.local/share/xorg/Xorg.0.log", Time: Sat Aug 20 14:01:17 2022
[ 2937.954] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2937.954] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2937.954] (==) No Layout section. Using the first Screen section.
[ 2937.954] (==) No screen section available. Using defaults.
[ 2937.954] (**) |-->Screen "Default Screen Section" (0)
[ 2937.954] (**) | |-->Monitor "<default monitor>"
[ 2937.954] (==) No monitor specified for screen "Default Screen Section".
[ 2937.954] (==) Automatically adding devices
[ 2937.954] (==) Automatically enabling devices
[ 2937.954] (==) Automatically adding GPU devices
[ 2937.954] (==) Automatically binding GPU devices
[ 2937.954] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2937.954] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 2937.954] Entry deleted from font path.
[ 2937.954] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2937.954] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2937.954] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2937.954] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 2937.954] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2937.954] (II) The server relies on udev to provide the list of input devices.
[ 2937.954] (II) Module ABI versions:
[ 2937.954] X.Org ANSI C Emulation: 0.4
[ 2937.954] X.Org Video Driver: 25.2
[ 2937.954] X.Org XInput driver : 24.4
[ 2937.954] X.Org Server Extension : 10.0
[ 2937.955] (++) using VT number 5
[ 2937.957] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[ 2937.958] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2937.958] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 2937.959] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 2937.960] (--) PCI:*(0@0:2:0) 8086:1616:17aa:5036 rev 9, Mem @ 0xf0000000/16777216, 0xe0000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[ 2937.960] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2937.960] (II) LoadModule: "glx"
[ 2937.960] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2937.962] (II) Module glx: vendor="X.Org Foundation"
[ 2937.962] compiled for 1.21.1.4, module version = 1.0.0
[ 2937.962] ABI class: X.Org Server Extension, version 10.0
[ 2937.962] (==) Matched modesetting as autoconfigured driver 0
[ 2937.962] (==) Matched fbdev as autoconfigured driver 1
[ 2937.962] (==) Matched vesa as autoconfigured driver 2
[ 2937.962] (==) Assigned the driver to the xf86ConfigLayout
[ 2937.962] (II) LoadModule: "modesetting"
[ 2937.962] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 2937.962] (II) Module modesetting: vendor="X.Org Foundation"
[ 2937.962] compiled for 1.21.1.4, module version = 1.21.1
[ 2937.962] Module class: X.Org Video Driver
[ 2937.962] ABI class: X.Org Video Driver, version 25.2
[ 2937.962] (II) LoadModule: "fbdev"
[ 2937.962] (WW) Warning, couldn't open module fbdev
[ 2937.962] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 2937.962] (II) LoadModule: "vesa"
[ 2937.962] (WW) Warning, couldn't open module vesa
[ 2937.962] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 2937.962] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2937.963] (II) modeset(0): using drv /dev/dri/card0
[ 2937.963] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 2937.963] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 2937.963] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 2937.963] (==) modeset(0): RGB weight 888
[ 2937.963] (==) modeset(0): Default visual is TrueColor
[ 2937.963] (II) Loading sub module "glamoregl"
[ 2937.963] (II) LoadModule: "glamoregl"
[ 2937.963] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 2937.966] (II) Module glamoregl: vendor="X.Org Foundation"
[ 2937.966] compiled for 1.21.1.4, module version = 1.0.1
[ 2937.966] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2937.997] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 5500 (BDW GT2)
[ 2937.997] (II) modeset(0): glamor initialized
[ 2937.997] (==) modeset(0): VariableRefresh: disabled
[ 2937.997] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 2937.998] (II) modeset(0): Output eDP-1 has no monitor section
[ 2937.998] (II) modeset(0): Output DP-1 has no monitor section
[ 2938.178] (II) modeset(0): Output HDMI-1 has no monitor section
[ 2938.178] (II) modeset(0): Output DP-2 has no monitor section
[ 2938.180] (II) modeset(0): Output HDMI-2 has no monitor section
[ 2938.181] (II) modeset(0): EDID for output eDP-1
[ 2938.181] (II) modeset(0): Manufacturer: CMN Model: 1482 Serial#: 0
[ 2938.181] (II) modeset(0): Year: 2012 Week: 31
[ 2938.181] (II) modeset(0): EDID Version: 1.4
[ 2938.181] (II) modeset(0): Digital Display Input
[ 2938.181] (II) modeset(0): 6 bits per channel
[ 2938.181] (II) modeset(0): Digital interface is DisplayPort
[ 2938.181] (II) modeset(0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 2938.181] (II) modeset(0): Gamma: 2.20
[ 2938.181] (II) modeset(0): No DPMS capabilities specified
[ 2938.181] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 2938.181] (II) modeset(0): First detailed timing is preferred mode
[ 2938.181] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 2938.181] (II) modeset(0): redX: 0.580 redY: 0.335 greenX: 0.325 greenY: 0.575
[ 2938.181] (II) modeset(0): blueX: 0.160 blueY: 0.140 whiteX: 0.313 whiteY: 0.329
[ 2938.181] (II) modeset(0): Manufacturer's mask: 0
[ 2938.181] (II) modeset(0): Supported detailed timing:
[ 2938.181] (II) modeset(0): clock: 107.8 MHz Image Size: 309 x 174 mm
[ 2938.181] (II) modeset(0): h_active: 1600 h_sync: 1648 h_sync_end 1680 h_blank_end 1940 h_border: 0
[ 2938.181] (II) modeset(0): v_active: 900 v_sync: 903 v_sync_end 908 v_blanking: 926 v_border: 0
[ 2938.181] (II) modeset(0): N140FGE-EA2
[ 2938.181] (II) modeset(0): CMN
[ 2938.181] (II) modeset(0): EDID (in hex):
[ 2938.181] (II) modeset(0): 00ffffffffffff000dae821400000000
[ 2938.181] (II) modeset(0): 1f160104951f117802b5359455539329
[ 2938.181] (II) modeset(0): 23505400000001010101010101010101
[ 2938.181] (II) modeset(0): 0101010101011c2a405461841a303020
[ 2938.181] (II) modeset(0): 350035ae10000018000000fe004e3134
[ 2938.181] (II) modeset(0): 304647452d4541320a20000000fe0043
[ 2938.181] (II) modeset(0): 4d4e0a202020202020202020000000fe
[ 2938.181] (II) modeset(0): 004e3134304647452d4541320a200060
[ 2938.181] (II) modeset(0): Printing probed modes for output eDP-1
[ 2938.181] (II) modeset(0): Modeline "1600x900"x60.0 107.80 1600 1648 1680 1940 900 903 908 926 -hsync -vsync (55.6 kHz eP)
[ 2938.181] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 2938.181] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 2938.181] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 2938.181] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 2938.181] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 2938.181] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 2938.181] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 2938.181] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 2938.181] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 2938.181] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 2938.181] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 2938.181] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 2938.181] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 2938.181] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 2938.181] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 2938.181] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 2938.181] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 2938.181] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 2938.182] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 2938.182] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 2938.182] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 2938.182] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 2938.182] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 2938.182] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 2938.182] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 2938.182] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 2938.182] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 2938.182] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 2938.182] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 2938.182] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 2938.182] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 2938.182] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 2938.182] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 2938.182] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 2938.182] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 2938.182] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 2938.182] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 2938.182] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 2938.182] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 2938.182] (II) modeset(0): EDID for output DP-1
[ 2938.361] (II) modeset(0): EDID for output HDMI-1
[ 2938.361] (II) modeset(0): EDID for output DP-2
[ 2938.363] (II) modeset(0): EDID for output HDMI-2
[ 2938.363] (II) modeset(0): Output eDP-1 connected
[ 2938.363] (II) modeset(0): Output DP-1 disconnected
[ 2938.363] (II) modeset(0): Output HDMI-1 disconnected
[ 2938.363] (II) modeset(0): Output DP-2 disconnected
[ 2938.363] (II) modeset(0): Output HDMI-2 disconnected
[ 2938.363] (II) modeset(0): Using exact sizes for initial modes
[ 2938.363] (II) modeset(0): Output eDP-1 using initial mode 1600x900 +0+0
[ 2938.363] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2938.363] (==) modeset(0): DPI set to (96, 96)
[ 2938.363] (II) Loading sub module "fb"
[ 2938.363] (II) LoadModule: "fb"
[ 2938.363] (II) Module "fb" already built-in
[ 2938.893] (==) modeset(0): Backing store enabled
[ 2938.893] (==) modeset(0): Silken mouse enabled
[ 2938.971] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 2938.971] (==) modeset(0): DPMS enabled
[ 2938.971] (II) modeset(0): [DRI2] Setup complete
[ 2938.971] (II) modeset(0): [DRI2] DRI driver: iris
[ 2938.971] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 2938.971] (II) Initializing extension Generic Event Extension
[ 2938.972] (II) Initializing extension SHAPE
[ 2938.972] (II) Initializing extension MIT-SHM
[ 2938.972] (II) Initializing extension XInputExtension
[ 2938.973] (II) Initializing extension XTEST
[ 2938.973] (II) Initializing extension BIG-REQUESTS
[ 2938.973] (II) Initializing extension SYNC
[ 2938.974] (II) Initializing extension XKEYBOARD
[ 2938.974] (II) Initializing extension XC-MISC
[ 2938.974] (II) Initializing extension SECURITY
[ 2938.975] (II) Initializing extension XFIXES
[ 2938.975] (II) Initializing extension RENDER
[ 2938.975] (II) Initializing extension RANDR
[ 2938.976] (II) Initializing extension COMPOSITE
[ 2938.976] (II) Initializing extension DAMAGE
[ 2938.977] (II) Initializing extension MIT-SCREEN-SAVER
[ 2938.977] (II) Initializing extension DOUBLE-BUFFER
[ 2938.977] (II) Initializing extension RECORD
[ 2938.978] (II) Initializing extension DPMS
[ 2938.978] (II) Initializing extension Present
[ 2938.978] (II) Initializing extension DRI3
[ 2938.979] (II) Initializing extension X-Resource
[ 2938.979] (II) Initializing extension XVideo
[ 2938.979] (II) Initializing extension XVideo-MotionCompensation
[ 2938.979] (II) Initializing extension GLX
[ 2938.986] (II) AIGLX: Loaded and initialized iris
[ 2938.986] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 2938.986] (II) Initializing extension XFree86-VidModeExtension
[ 2938.986] (II) Initializing extension XFree86-DGA
[ 2938.986] (II) Initializing extension XFree86-DRI
[ 2938.986] (II) Initializing extension DRI2
[ 2938.987] (II) modeset(0): Damage tracking initialized
[ 2938.987] (II) modeset(0): Setting screen physical size to 423 x 238
[ 2939.128] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 2939.128] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 2939.128] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 2939.128] (**) Power Button: Applying InputClass "system-keyboard"
[ 2939.128] (II) LoadModule: "libinput"
[ 2939.128] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 2939.129] (II) Module libinput: vendor="X.Org Foundation"
[ 2939.129] compiled for 1.21.1.3, module version = 1.2.1
[ 2939.129] Module class: X.Org XInput Driver
[ 2939.129] ABI class: X.Org XInput driver, version 24.4
[ 2939.129] (II) Using input driver 'libinput' for 'Power Button'
[ 2939.130] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 29 paused 0
[ 2939.130] (**) Power Button: always reports core events
[ 2939.130] (**) Option "Device" "/dev/input/event2"
[ 2939.132] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 2939.132] (II) event2 - Power Button: device is a keyboard
[ 2939.132] (II) event2 - Power Button: device removed
[ 2939.132] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 2939.132] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 2939.132] (**) Option "xkb_layout" "br"
[ 2939.149] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 2939.149] (II) event2 - Power Button: device is a keyboard
[ 2939.149] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 2939.149] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 2939.149] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 2939.149] (**) Video Bus: Applying InputClass "system-keyboard"
[ 2939.149] (II) Using input driver 'libinput' for 'Video Bus'
[ 2939.150] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 32 paused 0
[ 2939.150] (**) Video Bus: always reports core events
[ 2939.150] (**) Option "Device" "/dev/input/event6"
[ 2939.151] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 2939.151] (II) event6 - Video Bus: device is a keyboard
[ 2939.151] (II) event6 - Video Bus: device removed
[ 2939.151] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event6"
[ 2939.151] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 2939.151] (**) Option "xkb_layout" "br"
[ 2939.152] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 2939.152] (II) event6 - Video Bus: device is a keyboard
[ 2939.153] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 2939.153] (II) No input driver specified, ignoring this device.
[ 2939.153] (II) This device may have been added with another device file.
[ 2939.153] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 2939.153] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 2939.153] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 2939.153] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 2939.153] (II) Using input driver 'libinput' for 'Sleep Button'
[ 2939.154] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 33 paused 0
[ 2939.154] (**) Sleep Button: always reports core events
[ 2939.154] (**) Option "Device" "/dev/input/event1"
[ 2939.154] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 2939.155] (II) event1 - Sleep Button: device is a keyboard
[ 2939.155] (II) event1 - Sleep Button: device removed
[ 2939.155] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 2939.155] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 2939.155] (**) Option "xkb_layout" "br"
[ 2939.155] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 2939.156] (II) event1 - Sleep Button: device is a keyboard
[ 2939.156] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event8)
[ 2939.156] (II) No input driver specified, ignoring this device.
[ 2939.156] (II) This device may have been added with another device file.
[ 2939.157] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event9)
[ 2939.157] (II) No input driver specified, ignoring this device.
[ 2939.157] (II) This device may have been added with another device file.
[ 2939.157] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event10)
[ 2939.157] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event11)
[ 2939.158] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event7)
[ 2939.158] (II) No input driver specified, ignoring this device.
[ 2939.158] (II) This device may have been added with another device file.
[ 2939.158] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event17)
[ 2939.158] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[ 2939.158] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 2939.158] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[ 2939.158] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[ 2939.159] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 34 paused 0
[ 2939.159] (**) Integrated Camera: Integrated C: always reports core events
[ 2939.159] (**) Option "Device" "/dev/input/event17"
[ 2939.160] (II) event17 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 2939.160] (II) event17 - Integrated Camera: Integrated C: device is a keyboard
[ 2939.160] (II) event17 - Integrated Camera: Integrated C: device removed
[ 2939.160] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.0/input/input20/event17"
[ 2939.160] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 9)
[ 2939.160] (**) Option "xkb_layout" "br"
[ 2939.161] (II) event17 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 2939.161] (II) event17 - Integrated Camera: Integrated C: device is a keyboard
[ 2939.162] (II) config/udev: Adding input device HDA Intel PCH Dock Mic (/dev/input/event12)
[ 2939.162] (II) No input driver specified, ignoring this device.
[ 2939.162] (II) This device may have been added with another device file.
[ 2939.162] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[ 2939.163] (II) config/udev: Adding input device HDA Intel PCH Dock Headphone (/dev/input/event14)
[ 2939.163] (II) No input driver specified, ignoring this device.
[ 2939.163] (II) This device may have been added with another device file.
[ 2939.163] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event15)
[ 2939.163] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 2939.163] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 2939.163] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 2939.163] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 2939.163] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 2939.164] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 35 paused 0
[ 2939.164] (**) AT Translated Set 2 keyboard: always reports core events
[ 2939.164] (**) Option "Device" "/dev/input/event3"
[ 2939.165] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 2939.165] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 2939.165] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 2939.166] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 2939.166] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 2939.166] (**) Option "xkb_layout" "br"
[ 2939.166] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 2939.166] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 2939.167] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 2939.167] (II) No input driver specified, ignoring this device.
[ 2939.167] (II) This device may have been added with another device file.
[ 2939.170] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event5)
[ 2939.170] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[ 2939.170] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[ 2939.170] (**) ThinkPad Extra Buttons: Applying InputClass "system-keyboard"
[ 2939.170] (II) Using input driver 'libinput' for 'ThinkPad Extra Buttons'
[ 2939.170] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 36 paused 0
[ 2939.170] (**) ThinkPad Extra Buttons: always reports core events
[ 2939.170] (**) Option "Device" "/dev/input/event5"
[ 2939.171] (II) event5 - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[ 2939.171] (II) event5 - ThinkPad Extra Buttons: device is a keyboard
[ 2939.171] (II) event5 - ThinkPad Extra Buttons: device removed
[ 2939.171] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input6/event5"
[ 2939.171] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 11)
[ 2939.171] (**) Option "xkb_layout" "br"
[ 2939.172] (II) event5 - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[ 2939.172] (II) event5 - ThinkPad Extra Buttons: device is a keyboard
[ 2939.173] (II) config/udev: Adding input device Synaptics TM3053-004 (/dev/input/event16)
[ 2939.173] (**) Synaptics TM3053-004: Applying InputClass "evdev touchpad catchall"
[ 2939.173] (**) Synaptics TM3053-004: Applying InputClass "libinput touchpad catchall"
[ 2939.173] (II) Using input driver 'libinput' for 'Synaptics TM3053-004'
[ 2939.174] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 37 paused 0
[ 2939.174] (**) Synaptics TM3053-004: always reports core events
[ 2939.174] (**) Option "Device" "/dev/input/event16"
[ 2939.174] (II) event16 - Synaptics TM3053-004: is tagged by udev as: Touchpad
[ 2939.176] (II) event16 - Synaptics TM3053-004: device is a touchpad
[ 2939.176] (II) event16 - Synaptics TM3053-004: device removed
[ 2939.176] (**) Option "config_info" "udev:/sys/devices/rmi4-00/input/input18/event16"
[ 2939.176] (II) XINPUT: Adding extended input device "Synaptics TM3053-004" (type: TOUCHPAD, id 12)
[ 2939.177] (**) Option "AccelerationScheme" "none"
[ 2939.177] (**) Synaptics TM3053-004: (accel) selected scheme none/0
[ 2939.177] (**) Synaptics TM3053-004: (accel) acceleration factor: 2.000
[ 2939.177] (**) Synaptics TM3053-004: (accel) acceleration threshold: 4
[ 2939.178] (II) event16 - Synaptics TM3053-004: is tagged by udev as: Touchpad
[ 2939.179] (II) event16 - Synaptics TM3053-004: device is a touchpad
[ 2939.180] (II) config/udev: Adding input device Synaptics TM3053-004 (/dev/input/mouse0)
[ 2939.180] (II) No input driver specified, ignoring this device.
[ 2939.180] (II) This device may have been added with another device file.
[ 2939.180] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event18)
[ 2939.180] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[ 2939.180] (**) TPPS/2 IBM TrackPoint: Applying InputClass "libinput pointer catchall"
[ 2939.180] (II) Using input driver 'libinput' for 'TPPS/2 IBM TrackPoint'
[ 2939.181] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 38 paused 0
[ 2939.181] (**) TPPS/2 IBM TrackPoint: always reports core events
[ 2939.181] (**) Option "Device" "/dev/input/event18"
[ 2939.182] (II) event18 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[ 2939.182] (II) event18 - TPPS/2 IBM TrackPoint: device is a pointer
[ 2939.183] (II) event18 - TPPS/2 IBM TrackPoint: device removed
[ 2939.183] (**) Option "config_info" "udev:/sys/devices/rmi4-00/rmi4-00.fn03/serio2/input/input19/event18"
[ 2939.183] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 13)
[ 2939.183] (**) Option "AccelerationScheme" "none"
[ 2939.183] (**) TPPS/2 IBM TrackPoint: (accel) selected scheme none/0
[ 2939.183] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[ 2939.184] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[ 2939.184] (II) event18 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[ 2939.185] (II) event18 - TPPS/2 IBM TrackPoint: device is a pointer
[ 2939.186] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse1)
[ 2939.186] (II) No input driver specified, ignoring this device.
[ 2939.186] (II) This device may have been added with another device file.
[ 2939.330] (**) Option "fd" "29"
[ 2939.330] (II) event2 - Power Button: device removed
[ 2939.330] (**) Option "fd" "32"
[ 2939.330] (II) event6 - Video Bus: device removed
[ 2939.330] (**) Option "fd" "33"
[ 2939.330] (II) event1 - Sleep Button: device removed
[ 2939.330] (**) Option "fd" "34"
[ 2939.330] (II) event17 - Integrated Camera: Integrated C: device removed
[ 2939.330] (**) Option "fd" "35"
[ 2939.330] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 2939.330] (**) Option "fd" "36"
[ 2939.330] (II) event5 - ThinkPad Extra Buttons: device removed
[ 2939.330] (**) Option "fd" "37"
[ 2939.330] (II) event16 - Synaptics TM3053-004: device removed
[ 2939.330] (**) Option "fd" "38"
[ 2939.330] (II) event18 - TPPS/2 IBM TrackPoint: device removed
[ 2939.337] (II) UnloadModule: "libinput"
[ 2939.337] (II) systemd-logind: releasing fd for 13:82
[ 2939.368] (II) UnloadModule: "libinput"
[ 2939.368] (II) systemd-logind: releasing fd for 13:80
[ 2939.445] (II) UnloadModule: "libinput"
[ 2939.445] (II) systemd-logind: releasing fd for 13:69
[ 2939.471] (II) UnloadModule: "libinput"
[ 2939.471] (II) systemd-logind: releasing fd for 13:67
[ 2939.498] (II) UnloadModule: "libinput"
[ 2939.498] (II) systemd-logind: releasing fd for 13:81
[ 2939.565] (II) UnloadModule: "libinput"
[ 2939.565] (II) systemd-logind: releasing fd for 13:65
[ 2939.591] (II) UnloadModule: "libinput"
[ 2939.591] (II) systemd-logind: releasing fd for 13:70
[ 2939.632] (II) UnloadModule: "libinput"
[ 2939.632] (II) systemd-logind: releasing fd for 13:66
[ 2939.741] (II) Server terminated successfully (0). Closing log file.
theres really nothing there … post output from:
pacman -Qs lightdm
local/light-locker 1.9.0-5
A simple session locker for LightDM
local/lightdm 1:1.32.0-1
A lightweight display manager
local/lightdm-gtk-greeter 1:2.0.8-2
GTK+ greeter for LightDM
local/lightdm-gtk-greeter-settings 1.2.2-7
Settings editor for the LightDM GTK+ Greeter
so lets reinstall lightdm and xorg:
pacman -S lightdm-gtk-greeter-settings lightdm-gtk-greeter lightdm light-locker xorg-server
then type: exit
reboot
if it didnt work, chroot and post output from:
ls -hl /var/cache/pacman/pkg | grep linux515
cat /var/log/pacman.log | grep upgrade | tail -50
-rw-r--r-- 1 root root 101M Aug 3 11:55 linux515-5.15.59-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 438 Aug 3 11:55 linux515-5.15.59-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 101M Aug 11 15:35 linux515-5.15.60-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 438 Aug 11 15:35 linux515-5.15.60-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 32M Aug 3 11:55 linux515-headers-5.15.59-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 438 Aug 3 11:55 linux515-headers-5.15.59-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 32M Aug 11 15:35 linux515-headers-5.15.60-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 438 Aug 11 15:35 linux515-headers-5.15.60-1-x86_64.pkg.tar.zst.sig
[2022-08-14T16:38:46-0300] [ALPM] upgraded unzip (6.0-18 -> 6.0-19)
[2022-08-14T16:38:46-0300] [ALPM] upgraded vulkan-intel (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:38:46-0300] [ALPM] upgraded vulkan-radeon (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:38:46-0300] [ALPM] upgraded wpebackend-fdo (1.12.0-2 -> 1.12.1-1)
[2022-08-14T16:38:48-0300] [ALPM] upgraded webkit2gtk (2.36.5-2 -> 2.36.6-1)
[2022-08-14T16:39:00-0300] [ALPM] upgraded webkit2gtk-4.1 (2.36.5-2 -> 2.36.6-1)
[2022-08-14T16:39:01-0300] [ALPM] upgraded xdg-user-dirs (0.17-3 -> 0.18-1)
[2022-08-14T16:39:01-0300] [ALPM] upgraded xfce4-screenshooter (1.9.10-2 -> 1.9.11-1)
[2022-08-14T16:39:01-0300] [ALPM] upgraded zsh-completions (0.34.0-1 -> 0.34.0-2)
[2022-08-16T15:31:31-0300] [ALPM] upgraded tzdata (2022a-1 -> 2022b-1)
[2022-08-16T15:31:31-0300] [ALPM] upgraded glibc (2.36-1 -> 2.36-2)
[2022-08-16T15:31:36-0300] [ALPM] upgraded xz (5.2.5-3 -> 5.2.6-1)
[2022-08-16T15:31:36-0300] [ALPM] upgraded libtirpc (1.3.2-1 -> 1.3.3-1)
[2022-08-16T15:31:36-0300] [ALPM] upgraded libnftnl (1.2.2-1 -> 1.2.3-1)
[2022-08-16T15:31:36-0300] [ALPM] upgraded device-mapper (2.03.16-1 -> 2.03.16-2)
[2022-08-16T15:31:36-0300] [ALPM] upgraded android-tools (31.0.3-6 -> 31.0.3-7)
[2022-08-16T15:31:36-0300] [ALPM] upgraded bluez (5.65-1 -> 5.65-2)
[2022-08-16T15:31:36-0300] [ALPM] upgraded bluez-libs (5.65-1 -> 5.65-2)
[2022-08-16T15:31:36-0300] [ALPM] upgraded cifs-utils (6.15-1 -> 7.0-1)
[2022-08-16T15:31:36-0300] [ALPM] upgraded dhclient (4.4.3-1 -> 4.4.3-3)
[2022-08-16T15:31:36-0300] [ALPM] upgraded xorgproto (2022.1-1 -> 2022.2-1)
[2022-08-16T15:31:36-0300] [ALPM] upgraded pango (1:1.50.8-1 -> 1:1.50.9-1)
[2022-08-16T15:31:36-0300] [ALPM] upgraded sqlite (3.39.2-1 -> 3.39.2-2)
[2022-08-16T15:31:37-0300] [ALPM] upgraded gcr (3.41.1-1 -> 3.41.1-2)
[2022-08-16T15:31:37-0300] [ALPM] upgraded git (2.37.1-1 -> 2.37.2-1)
[2022-08-16T15:31:37-0300] [ALPM] upgraded glslang (11.10.0-1 -> 11.11.0-1)
[2022-08-16T15:31:37-0300] [ALPM] upgraded gpgme (1.17.1-1 -> 1.18.0-1)
[2022-08-16T15:31:37-0300] [ALPM] upgraded hwinfo (22.0-1 -> 22.1-1)
[2022-08-16T15:31:37-0300] [ALPM] upgraded poppler (22.07.0-1 -> 22.08.0-1)
[2022-08-16T15:31:37-0300] [ALPM] upgraded poppler-glib (22.07.0-1 -> 22.08.0-1)
[2022-08-16T15:31:38-0300] [ALPM] upgraded inkscape (1.2.1-1 -> 1.2.1-2)
[2022-08-16T15:31:38-0300] [ALPM] upgraded lib32-glibc (2.36-1 -> 2.36-2)
[2022-08-16T15:31:38-0300] [ALPM] upgraded lib32-sqlite (3.39.0-1 -> 3.39.2-2)
[2022-08-16T15:31:38-0300] [ALPM] upgraded libinih (55-2 -> 56-1)
[2022-08-16T15:31:38-0300] [ALPM] upgraded lv2 (1.18.6-1 -> 1.18.8-1)
[2022-08-16T15:31:38-0300] [ALPM] upgraded lilv (0.24.14-2 -> 0.24.18-1)
[2022-08-16T15:31:38-0300] [ALPM] upgraded lvm2 (2.03.16-1 -> 2.03.16-2)
[2022-08-16T15:31:39-0300] [ALPM] upgraded manjaro-release (21.3.6-1 -> 21.3.7-1)
[2022-08-16T15:31:39-0300] [ALPM] upgraded mhwd-db (0.6.5-22 -> 0.6.5-23)
[2022-08-16T15:31:39-0300] [ALPM] upgraded python-urllib3 (1.26.9-1 -> 1.26.11-1)
[2022-08-16T15:31:39-0300] [ALPM] upgraded mhwd (0.6.5-22 -> 0.6.5-23)
[2022-08-16T15:31:39-0300] [ALPM] upgraded nfsidmap (2.6.1-1 -> 2.6.2-1)
[2022-08-16T15:31:39-0300] [ALPM] upgraded nfs-utils (2.6.1-1 -> 2.6.2-1)
[2022-08-16T15:31:39-0300] [ALPM] upgraded tumbler (4.16.0-3 -> 4.16.1-1)
[2022-08-16T15:31:39-0300] [ALPM] upgraded wireplumber (0.4.11-3 -> 0.4.11-4)
[2022-08-16T15:31:40-0300] [ALPM] upgraded xdg-desktop-portal (1.14.6-1 -> 1.15.0-1)
[2022-08-20T10:37:56-0300] [PACMAN] starting full system upgrade
[2022-08-20T10:38:02-0300] [ALPM] upgraded pamac-cli (10.4.1-1 -> 10.4.2-1)
[2022-08-20T10:38:02-0300] [ALPM] upgraded pamac-gtk (10.4.1-1 -> 10.4.2-1)
[2022-08-20T12:35:26-0300] [ALPM] running '70-dkms-upgrade.hook'...
no I don’t have any. Will answer something about it in a couple minutes.
What’s the problem in here, btw?
I’m asking it bc we don’t have time to install manjaro every week.
the problem is that we dont know that the problem is, there is nothing in logs … and there were others with the same issues as you have, but they had nvidia … and downgrading kernel and nvidia resolved the issue …
so post also output from:
pamac list -qm
mm there’s no output for it
ok so downgrade the kernel:
pacman -U linux515-5.15.59-1-x86_64.pkg.tar.zst linux515-headers-5.15.59-1-x86_64.pkg.tar.zst
then:
exit
reboot and hopefully it will work
any errors from the command post here
oh i just remembered i made a few days ago a change in kernels stuff for using OBS virtual camera, once I couldn’t install v4l2loopback-utils; also, what’s happening with files after i downgrade the kernel?
i had a problem that lookalike this one:
you installed kernel headers and we are downgrading those too … nothing will happen to your files …post any errors from the downgrading command…
loading packages...
error: 'linux515-5.15.59-1-x86_64.pkg.tar.zst': could not find or read package
error: 'linux515-headers-5.15.59-1-x86_64.pkg.tar.zst': could not find or read package
are you chrooted?
try this:
pacman -U /var/cache/pacman/pkg/linux515-5.15.59-1-x86_64.pkg.tar.zst linux515-headers-5.15.59-1-x86_64.pkg.tar.zst
loading packages...
warning: downgrading package linux515 (5.15.60-1 => 5.15.59-1)
and only kernel:
