Popping in left ear when wearing headphones
When I am using headphones and there is no sound for around five seconds, it starts popping in the left headphone. My laptop is a Teclast F7 Plus
Hi @Gauley, and welcome!
If it starts popping in either ear when you do something, I suggest an audiologist rather than the internet…
If, however, you mean the headphones pop, and it doesn’t happen normally, I think it’s the headphones or the headphones’ cable itself causing it.
@Mirdarthos It happens with all headphones, but it doesn’t happen on Windows. It happens once there is no sound playing for 5 seconds
Well, since my crystal ball is acting up, I, and I think anyone else trying to help, need moar information. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Most likely it is pipewire and the 5 sec idle pop when it suspends. Most soundcards suspend quietly, some not.
mkdir -pv  ~/.config/wireplumber/main.lua.d/
nano ~/.config/wireplumber/main.lua.d/51-disable-suspension.lua
Then put this into it:
table.insert (alsa_monitor.rules, {
  matches = {
      -- Matches all sources.
      { "node.name", "matches", "alsa_input.*" },
      -- Matches all sinks.
      { "node.name", "matches", "alsa_output.*" },
  apply_properties = {
    ["session.suspend-timeout-seconds"] = 0,  -- 0 disables suspend
Then restart pipewire:
systemctl --user restart pipewire.service
:notebook: That config modfies this system config: /usr/share/wireplumber/main.lua.d/50-alsa-config.lua
Here is the system info:
  Kernel: 5.15.114-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=c2e46044-7457-40e9-9b76-00aafcd8d7d1 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: TECLAST product: F7 Plus v: N/A
  Mobo: TECLAST model: F7 Plus v: 3.1 serial: <superuser required>
    UEFI: American Megatrends v: tPAD 3.06 date: 12/20/2019
  ID-1: BAT0 charge: 12.0 Wh (33.1%) condition: 36.2/37.0 Wh (97.7%) volts: 7.6
    min: N/A model: N/A type: Unknown serial: <filter> status: discharging
  System RAM: available: 7.59 GiB used: 5.71 GiB (75.2%)
  Info: model: Intel Celeron N4100 bits: 64 type: MCP arch: Goldmont Plus
    level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
    stepping: 1 microcode: 0x3E
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
    desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1899 high: 2234 min/max: 800/2400 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2234 2: 1963 3: 1678
    4: 1724 bogomips: 8756
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
    arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
    flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
    lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
    nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
    pse36 pti pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3185
    class-ID: 0300
  Device-2: Alcor Micro USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 058f:5608
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x0868 built: 2019 res: 1920x1080
    hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 600 (GLK
    2) direct-render: Yes
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
    vendor: Realtek driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
    chip-ID: 8086:3198 class-ID: 0403
  API: ALSA v: k5.15.114-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: active tools: pw-cat,pw-cli
  Device-1: Intel Wireless 3165 driver: N/A modules: iwlwifi pcie:
    speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0
    chip-ID: 8086:3165 class-ID: 0280
  Device-2: Ralink RT5370 Wireless Adapter driver: rt2800usb type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:7 chip-ID: 148f:5370
    class-ID: 0000 serial: <filter>
  IF: wlp0s21f0u2 state: up mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2a
    class-ID: e001
  Local Storage: total: 238.47 GiB used: 37.3 GiB (15.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Teclast model: 256GB NA850-2280
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4A0S scheme: GPT
  ID-1: / raw-size: 83.19 GiB size: 81.33 GiB (97.76%) used: 37.23 GiB (45.8%)
    fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: c2e46044-7457-40e9-9b76-00aafcd8d7d1
    used: 68.9 MiB (71.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
    uuid: 282D-8CBB
  ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 153.9 GiB fs: ntfs label: Windows
    uuid: 7AB2343DB233FBE7
  ID-3: /dev/sda4 maj-min: 8:4 size: 518 MiB fs: ntfs label: N/A
    uuid: FE7E93D17E9380D7
  ID-4: /dev/sda5 maj-min: 8:5 size: 780 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
  Device-1: 1-2:7 info: Ralink RT5370 Wireless Adapter type: Network
    driver: rt2800usb interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 450mA chip-ID: 148f:5370 class-ID: 0000
    serial: <filter>
  Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Device-4: 1-8:5 info: Alcor Micro USB 2.0 Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 200mA chip-ID: 058f:5608 class-ID: 0e02
  Hub-2: 2-0:1 info: super-speed hub ports: 7 rev: 3.0
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 228 Uptime: 1d 4h 35m wakeups: 54 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1517 libs: 448 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.27
When I restart pipewire, I get this:
Failed to restart pipewire.service: Unit pipewire.service not found.
Ah well you use pulseaudio. There is a file called default.pa in /etc/pulse/. Copy it to ~/.config/pulse/ and edit it. Remove the line with load-module module-suspend-on-idle or comment it by putting a # in front of it. Then restart it:
systemctl --user restart pulseaudio.service
If that does not work, then no idea.
Thank you so much!
