Little pop sound in earbuds before and after using audio(firefox,vlc kde settings etc)after the last update
as described above.
happens also sometimes when just browsing any site.
inxi
  Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=a445c87d-e6a9-47fd-9601-614f3b3e7781 rw quiet apparmor=1
    security=apparmor resume=UUID=29e42246-1548-46dd-91f5-17d1f76c7bfd
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 info: latte-dock
    wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: TUF Gaming FX705GD_FX705GD v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: FX705GD v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FX705GD.306 date: 05/25/2020
  ID-1: BAT0 charge: 50.4 Wh (100.0%) condition: 50.4/64.1 Wh (78.6%)
    volts: 15.0 min: 15.6 model: Simplo SDI ICR18650 type: Li-ion
    serial: <filter> status: full cycles: 41
  Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 3104 high: 4068 min/max: 800/4100 scaling:
    driver: intel_pstate governor: performance cores: 1: 3984 2: 4068 3: 2200
    4: 2200 5: 3998 6: 4000 7: 4000 8: 2200 9: 2200 10: 4000 11: 2200 12: 2200
    bogomips: 52815
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
    driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:1c8d class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4 chip-ID: 13d3:56a2
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x429d built: 2018 res: 1920x1080
    hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.77 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
  Local Storage: total: 476.94 GiB used: 64.73 GiB (13.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3512GJ
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
    lanes: 2 tech: SSD serial: <filter> fw-rev: E8FK11.C temp: 47.9 C
    scheme: GPT
  ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
    used: 64.73 GiB (14.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 54.0 C pch: 50.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 281 Uptime: 22m wakeups: 9 Memory: total: 16 GiB
  available: 15.48 GiB used: 3.22 GiB (20.8%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1456 libs: 414 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.28
i think i solved it by following this solution(not sure what changed in the latest update):
Try this to stop audio sinks being suspended in PulseAudio
pactl unload-module module-suspend-on-idle
If that works to eliminate pop noise, PulseAudio can be reconfigured to disable the module permanently
sudo sed -i '/load-module module-suspend-on-idle/s/^/#/' /etc/pulse/default.pa
thanks
it seems it’s indeed this module.
I’ll save the last command in case i want to use this approach.
I had sound issues with my Dell OptiPlex 7050 Micro too with latest update.
As soon as computer was idle for a few seconds there would come a noise from
the headphones jack. Constant noise and no popping.
If i open any window or settings it would stop and then start again if computer was left idle.
Even if i reboot and not login. It would make noise in the login screen.
Was solved all by commenting out
load-module module-suspend-on-idle in /etc/pulse/default.pa
Thank you!
sed command in post #2 adds comment tag # to disable loading of module-suspend-on-idle
