Dubbox
25 February 2022 11:59
1
Hi,
I have updated my system today (there has been some time since the last update, since a friend struggled with nvidida drives and told me to not update for some time). After restarting my laptop, my internal monitor is not recognized at all!
$xrandr --listmonitors
Monitors: 1
0: +*DP-0 1920/521x1080/293+0+0 DP-0
Does anyone know this issue? If I unplug my external monitor and restart, the screen of my laptop just stays black. If I then connect my external monitor, everything works fine but the laptop screen stays black.
In terms of my system, following might be interesting:
$inxi --full --verbosity=7 --filter --no-host
Kernel: 5.10.98-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 3.38.2
Type: Laptop System: Acer product: Predator PH317-53 v: V1.11
Mobo: CFL model: Alphard_CFS v: V1.11 serial: <superuser required>
UEFI: Insyde v: 1.11 date: 03/25/2020
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: none
off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 510.47.03 pcie:
speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f10
class-ID: 0300
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: modesetting,nvidia gpu: i915,nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Message: Unable to show GL data. Required tool glxinfo missing.
Thank you for your time and help!
Hi @Dubbox ,
a Big question is how did you do the upgrade?
Also, please provide the output for:
mhwd --list
And
mhwd --listinstalled
Also go thorough these and provide info where necessary:
Hope you manage!
Look here:
Dubbox:
active: none
off: eDP-1
I would say there is xorg config which only target the nvidia gpu…
Did you install video-nvidia or video-hybrid-intel-nvidia-prime ?
Mirdarthos:
mhwd --list
And
Dubbox
25 February 2022 12:45
4
Hi, Thank you for your quick response!
I updated my system using
$ sudo pacman -Syu
the outputs you requested are as follows:
$ mhwd --list
> 0000:01:00.0 (0300:10de:1f10) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
and
$ mhwd --listinstalled
> Installed PCI configs:
Hope this helps! Thanks a lot!
**Previous to the update, both monitors worked, I have not done anything else to the pacman update
Could you add the content of the config files?
Here 2 easy commands:
(in case your shell is zsh, run bash beforehand)
export configs=("/etc/X11/xorg.conf" "/etc/X11/xorg.conf.d/*.conf" "/etc/modprobe.d/*.conf" "/etc/modules-load.d/*.conf")
for x in ${configs[@]}; do echo -e "\n---$x---\n$(cat $x)"; done
Dubbox
25 February 2022 12:51
6
Hi, thank you for helping!
I am running zsh, therefore I executed bash first and then your commands, resulting in the following output:
cat: /etc/X11/xorg.conf: No such file or directory
---/etc/X11/xorg.conf---
---/etc/X11/xorg.conf.d/00-keyboard.conf---
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "de"
Option "XkbModel" "pc105"
EndSection
---/etc/X11/xorg.conf.d/10-optimus-manager.conf---
Section "Files"
ModulePath "/usr/lib/nvidia"
ModulePath "/usr/lib32/nvidia"
ModulePath "/usr/lib32/nvidia/xorg/modules"
ModulePath "/usr/lib32/xorg/modules"
ModulePath "/usr/lib64/nvidia/xorg/modules"
ModulePath "/usr/lib64/nvidia/xorg"
ModulePath "/usr/lib64/xorg/modules"
EndSection
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "integrated"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "Coolbits" "28"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration"
EndSection
Section "Device"
Identifier "integrated"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Device "integrated"
EndSection
---/etc/modprobe.d/mhwd-gpu.conf---
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
---/etc/modules-load.d/mhwd-gpu.conf---
nvidia
nvidia-drm
---/etc/modules-load.d/modules.conf---
# List of modules to load at boot
Does this help?
Please post the output of:
xrandr --query
Dubbox
25 February 2022 12:52
8
Hi, the output is:
$xrandr --query
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+ 143.85 119.98 99.93 59.94 50.00
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
That should be:
Identifier "layout"
Screen 0 "integrated"
Inactive "nvidia"
EndSection
That is normally done at the optimus-manager… switch the gpu there.
Dubbox
25 February 2022 13:00
10
I tried that also, (using the Icon and pressing “Switch to NVIDIA”
I get the following error-message
However, running the commands stated here does not allow me to switch. What am I doing wrong?
You re-enabled the service?
sudo systemctl enable --now optimus-manager
Maybe restart after that?
or just:
sudo systemctl restart display-manager
Dubbox
25 February 2022 13:05
12
I just typed that command, still the same error.
Also the Icon of optimus-manager is the NVIDIA-Icon:
the startup-mode is also NVIDIA:
Dubbox
25 February 2022 13:09
13
Did also not work, I also rebooted my system. (I am on dualboot, however I do not think this is causing the issue, since I have not done updates on the other system)
So the problem here is that you cannot switch to integrated gpu, because the optimus service is not running?
sudo systemctl status optimus-manager
Dubbox
25 February 2022 13:17
15
Hi I get the following output:
Ă— optimus-manager.service - Optimus Manager Commands Daemon
Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2022-02-25 14:07:00 CET; 20min ago
Process: 551 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_daemon_start (code=exited, status=1/FAILURE)
Process: 592 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_xorg_start (code=exited, status=1/FAILURE)
Process: 597 ExecStart=/usr/bin/python3 -u -m optimus_manager.daemon (code=exited, status=1/FAILURE)
Process: 615 ExecStopPost=/usr/bin/python3 -u -m optimus_manager.hooks.post_daemon_stop (code=exited, status=1/FAILURE)
Main PID: 597 (code=exited, status=1/FAILURE)
CPU: 92ms
Feb 25 14:07:00 manjaro systemd[1]: Starting Optimus Manager Commands Daemon...
Feb 25 14:07:00 manjaro python3[551]: /usr/bin/python3: Error while finding module specification for 'optimus_manager.hooks.pre_daemon_start' (ModuleNotFoundError: No module named 'optimus_manager')
Feb 25 14:07:00 manjaro python3[592]: /usr/bin/python3: Error while finding module specification for 'optimus_manager.hooks.pre_xorg_start' (ModuleNotFoundError: No module named 'optimus_manager')
Feb 25 14:07:00 manjaro systemd[1]: Started Optimus Manager Commands Daemon.
Feb 25 14:07:00 manjaro python3[597]: /usr/bin/python3: Error while finding module specification for 'optimus_manager.daemon' (ModuleNotFoundError: No module named 'optimus_manager')
Feb 25 14:07:00 manjaro systemd[1]: optimus-manager.service: Main process exited, code=exited, status=1/FAILURE
Feb 25 14:07:00 manjaro python3[615]: /usr/bin/python3: Error while finding module specification for 'optimus_manager.hooks.post_daemon_stop' (ModuleNotFoundError: No module named 'optimus_manager')
Feb 25 14:07:00 manjaro systemd[1]: optimus-manager.service: Control process exited, code=exited, status=1/FAILURE
Feb 25 14:07:00 manjaro systemd[1]: optimus-manager.service: Failed with result 'exit-code'.
Might it be the case that I have to get it from the AUR? (see Optimus manager doesn't work after upgrade - #28 by linub )
the output is cut off… pls update the output with that:
sudo systemctl status optimus-manager --no-pager
Dubbox
25 February 2022 13:28
17
sorry, did so and edited the post
Yeah seems there is no community packages for optimus-manager anymore. So I guess you have to switch to the AUR.
So remove the optimus-manager, if installed from the offical repo and reinstall from the AUR:
pamac build optimus-manager optimus-manager-qt
Not sure, I don’t use it, but must be these AUR packages.
There is also the git version:
pamac build optimus-manager-git optimus-manager-qt-git
Dubbox
25 February 2022 13:42
19
Oh finally, this was the solution!
So in summary, do not use pacman to install and update optimus-manager. If done so do the following:
$pacman -R optimus-manager optimus-manager-qt
to uninstall this version and after this install from AUR using for example:
Thank you very much for your quick and informative support!
But just keep in mind:
AUR is not offical and made by users. You are on your own here.
