Only 1 ssd drive visible
I have 2 disks,the system is installed on the ssd(sdb) disk, and i want to store files on the hdd(sda) disk, but the disk is not displayed? how to fix it? kde plasma
Hi @Deff, and welcome!
There are a couple of reasons that can be, the most likely being the partition of the hard drive is either
  1. not mounted; or
  2. not recognized.
Please see:
Hope it helps!
Please also see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
…it will save both you and those trying to help many hours and headaches.
launch kde partition manager, and see how to continue.
From your description, probably the other disk is not formatted so cannot be detected. In almost every case, if there is a partition that can be accessed, it would show up in the file explorer you posted a picture of.
