No wifi on HP Probook
Hello,
I replaced my Windows 10 (bye bye) by Manjaro XFCE, so no dual boot.
Unfortunately I don’t know how to connect to WIFI… I am very beginner and I am from Xubuntu.
lspci :
Network controller : Realtek Semiconductor Co., Ltd. Device b852
rfkill list :
0: hci0: Bluetooh
         Soft blocked : no
         Hard blocked : no
Thank you
Hi @Yass, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
can you post the output of inxi -NSMBa, lists
  1. N - Network devices
  2. MS - System info
  3. B - Bluetooth
  Host: ... Kernel: 6.1.26-1-MANJARO
    arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=ddc5c5b4-d42b-4cba-bdcc-f0193da7d47c rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HP product: HP ProBook 445 14 inch G9 Notebook PC
    v: N/A Chassis: type: 10
  Mobo: HP model: 8B17 v: KBC Version 22.47.00
    UEFI: HP v: U88 Ver. 01.09.00 date: 10/18/2022
    vendor: Hewlett-Packard ProBook 445 G9/455 G9 driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
  Device-2: Realtek vendor: Hewlett-Packard driver: N/A pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852
    class-ID: 0280
Maybe wifi driver must be installed ?
The driver should be included in the kernel. If it is not recognized with kernel 6.1, try 6.2 or 6.3 and reboot.
Manjaro-Settings-Manager- Kernel
Ok I will try 6.3 (better than 6.2 hein ??).
And I don’t know if it is usefull but when I type “mhwd” I have :
0000:01:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
That is showing your Ethernet.
Thank you very much, its good with 6.3.0-1 but I have a question : why this version isn’t recommended ? Only LTS version are recommended… so it is risky to use this version (6.3.0-1) ??
You should be fine. Just update to a newer kernel when 6.3 is marked EOL. Best practice is to read the update announcements on the forum.
