Hi,
after latest updates sound doesn’t works. I’ve my barebone connected to a TV trhought a HDMI cable. I tryed lots of instructions found on forums but noone works.
Can somebody help me?
Thanks
Hi,
Thanks
Sure we can, but you should provide us with some basis info.
Hi,
what info do you need?
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=68b90829-3777-4dc9-b4a0-9291c2c7628a rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Desktop System: MICRO-STAR product: MS-B09611 v: N/A serial: <filter>
Mobo: MICRO-STAR model: MS-B0961 v: 1.0 serial: <filter>
UEFI [Legacy]: American Megatrends v: EB096IMS V1.4 date: 09/07/2015
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Topology: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F
L2 cache: 3072 KiB
bogomips: 17566
Speed: 2635 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 2464 2: 2238
3: 2334 4: 2290
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Micro-Star MSI driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1616
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:9ca0
Sound Server: ALSA v: k5.8.6-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:08b3
Local Storage: total: 931.51 GiB used: 231.74 GiB (24.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPLX-00MBPT0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1H01 scheme: MBR
ID-1: / raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 231.74 GiB (25.3%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 220 Uptime: 8m Memory: 15.52 GiB used: 2.64 GiB (17.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1382 lib: 370
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
That’s a start…
What’s the output of alsa-info.sh ?
Open the file it creates and please copy-paste it in-between 3 backticks ``` *like your inxi output…
Hi,
the thing is that sometimes I’ve sound and sometimes not. Sometimes if I reboot the system two or three times the sound works, other not.
There is the alsa information (now sound it’s working)
> ALSA Information Script v 0.4.65
> This script visits the following commands/files to collect diagnostic
> information about your ALSA installation and sound related hardware.
> dmesg
> lspci
> aplay
> amixer
> alsactl
> rpm, dpkg
> /proc/asound/
> /sys/class/sound/
> ~/.asoundrc (etc.)
> See '/usr/bin/alsa-info.sh --help' for command line options.
> dmesg: read kernel buffer failed: Operation not permitted
dmesg: read kernel buffer failed: Operation not permitted is just an error message that you need to run with sudo privileges (Sorry, we tend not to include that)
Then also give both an inxi output and the file that sudo alsa-info.sh creates when the sound is not working so we can compare what’s missing / is failing…
Hi,
I can’t post because the forum says that I can’t post links… Even if I use the ```
How can I proceed?
Please read this:
Hi,
I didn’t try to send screenshots of text. I copied the text from terminal but after to paste it to the box text and put the ``` If i clik to Reply button It says that I can’t send links and the post doesn’t be send.
Please read it again because it also says:
I did the change from all http for ht!tp and I get the same error: You can’t send links to forum.
I’m so tired. I want to hear on manjaro but this forum don’t let me send the answers.
I’m going to take I’ve taken it up with the admins…
Apparently it’s because of SPAM… Please be patient while background discussions are on-going.
When I’ll know that I can post?
You succeeded in a post above, what’s different now? Are you sure you’re putting backticks around the whole output? It should begin and end the three ticks. If there’s an html link in the output you’re trying to paste, can you just remove the whole link? We probably don’t need it anyway…
If you cannot post link for using alsa-info.sh there are other ways get data for troubleshooting
To establish which of the 2 audio devices is used for HDMI audio, please post response to
aplay -l
to check if devices are detected in ALSA (or any error messages)
sudo dmesg | grep snd
and to check audio devices detected in pulseaudio
pacmd list-sinks
Hi,
here it goes:
~ >>> aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC283 Analog [ALC283 Analog]
Subdevices: 1/1
[sudo] contrasenya per a alfred:
[ 11.166444] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC283: line_outs=1 (0x21/0x0/0x0/0x0/0x0) type:hp
[ 11.166446] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 11.166448] snd_hda_codec_realtek hdaudioC1D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 11.166449] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 11.166450] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 11.407395] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 11.480116] Modules linked in: rapl i915 iwlwifi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio cfg80211 snd_hda_intel iTCO_wdt intel_pmc_bxt snd_intel_dspcfg snd_hda_codec iTCO_vendor_support i2c_algo_bit ofpart r8169 drm_kms_helper cmdlinepart snd_hda_core intel_spi_platform intel_spi spi_nor snd_hwdep mei_hdcp at24 mtd cec mxm_wmi sparse_keymap realtek intel_cstate intel_uncore rc_core rfkill pcspkr libphy snd_pcm intel_gtt snd_timer snd syscopyarea sysfillrect sysimgblt fb_sys_fops soundcore evdev lpc_ich mei_me i2c_i801 mac_hid i2c_smbus mei wmi drm uinput agpgart sg crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 xhci_pci xhci_pci_renesas crc32c_intel xhci_hcd ehci_pci ehci_hcd
and
~ >>> pacmd list-sinks
1 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9030
volume: front-left: 53682 / 82% / -5,20 dB, front-right: 53682 / 82% / -5,20 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Estèreo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 1999,82 ms
card: 0 <alsa_card.pci-0000_00_03.0>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 1"
alsa.id = "HDMI 1"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "7"
alsa.card = "0"
alsa.card_name = "HDA Intel HDMI"
alsa.long_card_name = "HDA Intel HDMI at 0xf7214000 irq 52"
device.bus_path = "pci-0000:00:03.0"
sysfs.path = "/devices/pci0000:00/0000:00:03.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "160c"
device.product.name = "Broadwell-U Audio Controller"
device.string = "hdmi:0,1"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "hdmi-stereo-extra1"
device.profile.description = "Digital Stereo (HDMI 2)"
device.description = "Àudio intern Digital Stereo (HDMI 2)"
alsa.mixer_name = "Intel Broadwell HDMI"
alsa.components = "HDA:80862808,80860101,00100000"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: yes)
properties:
device.product.name = "SONY TV"
active port: <hdmi-output-1>
Thanks for help
Thanks
Have you already tried changing the HDMI cable?
@nikgnomic : this is way above my head, mate!
According to MSI specifications, this system should have “1 x Mic in/ Headphone out” on the front panel to support a headset
but dmesg data is showing only analog output for headphones, no input for microphone
Rear panel appears to have 2 possible output connections for HDMI audio
1 x HDMI out
1 x Mini DP out
but Pulseaudio appears to have only 1 sink and 1 port
alsa.id = "HDMI 1"
alsa.device = "7"
alsa.card = "0"
The ALSA subdevice
Subdevices: 1/1
I would expect if Pulseaudio was connected to the ALSA device correctly it would show as Subdevices 0/1, but the Pulseaudio sink may just be suspended if no audio is playing
I was hoping OP might have made it to TL1 (Basic user badge) to be able to post some form of link to alsa-info but that has not happened yet
so the only way to get more ALSA data is to use variations on alsa-info script commands discretely
amixer --card=0
to check if HDMI output has been muted (not likely)
and
grep -i snd /etc/modprobe.d/*.conf
to check if any kernel patches for audio have been added
and
lspci -vvnnd "::0403"
to try a websearch for a patch using the audio vendorID:productID
(vid for MSI = 1462)
also suggest check pulseaudio.service for error messages
systemctl --user --no-pager -l status pulseaudio.service
