New Raspberry Pi Kernels & Related Packages
The error
The villian
I got back to the office and hooked things back up and lo and behold, the error is back! I fiddle with stuff and it turns out that if I replace the Apple keyboard with a Logitech keyboard, the SSD works again. Odd that a device on the USB 2.0 controller causes an issue on the the USB 3.0 controller. But I am not a Electrical Engineer, so who knows. And I have used this keyboard on this same RPi4 since I began working with them, very weird.
Edit: Then I remembered that I loaned out the USB extension cable that comes with the keyboard. I hunt down a replacement and hook it up… and now the RPI4 will boot with both the Apple keyboard and the SSD once again.
Just wanted to update the raspberrypi/firmware repository had an issue which caused PoE hat fans to stop working recently (around mid jan) Rpi PoE hat goes brrrrr on Rpi 4b · Issue #1531 · raspberrypi/firmware · GitHub
They’ve fixed the issue with this commit kernel: Bump to 5.10.14 · raspberrypi/firmware@f11bc13 · GitHub
As I mentioned above I was holding back the latest 2 raspberrypi-bootloader packages as it broke bluetooth. I told them and they responded with a confusing answer which took me a couple of days to figure out what they meant and at the same time I was having to put out some other fires:
“The only change vaguely UART-related - at least on the firmware side - in the last week or so is the removal of the code that automatically converts an old cmdline.txt reference to ttyAMA0 to ttyS0 in the event that ttyS0 is the primary (console) UART. All new images for years have used “serial0” as an alias, and now all cmdline.txts have to either do the same or get it write and use ttyS0.”
Long story short I tried several combinations with cmdline.txt and the attach-bluetooth service. arch-arm uses ttyAMA0 in the /boot/cmdline.txt file and this has to be changed in 2 places in the file to have bluetooth:
console=ttyAMA0,115200 ==> console=serial0,115200
kgdboc=ttyAMA0,115200 ==> kgdboc=serial0,115200
The latest 2 raspberry-pi bootloader files has been pushed to the unstable branch when the mirrors sync. Be sure to make the 2 adjustments above in /boot/cmdline.txt to have bluetooth.
raspberrypi-bootloader 20210208-1
raspberrypi-bootloader-x 20210208-1
With latest bootloader, I see unusual core% CPU usage.
Did you make the changes in /boot/cmdline.txt I posted above?
top
From looking at the posted image, I think maybe he has the same issue I had… twice. :wink:
brcm_patchram at 100%
If he has blocked bluetooth in config.txt like you did that prevents brmcm_patchram from loading but that would be with any bootloader.
Oh, so not making the edits causes a similar looking issue. Good to know, because you know I will forget to edit also. And I would have tried to “fix it”, convinced I had the same issue again.
You would have been ok since you disabled attach-bluetooth.service and bluetooth.service.
Thanks Darksky I didn’t. But now, back to normal!
I’m really impress how well RPI4 works with latest kernel 5.11.0 RC6 on KDE release with KMS and Vulkan enabled.
last bootloader update, lost wifi connect.
does disable BT matter?
Wifi works here. Do you have crda installed and the Regulatory Domain set for your country.
BT matters to a lot of people. I personally like to use my BT headphones and also have internet backup by doing a bluetooth tether from my phone.
wifi work before last bootloader update.
does disable-bt matter wifi dead.
btw, test kernel-rc then audio dead.
All of the above works here. I am leaning towards some issue on your end with:
pi wifi router relationship and or config and the same with your sound with a config.
I got home and booted my unstable image, and it was minus the wifi device. I rolled back the linux-firmware and wifi was restored. Then reinstaleld the new linux-firmware, rebooted and wifi device was gone again. Rolled back again and the wifi device was back. So currently I am running on the previous version as I need wifi.
Not sure why I just now noticed this. Maybe I forgot to reboot after the update last night? Sorry I did not find this sooner.
Interesting that my wifi works on the stable branch. To be clear it was the linux-firmware package and not firmware-raspberrypi.
pacman -U linux-firmware-20201218.646f159-1-any.pkg.tar.xz
That is my exact roll-back command. There is no reference to wlan0 in dmesg or journalctl -b with the new linux-firmware installed.
I just found that dracut is indeed passing a kernel command line, and it is my old one. So I am investigating that. But I don’t think the cmdline.txt changes has any effect on the wifi.
$ cat /boot/cmdline.txt
root=LABEL=MNJRO_ROOT rw rootfstype=btrfs rootwait console=serial0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=serial0,115200 usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0 usb-storage.quirks=152d:1561:u
$ cat /proc/cmdline
coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:C1:E1:C7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  root=LABEL=MNJRO_ROOT rw rootfstype=btrfs rootwait console=ttyAMA0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyAMA0,115200 usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0 usb-storage.quirks=152d:1561:u
So I made the change to cmdline.txt, but dracut is biting me now. :slight_smile:
I will boot my arm-testing and grab the new firmware and try that.
Edit: this will take a several minutes due to download time. But I wanted to say no Dracut on my arm-testing, so this will be a better test.
ok, rollback linux-firmware and wifi back.
The new firmware-raspberrypi is supposed to fix a dis-connect issue with the pi4 wifi but the problem is it’s new files are in usr/lib/firmware/updates/brcm compounded by linux-firmware packages puts it’s files in /usr/lib/firmware/brcm which also has firmware for the pi4 wifi which would normally not be an issue because linux is supposed to look first in /usr/lib/firmware/updates first.
The kicker is it is hard coded to the /usr/lib/firmware/brcm directory for it to look for the firmware to load so it will never see the latest firmware and lately the linux-firmware package is providing outdated and in this case now looking like bad firmware for the pi wifi.
I can not dump the firmware-raspberrypi package in /usr/lib/firmware/brcm as it will refuse saying the files exist belonging to linux-firmware.
My freshly updated arm-testing has the same issue with the linux-firmware. So I am back to the previous version.
The thing that has me stumped now is:
$ cat /proc/cmdline
coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:C1:E1:C7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  root=LABEL=MNJRO_ROOT rw rootfstype=btrfs rootwait console=ttyAMA0,115200 console=tty1 selinux=0 kgdboc=ttyAMA0,115200 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0 usb-storage.quirks=152d:1561:u
root=LABEL=MNJRO_ROOT rw rootfstype=btrfs rootwait console=serial0,115200 console=tty1 selinux=0 kgdboc=serial0,115200 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0 usb-storage.quirks=152d:1561:u
I now suspect the systemd hook for mkinitcpio, that is common between my stable and testing installs.
Edit: I replaced the systemd hook with udev… and now I am stumped.
$ cat /proc/cmdline
