New Raspberry Pi Kernels & Related Packages
I do not know what you are referring to specifically. If you are saying more stuff is added than what is in cmdline.txt there are system defaults it knows to add to your cmdline.txt to get it booting properly. So there will be more in addition to your cmdline.txt in /proc/cmdline as that is what it is using in it’s entirety to boot with.
Oh, sorry I was not clear.
Something is changing my command line from:
console=serial0,115200
to:
console=ttyAMA0,115200
No dracut on this install, so can’t be related to that. I then suspected the systemd hook but I switched to udev and /proc/cmdline shows exactly what we just changed in cmdline.txt
I see now. That should not worry you at all. That terminal is reserved for bluetooth and it is a messed up deal I believe to begin with. In post #343 above I talked about it where we had ttyAMA0 and had to change it to serial0 so bluetooth to work. In my trials to get it to work I found that you have to no say serial0 in cmdline.txt but for some reason in the end it will use the ttyAMA0 terminal as that is what is used to patch the firmware to the ram that attach-bluetooth does. In the end /dev/serial0 does not exist.
Messed up deal but you have bluetooth disabled and if you did not it is going to do what it does anyway.
Find something else to worry about… lol
lol, yes, that would explain it.
And the next time I go off on another meaningless tangent, even if you don’t know the answer, just make one up and help put me out of my misery. :smiley:
As for the firmware issue:
$ mount --bind /usr/lib/firmware/updates/brcm /usr/lib/firmware/brcm
Probably not a solution you prefer, but it might work with a fstab entry and a couple alpm hooks to (un)mount on linux-firmware updates. Or maybe trigger a reinstall of firmware-raspberrypi.
Edit2 : Well, I decided to give it a try and see if it actually works. Evidently the bind mount does not occur soon enough. Once booted, the mount is in place and works as expected, but still no wlan0. I wonder if there is a way to trigger that mount sooner, or delay the loading of the firmware until after the mount?
Well, it would seem that I have managed to get the latest linux-firmware to work, I have wlan0 now. How did I do it? What changed? I am not sure, as I was not expecting this result from my actions.
I think it begins with the bind mount above. I mistakenly started a linux-firmware re-install of the previous version, with the bind mount in place. I hit ctrl-c durring the update and it appeared to finish writing the firmware files and then the update terminated.
I then umount the bind mount and reinstalled the linux-firmware package, then I reinstalled the firmware-raspberrypi. There were no complaints from pacman at this point, as I recall.
I rebooted and had wifi as expected.
This is were I am not exactly sure… but I believe I then attempted to re-upgrade the linux-firmware as I wanted to investigate more why the bind mount did not work. But pacman complained that the following files already existed on the filesystem:
/usr/lib/firmware/brcm/brcmfmac43012-sdio.bin
/usr/lib/firmware/brcm/brcmfmac43012-sdio.clm_blob
/usr/lib/firmware/brcm/brcmfmac43430-sdio.clm_blob
/usr/lib/firmware/brcm/brcmfmac43455-sdio.Raspberry Pi Foundation-Raspberry Pi 4 Model B.txt
/usr/lib/firmware/brcm/brcmfmac43455-sdio.clm_blob
/usr/lib/firmware/brcm/brcmfmac4354-sdio.clm_blob
/usr/lib/firmware/brcm/brcmfmac4356-pcie.clm_blob
/usr/lib/firmware/brcm/brcmfmac4356-sdio.clm_blob
/usr/lib/firmware/brcm/brcmfmac4356-sdio.vamrs,rock960.txt
/usr/lib/firmware/brcm/brcmfmac43570-pcie.clm_blob
/usr/lib/firmware/brcm/brcmfmac4373-sdio.clm_blob
/usr/lib/firmware/brcm/brcmfmac54591-pcie.bin
/usr/lib/firmware/brcm/brcmfmac54591-pcie.clm_blob
So I then deleted each of the above and then successfully reinstalled both the new linux-firmware and firmware-raspberrypi and rebuilt initramfs and then rebooted.
And to my surprise, I now have working wifi with the new firmwares.
It appears you strive to keep my head spinning with your endeavors. :dizzy_face:
My only question is that is there nothing wrong with the latest linux-firmware or firmware-raspberrypi packages now?
Well, as wifi seems to be working with the newest packages, they must be fine. Maybe I had a old symbolic link that was “misdirecting” the kernel as to which firmware to use? I really do not know at this point.
Below are the contents of my current /usr/lib/firmware/brcm/ with the most current update:
$ ls -l /usr/lib/firmware/brcm
total 12024
lrwxrwxrwx 1 root root      17 Feb 10 08:26  BCM-0a5c-6410.hcd -> BCM-0bb4-0306.hcd
-rw-r--r-- 1 root root   54734 Feb 10 08:26  BCM-0bb4-0306.hcd
-rw-r--r-- 1 root root  269595 Feb 10 08:26  bcm4329-fullmac-4.bin
-rw-r--r-- 1 root root   96224 Feb 10 08:26  bcm43xx-0.fw
-rw-r--r-- 1 root root     180 Feb 10 08:26  bcm43xx_hdr-0.fw
lrwxrwxrwx 1 root root      31 Feb 10 08:26  brcmfmac43012-sdio.bin -> ../cypress/cyfmac43012-sdio.bin
lrwxrwxrwx 1 root root      36 Feb 10 08:26  brcmfmac43012-sdio.clm_blob -> ../cypress/cyfmac43012-sdio.clm_blob
-rw-r--r-- 1 root root  397312 Feb 10 08:26  brcmfmac43143.bin
-rw-r--r-- 1 root root  385067 Feb 10 08:26  brcmfmac43143-sdio.bin
-rw-r--r-- 1 root root  348160 Feb 10 08:26  brcmfmac43236b.bin
-rw-r--r-- 1 root root  455745 Feb 10 08:26  brcmfmac43241b0-sdio.bin
-rw-r--r-- 1 root root  403855 Feb 10 08:26  brcmfmac43241b4-sdio.bin
-rw-r--r-- 1 root root  408682 Feb 10 08:26  brcmfmac43241b5-sdio.bin
-rw-r--r-- 1 root root  479232 Feb 10 08:26  brcmfmac43242a.bin
-rw-r--r-- 1 root root  253748 Feb 10 08:26  brcmfmac4329-sdio.bin
-rw-r--r-- 1 root root  222126 Feb 10 08:26  brcmfmac4330-sdio.bin
-rw-r--r-- 1 root root    1509 Feb 10 08:26  brcmfmac4330-sdio.Prowise-PT301.txt
lrwxrwxrwx 1 root root      31 Feb 10 08:26  brcmfmac43340-sdio.bin -> ../cypress/cyfmac43340-sdio.bin
-rw-r--r-- 1 root root    1693 Feb 10 08:26  brcmfmac43340-sdio.meegopad-t08.txt
-rw-r--r-- 1 root root    1724 Feb 10 08:26  brcmfmac43340-sdio.pov-tab-p1006w-data.txt
-rw-r--r-- 1 root root  451566 Feb 10 08:26  brcmfmac4334-sdio.bin
-rw-r--r-- 1 root root  569291 Feb 10 08:26  brcmfmac4335-sdio.bin
lrwxrwxrwx 1 root root      31 Feb 10 08:26  brcmfmac43362-sdio.bin -> ../cypress/cyfmac43362-sdio.bin
-rw-r--r-- 1 root root     803 Feb 10 08:26  brcmfmac43362-sdio.cubietech,cubietruck.txt
lrwxrwxrwx 1 root root      43 Feb 10 08:26  brcmfmac43362-sdio.lemaker,bananapro.txt -> brcmfmac43362-sdio.cubietech,cubietruck.txt
lrwxrwxrwx 1 root root      30 Feb 10 08:26  brcmfmac4339-sdio.bin -> ../cypress/cyfmac4339-sdio.bin
-rw-r--r-- 1 root root  382455 Feb 10 08:26  brcmfmac43430a0-sdio.bin
-rw-r--r-- 1 root root     951 Feb 10 08:26  brcmfmac43430a0-sdio.jumper-ezpad-mini3.txt
-rw-r--r-- 1 root root     989 Feb 10 08:26 'brcmfmac43430a0-sdio.ONDA-V80 PLUS.txt'
-rw-r--r-- 1 root root     875 Feb 10 08:26  brcmfmac43430-sdio.AP6212.txt
lrwxrwxrwx 1 root root      31 Feb 10 08:26  brcmfmac43430-sdio.bin -> ../cypress/cyfmac43430-sdio.bin
lrwxrwxrwx 1 root root      36 Feb 10 08:26  brcmfmac43430-sdio.clm_blob -> ../cypress/cyfmac43430-sdio.clm_blob
-rw-r--r-- 1 root root     928 Feb 10 08:26  brcmfmac43430-sdio.Hampoo-D2D3_Vi8A1.txt
-rw-r--r-- 1 root root     831 Feb 10 08:26  brcmfmac43430-sdio.MUR1DX.txt
-rw-r--r-- 1 root root     874 Feb 10 08:26  brcmfmac43430-sdio.raspberrypi,3-model-b.txt
lrwxrwxrwx 1 root root      29 Feb 10 08:26  brcmfmac43430-sdio.sinovoip,bpi-m2-plus.txt -> brcmfmac43430-sdio.AP6212.txt
lrwxrwxrwx 1 root root      29 Feb 10 08:26  brcmfmac43430-sdio.sinovoip,bpi-m2-zero.txt -> brcmfmac43430-sdio.AP6212.txt
lrwxrwxrwx 1 root root      31 Feb 10 08:26  brcmfmac43455-sdio.bin -> ../cypress/cyfmac43455-sdio.bin
lrwxrwxrwx 1 root root      36 Feb 10 08:26  brcmfmac43455-sdio.clm_blob -> ../cypress/cyfmac43455-sdio.clm_blob
-rw-r--r-- 1 root root    2510 Feb 10 08:26 'brcmfmac43455-sdio.MINIX-NEO Z83-4.txt'
lrwxrwxrwx 1 root root      49 Feb 10 08:26  brcmfmac43455-sdio.raspberrypi,3-model-a-plus.txt -> brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt
-rw-r--r-- 1 root root    1884 Feb 10 08:26  brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt
-rw-r--r-- 1 root root    1883 Feb 10 08:26  brcmfmac43455-sdio.raspberrypi,4-model-b.txt
lrwxrwxrwx 1 root root      44 Feb 10 08:26 'brcmfmac43455-sdio.Raspberry Pi Foundation-Raspberry Pi 4 Model B.txt' -> brcmfmac43455-sdio.raspberrypi,4-model-b.txt
-rw-r--r-- 1 root root  623304 Feb 10 08:26  brcmfmac4350c2-pcie.bin
-rw-r--r-- 1 root root  626140 Feb 10 08:26  brcmfmac4350-pcie.bin
lrwxrwxrwx 1 root root      30 Feb 10 08:26  brcmfmac4354-sdio.bin -> ../cypress/cyfmac4354-sdio.bin
lrwxrwxrwx 1 root root      35 Feb 10 08:26  brcmfmac4354-sdio.clm_blob -> ../cypress/cyfmac4354-sdio.clm_blob
-rw-r--r-- 1 root root  557056 Feb 10 08:26  brcmfmac43569.bin
lrwxrwxrwx 1 root root      30 Feb 10 08:26  brcmfmac4356-pcie.bin -> ../cypress/cyfmac4356-pcie.bin
lrwxrwxrwx 1 root root      35 Feb 10 08:26  brcmfmac4356-pcie.clm_blob -> ../cypress/cyfmac4356-pcie.clm_blob
-rw-r--r-- 1 root root    2515 Feb 10 08:26  brcmfmac4356-pcie.gpd-win-pocket.txt
lrwxrwxrwx 1 root root      30 Feb 10 08:26  brcmfmac4356-sdio.bin -> ../cypress/cyfmac4356-sdio.bin
lrwxrwxrwx 1 root root      35 Feb 10 08:26  brcmfmac4356-sdio.clm_blob -> ../cypress/cyfmac4356-sdio.clm_blob
-rw-r--r-- 1 root root    2610 Feb 10 08:26  brcmfmac4356-sdio.vamrs,rock960.txt
lrwxrwxrwx 1 root root      31 Feb 10 08:26  brcmfmac43570-pcie.bin -> ../cypress/cyfmac43570-pcie.bin
lrwxrwxrwx 1 root root      36 Feb 10 08:26  brcmfmac43570-pcie.clm_blob -> ../cypress/cyfmac43570-pcie.clm_blob
-rw-r--r-- 1 root root  633817 Feb 10 08:26  brcmfmac4358-pcie.bin
-rw-r--r-- 1 root root  595472 Feb 10 08:26  brcmfmac43602-pcie.ap.bin
-rw-r--r-- 1 root root  635449 Feb 10 08:26  brcmfmac43602-pcie.bin
-rw-r--r-- 1 root root 1105361 Feb 10 08:26  brcmfmac4366b-pcie.bin
-rw-r--r-- 1 root root 1120971 Feb 10 08:26  brcmfmac4366c-pcie.bin
-rw-r--r-- 1 root root  623448 Feb 10 08:26  brcmfmac4371-pcie.bin
-rw-r--r-- 1 root root  479232 Feb 10 08:26  brcmfmac4373.bin
lrwxrwxrwx 1 root root      30 Feb 10 08:26  brcmfmac4373-sdio.bin -> ../cypress/cyfmac4373-sdio.bin
lrwxrwxrwx 1 root root      35 Feb 10 08:26  brcmfmac4373-sdio.clm_blob -> ../cypress/cyfmac4373-sdio.clm_blob
lrwxrwxrwx 1 root root      31 Feb 10 08:26  brcmfmac54591-pcie.bin -> ../cypress/cyfmac54591-pcie.bin
lrwxrwxrwx 1 root root      36 Feb 10 08:26  brcmfmac54591-pcie.clm_blob -> ../cypress/cyfmac54591-pcie.clm_blob
Below is what I had prior to the update, per my btfs snapshot:
$ ls -l
total 16636
lrwxrwxrwx 1 root root      17 Dec 20 21:48  BCM-0a5c-6410.hcd -> BCM-0bb4-0306.hcd
-rw-r--r-- 1 root root   54734 Dec 20 21:48  BCM-0bb4-0306.hcd
-rw-r--r-- 1 root root  269595 Dec 20 21:48  bcm4329-fullmac-4.bin
-rw-r--r-- 1 root root   96224 Dec 20 21:48  bcm43xx-0.fw
-rw-r--r-- 1 root root     180 Dec 20 21:48  bcm43xx_hdr-0.fw
-rw-r--r-- 1 root root  397312 Dec 20 21:48  brcmfmac43143.bin
-rw-r--r-- 1 root root  385067 Dec 20 21:48  brcmfmac43143-sdio.bin
-rw-r--r-- 1 root root  348160 Dec 20 21:48  brcmfmac43236b.bin
-rw-r--r-- 1 root root  455745 Dec 20 21:48  brcmfmac43241b0-sdio.bin
-rw-r--r-- 1 root root  403855 Dec 20 21:48  brcmfmac43241b4-sdio.bin
-rw-r--r-- 1 root root  408682 Dec 20 21:48  brcmfmac43241b5-sdio.bin
-rw-r--r-- 1 root root  479232 Dec 20 21:48  brcmfmac43242a.bin
-rw-r--r-- 1 root root  253748 Dec 20 21:48  brcmfmac4329-sdio.bin
-rw-r--r-- 1 root root  222126 Dec 20 21:48  brcmfmac4330-sdio.bin
-rw-r--r-- 1 root root    1509 Dec 20 21:48  brcmfmac4330-sdio.Prowise-PT301.txt
-rw-r--r-- 1 root root  400864 Dec 20 21:48  brcmfmac43340-sdio.bin
-rw-r--r-- 1 root root    1693 Dec 20 21:48  brcmfmac43340-sdio.meegopad-t08.txt
-rw-r--r-- 1 root root    1724 Dec 20 21:48  brcmfmac43340-sdio.pov-tab-p1006w-data.txt
-rw-r--r-- 1 root root  451566 Dec 20 21:48  brcmfmac4334-sdio.bin
-rw-r--r-- 1 root root  569291 Dec 20 21:48  brcmfmac4335-sdio.bin
-rw-r--r-- 1 root root  202107 Dec 20 21:48  brcmfmac43362-sdio.bin
-rw-r--r-- 1 root root     803 Dec 20 21:48  brcmfmac43362-sdio.cubietech,cubietruck.txt
lrwxrwxrwx 1 root root      43 Dec 20 21:48  brcmfmac43362-sdio.lemaker,bananapro.txt -> brcmfmac43362-sdio.cubietech,cubietruck.txt
-rw-r--r-- 1 root root  562183 Dec 20 21:48  brcmfmac4339-sdio.bin
-rw-r--r-- 1 root root  382455 Dec 20 21:48  brcmfmac43430a0-sdio.bin
-rw-r--r-- 1 root root     951 Dec 20 21:48  brcmfmac43430a0-sdio.jumper-ezpad-mini3.txt
-rw-r--r-- 1 root root     989 Dec 20 21:48 'brcmfmac43430a0-sdio.ONDA-V80 PLUS.txt'
-rw-r--r-- 1 root root     875 Dec 20 21:48  brcmfmac43430-sdio.AP6212.txt
-rw-r--r-- 1 root root  388739 Dec 20 21:48  brcmfmac43430-sdio.bin
-rw-r--r-- 1 root root     928 Dec 20 21:48  brcmfmac43430-sdio.Hampoo-D2D3_Vi8A1.txt
-rw-r--r-- 1 root root     831 Dec 20 21:48  brcmfmac43430-sdio.MUR1DX.txt
-rw-r--r-- 1 root root     874 Dec 20 21:48  brcmfmac43430-sdio.raspberrypi,3-model-b.txt
lrwxrwxrwx 1 root root      29 Dec 20 21:48  brcmfmac43430-sdio.sinovoip,bpi-m2-plus.txt -> brcmfmac43430-sdio.AP6212.txt
lrwxrwxrwx 1 root root      29 Dec 20 21:48  brcmfmac43430-sdio.sinovoip,bpi-m2-zero.txt -> brcmfmac43430-sdio.AP6212.txt
-rw-r--r-- 1 root root  488193 Dec 20 21:48  brcmfmac43455-sdio.bin
-rw-r--r-- 1 root root    2510 Dec 20 21:48 'brcmfmac43455-sdio.MINIX-NEO Z83-4.txt'
lrwxrwxrwx 1 root root      49 Dec 20 21:48  brcmfmac43455-sdio.raspberrypi,3-model-a-plus.txt -> brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt
-rw-r--r-- 1 root root    1864 Dec 20 21:48  brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt
-rw-r--r-- 1 root root    1863 Dec 20 21:48  brcmfmac43455-sdio.raspberrypi,4-model-b.txt
-rw-r--r-- 1 root root  623304 Dec 20 21:48  brcmfmac4350c2-pcie.bin
-rw-r--r-- 1 root root  626140 Dec 20 21:48  brcmfmac4350-pcie.bin
-rw-r--r-- 1 root root  605388 Dec 20 21:48  brcmfmac4354-sdio.bin
-rw-r--r-- 1 root root  557056 Dec 20 21:48  brcmfmac43569.bin
-rw-r--r-- 1 root root  648770 Dec 20 21:48  brcmfmac4356-pcie.bin
-rw-r--r-- 1 root root    2515 Dec 20 21:48  brcmfmac4356-pcie.gpd-win-pocket.txt
-rw-r--r-- 1 root root  526383 Dec 20 21:48  brcmfmac4356-sdio.bin
-rw-r--r-- 1 root root  550333 Dec 20 21:48  brcmfmac43570-pcie.bin
-rw-r--r-- 1 root root  633817 Dec 20 21:48  brcmfmac4358-pcie.bin
-rw-r--r-- 1 root root  595472 Dec 20 21:48  brcmfmac43602-pcie.ap.bin
-rw-r--r-- 1 root root  635449 Dec 20 21:48  brcmfmac43602-pcie.bin
-rw-r--r-- 1 root root 1105361 Dec 20 21:48  brcmfmac4366b-pcie.bin
-rw-r--r-- 1 root root 1120971 Dec 20 21:48  brcmfmac4366c-pcie.bin
-rw-r--r-- 1 root root  623448 Dec 20 21:48  brcmfmac4371-pcie.bin
-rw-r--r-- 1 root root  479232 Dec 20 21:48  brcmfmac4373.bin
-rw-r--r-- 1 root root  457994 Dec 20 21:48  brcmfmac4373-sdio.bin
Quite different.
The brcmfmac43455’s are the files that affect you.
Below are the current links that pacman complained about already existing on the file system, and that I manually deleted. I suspect something here as this was the only “non-standard” event I experienced. It caused me to do something I do not normally do. Since the normal updates did not result in a working wifi, the things done out of the ordinary would likely contain the “fix”.
lrwxrwxrwx 1 root root 31 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac43012-sdio.bin -> ../cypress/cyfmac43012-sdio.bin
lrwxrwxrwx 1 root root 36 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac43012-sdio.clm_blob -> ../cypress/cyfmac43012-sdio.clm_blob
lrwxrwxrwx 1 root root 36 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac43430-sdio.clm_blob -> ../cypress/cyfmac43430-sdio.clm_blob
lrwxrwxrwx 1 root root 44 Feb 10 08:26 '/usr/lib/firmware/brcm/brcmfmac43455-sdio.Raspberry Pi Foundation-Raspberry Pi 4 Model B.txt' -> brcmfmac43455-sdio.raspberrypi,4-model-b.txt
lrwxrwxrwx 1 root root 36 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac43455-sdio.clm_blob -> ../cypress/cyfmac43455-sdio.clm_blob
lrwxrwxrwx 1 root root 35 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac4354-sdio.clm_blob -> ../cypress/cyfmac4354-sdio.clm_blob
lrwxrwxrwx 1 root root 35 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac4356-pcie.clm_blob -> ../cypress/cyfmac4356-pcie.clm_blob
lrwxrwxrwx 1 root root 35 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac4356-sdio.clm_blob -> ../cypress/cyfmac4356-sdio.clm_blob
-rw-r--r-- 1 root root 2610 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac4356-sdio.vamrs,rock960.txt
lrwxrwxrwx 1 root root 36 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac43570-pcie.clm_blob -> ../cypress/cyfmac43570-pcie.clm_blob
lrwxrwxrwx 1 root root 35 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac4373-sdio.clm_blob -> ../cypress/cyfmac4373-sdio.clm_blob
lrwxrwxrwx 1 root root 31 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac54591-pcie.bin -> ../cypress/cyfmac54591-pcie.bin
lrwxrwxrwx 1 root root 36 Feb 10 08:26 /usr/lib/firmware/brcm/brcmfmac54591-pcie.clm_blob -> ../cypress/cyfmac54591-pcie.clm_blob
I went back to look the snapshot before I rolled back the linux-firmware, first time. I wanted to see what a “non-working” updated firmware looked like. And I do not see any different in the 43455 files from when wifi did not work and with wifi working.
I am stumped as to what “fixed” this firmware issue for me.
I have switched over to using my arm-testing as it is still “broken”. I can switch back and forth between the two linux-firmware versions with the expected working and broken wifi to try an figure out what I can change to get wifi to work on the new firmware. I do not yet have an answer, still fiddling with it.
What I can say is, this device is not created with the new linux-firmware:
/sys/devices/platform/soc/fe300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/ieee80211/phy0/
From comparing journalctl messages, this device is not found by rfkill.
Edit: Some notes here for myself, messages that do not occur on my arm-testing install.
$ journalctl -b
Feb 13 15:48:21 roulette NetworkManager[652]: <info>  [1613252901.0693] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/platform/soc/fe300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/ieee80211/phy0/rfkill0) (driver brcmfmac)
Feb 13 15:48:23 roulette systemd[1]: systemd-rfkill.service: Succeeded.
rfkill module used 6 times, only 4 on arm-testing
$ lsmod | grep cfg80211
cfg80211              876544  1 brcmfmac
rfkill                 36864  6 cfg80211
dmesg | grep 80211
[   11.568890] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
This change in /lib/firmware/brcmfmac43455-sdio.raspberrypi,4-model-b.txt
Old firmware:
boardflags3=0x44200100
New firmware:
boardflags3=0x48200100
is what “breaks” wifi in the new firmware. Edit this file and replace it with the setting from the old firmware and wifi works. See this link, the wifi section.
My arm-unstable install is somehow using /usr/lib/firmware/updates/brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt which has the correct boardflags3 for the RPi4. The file supplied by linux-firmware has boardflags3 for the RPi3.
Now to find out how/why is it using the correct file when my arm-testing continues to use the incorrect file?
I found the inconsistency, how my arm-unstable seemed to be fixed. It is not. I managed to get some old /lib/firmware/brcm/ files in /lib/firmware/updates/brcm/ with my bind mount snafu. After manually removing all files from /lib/firmware/updates/brcm/ and reinstalling, my arm-unstable now behaves just as my arm-testing. Which is odd given my current understanding of the firmware loading. I would have thought any files in the updates/brcm/ directory would have been ignored.
@Darksky The problem with the current linux-firmware is exactly as stated above, the incorrect boardflags3 setting, it is set as an rpi3, not an rpi4. The wifi can not be properly discovered, so the device is not created.
I am pushing new kernels after a while but am posting first as there are a lot of changes and want members to read first before upgrading:
linux 5.10.16 is now in the linux-rpi4 package and I will be pushing this package to the testing and unstable branch to get as much testing done on it before the new upcoming images are released.
linux 5.11.0 is now in the linux-rpi4-mainline package and will be pushed to the unstable branch.
The 2 new raspberrypi-bootloader packages I will be pushing to the testing and unstable branch.
As requested to stop custom config.txt and cmdline.txt files in /boot from being over written on every upgrade I have removed them from the kernel initial install phase. The old kernel will remove them before these new kernels get installed but I have made provisions in the .install files to look for these files in their respective .pacsave files in /boot and restore them back otherwise it will create the 2 files with their default values.
So if you have custom config.txt and cmdline.txt and want to keep them do this one time procedure below before upgrading to get past this transition period. If you have not changed these files then do nothing and do a kernel upgrade as normal.
sudo cp /boot/cmdline.txt /boot/cmdline.txt.pacsave
sudo cp /boot/config.txt /boot/config.txt.pacsave
New upgraded files:
linux-rpi4 5.10.16-1
linux-rpi4-headers 5.10.16-1
linux-rpi4-mainline 5.11.0-1
linux-rpi4-mainline headers-5.11.0-1
raspberrypi-bootloader 20210216-1
raspberrypi-bootloader-x 20210216-1
I made the .pacsave copies and then performed the update, including a mainline kernel update. However the copies were not restored. So I then switched to the linux-rpi4 kernel and this time the copies were restored, see below.
(1/2) removing linux-rpi4-mainline-headers                                                             [#############################################################] 100%
(2/2) removing linux-rpi4-mainline        [#############################################################] 100%
(1/2) installing linux-rpi4        [#############################################################] 100%
===> Restoring old cmdline.txt file...
===> Restoring old config.txt file...
I grabbed this after the switch back to the mainline, unfortunately I did not capture this from the first update. I did not know to look for it.
(1/2) removing linux-rpi4-headers        [#############################################################] 100%
(2/2) removing linux-rpi4        [#############################################################] 100%
(1/2) installing linux-rpi4-mainline        [#############################################################] 100%
If it seems unlikely that it did not work the first time, I would not argue… been a very long day.
I really appreciate this change, thank you!
No external sound card hifiberry after linux-rpi4-rc 5.11.rc6-1 to linux-rpi4-mainline 5.11.0-1.
But aplay -l is correct with linux-rpi4-rc 5.11.rc6-1 and linux-rpi4 5.10.16-1
 aplay -l
**** Liste des Périphériques Matériels PLAYBACK ****
carte 0: Headphones [bcm2835 Headphones], périphérique 0: bcm2835 Headphones [bcm2835  Headphones]
Sous-périphériques: 8/8
Sous-périphérique #0: subdevice #0
Sous-périphérique #1: subdevice #1
Sous-périphérique #2: subdevice #2
Sous-périphérique #3: subdevice #3
Sous-périphérique #4: subdevice #4
Sous-périphérique #5: subdevice #5
Sous-périphérique #6: subdevice #6
Sous-périphérique #7: subdevice #7
carte 1: sndrpihifiberry [snd_rpi_hifiberry_dacplus], périphérique 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0 [HiFiBerry DAC+ HiFi pcm512x-hifi-0]
Sous-périphériques: 0/1
carte 2: vc4hdmi0 [vc4-hdmi-0], périphérique 0: MAI PCM vc4-hdmi-hifi-0 [MAI PCM vc4-hdmi-hifi-0]
Sous-périphériques: 1/1
carte 3: vc4hdmi1 [vc4-hdmi-1], périphérique 0: MAI PCM vc4-hdmi-hifi-0 [MAI PCM vc4-hdmi-hifi-0]
I have updated the linux-rpi4 and linux-rpi4-mainline kernels as they both had changes today that look important. They have been pushed to the testing and unstable branch when the mirrors sync.
Added missing IPV6 modules
Added display drm modules
Reverted i2c patch on kernel 5.11.0
Also I had a request on gitlab to add rpi-cm4 support
New kernels:
linux-rpi4 5.10.16-2
linux-rpi4-headers 5.10.16-2
linux-rpi4-mainline 5.11.0-2
linux-rpi4-mainline-headers 5.11.0-2
I am stumped on this at the moment. All of the modules are enabled in the kernel. Try the new kernels I just posted above.
1
2
Added:
They did mess with the code 8 days ago. Maybe they put it to sleep permanently!
https://github.com/raspberrypi/linux/commit/656dc8295f67e3c4c475f76f10426fc358a952d0
I updated the mainline kernel and /dev/i2c-1 is back, my fan is operational again.
