I have a BT mouse and BT headphone, when both are connected and I move/click with the mouse the audio crack and glitch. This behavior never happens when only the headphone is connected.
inxi -v7azy
Kernel: 6.1.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=3a33bc20-cdfc-45f6-94b2-627cc60aa5e5 rw rootflags=subvol=@
Desktop: GNOME v: 45.0 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: LENOVO product: 82NM v: Lenovo V14 G2 ITL
serial: <superuser required> Chassis: type: 10 v: Lenovo V14 G2 ITL
Mobo: LENOVO model: LNVNB161216 v: SDK0T76464 WIN
serial: <superuser required> UEFI: LENOVO v: GGCN51WW date: 11/16/2022
ID-1: BAT0 charge: 15.6 Wh (40.3%) condition: 38.7/38.0 Wh (101.9%)
power: 16.7 W volts: 7.4 min: 7.7 model: LGC L20L2PF0 type: Li-poly
serial: <filter> status: discharging cycles: 12
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
status: discharging
System RAM: total: 12 GiB note: est. available: 11.47 GiB
used: 8.96 GiB (78.1%)
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xAC
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 877 high: 1144 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 748 2: 1123 3: 1044
4: 1105 5: 1058 6: 1144 7: 400 8: 400 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce MX350] vendor: Lenovo driver: nvidia
v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 bus-ID: 0000:01:00.0 chip-ID: 10de:1c94 class-ID: 0302
Device-3: Syntek [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 174f:2459 class-ID: fe01
serial: <filter>
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: AOC 1970W
serial: <filter> built: 2016 res: 1920x1080 dpi: 119 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x09ae built: 2020
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 11.2 GiB unified: yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.1.60-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.83 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 4000
bus-ID: 0000:02:00.0 chip-ID: 10ec:c822 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 0000:03:00.0
Device-1: Realtek [] driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:c123 class-ID: e001
serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 116.37 GiB (24.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPMQD-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73110001 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 116.37 GiB (24.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 3a33bc20-cdfc-45f6-94b2-627cc60aa5e5
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 346D-120A
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /swap raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-5: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-6: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
compressor: zstd max-pool: 25%
ID-1: swap-1 type: file size: 512 MiB used: 483.8 MiB (94.5%) priority: -2
file: /swap/swapfile
ID-2: swap-2 type: file size: 256 MiB used: 255.9 MiB (99.9%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
ID-3: swap-3 type: file size: 256 MiB used: 255.8 MiB (99.9%) priority: 49
file: /var/lib/systemd-swap/swapfc/2
ID-4: swap-4 type: file size: 256 MiB used: 243.7 MiB (95.2%) priority: 48
file: /var/lib/systemd-swap/swapfc/3
ID-5: swap-5 type: file size: 256 MiB used: 176.5 MiB (69.0%) priority: 47
file: /var/lib/systemd-swap/swapfc/4
ID-6: swap-6 type: file size: 256 MiB used: 172.5 MiB (67.4%) priority: 46
file: /var/lib/systemd-swap/swapfc/5
ID-7: swap-7 type: file size: 256 MiB used: 199.8 MiB (78.1%) priority: 45
file: /var/lib/systemd-swap/swapfc/6
ID-8: swap-8 type: file size: 256 MiB used: 175.5 MiB (68.5%) priority: 44
file: /var/lib/systemd-swap/swapfc/7
ID-9: swap-9 type: file size: 256 MiB used: 184.2 MiB (71.9%) priority: 43
file: /var/lib/systemd-swap/swapfc/8
ID-10: swap-10 type: file size: 256 MiB used: 188.3 MiB (73.5%)
priority: 42 file: /var/lib/systemd-swap/swapfc/9
ID-11: swap-11 type: file size: 256 MiB used: 207.5 MiB (81.1%)
priority: 41 file: /var/lib/systemd-swap/swapfc/10
ID-12: swap-12 type: file size: 256 MiB used: 199 MiB (77.7%) priority: 40
file: /var/lib/systemd-swap/swapfc/11
ID-13: swap-13 type: file size: 256 MiB used: 114.1 MiB (44.6%)
priority: 39 file: /var/lib/systemd-swap/swapfc/12
ID-14: swap-14 type: file size: 256 MiB used: 0 KiB (0.0%) priority: 38
file: /var/lib/systemd-swap/swapfc/13
ID-15: swap-15 type: file size: 256 MiB used: 0 KiB (0.0%) priority: 37
file: /var/lib/systemd-swap/swapfc/14
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-4: 3-2:5 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-2.1:6 info: [] type: keyboard,mouse driver: hid-generic,usbhid
power: 100mA chip-ID: 3151:3020 class-ID: 0301 serial: <filter>
Device-2: 3-5:3 info: Syntek [] type: video driver: uvcvideo interfaces: 3
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Device-3: 3-10:4 info: Realtek [] type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 4-3:2 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 394 Uptime: 1h 7m wakeups: 0 Init: systemd v: 254
Packages: 1450 pm: pacman pkgs: 1419 libs: 367
tools: gnome-software,pamac,yay pm: flatpak pkgs: 31 Shell: Zsh v: 5.9
running-in: gjs inxi: 3.3.31
bluetoothctl
Agent registered
hci0 new_settings: powered bondable ssp br/edr le secure-conn
[CHG] Controller 00:45:E2:CF:5C:6A Pairable: yes
AdvertisementMonitor path registered
[Philips SHB3075]#
pamac info pulseaudio-bluetooth | grep Ins
Installed Size : 304,5 kB
Optional Dependencies : gst-plugins-bad: AptX and LDAC support [Installed]
Install Date : seg 29 mai 2023 06:08:52
Install Reason : Installed as a dependency for another package
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Alternatively , paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB , causing it to render the same way as described above.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Thanks. I have updated my original post.
Thank you. Perhaps someone else who knows more than me can help, seeing as I’ve never used BT, all my peripherals are wired because I don’t want to use wireless stuff. So I can’t help anymore. Sorry.
Olli
10 November 2023 15:56
5
please post the output of
Thank you, for helping me!
Olli
10 November 2023 16:06
7
you should know that there is a lot of trouble with tiger-lake-sound in the past because the driver couldn’t be installed correct. for this it’s good to know that it seems to work on your system.
i’ve got a question, is it possible that you create a backup of your existing system first ? that would be very safe before ongoing.
next step is to skip pulse-audio and install pipewire instead.
I see.
Yes I can, I don’t know how though, I will look it up. But if you have a link showing how to I appreciate.
Well I have these in Timeshift
Olli
10 November 2023 16:16
10
you know how to use timeshift and restore a backup from it ?
I’ve never done it before, but I suppose I just need to select the last snapshot and hit Restore button. Are there more steps to it?
Olli
10 November 2023 16:21
12
i’m using something else for backups, i can’t tell you how to use it but it seems to be that simple.
It is all good, we can proceed.
Olli
10 November 2023 16:33
14
sudo pacman -R pulseaudio pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-bluetooth
sudo pacman -S manjaro-pipewire
Wow. Is it necessary to restart the system? So far it seems to work just fine.
Nah, I was claiming victory too soon. I will restart the system.
Olli
10 November 2023 17:19
16
yes a restart is needed. please report
ID-1: BAT0 charge: 38.7 Wh (100.0%) condition: 38.7/38.0 Wh (101.9%)
volts: 8.5 min: 7.7 model: LGC L20L2PF0 type: Li-poly serial: <filter>
status: full cycles: 12
status: discharging
used: 4.46 GiB (38.9%)
microcode: 0xAC
desc: 1x12 MiB
Speed (MHz): avg: 1454 high: 3614 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 658 2: 400 3: 400 4: 2235
5: 3614 6: 3532 7: 400 8: 400 bogomips: 44864
lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 174f:2459 class-ID: fe01
serial: <filter>
screens: 1
Server-3: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 0bda:c123 class-ID: e001
serial: <filter>
Local Storage: total: 476.94 GiB used: 106.79 GiB (22.4%)
fw-rev: 73110001 temp: 45.9 C scheme: GPT
used: 106.79 GiB (22.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
uuid: 346D-120A
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
Hub-4: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-2.1:5 info: [] type: keyboard,mouse driver: hid-generic,usbhid
Device-2: 3-5:4 info: Syntek [] type: video driver: uvcvideo interfaces: 3
Device-3: 3-10:6 info: Realtek [] type: bluetooth driver: btusb
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 312 Uptime: 7m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1454
pm: pacman pkgs: 1423 libs: 369 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 31 Shell: Zsh v: 5.9 running-in: gjs inxi: 3.3.31
Looks like it overall improved, but the glitches still happens, less often I would say.
Looks like the BT Mouse interferes with the BT headphone signal, does it makes sense?
When I am using the mouse without bluetooth there is no issue.
Olli
10 November 2023 18:35
19
okay let’s assume the setting to pipewire was success. let’s try to dig deeper in this malad. please do a backup of the actual system first before going on.
bluetooth is a mess…
btw.: this is a logitech-bluetooth mouse we’re talking about with this unified-controller in combination with a keyboard ?
The keyboard is a Logitech. The mouse is generic (propably chinese), no brand. The headphone is Philips.
