When I first open the laptop I update using pacman. And then I download some bluetooth derivers(I can’t remember its name). Then I updated everything again and reboot the computer. Now İt is stucked on booting screen I can’t access the terminal. What should I do
When I rebooted 1412084 time it didn’t stuck this time. I don’t know what went wrong or how the things worked right but now I have access to terminal. I really appreciate If anyone helps me to find the problem and fix it
Hi @yayiz, and welcome!
I’m presuming your native language isn’t English. (Don’t worry, mine isn’t either.)
Fixing it depends on what needs to be fixed. Not if it can be done, but how it needs to be done., what needs to be done.
I’m also pretty sure that’s exaggerating it, but nevertheless, can you boot up now?
If so, open a terminal and provide more information, please. Also see:
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Also, from a terminal, please provide the output for:
journalctl --priority=3 --boot=-1
Hi @Mirdarthos ,
Well I am currently on the desktop session but I was afraid to boot up again.
this is the output for journalctl --priority=3 --boot
Mar 08 14:45:40 milkyway kernel: x86/cpu: SGX disabled by BIOS.
Mar 08 14:45:41 milkyway kernel:
Mar 08 14:45:42 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:45:46 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:45:47 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:45:49 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:45:50 milkyway gnome-session-binary[789]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
Mar 08 14:45:53 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:45:58 milkyway gdm-password][1137]: gkr-pam: unable to locate daemon control file
Mar 08 14:46:00 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:46:02 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:46:04 milkyway systemd[1148]: Failed to start Application launched by gnome-session-binary.
Mar 08 14:46:06 milkyway kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mar 08 14:46:06 milkyway gdm-launch-environment][714]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mar 08 14:53:06 milkyway kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=27534 end=27535) time 327 us, min 1073, max 1079, scanline start 1070, end 1090
Mar 08 14:55:21 milkyway kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=35593 end=35594) time 316 us, min 1073, max 1079, scanline start 1064, end 1084
Mar 08 15:04:17 milkyway systemd-coredump[5243]: [🡕] Process 3169 (pamac-manager) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id c92da1914b8d8df59d1e5784659d5e3558731667
Module librsvg-2.so.2 with build-id ee2b5961f905a5f62b70dc6222968aaca76a0d81
Module libpixbufloader-svg.so with build-id d31f1f5a38b6d6ef3a41361bd59a05b82bf8900d
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id ad0a6c1af8f219b4e314090b6e8847223d424cbe
Module libltdl.so.7 with build-id 04a5ffeff80ecdfcb5f7ff2d889b5a3ecfb88d7c
Module libtdb.so.1 with build-id 6c9ccf6d9a22d117d984d1666842a49fd7669f09
Module libvorbisfile.so.3 with build-id 0010b21da05e318b42e718d90738febf58028141
Module libcanberra.so.0 with build-id 379ed64f9d1408a83806cd5d94dc5bb903765615
Module libcanberra-gtk3.so.0 with build-id 133409dc3e744fe0edc6a4d078714dce82dacf98
Module libcanberra-gtk-module.so with build-id 72bd14fd5ba4fb0eda082b3daeccc80b796a5586
Module libxkbfile.so.1 with build-id de5e415879c20263a8dd42f8cf2dd88107c2bfb2
Module libxklavier.so.16 with build-id cefd678b3d270e389f50a9686ad2db83a8c67494
Module libgnomekbd.so.8 with build-id 794a46e6fb5c4ca09e07a74b1199fb1d480d0843
Module libgnomekbdui.so.8 with build-id 0f2fd1658447a0f5bf23a5eff2ec69bc9c306142
Module libxapp.so.1 with build-id 2d6867c3b087052ef8acd12a1a6c82b3c62b8f36
Module libxapp-gtk3-module.so with build-id 12b94957cbe0eb705d8e900c9006d5333846d4db
Module libsodium.so.23 with build-id 08ab1599930a2b6926271758092485a609f71ce3
Module libavahi-glib.so.1 with build-id debfeef72739e62828707451a83d47bfbd6e00c3
Module libavahi-client.so.3 with build-id 1858551543958190c653b565cf0eb64609ad908a
Module libavahi-common.so.3 with build-id 80fda945459a3476ccd1050783dfd5f5c17c479a
Module libostree-1.so.1 with build-id 830ad7b4c24733a1d3abdd15c4ba17775bddf44f
Module libseccomp.so.2 with build-id 54179323d84e1b713b7547ba0b3f8310e65eec93
Module libdconf.so.1 with build-id 4e1bd6ba12d7f2997624fe360181059f73e5c84a
Module libflatpak.so.0 with build-id 4c6e8cb61133a44ac5f5b1b12f12f7a5046d3a4a
Module libpamac-flatpak.so with build-id a19884195a6b79b23d1e92de2556ed97f0f6090c
Module libsnapd-glib.so.1 with build-id 067c8709d02907d1fce5401d5aa853ec849c15e6
Module libpamac-snap.so with build-id 3c9a83d7ec1a3084f0075dcb04dfd7678f496769
Module libgvfscommon.so with build-id 643d4362b74f55b036829781680105545e0e1ad9
Module libgvfsdbus.so with build-id 80d171a1b9e2e4327b393f38166fc31d2925365d
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
Module libassuan.so.0 with build-id 21dba3fc93d5d174beca9378b016bcd85829a5c1
Module libssl.so.1.1 with build-id 1024424ab33a3767da03f4fdb1fc1b02479f160f
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libnghttp2.so.14 with build-id f2738fead8e6593084b4fb8756f460aa8cf5535a
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libsystemd.so.0 with build-id c9e19a3f6e503f05f60867b9240c1d59bf6c605e
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libyaml-0.so.2 with build-id 94fd2b16e4c311e4c8b041061dfdb9ca8f508e29
Module libuuid.so.1 with build-id cc94de1b28210d2b06109bd76c198c80f518aad6
Module libgpgme.so.11 with build-id 8c0960c611a9f6c9a5eb065d8dd3a2739c782fc9
Module libcurl.so.4 with build-id d4dec3d9f8c789ec28d441f2a3f73d532809e6ef
Module libarchive.so.13 with build-id 985731a3b1f779e47cfa73d88ad8f36e561d6ec6
Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0786de4
Module libblkid.so.1 with build-id 9e4bb910a2e63ba71cae0e3b89c07fdd45033ff2
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libzstd.so.1 with build-id 72f3511cba7db578f6a2647925f35664da6c838b
Module libxml2.so.2 with build-id 34aa03d6fadb52a051964f0e50a977efaea9482e
Module libsqlite3.so.0 with build-id 132f0de53d66f5245cd1b1c863e1ec81f32ddebe
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libstemmer.so.0 with build-id aa44a40dfb223020ed8e49cd2d28fc3887128463
Module libatspi.so.0 with build-id de251156cf6f2f447c5e2b8721bd913d79995d4f
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libexpat.so.1 with build-id 63a4ee083a938cbb472c2c4d32e1050474c94382
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libsoup-2.4.so.1 with build-id 678dafa54638a6d0ab73f810643f9a23d988db00
Module libappstream-glib.so.8 with build-id b6c2db18354ad660b26ce2281398e50765c225a8
Module libjson-glib-1.0.so.0 with build-id 5865be5fcc01b48a0a113e0145ec45529bff89a6
Module libalpm.so.13 with build-id 1407b7abcb95846a537d3909fb2549d118a5aa48
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libmount.so.1 with build-id 765508fe9812e693ac41fd3d0aedd65d7a78b287
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libwayland-egl.so.1 with build-id 791e39283cdcc5a08cfd091b8cd4c59869a11278
Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module librt.so.1 with build-id 4761858b348db8303e872e515aa8d56c046c921c
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id b0eee5a9b660fed5221ea15139e9608282320503
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
Module libatk-1.0.so.0 with build-id aacaa40363d304858b654728a893bc212a4ca119
Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
Module libfontconfig.so.1 with build-id 9fdeb38479c4090d673efc2e8cb60176efe65da1
Module libpangoft2-1.0.so.0 with build-id 9b0353693557b4fb68124a9dffac9b07678d86a1
Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
Module libharfbuzz.so.0 with build-id 716df25c59c91f456ae107457e4250f7c32bde1b
Module libpango-1.0.so.0 with build-id f7a7e74f7ade4cbcf3840f685d760da19b0dc38c
Module libpangocairo-1.0.so.0 with build-id a47bf17ab99c1840764fca52a2d772800d81d6e1
Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libpamac.so.11 with build-id 826f436e599a4caaa2aa8abddc3314701e9c332b
Module libhandy-1.so.0 with build-id fa74e1154b327e4622b580cbc28fb20fd8003211
Module libglib-2.0.so.0 with build-id 24e675eddd4654b470e0a892f4a4aec012b04160
Module libgobject-2.0.so.0 with build-id 6d7ff6c8e4e9c12caa92cf25a74d3ecdd9461c36
Module libgio-2.0.so.0 with build-id c4e89ca22afc7f17db176d2063fe379dbc88d99b
Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b36
Module libgdk-3.so.0 with build-id 0d1048ff040bb420bc2b7da992590559226a1beb
Module libgtk-3.so.0 with build-id 237211b929fd493858b4269bbf63f407c24e0fb4
Module libpamac-gtk.so with build-id 0b14287660a694a74cc27018b0cf38aa4b03c45e
Module pamac-manager with build-id 0c9a15346975c15967b2263571bee4fcd8b62a54
Stack trace of thread 3169:
#0 0x00007ff135b6c5dc pamac_package_get_name (libpamac.so.11 + 0x195dc)
#1 0x000055cb180dc7be pamac_sort_pkgs_by_relevance (pamac-manager + 0x277be)
#2 0x00007ff135d0cb35 n/a (libglib-2.0.so.0 + 0x5ab35)
#3 0x00007ff135d0cac3 n/a (libglib-2.0.so.0 + 0x5aac3)
#4 0x00007ff135d0cac3 n/a (libglib-2.0.so.0 + 0x5aac3)
#5 0x00007ff135d0cac3 n/a (libglib-2.0.so.0 + 0x5aac3)
#6 0x00007ff135d0cac3 n/a (libglib-2.0.so.0 + 0x5aac3)
#7 0x00007ff135d0cad1 n/a (libglib-2.0.so.0 + 0x5aad1)
#8 0x00007ff135d0cac3 n/a (libglib-2.0.so.0 + 0x5aac3)
#9 0x00007ff135d0cad1 n/a (libglib-2.0.so.0 + 0x5aad1)
#10 0x00007ff135d0cad1 n/a (libglib-2.0.so.0 + 0x5aad1)
#11 0x00007ff135d0cac3 n/a (libglib-2.0.so.0 + 0x5aac3)
#12 0x00007ff135d0cac3 n/a (libglib-2.0.so.0 + 0x5aac3)
#13 0x00007ff135d0cad1 n/a (libglib-2.0.so.0 + 0x5aad1)
#14 0x00007ff135d0cad1 n/a (libglib-2.0.so.0 + 0x5aad1)
#15 0x00007ff135d1008d n/a (libglib-2.0.so.0 + 0x5e08d)
#16 0x000055cb180c9e7a vala_g_ptr_array_sort (pamac-manager + 0x14e7a)
#17 0x000055cb180d98f4 pamac_manager_window_populate_packages_list (pamac-manager + 0x248f4)
#18 0x000055cb180d99ea ___lambda28__gasync_ready_callback (pamac-manager + 0x249ea)
#19 0x00007ff135eefd34 n/a (libgio-2.0.so.0 + 0xa3d34)
#20 0x00007ff135ef3a89 n/a (libgio-2.0.so.0 + 0xa7a89)
#21 0x00007ff135b879ed pamac_database_get_repo_pkgs_async_co (libpamac.so.11 + 0x349ed)
#22 0x00007ff135d06f13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
#23 0x00007ff135d5d0d9 n/a (libglib-2.0.so.0 + 0xab0d9)
#24 0x00007ff135d04485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#25 0x00007ff135f276ee g_application_run (libgio-2.0.so.0 + 0xdb6ee)
#26 0x000055cb180c2100 main (pamac-manager + 0xd100)
#27 0x00007ff135976310 __libc_start_call_main (libc.so.6 + 0x2d310)
#28 0x00007ff1359763c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#29 0x000055cb180c2175 _start (pamac-manager + 0xd175)
Stack trace of thread 3205:
#0 0x00007ff135a4f2af __poll (libc.so.6 + 0x1062af)
#1 0x00007ff135d5d066 n/a (libglib-2.0.so.0 + 0xab066)
#2 0x00007ff135d06463 g_main_loop_run (libglib-2.0.so.0 + 0x54463)
#3 0x00007ff135f5415c n/a (libgio-2.0.so.0 + 0x10815c)
#4 0x00007ff135d36845 n/a (libglib-2.0.so.0 + 0x84845)
#5 0x00007ff1359d65c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007ff135a5b584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 3204:
#2 0x00007ff135d04485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#3 0x00007ff135d044d2 n/a (libglib-2.0.so.0 + 0x524d2)
Mar 08 15:04:24 milkyway gdm[626]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Mar 08 15:04:26 milkyway kernel: watchdog: watchdog0: watchdog did not stop!
lines 173-225/225 (END)
I found the pacman log I don’t know if you need this information but the driver I installed is bluez-utils and I used pacman -Syyu to update
OK, do me a favor and sync via pamac:
sudo pacman-mirrors -f5 --fasttrack && pamac checkupdates && pamac upgrade --enable-downgrade
That should update your mirror pool, followed by checking that everything’s in sync, followed by syncing those that aren’t.
Edit:
And in the future, when providing terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Sorry for messed up messages, it should be okey now. When I want to update the system should I run
or should I run above code after when I run sudo pacman -Syyu
Do it instead of sudo pacman -Syyu please. Just for giggles, if nothing else.
@Mirdarthos I updated and sync using pamac as you said. Then I tried reboot it freezed on the same screen.
OK, there’s possibly some configuration mishap in your $HOME directory. Can you access TTY?
I couldn’t access. I waited around 10-15 min and relaunch the laptop. It booted without a problem. I really don’t get it what’s wrong with it.
Is due to plymouth and nvidia drivers. Please read on from this point, and linked topics.
I don’t either. That’s why it’s troubleshooting time.
Nevermind me, go with @bogdancovaciu' option first.
I’m guessing that screen there, where it’s hanging, is after the prompt for the password to log in?
If so, what happens when you press Ctrl+Alt+F1-F6?
i changed gdm-plymouth with gdm and used early kms thing you posted. When I run sudo mkinitcpio -P command I got following error
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
Beside that , I think I don’t have proper nvidia drivers. I tried to use mhwd -a pci *** but I couldn’t figure out what should I write insted of ***
Turns out I use hybrid GPU laptop. I followed this link to install and configure optimus manager and my problem solved. (I rebooted many times) thank you guys for you attention and support.
