[Testing Update] 2026-06-23 - Kernels, KDE Frameworks, KDE Gear, Xorg-Server
Hello Manjaro user community, here we have another set of package updates. We are continuing our development of the upcoming release of ‘Bian-May’ which can be expected end of June, Mid of July. Development speed may be a little slower the upcoming weeks. However, still let us know any issues you may found thus far.
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages.
  • Manjaro 26.1 Bian-May - Preview released
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 5.4.302, the 5.4 series is now EOL (End Of Life). Please install 5.10 LTS (Long Term Support) or 5.15 LTS.
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.19.14, the 6.19 series is now EOL (End Of Life). Please install 7.0, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux61 6.1.176
  • linux66 6.6.143
  • linux612 6.12.94
  • linux618 6.18.36
  • linux70 7.0.13
  • linux71 7.1.1
  • linux72 7.2.0-rc0
  • linux61-rt 6.1.167_rt62
  • linux66-rt 6.6.135_rt74
  • linux612-rt 6.12.89_rt18
Package Changes (Tue Jun 16 2026 12:41:23 GMT+0000)
  • testing core x86_64: 28 new and 28 removed package(s)
  • testing extra x86_64: 3515 new and 3453 removed package(s)
  • testing multilib x86_64: 40 new and 40 removed package(s)
Overlay Changes
  • testing core x86_64: 16 new and 14 removed package(s)
  • testing extra x86_64: 170 new and 165 removed package(s)
  • testing multilib x86_64: 3 new and 3 removed package(s)
A list of all package changes can be found here.
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Known issues and solutions
:arrow_right: 2026-06-23
2026-05-11
A week after Copy Fail, researcher Hyunwoo Kim disclosed a second Linux kernel flaw in the same broad area — IPsec ESP and rxrpc — that they have named Dirty Frag. The bug lives in the in-place decryption fast paths of esp4, esp6, and rxrpc: when a socket buffer carries paged fragments that are not privately owned by the kernel (e.g. pipe pages attached via splice(2)/sendfile(2)/MSG_SPLICE_PAGES), the receive path decrypts directly over those externally-backed pages, exposing or corrupting plaintext that an unprivileged process still holds a reference to.
Like the previous Copy Fail vulnerability, Dirty Frag immediately yields root on all major distributions. Every supported Manjaro release is affected. Dirty Frag chains two distinct kernel bugs, each with its own CVE: CVE-2026-43284 covers the IPsec ESP half (esp4 / esp6), and CVE-2026-43500 (NVD entry pending) covers the rxrpc half. Per Hyunwoo Kim’s public disclosure on oss-security (2026-05-07), the responsible-disclosure embargo was broken before distributions could coordinate, and a working exploit is publicly available. A second public exploit, Copy Fail 2: Electric Boogaloo, targets the same vulnerability under a different name; both reach root through the same esp4/esp6/rxrpc code paths and are blocked by the same fix.
Temporary mitigation
You can neutralize the attack surface by blacklisting the affected modules. None of esp4, esp6, or rxrpc are loaded on a typical workload that does not use IPsec transport mode or AFS, so on most systems this is safe to apply immediately:
sudo sh -c "printf 'install esp4 /bin/false\ninstall esp6 /bin/false\ninstall rxrpc /bin/false\n' > /etc/modprobe.d/dirtyfrag.conf; rmmod esp4 esp6 rxrpc 2>/dev/null; true"
This writes a modprobe config that prevents the three modules from loading, and unloads them if they happen to be loaded already (the rmmod is best-effort and silent if the module isn’t present). To revert, remove /etc/modprobe.d/dirtyfrag.conf.
The Dirty Frag exploit works by corrupting page-cache pages of sensitive files (such as /etc/passwd or /usr/bin/su). If you suspect the system may have already been targeted before you applied the mitigation, drop the page cache so any tampered pages are evicted and the next read comes fresh from disk:
sudo sh -c 'echo 3 > /proc/sys/vm/drop_caches'
This is safe to run on a live system — it only frees clean cache and dentry/inode entries — and pairs well with the blacklist above.
2026-05-01
On 29 April 2026, a high local privilege escalation vulnerability in the Linux kernel, tracked as CVE-2026-31431 and named “Copy Fail”, was publicly disclosed. The vulnerability affects Manjaro Linux since 2017. A public proof-of-concept exploit has been released.
We have patched most of our kernels and released them to our testing and unstable branches:
  • patched kernels are: 5.10.254+, 5.15.204+, 6.1.170+, 6.6.137+, 6.12.85+, 6.18.22+, 6.19.12+, 7.0-rc7+
  • affected kernels are: 6.1.167_rt62, 6.6.133_rt73, 6.12.79_rt17, 6.17.5_rt7 and lower
Temporary Mitigation
Disable the algif_aead kernel module persistently on all affected systems until a patched kernel is available:
sudo su
echo "install algif_aead /bin/false" > /etc/modprobe.d/disable-algif.conf
rmmod algif_aead 2>/dev/null || true
exit
More Information: CERT-EU - High Vulnerability in the Linux Kernel ("Copy Fail")
2026-04-06
udev-usb-sync and kernel 7.0-rc
If you experience slow transfers to USB attached disks, remove the package udev-usb-sync. It is not known why the 7.0-rc kernel causes this. There may be a regression of some sort. Awaiting the final release of the 7.0 kernel before jumping to conclusions.
See [Unstable Update] April 2026 thread for more info
2026-04-23T22:00:00Z
The issue is solved with the release of 7.0 kernel
Previous testing threads:
ISOs including this update: Release 202606230955 · manjaro/release-review · GitHub
A post was split to a new topic: Virtualbox-dkms compile failed with 7.1 kernel
A post was merged into an existing topic: Virtualbox-dkms compile failed with 7.1 kernel
@philm We have mismatched virtualbox packages in this update. Somehow we ended up with virtualbox 7.2.8 packages with 7.2.10 kernel modules.
On a plasma system with nvidia, I have a PS4 dualshock controller connected via USB.
In the sound widget of the plasma panel, the input audio radio button for the dualshock is selected by default.
However, if I select the radio button for internal audio, then the radio buttons for both devices (dualshock + internal audio) remain selected [1]. I see this with both linux70 and linux71.
Is this intended behaviour, or a bug ?
  1. I had expected to see the active radio button switch from the dualshock to internal audio. ↩︎
8 posts were split to a new topic: After the latest update keepassxc crashes with segmentation fault
Well in spite of the issues I was having, recently. This update went without issues.
I pushed the correct 7.2.8 virtualbox host kernel modules incl. a patched version for 7.1 kernel series.
- testing extra x86_64:  10 new and 10 removed package(s)
[New Packages]
linux61-rt-virtualbox-host-modules-7.2.8-15-x86_64.pkg.tar.zst
linux61-virtualbox-host-modules-7.2.8-15-x86_64.pkg.tar.zst
linux612-rt-virtualbox-host-modules-7.2.8-15-x86_64.pkg.tar.zst
linux612-virtualbox-host-modules-7.2.8-15-x86_64.pkg.tar.zst
linux618-virtualbox-host-modules-7.2.8-18-x86_64.pkg.tar.zst
linux66-rt-virtualbox-host-modules-7.2.8-15-x86_64.pkg.tar.zst
linux66-virtualbox-host-modules-7.2.8-15-x86_64.pkg.tar.zst
linux70-virtualbox-host-modules-7.2.8-18-x86_64.pkg.tar.zst
linux71-virtualbox-host-modules-7.2.8-15-x86_64.pkg.tar.zst
plasma-setup-6.6.5-1-x86_64.pkg.tar.zst
[Removed Packages]
linux61-rt-virtualbox-host-modules-7.2.10-1-x86_64.pkg.tar.zst
linux61-virtualbox-host-modules-7.2.10-2-x86_64.pkg.tar.zst
linux612-rt-virtualbox-host-modules-7.2.10-1-x86_64.pkg.tar.zst
linux612-virtualbox-host-modules-7.2.10-2-x86_64.pkg.tar.zst
linux618-virtualbox-host-modules-7.2.10-2-x86_64.pkg.tar.zst
linux66-rt-virtualbox-host-modules-7.2.10-1-x86_64.pkg.tar.zst
linux66-virtualbox-host-modules-7.2.10-2-x86_64.pkg.tar.zst
linux70-virtualbox-host-modules-7.2.10-2-x86_64.pkg.tar.zst
linux71-virtualbox-host-modules-7.2.10-4-x86_64.pkg.tar.zst
plasma-setup-6.7.0-1-x86_64.pkg.tar.zst
I’ve had this a few times before this update, on my internal sound and external bluetooth headphones. I haven’t been able to get to the bottom of it, but a logout and back in seems to resolve it.
I had that problem a while back, and this command worked for me:
systemctl --user restart plasma-plasmashell.service
Thanks @bananamangodog and @pwx.
Tried both suggestions, but without success : the result is the same for each suggestion.
In each case, the suggestion removes the two activated radio buttons, but if I reselect internal audio, the radio buttons for both devices are activated again.
It might be possible to restart pipewire/wireplumber services, but system should be restarted after a major update anyway
If problem persists after restart, I suggest install pavucontrol-qt to check audio devices
5 posts were split to a new topic: A question about Plymouth
Had a problem with kernel 7.1.1-3, no poweroff, no REISUO, complete stall.
inxi -zv8
[p16s ~]$ inxi -zv8
  Kernel: 7.1.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.1-x86_64
    root=UUID=d1c1f021-26a1-4666-bc9e-b859a2f2d269 ro nowatchdog quiet
    loglevel=3 rd.udev.log_level=3 zswap.enabled=0 apm=power_off
  Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 21CKCTO1WW v: ThinkPad P16s Gen 1
  Mobo: LENOVO model: 21CKCTO1WW v: ThinkPad serial: <superuser required>
    part-nu: LENOVO_MT_21CK_BU_Think_FM_ThinkPad P16s Gen 1
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: R23ET87W (1.63 ) date: 04/09/2026
  ID-1: BAT0 charge: 74.9 Wh (83.7%) condition: 89.4/86 Wh (104%) volts: 15.09
    min: 15.44 model: SMP LNV-5B10W51871�� type: Li-poly serial: <filter>
    charging: status: not charging control: start: 70% end: 85% cycles: 2
  System RAM: total: 32 GiB available: 27.17 GiB used: 2.31 GiB (8.5%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Hynix
    part-no: H9JCNNNFA5MLYR-N6E serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
    process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
    microcode: 0xA40410A
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1092 min/max: 402/4770 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1092 2: 1092 3: 1092
    4: 1092 5: 1092 6: 1092 7: 1092 8: 1092 9: 1092 10: 1092 11: 1092 12: 1092
    13: 1092 14: 1092 15: 1092 16: 1092 bogomips: 86236
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
    vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, DP-5, DP-6, Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 45.0 C
  Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
    chip-ID: 30c9:0050 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.23 with: Xwayland v: 24.1.12
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: amdgpu
    unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: Samsung
    serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 40 gamma: 1.2 chroma: red: x: 0.643 y: 0.329 green: x: 0.302 y: 0.600
    blue: x: 0.149 y: 0.059 white: x: 0.278 y: 0.290
    size: 1210x680mm (47.64x26.77") diag: 801mm (31.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1366x768,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  Monitor-2: eDP-1 mapped: eDP note: disabled model: Lenovo 0x41b7
    built: 2021 res: 1920x1080 dpi: 141 gamma: 1.2 chroma: red: x: 0.651
    y: 0.333 green: x: 0.302 y: 0.612 blue: x: 0.145 y: 0.059 white: x: 0.318
    y: 0.337 size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.2-arch1.2 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Graphics (radeonsi rembrandt ACO
    DRM 3.64 7.1.1-3-MANJARO) device-ID: 1002:1681 memory: 3.91 GiB
    unified: yes
  API: Vulkan v: 1.4.350 layers: 6 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 26.1.2-arch1.2
    device-ID: 1002:1681 surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
    snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k7.1.1-3-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0f0 state: down mac: <filter>
  Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
    driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
  Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3.1:4 chip-ID: 10ab:9309 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 953.87 GiB used: 200.42 GiB (21.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKBA1T0TFK
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 7003V5LN temp: 36.9 C
    scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 19.98 GiB (20.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: d1c1f021-26a1-4666-bc9e-b859a2f2d269
    used: 408 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 5759-84E8
  ID-3: /home raw-size: 853.37 GiB size: 838.9 GiB (98.30%)
    used: 180.44 GiB (21.5%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: f986f6b3-74b9-4497-bf9f-5797e5bd003f
  ID-1: swap-1 type: zram size: 13.58 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
  Hub-2: 1-3:2 info: Genesys Logic Hub ports: 3 rev: 2.0
  Device-1: 1-3.1:4 info: USI type: bluetooth driver: btusb interfaces: 2
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-1:2 info: Microsoft Wireless keyboard (All-in-One-Media)
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 045e:0800 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Luxvisions Innotech Integrated RGB Camera
    type: video driver: uvcvideo interfaces: 5 rev: 2.0
  Hub-7: 6-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 7-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 8-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 9-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
  Fan Speeds (rpm): fan-1: 0
  Packages: pm: pacman pkgs: 1438 libs: 406 tools: pamac,yay pm: rpm pkgs: 0
    1: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    2: https://mirrors2.manjaro.org/testing/$repo/$arch
Processes:
  CPU top: 5 of 352
  1: cpu: 5.4% command: chromium pid: 4457 mem: 288.5 MiB (1.0%)
  2: cpu: 4.2% command: xfce4-terminal pid: 11320 mem: 51.8 MiB (0.1%)
  3: cpu: 3.3% command: wireplumber pid: 1286 mem: 26.5 MiB (0.0%)
  4: cpu: 2.5% command: Xorg pid: 724 mem: 98.8 MiB (0.3%)
  5: cpu: 2.2% command: pragha pid: 2685 mem: 90.7 MiB (0.3%)
  Memory top: 5 of 352
  1: mem: 337.5 MiB (1.2%) command: chromium pid: 4172 cpu: 1.3%
  2: mem: 288.5 MiB (1.0%) command: chromium pid: 4457 cpu: 5.4%
  3: mem: 236.3 MiB (0.8%) command: chromium pid: 4207 cpu: 1.6%
  4: mem: 220.3 MiB (0.7%) command: chromium pid: 4479 cpu: 0.7%
  5: mem: 125.2 MiB (0.4%) command: chromium pid: 4487 cpu: 0.1%
  Processes: 352 Power: uptime: 12m states: freeze,mem,disk suspend: s2idle
    image: 10.81 GiB services: power-profiles-daemon, upowerd,
    xfce4-power-manager Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Bash v: 5.3.15
    running-in: xfce4-terminal inxi: 3.3.40
[p16s ~]$
After some less successful tries…
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 rd.udev.log_level=3 zswap.enabled=0 apm=power_off"
…apm=power_off at the end of the line did the trick.
Update worked fine and also installed the new 7.1 Kernel.
The only problem i had was removing Kernel 7.0, I had to use pacman -R to remove both the 7.0 Kernel Meta and the 7.0 Nvidia open meta, after that it uninstalled as it should using Manjaro Settings Manager.
