[Testing Update] 2026-09-05 - Kernels, Mesa, Firefox, Deepin, Haskell
Hello Manjaro user community, here we have another set of package updates. We are continuing our development of our current release ‘Bian-May’. If all went well, this will mark the second point release of 26.1 series.
Note: I’ve super limited time to do Manjaro these days. So expect delayed response from me or none at all …
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-580xx, or related DKMS packages.
  • Manjaro 26.1 Bian-May - Preview released
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.19.14, the 6.19 series is now EOL (End Of Life). Please install 7.2, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 7.0.14, the 7.0 series is now EOL (End Of Life). Please install 7.2, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
  • Kernels
  • Firefox 155.0
  • Mesa 26.2.2
  • Updates to Deepin and Haskell
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux61 6.1.187
  • linux66 6.6.156
  • linux612 6.12.108
  • linux618 6.18.49
  • linux71 7.1.13 [EOL]
  • linux72 7.2.3
  • linux73 7.3.0-rc1
  • linux61-rt 6.1.167_rt62
  • linux66-rt 6.6.135_rt74
  • linux612-rt 6.12.89_rt18
Package Changes (9/4/26 17:34 CEST)
  • testing core x86_64: 26 new and 26 removed package(s)
  • testing extra x86_64: 1781 new and 1886 removed package(s)
  • testing multilib x86_64: 22 new and 23 removed package(s)
A list of all package changes can be found here.
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Known issues and solutions
:arrow_right: 2026-09-05
2026-08-24
tar backup/restore scripts have been moved to tar-scripts
tar package no longer ships the helper scripts /usr/bin/backup and /usr/bin/restore.
If you rely on these tools, install tar-scripts
The core tar archiving utility itself is unaffected.
2026-05-11
Dirty Frag vulnerability
A week after Copy Fail, researcher Hyunwoo Kim disclosed a second Linux kernel flaw in the same broad area — IPsec ESP and rxrpc — that they have named Dirty Frag. The bug lives in the in-place decryption fast paths of esp4, esp6, and rxrpc: when a socket buffer carries paged fragments that are not privately owned by the kernel (e.g. pipe pages attached via splice(2)/sendfile(2)/MSG_SPLICE_PAGES), the receive path decrypts directly over those externally-backed pages, exposing or corrupting plaintext that an unprivileged process still holds a reference to.
Like the previous Copy Fail vulnerability, Dirty Frag immediately yields root on all major distributions. Every supported Manjaro release is affected. Dirty Frag chains two distinct kernel bugs, each with its own CVE: CVE-2026-43284 covers the IPsec ESP half (esp4 / esp6), and CVE-2026-43500 (NVD entry pending) covers the rxrpc half. Per Hyunwoo Kim’s public disclosure on oss-security (2026-05-07), the responsible-disclosure embargo was broken before distributions could coordinate, and a working exploit is publicly available. A second public exploit, Copy Fail 2: Electric Boogaloo, targets the same vulnerability under a different name; both reach root through the same esp4/esp6/rxrpc code paths and are blocked by the same fix.
Temporary mitigation
You can neutralize the attack surface by blacklisting the affected modules. None of esp4, esp6, or rxrpc are loaded on a typical workload that does not use IPsec transport mode or AFS, so on most systems this is safe to apply immediately:
sudo sh -c "printf 'install esp4 /bin/false\ninstall esp6 /bin/false\ninstall rxrpc /bin/false\n' > /etc/modprobe.d/dirtyfrag.conf; rmmod esp4 esp6 rxrpc 2>/dev/null; true"
This writes a modprobe config that prevents the three modules from loading, and unloads them if they happen to be loaded already (the rmmod is best-effort and silent if the module isn’t present). To revert, remove /etc/modprobe.d/dirtyfrag.conf.
The Dirty Frag exploit works by corrupting page-cache pages of sensitive files (such as /etc/passwd or /usr/bin/su). If you suspect the system may have already been targeted before you applied the mitigation, drop the page cache so any tampered pages are evicted and the next read comes fresh from disk:
sudo sh -c 'echo 3 > /proc/sys/vm/drop_caches'
This is safe to run on a live system — it only frees clean cache and dentry/inode entries — and pairs well with the blacklist above.
2026-05-01
On 29 April 2026, a high local privilege escalation vulnerability in the Linux kernel, tracked as CVE-2026-31431 and named “Copy Fail”, was publicly disclosed. The vulnerability affects Manjaro Linux since 2017. A public proof-of-concept exploit has been released.
We have patched most of our kernels and released them to our testing and unstable branches:
  • patched kernels are: 5.10.254+, 5.15.204+, 6.1.170+, 6.6.137+, 6.12.85+, 6.18.22+, 6.19.12+, 7.0-rc7+
  • affected kernels are: 6.1.167_rt62, 6.6.133_rt73, 6.12.79_rt17, 6.17.5_rt7 and lower
Temporary Mitigation
Disable the algif_aead kernel module persistently on all affected systems until a patched kernel is available:
sudo su
echo "install algif_aead /bin/false" > /etc/modprobe.d/disable-algif.conf
rmmod algif_aead 2>/dev/null || true
exit
More Information: CERT-EU - High Vulnerability in the Linux Kernel ("Copy Fail")
2026-04-06
udev-usb-sync and kernel 7.0-rc
If you experience slow transfers to USB attached disks, remove the package udev-usb-sync. It is not known why the 7.0-rc kernel causes this. There may be a regression of some sort. Awaiting the final release of the 7.0 kernel before jumping to conclusions.
See [Unstable Update] April 2026 thread for more info
2026-04-23T22:00:00Z
The issue is solved with the release of 7.0 kernel
Previous testing threads:
