Gnome 49 login screen is zoomed-in, how to scale it down?
After the Gnome 49 update my login screen & desktop were zoomed 130%.
I was able to change the overall system in settings > display > scale & set it back to 100%
But the login screen remains at 130%, how to correct that?
/usr/share/sddm theme didnt reveal any obvious settings to me.
The accessibility settings on the login screen only make it larger still.
EDIT: I should add that its only the login screen & not the lockscreen affected.
The only thing I can tell you is that looking for anything with the name sddm in it will be the wrong place.
Configuration takes place in /etc - in /etc/gdm/… in particular
because Gnome (by default) uses GDM as a display manager - not SDDM
unless you changed / replaced the default
SDDM is the default for Plasma
Tell us some useful information about your monitor(s); their resolutions; etc. If you’re using Nvidia graphics there is an issue with the 580xx drivers on some older systems using large screens, where the higher resolutions are no longer achievable. Installing the 575xx drivers apparently fixed that sor some, the 570xx drivers, for others.
Whether this is relevant to your issue, I can’t say.
Without knowing more details, any responses will likely be tentative, at best. Please provide your system information as described (below).
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
If running `inxi` within a `chroot` environment
Your privacy is respected
Thanks for the reply. Sorry I should have included inxi.
 inxi -zv8                                                        ✔
  Kernel: 6.6.119-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=e96747c7-79c2-4694-8b9d-282e184b02d1 rw quiet splash
    amd_iommu=off apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 20VF v: ThinkBook 14 G2 ARE
    serial: <superuser required> Chassis: type: 10 v: ThinkBook 14 G2 ARE
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20VF_BU_idea_FM_ThinkBook
    14 G2 ARE uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: FACN28WW(V1.11) date: 05/18/2021
  ID-1: BAT1 charge: 37.3 Wh (96.3%) condition: 38.7/45 Wh (86%) power: 8.3 W
    volts: 12.36 min: 11.52 model: 0x43 0x65 0x6C 0x78 0x70 0x72 0x74 0x00 0x32
    0x30 0x31 0x4C 0x31 0x39 0x43 0x33 0x50 0x44 0x41 type: Li-ion
    serial: <filter> charging: status: discharging cycles: 1082
  Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
    serial: <filter> charge: 50% (should be ignored) rechargeable: yes
    status: N/A
  System RAM: total: 24 GiB available: 19.4 GiB used: 5.57 GiB (28.7%)
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT16G4SFD832A.M16FRS serial: <filter>
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1G44AB0-CWE serial: N/A
  Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 2375 min/max: 1400/2375 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2375 2: 2375 3: 2375
    4: 2375 5: 2375 6: 2375 bogomips: 28463
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb
    ibpb_exit_to_user ibrs ibs irperf lahf_lm lbrv lm mba mca mce misalignsse
    mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save
    nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt
  Type: spec_rstack_overflow mitigation: SMT disabled
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1636
    class-ID: 0300 temp: 36.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:56ff
    class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2016 res: 1920x1080
    dpi: 158 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
    blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    renoir ACO DRM 3.54 6.6.119-1-MANJARO) device-ID: 1002:1636
    memory: 3.91 GiB unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo de: kscreen-doctor
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.119-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:4 chip-ID: 0bda:4852
  Report: btmgmt ID: hci0 rfk-id: 17 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 704.24 GiB used: 410.36 GiB (58.3%)
    model: MZALQ256HAJD-000L2 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: BL2QFXV7 temp: 30.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 032 scheme: MBR
  ID-1: / raw-size: 179.38 GiB size: 175.5 GiB (97.84%)
    used: 69.03 GiB (39.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: e96747c7-79c2-4694-8b9d-282e184b02d1
    used: 8.1 MiB (1.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: EB07-8818
  ID-3: /mnt/SSD500 raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 341.33 GiB (74.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: SSD500
    uuid: a1936d96-6ea6-4cb5-b62d-618a8ec8a2a8
  ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 58.59 GiB fs: ext4 label: N/A
    uuid: dc875819-9c07-4221-94c7-5994be185a1d
  Device-1: 1-3:2 info: IMC Networks Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56ff class-ID: 0e02
  Device-1: 3-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-3:18 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c4b class-ID: 0000
  Device-3: 3-4:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  System Temperatures: cpu: 37.2 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (rpm): N/A
  Packages: 2311 pm: pacman pkgs: 2291 libs: 564 tools: gnome-software,pamac
    pm: flatpak pkgs: 20
    1: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    2: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    3: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 316
  1: cpu: 100% command: ps pid: 311669 mem: 4.02 MiB (0.0%)
  2: cpu: 13.6% command: gnome-terminal-server pid: 311412
    mem: 60.2 MiB (0.3%)
  3: cpu: 7.2% command: firefox pid: 310295 mem: 355.3 MiB (1.7%)
  4: cpu: 6.3% command: gnome-shell pid: 2825 mem: 398.3 MiB (2.0%)
  5: cpu: 5.7% command: firefox pid: 259549 mem: 919.6 MiB (4.6%)
  Memory top: 5 of 316
  1: mem: 919.6 MiB (4.6%) command: firefox pid: 259549 cpu: 5.7%
  2: mem: 444.0 MiB (2.2%) command: firefox pid: 259949 cpu: 0.6%
  3: mem: 400.3 MiB (2.0%) command: Screenshot started-by: gimp-3.0
    pid: 266737 cpu: 0.0%
  4: mem: 398.3 MiB (2.0%) command: gnome-shell pid: 2825 cpu: 6.3%
  5: mem: 355.3 MiB (1.7%) command: firefox pid: 310295 cpu: 7.2%
  Processes: 316 Power: uptime: 1d 9h 47m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 14 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 7.75 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.40
Thank you for the system information, but you neglected to add requested detail concening your monitors.
Its an Lenovo laptop: Thinkbook 14 G2 AMD, built in display 1920x1080
OK, thanks. In that case the possible issue I referred to does not apply. It was related to the Nvidia 580xx driver and larger screen resolutions.
Thanks.
I checked this folder & the files in place all appear to be unedited default files.
Yes.
Perhaps there can be some configuration option applied that affects the scaling - but I don’t know about it.
To me there appears to be no reason for the scaling to have changed at all.
(it did not for me, for whatever that is worth)
I was just saying that sddm files where the wrong place to look at, because sddm is not the display manager here.
ok, thanks.
I have archcraft on another partition & that uses sddm, I really just didnt think too clearly about what gnome uses. But thanks for pointing that out.
The scaling isnt a huge issue (no pun intended) its just odd seeing the power menu & login box oversized.
The solution is to copy your user monitors.xml to the system.
cp ~/.config/monitors.xml /etc/xdg/monitors.xml
(see GDM - ArchWiki)
Its seems Gnome is intentionally forcing the login screen to 125%. But I cant say why it only affects some people, perhaps if you have no modified xdg/monitors.xml
