Manjaro 23 Randomly reboots or freezes
My new Asus Zephyrus G15 randomly reboots when locked and sometimes freezes during normal use previously my second NVME used to randomly disappear but that has been fixed with a bios update hopefully
I use Manjaro 23 KDE Kernel 6.5.5-1
My laptop is Asus ZEPHYRUS G15 with AMD CPU and NVIDIA GPU
The driver installed is vedio-hybrid-amd-nvidia-prime, video-linux, video-modset & video-vesa
with ROG-Control-Center
before that, I tried Bumblebee but it only showed NVIDIA driver, not the hybrid, and the problem hasn’t been affected
Although I tried Manjaro 22 before same issues
Please Help
Hi @zeph, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
ok
can anyone assist me with my issue?
you should remove this…
provide system info as instructed in mirdarthos post…
mhwd -l -d         āœ”
> PCI Device: /devices/pci0000:00/0000:00:01.1/0000:01:00.0 (0300:10de:2520)
  Display controller nVidia Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q]
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   INFO:        Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source amd driver.
   PRIORITY:    8
   FREEDRIVER:  false
   DEPENDS:     video-linux
   CONFLICTS:   video*nvidia*
   CLASSIDS:    0300 0302 0300
   VENDORIDS:   10de 1002
   ATTACHED:    PCI
   VERSION:     2018.05.04
   INFO:        Standard open source drivers.
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300 0380 0302
   VENDORIDS:   1002 8086 10de
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    8
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    7
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2023.03.23
   INFO:        Closed source NVIDIA drivers for linux.
   PRIORITY:    5
   FREEDRIVER:  false
   DEPENDS:     -
   CLASSIDS:    0300 0302
   VENDORIDS:   10de
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    4
   FREEDRIVER:  false
   DEPENDS:     -
   CLASSIDS:    0300 0302
   VENDORIDS:   10de
   ATTACHED:    PCI
   VERSION:     2018.05.04
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   ATTACHED:    PCI
   VERSION:     2020.01.13
   INFO:        X.org modesetting video driver.
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2017.03.12
   INFO:        X.org vesa video driver.
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
> PCI Device: /devices/pci0000:00/0000:00:08.1/0000:07:00.0 (0300:1002:1681)
  Display controller ATI Technologies Inc
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    8
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2018.05.04
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    8
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    7
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2018.05.04
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   ATTACHED:    PCI
   VERSION:     2020.01.13
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2017.03.12
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
Warning: no configs for USB devices found!
Please guide me on what more info you need exactly.
This at least:
inxi -Fazy
And maybe also this:
sudo dmesg | grep -i error
And I’m already thinking its maybe this:
https://wiki.archlinux.org/title/Ryzen#Random_reboots
and this:
https://wiki.archlinux.org/title/Ryzen#Soft_lock_freezing
He did:
Said post:
inxi --full --admin --filter --width                                                           āœ”
  Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=a1ce8ef0-89fe-4391-930e-d7de80c4b5fb rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503RM_GA503RM v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: GA503RM v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GA503RM.315 date: 07/31/2023
  ID-1: BAT1 charge: 79.3 Wh (99.0%) condition: 80.1/90.2 Wh (88.8%)
    volts: 17.1 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: AMD Ryzen 7 6800HS with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1389 high: 2755 min/max: 400/4785 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1534 2: 1504 3: 400
    4: 400 5: 2006 6: 1828 7: 400 8: 1639 9: 1406 10: 2004 11: 2246 12: 400
    13: 1685 14: 2755 15: 1620 16: 400 bogomips: 102243
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 ports: active: none empty: DP-9,HDMI-A-1,eDP-2
    bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
    v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8 bus-ID: 07:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 56.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:56eb
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
    compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
    unloaded: fbdev,modesetting,nouveau,radeon alternate: nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1540 built: 2020
    res: 2560x1440 hz: 165 dpi: 189 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.8-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
    16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:1681 memory: 500 MiB
    unified: no
  API: Vulkan v: 1.3.264 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: nvidia v: 535.113.01
    device-ID: 10de:2520 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV REMBRANDT) driver: mesa radv
    v: 23.1.8-manjaro1.1 device-ID: 1002:1681 surfaces: xcb,xlib
  Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
    bus-ID: 07:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.80 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0489:e0e2
  Local Storage: total: 2.75 TiB used: 957.89 GiB (34.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Western Digital model: WD PC
    SN735 SDBPNHH-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 70626000 temp: 54.9 C scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 53.9 C scheme: GPT
  ID-1: / raw-size: 290.6 GiB size: 284.98 GiB (98.06%)
    used: 103.12 GiB (36.2%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 610 MiB size: 608.8 MiB (99.80%)
    used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
  ID-1: swap-1 type: partition size: 9.98 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p3 maj-min: 259:3
  System Temperatures: cpu: 64.0 C mobo: N/A gpu: amdgpu temp: 58.0 C
  Fan Speeds (rpm): cpu: 1700
  Processes: 364 Uptime: 2h 35m wakeups: 9 Memory: total: 16 GiB note: est.
  available: 14.87 GiB used: 5.7 GiB (38.4%) Init: systemd v: 254
  Packages: 1586 pm: pacman pkgs: 1542 libs: 487 tools: pamac,yay pm: flatpak
  pkgs: 44 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.30
is that ok?
It’s still not everything asked:
Start reading, friend. You’ll find people much more willing to help, if you do your part. If, for whatever reason, you have difficulty doing so, explain that. People willing to help are also usually more understanding than not.
Edit:
Work through this thread:
Considering you also have an AMD CPU, it might be related, if not the same thing.
I applied your suggestion by ā€œdisabling C6ā€ and it will take a couple of days of testing to confirm if there are no more crashes.
But anyway thank you for being patient with me and my ignorance of community roles.
You’re welcome!
I suspect you mean rules, not roles. And ignorance can be rectified with education, a willingness to learn, not thinking you know everything and everyone is supposed to bow to your will. So these should help:
Yeah ā€œrulesā€ is my mistake, but ā€œeveryone is supposed to bow to your willā€ Is that a sarcastic way of telling me to read the rules?
Nope, but if the shoe fits…
:stuck_out_tongue_winking_eye:
I meant that that is the attitude by some people, whether online or IRL. They are just entitled.
@zeph
hi, are you still using Manjaro on your Zephyrus?
You post is the most recent one I have found and I am considering to try Manjaro as well but have questions about external monitor(s).
