Hi, having issues with kodi locking up. Have an APU 4750g and was working then stopped. Cannot find much in the logs. Known issue? I used store and snap images, both had the same reaction.
Hi @Filipe, and welcome!
Please see [HowTo] Provide System Information, this [HowTo] post screenshots and links and finally, [HowTo] Increase your chances of solving your issue.
How did you install Kodi? Because, itâs in the community repository:
$ pamac search kodi
kodi 19.3-2 community
A software media player and entertainment hub for digital media
So can,theoretically, be installed using:
pamac install kodi
Hope you come right!
hi, thanks for the reply! Packages (1) kodi-19.3-2
using pacman same issue.
~]$ uname -r
5.15.12-1-MANJARO
~]$ amdgpu_device_initialize: amdgpu_query_info(ACCEL_WORKING) failed (-13)
amdgpu: amdgpu_device_initialize failed.
Canât load /etc/samba/smb.conf - run testparm to debug it
might help
The Arch Wiki on Samba:
Samba is configured in the
/etc/samba/smb.confconfiguration file, which is extensively documented in smb.conf(5).
Because the samba package does not provide this file, one needs to create it before starting smb.service.
A documented example as in
smb.conf.defaultfrom the Samba git repository may be used to setup/etc/samba/smb.conf.
done, many thanks, but still crashes
@Filipe when you say it crashes, what exactly happens, is it just frozen when you start and does essentially nothing?
When you start kodi from the commandline, is there an error message that you see? Did you experience the same issues before running the latest updates to python?
I donât want to be misleading, but with the upgrade to python 3.10 a lot of the scripts running in Kodi have been experiencing some issues. In my case i was getting the frozen screen upon starting Kodi, but please post what you are seeing.
ok will upgrade and see ⌠the CLI output is above GPU failure on init
media ~]$ python --version
Python 3.10.1
@filipe for me the problems started with the upgrade. I have reinstalled Kodi and run it in its unmodified form. That includes the baseskin.
Hi, thanks again for helping, but unfortunately that did not work. It opens and then just locks, doesnât allow any mouse movement, only alt tab. But the app is completely untouchable.
this is pure install, no addons etc ⌠last version in the pkg mgr
Can you install earlier versions on Manjaro
error log tail
2022-01-19 01:06:01.759 T:7648 ERROR : Exception ignored deletion of interned string failed
2022-01-19 01:06:01.759 T:7648 ERROR : :
2022-01-19 01:06:01.759 T:7648 ERROR : Traceback (most recent call last):
2022-01-19 01:06:01.759 T:7648 ERROR : File â/usr/lib/python3.10/sqlite3/dbapi2.pyâ, line 83, in register_adapters_and_converters
2022-01-19 01:06:01.771 T:7648 ERROR :
2022-01-19 01:06:01.771 T:7648 ERROR : register_converter(âtimestampâ, convert_timestamp)
2022-01-19 01:06:01.772 T:7648 ERROR : KeyError
2022-01-19 01:06:01.772 T:7648 ERROR : :
2022-01-19 01:06:01.772 T:7648 ERROR : âtimepart_fullâ
for me downgrading to python 3.10.0 solves the problem
will try it thanks!!
That worked perfectly. Thank you @psifi !! Also lined in pacman.conf as well until the update fixes. Owe you a coffee as now my kids are happy.
