KMail and KOrganiser issue after last update
Currently I’m facing problem with Kmail and kOrganizer.
org.kde.pim.akonadiserver: database server stopped unexpectedly
Please read this:
Especially these bits:
Also,
  1. Please read this:
    [HowTo] Provide System Information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:pray:
seems that you have to reinstall / reconfigure mariadb-server. That should be the solution I think…
is there an output for sudo systemctl status mysqld ?
○ mariadb.service - MariaDB 10.6.4 database server
    Loaded: loaded (/usr/lib/systemd/system/mariadb.service; disabled; vendor preset>
    Active: inactive (dead)
      Docs: man:mariadbd(8)
            https://mariadb.com/kb/en/library/systemd/
what gives you:
`sudo systemctl start mysqld`   ?
● mariadb.service - MariaDB 10.6.4 database server
     Active: active (running) since Tue 2021-09-07 17:12:46 IST; 16s ago
    Process: 167381 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_>
    Process: 167382 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR=>
    Process: 167405 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START>
   Main PID: 167390 (mariadbd)
     Status: "Taking your SQL requests now..."
      Tasks: 14 (limit: 9413)
     Memory: 60.1M
        CPU: 215ms
     CGroup: /system.slice/mariadb.service
             └─167390 /usr/bin/mariadbd
Sep 07 17:12:46 mozammel-tm1703 mariadbd[167390]: 2021-09-07 17:12:46 0 [Note] InnoDB>
Sep 07 17:12:46 mozammel-tm1703 mariadbd[167390]: 2021-09-07 17:12:46 0 [Note] Server>
Sep 07 17:12:46 mozammel-tm1703 mariadbd[167390]: 2021-09-07 17:12:46 0 [ERROR] Incor>
Sep 07 17:12:46 mozammel-tm1703 mariadbd[167390]: 2021-09-07 17:12:46 0 [ERROR] maria>
Sep 07 17:12:46 mozammel-tm1703 mariadbd[167390]: 2021-09-07 17:12:46 0 [Note] /usr/b>
Sep 07 17:12:46 mozammel-tm1703 mariadbd[167390]: Version: '10.6.4-MariaDB'  socket: >
Sep 07 17:12:46 mozammel-tm1703 systemd[1]: Started MariaDB 10.6.4 database server.
akonadictl start                                               ✔  41s 
org.kde.pim.akonadictl: Starting Akonadi Server...
org.kde.pim.akonadictl:    done.
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
org.kde.pim.akonadiserver: Starting up the Akonadi Server...
    ~  org.kde.pim.akonadiserver: mysqld for Akonadi is already running, trying to connect to it.
/usr/bin/mysqlcheck: Error: Couldn't get table list for database akonadi: Unknown database 'akonadi'
org.kde.pim.akonadiserver: Running DB initializer
org.kde.pim.akonadiserver: "\nSql error: Table 'schemaversiontable' already exists QMYSQL: Unable to execute query\nQuery: CREATE TABLE SchemaVersionTable (version INTEGER NOT NULL DEFAULT 0, generation INTEGER NOT NULL DEFAULT 0)  COLLATE=utf8_general_ci DEFAULT CHARSET=utf8"
org.kde.pim.akonadiserver: Unable to initialize database.
org.kde.pim.akonadiserver: Shutting down AkonadiServer...
org.kd
inxi --admin --verbosity=7 --filter --no-host --width                  ✔
  Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=42f2d665-4fe3-47ac-9fb4-d0db0d09b485 ro quiet apparmor=1
  security=apparmor resume=UUID=a2d2d02d-f2b3-4b08-896e-d59b388058e7
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Timi product: TM1703 v: XMAKB3M0P120C serial: <filter>
  Mobo: Timi model: TM1703 v: XMAKB3M0P120C serial: <filter> UEFI: Insyde
  v: XMAKB3M0P120C date: 07/10/2018
  ID-1: BAT0 charge: 22.9 Wh (100.0%) condition: 22.9/40.1 Wh (57.0%)
  volts: 8.4 min: 7.6 model: SUNWODA R13B02W type: Li-ion serial: <filter>
  status: Not charging
  RAM: total: 7.68 GiB used: 5.11 GiB (66.6%)
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: EA cache: L2: 6 MiB bogomips: 28808
  Speed: 1600 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 1600 2: 1600
  3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Xiaomi driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX150] vendor: Xiaomi driver: nvidia
  v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1d12 class-ID: 0302
  Device-3: Chicony XiaoMi USB 2.0 Webcam type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 04f2:b5a3 class-ID: 0e02
  loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 115 s-size: 424x238mm (16.7x9.4")
  s-diag: 486mm (19.1")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 166 size: 294x165mm (11.6x6.5")
  diag: 337mm (13.3")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.34 running: yes
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000
  bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  bus-ID: 1-7:5 chip-ID: 8087:0a2b class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
  Local Storage: total: 704.24 GiB used: 420.94 GiB (59.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW256HEHP-00000
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: CXB7401Q temp: 35.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
  logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 90WD
  scheme: GPT
  ID-1: / raw-size: 229.37 GiB size: 224.77 GiB (97.99%)
  used: 194.42 GiB (86.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: 42f2d665-4fe3-47ac-9fb4-d0db0d09b485
  ID-2: /StringD raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
  used: 226.32 GiB (49.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: StringD
  uuid: 45e0d749-9089-42ab-84c2-d8f95fb475e0
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
  uuid: 753C-7A0A
  ID-1: swap-1 type: partition size: 8.8 GiB used: 207.1 MiB (2.3%)
  priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
  uuid: a2d2d02d-f2b3-4b08-896e-d59b388058e7
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-1:2 info: MOSART Semi. 2.4G RF Keyboard & Mouse
  type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 12 Mb/s power: 100mA chip-ID: 3938:1032 class-ID: 0301
  Device-2: 1-5:3 info: Chicony XiaoMi USB 2.0 Webcam type: Video
  Device-3: 1-6:4 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 04f3:0c1a class-ID: 0000
  Device-4: 1-7:5 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 45.0 C mobo: 37.0 C
  Processes: 281 Uptime: 1d 21h 51m wakeups: 20 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1627 apt: 1
  pacman: 1626 lib: 416 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
try to reinstall those packages
extra/akonadi 21.08.1-1 [installed]
    PIM layer, which provides an asynchronous API to access all kind of PIM data
extra/akonadi-calendar 21.08.1-1 [installed]
    Akonadi calendar integration
extra/akonadi-calendar-tools 21.08.1-1 (kde-applications kdepim) [installed]
    CLI tools to manage akonadi calendars
extra/akonadi-contacts 21.08.1-1 [installed]
    Libraries and daemons to implement Contact Management in Akonadi
extra/akonadi-import-wizard 21.08.1-1 (kde-applications kdepim) [installed]
    Import data from other mail clients to KMail
extra/akonadi-mime 21.08.1-1 [installed]
    Libraries and daemons to implement basic email handling
extra/akonadi-notes 21.08.1-1 [installed]
    Libraries and daemons to implement management of notes in Akonadi
extra/akonadi-search 21.08.1-1 [installed]
    Libraries and daemons to implement searching in Akonadi
extra/akonadiconsole 21.08.1-1 (kde-applications kdepim) [installed]
    Akonadi management and debugging console
extra/libakonadi 21.08.1-1 [installed]
    Libraries used by applications based on Akonadi
that means:
akonadi, akonadi-calendar, akonadi-calendar-tools, akonadi-contacts, akonadi-mime, akonadi-notes, akonadi-search, akonadikonsole, libakonadi
and also then:
systemctl enable mysqld
Very same output after reinstall all the package you said.
    ~  akonadictl start                                                       ✔
    ~  org.kde.pim.akonadiserver: database server stopped unexpectedly        ✔
org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
org.kde.pim.akonadiserver: arguments: ("--defaults-file=/home/mozammel/.local/share/akonadi/mysql.conf", "--datadir=/home/mozammel/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
org.kde.pim.akonadiserver: stdout: ""
org.kde.pim.akonadiserver: stderr: "2021-09-07 20:37:25 0 [Note] /usr/bin/mysqld (server 10.6.4-MariaDB) starting as process 3134 ...\n"
org.kde.pim.akonadiserver: exit code: 1
org.kde.pim.akonadiserver: process error: "Unknown error"
org.kde.pim.akonadicontrol: Application '/usr/bin/akonadiserver' exited normally...
sudo aa-complain /usr/bin/akonadiserver
if I remember correctly, some months back when I had similar issue, I found this commend and it worked
but now it didn’t work. same result as before
org.kde.pim.akonadiserver: stderr: "2021-09-07 21:17:08 0 [Note] /usr/bin/mysqld (server 10.6.4-MariaDB) starting as process 3312 ...\n"
try:
sudo aa-enforce /usr/bin/akonadiserver
very same result. still not working.
 sudo aa-status                                                     INT ✘
[sudo] password for mozammel:
apparmor module is loaded.
9 profiles are loaded.
9 profiles are in enforce mode.
   dovecot-script-login
   lsb_release
   mariadbd_akonadi
   mysqld_akonadi
   nvidia_modprobe
   nvidia_modprobe//kmod
   php-fpm
   postgresql_akonadi
0 profiles are in complain mode.
0 profiles are in kill mode.
0 profiles are in unconfined mode.
0 processes have profiles defined.
0 processes are in enforce mode.
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
0 processes are in mixed mode.
0 processes are in kill mode.
but mysqld is running well ?
yes, mysql is running fine, also mariadb running fine.
I think akonadi uses mariadb.
mariadb and mysqld are the same thing …
yes. right.
 sudo systemctl status mariadb         ✔
     Loaded: loaded (/usr/lib/systemd/system/mariadb.service; disabled; vendor preset: disabled)
     Active: active (running) since Tue 2021-09-07 21:13:38 IST; 35min ago
   Main PID: 508 (mariadbd)
      Tasks: 8 (limit: 9413)
     Memory: 81.0M
        CPU: 547ms
             └─508 /usr/bin/mariadbd
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [Note] InnoDB: 10.6.4 started; log sequence number 45166>
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysq>
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [Note] InnoDB: Buffer pool(s) load completed at 210907 2>
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [Note] Server socket created on IP: '0.0.0.0'.
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [Note] Server socket created on IP: '::'.
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [ERROR] Incorrect definition of table mysql.event: expec>
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [ERROR] mariadbd: Event Scheduler: An error occurred whe>
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: 2021-09-07 21:13:38 0 [Note] /usr/bin/mariadbd: ready for connections.
Sep 07 21:13:38 mozammel-tm1703 mariadbd[508]: Version: '10.6.4-MariaDB'  socket: '/run/mysqld/mysqld.sock'  port: 3306  Arch>
Sep 07 21:13:38 mozammel-tm1703 systemd[1]: Started MariaDB 10.6.4 database server.
there is 2 error I don’t understand those error.
could you restart akonadi service once ?
