KMail and KOrganiser issue after last update
$akonadictl restart         ✔
Akonadi is not running.
$akonadictl start         4 ✘
org.kde.pim.akonadictl: Starting Akonadi Server...
org.kde.pim.akonadictl:    done.
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
org.kde.pim.akonadiserver: Starting up the Akonadi Server...
$org.kde.pim.akonadiserver: database server stopped unexpectedly                                                ✔
org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
org.kde.pim.akonadiserver: arguments: ("--defaults-file=/home/mozammel/.local/share/akonadi/mysql.conf", "--datadir=/home/mozammel/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
org.kde.pim.akonadiserver: stdout: ""
org.kde.pim.akonadiserver: stderr: "2021-09-07 21:51:23 0 [Note] /usr/bin/mysqld (server 10.6.4-MariaDB) starting as process 11705 ...\n"
org.kde.pim.akonadiserver: exit code: 1
org.kde.pim.akonadiserver: process error: "Unknown error"
org.kde.pim.akonadiserver: Shutting down AkonadiServer...
org.kde.pim.akonadicontrol: Application '/usr/bin/akonadiserver' exited normally...
oh thats is bad, could we try
sudo mariadb-upgrade
what does it say? … if positive then restart computer…
sudo mariadb-upgrade         INT ✘
[sudo] password for mozammel:
Sorry, try again.
Phase 1/7: Checking and upgrading mysql database
Processing databases
mysql
mysql.column_stats                                 OK
mysql.columns_priv                                 OK
mysql.db                                           OK
mysql.event                                        OK
mysql.func                                         OK
mysql.global_priv                                  OK
mysql.gtid_slave_pos                               OK
mysql.help_category                                OK
mysql.help_keyword                                 OK
mysql.help_relation                                OK
mysql.help_topic                                   OK
mysql.index_stats                                  OK
mysql.innodb_index_stats                           OK
mysql.innodb_table_stats                           OK
mysql.plugin                                       OK
mysql.proc                                         OK
mysql.procs_priv                                   OK
mysql.proxies_priv                                 OK
mysql.roles_mapping                                OK
mysql.servers                                      OK
mysql.table_stats                                  OK
mysql.tables_priv                                  OK
mysql.time_zone                                    OK
mysql.time_zone_leap_second                        OK
mysql.time_zone_name                               OK
mysql.time_zone_transition                         OK
mysql.time_zone_transition_type                    OK
mysql.transaction_registry                         OK
Phase 2/7: Installing used storage engines... Skipped
Phase 3/7: Fixing views
mysql.user                                         OK
Phase 4/7: Running 'mysql_fix_privilege_tables'
Phase 5/7: Fixing table and database names
Phase 6/7: Checking and upgrading tables
information_schema
performance_schema
sys
sys.sys_config                                     OK
Phase 7/7: Running 'FLUSH PRIVILEGES'
OK
but still issue not fixed
 akonadictl start                                                       ✔
    ~  org.kde.pim.akonadiserver: database server stopped unexpectedly        ✔
org.kde.pim.akonadiserver: stderr: "2021-09-07 22:18:44 0 [Note] /usr/bin/mysqld (server 10.6.4-MariaDB) starting as process 1902 ...\n"
did you restart the pc ?
Yes I did restart.
could also try: delete
/home/<your home name>/.local/share/akonadi/mysql.conf
wow… it worked. thank you so much.
youhoooo , glad it worked :grinning:
