After disabling the floating taskbar, it looks 99.1% the same, without the Wayland bugs.
Everything works well! No Plasma 6 yet though? Hopefully weâll be seeing that in the next one.
Plasma 6 is not even stable on Arch yet. But itâs good idea to wait for couple rounds of fixes.
Oh, if there are stability issues thatâs good then. Plasma 6 was just officially released: I was under the impression a final release thatâs no longer RC / Beta should always be stable with all major issues having been found.
Stability (=wonât crash essentially) and stable (=development goals reached) release are not same thing. Stable here points to repository. 6.0.1 is currently in Arch testing repo. It wonât be in Manjaro Stable repo until it reaches Arch Stable repo. While Plasma 6 was released as stable release by KDE, it wonât get adapted to various Linux distro repositories automatically. Distro has to maintain configurations and other relevant settings and compatibility with other packages, fit to release cycle and update policies etc. So itâs much bigger release in that sense than just KDE pushing it out.
Suppose it will take a while to get everything working as it should.
Maybe weâll see it soon(ish) in unstable
as arch just pushed 6.0.1
to extra
Btw: 5.27.11
is out as well:
Well kde 6 in the Arch repository has been updated to version 6.0.1 and moved from the extra-testing repository to extra.
@freggel.doe I canât view this link, is there something important there ?
I did not realize it was leading to a post in Member Hub (not available for all users).
Iâve edited my post to repost the content.
Yes indeed. Thatâs why I installed Timeshift on my main home desktop PC. I have a 1TB SSD taped to the side of my computer and plugged into a rear USB jack, and Timeshift set to backup the OS and all hidden contents of â/home/mainuserâ (but not the visible contents, which would bloat backup size from about 10GB to about 2TB), once every 2 weeks.
Why 2 weeks? Because it sometimes takes deeply-embedded Plasma bugs that long to manifest. So if I do a Plasma update, and 10 days later I find that that Plasma version is broken, I can time-shift back to a few days before the update.
That being said, I love Plasma, in spite of the occasional insects.
Wooh, 6.0.1 has just arrived for me! Now for some serious testingâŚ
Yup, wasnt even paying attention.
Suppose I should turn everything to breeze first.
(PS: for qt6-multimedia
I went for ffmpeg
. Kuz I know someone will ask)
Update:
- As expected some themes and extensions/plasmoids arent compatible 100%, or at all.
- Also as expected it defaults to wayland, which I wont be testing for now. X11 still selectable and seems to work.
- And as was mentioned
kglobalaccel
is discontinued. So if you set shortcuts using that then you must set them again. - Seems some icon canonical names have been moved around. So, for example, if you set âplasma-symbolicâ as the icon for your application menu, it may be a different icon now.
- Scaling seems ⌠different. Panel set to 44 pixels on plasma 5, looks a lot larger now, as do icons etc.
- Lots of menu layout changes and extra options in places ⌠maybe most notably is the floating panel, which can be disabled.
- X11 session seems to have a slight regression in that windows, when dragged, âstutterâ in rendering. This seems an entirely visual glitch that ceases when you stop dragging.
- Panel has a visual glitch on ~half the sizes that results in a small line on the far right side.
(I had to find a size that was roughly desirable, didnt produce the glitch, and resulted in âsmoothlyâ rendered icons ⌠which took a little fiddling)
Extra notes ⌠I did switch to breeze Global theme and also did for good measure
rm ~/.config/Trolltech.conf && kbuildsycoca5 --noincremental
Before rebooting.
Then started reapplying things like color.
It seems mostly fine.
[old image]
The qqc2-breeze-style package remains old and is trying to rollback to 5.27.9-1 otherwise no change from arch-testing.
Test with new user.
I tested Plasma 6 Wayland on my other device and fixed some issues manually.
A white cursor is invisible because its official âBreeze_Snowâ cursor theme was removed by Plasma 6. No, but it has been changed to the new name âBreeze_Lightâ.
[Fixed] You can reset a selected official cursor theme in KDE Setting.
GTK cursor does not take this QT6 cursor design
[Fixed] For example I want the theme Breeze_Light:
$ gsettings set org.gnome.desktop.interface cursor-theme Breeze_Light
GTK cursor size does not respect HiDPI scaling (display resolution: 2880 x 1800, scaling: 150%) when touching some GTK apps.
[Fixed] Move two folders
~/.config/gtk-3.0
and~/.config/gtk-4.0
including wrong configs to backup -
Some Electron apps donât respect QT6 Wayland HiDPI scaling
[Fixed] When using version 27 of electron, edit
~/.config/electron27-flags.conf
to add:
--enable-features=WaylandWindowDecorations
--ozone-platform-hint=auto
- Some appimages, for example Joplin, do not respect HiDPI scaling again.
[Fixed] Edit
~/.local/share/applications/appimagekit-joplin.desktop
to change
Exec=/$HOME/.joplin/Joplin.AppImage %u
to
Exec=env DESKTOPINTEGRATION=0 APPIMAGELAUNCHER_DISABLE=1 /$HOME/.joplin/Joplin.AppImage %u
- Some GTK apps in Flatpak do not respect your theme.
[Fixed]
All SDDM icons (Login, Shutdown, Reboot) are invisible
[Fixed] Go SDDM setting â Apply Plasma Settings â Reset to Default Settings
Konsole breaks nerd-fonts-symbols, but other terminals have no issue.
The known issue: 478549 â Nerd fonts are not rendered on plasma 6 when using detached font
[Trick] : Install some nerds-fonts packages for example:
ttf-hack-nerd
, then make Hack Nerd Font" as default font in your profile of Konsole -
Some icons are missing in the KDE pane
[Fixed] Use default icons âBreezeâ instead of custom icons
QT5 apps for example
octopi
does not respect QT6 theme.
[Fixed] [Unstable Update] March 2024 Edition - #84 by medmedin
I use dual monitors, but the display setting only shows one monitor (Maybe bug)
[Fixed] Go Display setting â Set Replica to âNoneâ then change any resolution to fix this issue.
The SDDM screen does not scale by a factor 1,5 and does not follow KDE display setting
[Fixed] You need to manually edit
/etc/sddm.conf.d/kde_settings.conf
to add
[General]
GreeterEnvironment=QT_SCREEN_SCALE_FACTORS=1.5
- SDDMâs cursor does not respect the SDDM setting
withCursorTheme=Breeze_Light
[Fixed] Edit
/usr/share/icons/default/index.theme
to change your cursor theme
[Icon Theme]
Inherits=Breeze_Light
If you want to change the cursor size for SDDM, edit /etc/sddm.conf.d/kde_settings.conf
[Theme]
Current=breeze
CursorSize=24
Everything else is fine.
PS: I noticed that some bugs of Plasma 5 have been fixed by Plasma 6
These settings may be irrelevant for a number of things.
https://wiki.archlinux.org/title/GTK#Wayland_backend
https://wiki.archlinux.org/title/Cursor_themes#GNOME
In whatever case you should make sure to have xdg-desktop-portal-gtk
installed.
Along with that you might want to set your portal preference.
~/.config/xdg-desktop-portal/portals.conf
[preferred]
# Use xdg-desktop-portal-kde for every portal interface; fallback to gtk; then any
default=kde;gtk;*
However, if I removed this config settings.ini
, your suggestion has no effect on Plasma 6 Wayland.
I run
That works.
First link
Second link
The portal on its own doesnt set the theme or anything ⌠but without that package some theming wont be sourced properly.
And since you have that portal installed (gtk
we might assume is at least second in addition to portal-kde
) you probably want to set the preferential order (using the config above).
PS.
I wasnt suggesting remove the ini config. Just that it on its own would not be enough.
PPS.
I did. Window stuttering remained.
I have able to move to permanently move to wayland though. With the help of installing xdg-desktop-portal-gtk
as noted above. Where none(*?) of those issues are present.
could be iâve spoken too soon. bit the bullet updated to plasma 6 and iâm left wondering why i hesitated so much. thought of this as a exercise finally leaping to wayland bandwagon, and voila everything looks good (as not expected). then to those habits only meant for X11 logged out and logged in to X11 session and everything seems very workable with no issues either. a very few settings app sub sections did crash but ran into no show stoppers whatsoever. logs do indicate plasma-xdg-desktop-portal-kde.service did crash, but seems to be up and running when i did check.
I just downloaded the packages and logged out and updated only in TTY. also made sure to get rid of all old plasmoids, .cache directory, and the aforementioned ~/.config/Trolltech.conf
and ran kbuildsycoca5 --noincremental also in TTY.
just because i got lucky(tentatively) does not mean everyone else should not heed the obvious troubles you might run into here. nevertheless, i think we ought to have bit more optimism here.
But why would you hide such information behind a Trust Level?
