Japanese input using Japanese keyboard
Hello,
 I installed a physical japanese keyboard (google x220 jp keyboard, I can't embed images yet) to my x220 thinkpad. I can't seem to find a way to get the japanese portion working. I've tried different combinations of models and key layouts in the keyboard settings section, but all to no avail. I know it works because I had it working on windows before installing Manjaro a few days ago. Please aid me!
Thank you
sorry it turned out like this… its my first post… idek what i did to make it like this.
here it is again hoping its readable.
I installed a physical japanese keyboard (google x220 jp keyboard, I can’t embed images yet) to my x220 thinkpad.
I can’t seem to find a way to get the japanese portion working. I’ve tried different combinations of models and key layouts in the keyboard settings section, but all to no avail.
Please aid me!
That google x220 jp keyboard works on Windows10 while not working on Manjaro? Is that right?
You need to install a japanese input method: Localization/Japanese - ArchWiki
(I use fcitx5-anthy, but other input methods should also work.)
If you do use fcitx5, you may need to run fcitx5-diagnose and follow the instructions for your system environments.
I have a Japanese laptop & run Manjaro Gnome & frequently use both langs. Fcitx5 Mozc is the best way to go.
  • In Settings set your KB input source to Japanese. This ensures the printed symbols such as @ will be on the correct keys when you are using English.
  • Open Add/Remove Software & search for ‘fcitx5’ & Install the following 6 items
    • manjaro-asian-input-support-fcitx5
    • fcitx5
    • fcitx5-gtk
    • fcitx5-qt
    • fcitx5-mozc
    • fcitx5-configtool
  • In your Apps > System Tools open the Fcitx5 Configuration Tool.
    & Set your Inputs to:
    • Keyboard - Japanese
    • Mozc
You can now use the Zenkaku key 半角/全角 (under esc) to change between hiragana & english.
Muhenkan 無変換 to change to Katakana. & in the settings you can set up the other kana keys as you require.
Screenshot from 2022-04-04 22-37-48
Screenshot from 2022-04-04 22-39-42
