I use fcitx5 for non-english typing. I’ve recently been trying to configure typing in Chinese but can’t get it to work. I’ve installed fcitx5-chinese-addons
and manjaro-asian-input-support-fcitx5
, restarted fcitx5, rebooted my computer, but the input method still doesn’t work. The only options available as input methods are “Keyboard - Chinese - Hanyu Pinyin Letters (with AltGr dead keys)” and “Keyboard - Chinese”, and neither of them does anything. Hitting the tab
key doesn’t do anything, no candidates pop up like with the Anthy ime for Japanese. I already have the environment variables for fcitx5 configured in /etc/environment, and I’ve looked at this post and this post. Is there anything else I’m missing somewhere?
Output of inxi --admin --verbosity=7 --filter --width
for completion
Kernel: 6.0.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=cf856565-20e8-404d-976d-30eef73ffa46 ro quiet
cryptdevice=UUID=ad957ad3-a762-471e-9704-84521a7824bf:luks-ad957ad3-a762-471e-9704-84521a7824bf
root=/dev/mapper/luks-ad957ad3-a762-471e-9704-84521a7824bf
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 3260EDU v: ThinkPad Edge E535
Mobo: LENOVO model: 3260EDU v: Win8 Pro DPK TPG
serial: <superuser required> UEFI-[Legacy]: LENOVO v: HHET75WW (2.08 )
date: 10/24/2012
ID-1: BAT0 charge: 32.8 Wh (97.9%) condition: 33.5/40.4 Wh (83.0%)
volts: 12.1 min: 10.8 model: LGC 45N1049 type: Li-ion serial: <filter>
status: not charging
RAM: total: 7.19 GiB used: 2.17 GiB (30.2%)
Info: model: AMD A4-4300M APU with Radeon HD Graphics bits: 64 type: MT MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 0x10 (16) stepping: 1 microcode: 0x6001119
Topology: cpus: 1x cores: 2 smt: enabled cache: L1: 96 KiB
desc: d-2x16 KiB; i-1x64 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 1950 high: 2500 min/max: 1400/2500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2500 2: 1400
bogomips: 9985
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Trinity 2 [Radeon HD 7420G] vendor: Lenovo driver: radeon
v: kernel alternate: amdgpu arch: TeraScale-3 code: Northern Islands
process: TSMC 32nm built: 2010-13 ports: active: LVDS-1
empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9992 class-ID: 0300
Device-2: Acer ThinkPad Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 5986:02d2 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_x11 driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS model: LG Display 0x033b built: 2011
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: OpenGL v: 4.3 Mesa 22.2.1 renderer: AMD ARUBA (DRM 2.50.0 /
6.0.6-1-MANJARO LLVM 14.0.6) compat-v: 3.1 direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound API: ALSA v: k6.0.6-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
vendor: Lenovo driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 02:00.0
chip-ID: 10ec:8176 class-ID: 0280
Device-1: luks-ad957ad3-a762-471e-9704-84521a7824bf maj-min: 254:0
type: LUKS dm: dm-0 size: 192.15 GiB
Components:
p-1: sda3 maj-min: 8:3 size: 192.15 GiB
Local Storage: total: 465.76 GiB used: 269.07 GiB (57.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPLX-00ZNTT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT80N rev: LN81
dev-links: cdrom
ID-1: / raw-size: 192.15 GiB size: 188.07 GiB (97.88%)
used: 118.85 GiB (63.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ad957ad3-a762-471e-9704-84521a7824bf label: N/A
uuid: cf856565-20e8-404d-976d-30eef73ffa46
ID-2: /data raw-size: 269.7 GiB size: 264.41 GiB (98.04%)
used: 150.22 GiB (56.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Data
uuid: 2bef8829-c06e-4bcf-9e4f-4a63554f8307
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0b002722-c7d8-4840-aaa2-a1c298346124
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Device-1: 2-2:2 info: Acer ThinkPad Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
Hub-3: 3-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-1:2 info: Areson Corp 2.4G Wireless Receiver
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 25a7:fa10 class-ID: 0301
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-7: 7-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 7-1:2 info: A4Tech 2.4G Wireless Device type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 09da:0024 class-ID: 0301
Hub-8: 8-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 43.2 C mobo: N/A gpu: radeon temp: 43.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 170 Uptime: 34m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1392
pm: pacman pkgs: 1368 libs: 380 tools: pamac,yay pm: flatpak pkgs: 24
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.23
