The screenshot shows my RAM usage after I just booted up. Now I am by no means short on RAM (I have 32 GB), but I’d like to know what’s taking up the extra RAM. 680MB to 1.1GB is quite a big difference.
While I don’t use Xfce, so would know for sure, if you take into consideration that there was quite a big update for Xfce not long ago, it does make sense.
Thanks for your reply. So is disk caching a fairly recent thing? Like it’s been implemented via the recent update? I mean it doesn’t make sense if it’s been around for a long time? Coz my ram usage was 680mb not too long ago.
“I’ve got 32GB of RAM, and barely any of it is being used? I’m being ripped off!”
Like @Hanzel said, the more RAM that can be used, the better for system performance. Especially for re-launching applications and caching data.
To put it into perspective, observe the difference in performance with a SMB share between,
Option #1: cache=none
Option #2: cache=loose
The first option will yield noticeable delays and slowdowns when frequently accessing files or reading large compressed archives. The second option will yield performance akin to accessing a locally attached drive, simply because its holding the data in cache (RAM) and doesn’t require constantly pulling data from the source.
First of all, I suppose I should rephrase my question? When I say “ram usage” I was referring to the number I read from htop. Typically when I ran htop right after I boot, the “Mem” meter showed 680MB/31.2G
It was only fairly recently that the 680MB became 1.1 GB, and I was just wondering about the change.
I wasn’t being technical when I implore people to mentally “reframe” the question / concern in their minds.
Old paradigms don’t always fit well into modern times. In the past it was all about squeezing down every last bit of RAM “usage” due to the smaller breathing room our systems had; lower hardware resources and capacities.
Now it’s different. As the performance-to-price ratio continues to rise, it’s a matter of using your hardware, RAM included.
“More sophisticated applications? More complex themes? Greater modularity? Caching data for near-instant access? Lessening the burden on non-volatile storage? Let’s use everything we’ve got!”
Otherwise, what’s the point in having 32GB of RAM on your personal computer, if it’s not even being used?
What’s the point of using a top-tier CPU with the highest benchmarks, if all you do is browse the web and check email, and constantly monitor your CPU temps to keep it as low as possible?
Look at games, web browsers, operating systems, and software in general. They require more disk space since they are larger in size than their predecessors. Hence, more to load up into RAM.
You’re sure this trend doesn’t have more to do with cheap/lazy development (not that I’m calling the XFCE devs lazy, but more big tech and the games industry) because there is an expectation for a fast SSD, fast and lots of empty RAM and a new generation fast CPU and to use those resources frivolously?
It’s all well and good if you have a new computer but my 8GB 1333Mhz DDR2 RAM is really starting to be come nowhere near suitable for running exactly the same stuff it ran 7 years ago.
If I play Dota 2 and open Firefox or Signal (or any other electron app) my system has to aggressively swap from ram and if I’m not careful my whole system can become quickly unusable.
Hello, no it’s not just you, thanks for posting I was wondering where to post then found this thread. I have been religiously running HTOP after every reboot for about a year now then keeping it open to monitor, my ram usage jumped exactly after the last stable update. No other changes. Previously it would always start fresh around 600MB (or I now gather it’s actually MiB,
it now starts at 1000+. This is my long-running messed with home XFCE system, I have a barely touched backup/road XFCE system that went from 500+ to 700+, again right after the last stable update.
I too am a beginner and will be studying this thread, from reading I understand that this may not be a ‘problem’ (I have 32MB of ram as well, 8MB on my backup) but just wanted to post because it definitely presented itself right after the last stable update (2021-09-24)
output from my barely tweaked XFCE road machine, I will add my long time home XFCE later after I reboot, thanks
After I read your post, I’ve checked what is going on my rig and looks like RAM usage is higher than it should be. I’ve switched kernels and on 5.14 the result is something around 632 and on 5.10 is 596 (I’ve trimmed my setup to something around 300-320 MiB).
Never paid attention to this, but for example, xfce4-power-manager have 3 outputs on 5.14 and 2 on 5.10 kernel in htop.
gnome-keyring-deamon have 4, xfce4-session have 3 and so on.
Thanks I’ll give 5.14 a shot later just to see what happens, as others mentioned the RAM usage itself might not be an issue in itself overall. I’ve stuck with LTS kernels only for some time now after some troubles I had way back. Can’t remember what, but I’m running 10-14 year old laptops… once the top models in their class, but now long in the tooth and bought cheap
I don’t have the knowledge to understand the repercussions of this off the top of my head, but thanks for the tip!
I’ve checked this on Xfce installed on VM, and it looks the same, those are sub-processes (I’m just stupid). However, RAM usage is normal, around 600 MiB (didn’t update VM yet).
I’ve checked 5.4 and 4.19 kernels, and they also have different RAM usage. Lowest is 5.10, at least on my potato.
heh, I misread this and your earlier post, I thought 5.14 was lowest. As I have plenty of RAM and saw a few glitches with 5.14 mentioned in the stable update thread I think I’ll just leave everything as is for now. 5.10 LTS. thanks again!
Data posted for the ‘road machine’ shows an uptime of 27m and may not be relevant to RAM use when first booted. But this data also shows only 158 active processes
Data for the ‘long time’ system is showing an uptime of 1m, but is also showing 2 wakeups
and 253 active processes
I rebooted my main system to get more data from free and inxi
total used free shared buff/cache available
Mem: 7.7Gi 536Mi 6.7Gi 4.0Mi 510Mi 7.0Gi
Swap: 3.9Gi 0B 3.9Gi
No packages were updated or changed since previous boot but system reports 2 MiB less than before
Based on the comments here and my own experimentation, it is clear that tools like htop/task manager understand “ram usage” differently compared to free
After making this post, I downloaded the ISO and did a clean reinstall so that I can compare the differences before and after the latest update. Here is a summary of what I discovered:
After the reinstall, htop reported 680MB initial RAM usage before I ran a system update.
After running the system update, htop reported 1.1GB RAM usage.
The results of the free command were consistent both before and after the system update. free -h reported around 590MiB RAM usage for both cases.
I think the best way to resolve this is to find out what htop considers as “ram usage.” Since free returned the same result before and after the latest stable update, it’s likely that the new update doesn’t use more RAM, just that somehow htop is reporting that it is using more.
I think this is the best possible answer based on limited data available
To get a more specific answer would require a lot of testing
User would have to start with an old ISO running v5.10 kernel, as already suggested
system would have to be cold-booted about 10 times to get an average of values from inxi and free
(values for RAM used can vary even when no changes are made to system)
Then system can be updated and repeat tests to get new data values
And for a thorough job the kernel should be updated to v5.14 and repeat tests for the later kernel
But considering that none of the comments here mention the usual consequences of having additional processes loaded and more RAM used (increase in time taken to boot or less responsive desktop) this seems like a lot of effort for not much gain
