Update fails with "keyring is not writable"
I tried to update one of my VMs and got: error: keyring is not writable. (The complete screen output is at the bottom of this post. I am Stable Branch, kernel 6.1 on this VM, Xfce and running VM in VMware in Windows 11.)
Since it’s a VM I restored a snapshot, tried to update, and got the same result.
I tried to follow instructions here: [HowTo] Solve Keyring Related Issues in Manjaro. But got
[jar-n ~]# pacman-key --refresh-keys
==> ERROR: You do not have sufficient permissions to read the pacman keyring.
==> Use 'pacman-key --init' to correct the keyring permissions.
[jar-n ~]# pacman-key --init
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/CB01ADA59A8111CC65183801C2D5DE4EE205537B.rev'
gpg: Done
==> Updating trust database...
gpg: public key of ultimately trusted key 87EA4C12984C55C3 not found
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   2  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 2u
==> ERROR: Trust database could not be updated.
[jar-n ~]#
Questions
  1. What’s the next thing I could try?
  2. How (probably) did I get this problem?
This line is added later: I was able to go round the problem by restoring my VM to an even earlier snapshot (from which update succeeded). But I would still like to understand the nature of the problem (including its probable causes and general approach to fixing it) to the extent the screen output may suggest them. Thanks.
Here follows the output from trying to update.
[luna@jar ~]$ ssh luna@jar-n
Last login: Tue Dec 12 17:23:37 2023
[luna@jar-n ~]$ pacman-mirrors
Pacman-mirrors version 4.24.0
Local mirror status for stable branch
Mirror #1   --  15:09   China          https://mirror.nyist.edu.cn/manjaro/
Mirror #2   OK  09:12   United_States  https://mirrors.sonic.net/manjaro/
Mirror #3   OK  01:01   Russia         https://mirror.kamtv.ru/manjaro/
Mirror #4   OK  03:09   Germany        https://mirror.seahost.de/manjaro/
Mirror #5   OK  01:40   Netherlands    https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
Mirror #6   OK  03:10   Mauritius      https://manjarolinux-mirror.cloud.mu/
Mirror #7   OK  09:08   Brazil         https://linorg.usp.br/manjaro/
Mirror #8   OK  01:38   Brazil         https://manjaro.c3sl.ufpr.br/
[luna@jar-n ~]$ sudo journalctl --vacuum-size=50M
[sudo] password for luna:
Vacuuming done, freed 0B of archived journals from /var/log/journal.
Vacuuming done, freed 0B of archived journals from /run/log/journal.
Deleted archived journal /var/log/journal/e0068f4c5910446384c0ae3bc0665c5e/system@f72386b7835f4422b326a87a18c0bf78-00000000000fada3-00060b419a46b0e8.journal (4.5M).
Deleted archived journal /var/log/journal/e0068f4c5910446384c0ae3bc0665c5e/user-1000@f72386b7835f4422b326a87a18c0bf78-00000000000fb58e-00060b419d8d5ef9.journal (4.7M).
Deleted archived journal /var/log/journal/e0068f4c5910446384c0ae3bc0665c5e/system@f72386b7835f4422b326a87a18c0bf78-00000000000fb58f-00060b419d8db314.journal (3.9M).
Deleted archived journal /var/log/journal/e0068f4c5910446384c0ae3bc0665c5e/system@484736053c004e15932c50c5e31c61ff-00000000000fc234-00060b41a8ca5ad2.journal (4.6M).
Vacuuming done, freed 17.9M of archived journals from /var/log/journal/e0068f4c5910446384c0ae3bc0665c5e.
[luna@jar-n ~]$ sudo paccache -ruk0
==> finished: 3 packages removed (disk space saved: 475.65 KiB)
[luna@jar-n ~]$ sudo pacman -Syu
 core                      145.4 KiB  99.1 KiB/s 00:01 [############################] 100%
 extra                       8.6 MiB   850 KiB/s 00:10 [############################] 100%
 community                  29.0   B   126   B/s 00:00 [############################] 100%
 multilib                  143.2 KiB   587 KiB/s 00:00 [############################] 100%
:: Replace grub-update with core/update-grub? [Y/n] y
resolving dependencies...
warning: dependency cycle detected:
warning: bashrc-manjaro will be installed before its bash dependency
Packages (217) android-udev-20231124-1  aom-3.8.0-2  appstream-1.0.1-1
               archlinux-appstream-data-20231203-1  avahi-1:0.8+r189+g35bb1ba-1
               bash-5.2.021-1  bashrc-manjaro-5.2.021-1  blas-3.12.0-3  bluez-5.71-3
               bluez-libs-5.71-3  boost-libs-1.83.0-4  btrfs-progs-6.6.3-1
               ca-certificates-mozilla-3.96.1-1  cblas-3.12.0-3  cpupower-6.6-1
               curl-8.5.0-1  enchant-2.6.4-2  faad2-2.11.1-1  ffmpeg-2:6.1-3
               firefox-121.0-1  fltk-1.3.9-1  gajim-1.8.4-1  gettext-0.22.4-1
               glib2-2.78.3-1  glslang-13.1.1-3  gnupg-2.4.3-2  gpgme-1.23.2-1
               grub-2.12-3  grub-update-2.12rc1.r49.ge58b870ff-2 [removal]
               gspell-1.12.2-2  gst-libav-1.22.8-1  gst-plugin-gtk-1.22.8-1
               gst-plugins-bad-1.22.8-1  gst-plugins-bad-libs-1.22.8-1
               gst-plugins-base-1.22.8-1  gst-plugins-base-libs-1.22.8-1
               gst-plugins-good-1.22.8-1  gst-plugins-ugly-1.22.8-1  gstreamer-1.22.8-1
               gtk3-1:3.24.39-1  harfbuzz-8.3.0-2  harfbuzz-icu-8.3.0-2  hwdata-0.377-1
               ibus-1.5.29-2  icu-74.2-1  imagemagick-7.1.1.23-1  jasper-4.1.1-1
               kauth5-5.113.0-1  kbd-2.6.4-1  kcoreaddons5-5.113.0-1
               kitemmodels5-5.113.0-1  kwindowsystem5-5.113.0-1  lapack-3.12.0-3
               lcms2-2.16-1  lib32-curl-8.5.0-1  lib32-glib2-2.78.3-1
               lib32-gtk3-1:3.24.39-1  lib32-harfbuzz-8.3.0-2  lib32-icu-74.2-1
               lib32-lcms2-2.16-1  lib32-libdecor-0.2.1-1  lib32-libdrm-2.4.118-1
               lib32-librsvg-2:2.57.1-1  lib32-libtiff-4.6.0-2  lib32-libxml2-2.12.3-1
               lib32-openssl-1:3.2.0-1  lib32-systemd-254.7-1  lib32-util-linux-2.39.3-1
               lib32-vulkan-icd-loader-1.3.274-1  libadwaita-1:1.4.2-1  libavif-1.0.3-1
               libbpf-1.3.0-1  libcap-2.69-3  libcdr-0.1.7-7  libcmis-0.6.2-1
               libde265-1.0.15-1  libdecor-0.2.1-2  libe-book-0.1.3-15  libebml-1.4.5-1
               libgedit-amtk-5.8.0-2  libgedit-gtksourceview-299.0.5-1  libheif-1.17.6-1
               libibus-1.5.29-2  libical-3.0.17-2  libksba-1.6.5-1  liblangtag-0.6.7-1
               libmspub-0.1.4-15  libnl-3.9.0-1  libpamac-11.6.3-1
               libpamac-flatpak-plugin-11.6.3-1  libpamac-snap-plugin-11.6.3-1
               libpipewire-1:1.0.0-2  libpulse-16.1-7  libqxp-0.0.2-11  libraw-0.21.2-1
               libreoffice-still-7.5.9-2  librsvg-2:2.57.1-1  libsecret-0.21.2-1
               libssh-0.10.6-1  libsynctex-2023.66984-17  libtiff-4.6.0-2  liburing-2.5-1
               libvisio-0.1.7-10  libwacom-2.9.0-2  libwbclient-4.19.3-2
               libxml2-2.12.3-1  libzmf-0.0.2-15  licenses-20231215-1  lightdm-1:1.32.0-5
               lilv-0.24.22-1  linux-firmware-20231211.f2e52a1c-1
               linux-firmware-whence-20231211.f2e52a1c-1  linux61-6.1.69-1  lmdb-0.9.31-1
               lua-5.4.6-3  luajit-2.1.1702233742-1  manjaro-hello-0.7.1-3
               manjaro-release-23.1.1-1  manjaro-settings-manager-0.5.7-19
               manjaro-settings-manager-notifier-0.5.7-19  mhwd-nvidia-545.29.06-1
               mkinitcpio-37.1-2  mujs-1.3.4-1  netpbm-10.86.39-1  noto-fonts-1:23.12.1-1
               nspr-4.35-2  nss-3.96.1-1  onevpl-2023.4.0-1  openresolv-3.13.2-2
               openssh-9.6p1-1  openssl-3.2.0-1  ostree-2023.8-1  pamac-cli-11.6.0-3
               pamac-gtk-11.7.1-1  papirus-icon-theme-20231201-2  pcsclite-2.0.1-1
               perl-5.38.1-1  perl-http-cookies-6.11-1  pipewire-1:1.0.0-2
               pkcs11-helper-1.30.0-1  plymouth-22.02.122-15  poppler-23.12.0-1
               poppler-glib-23.12.0-1  protobuf-c-1.5.0-1  pulseaudio-16.1-7
               pulseaudio-bluetooth-16.1-7  pulseaudio-zeroconf-16.1-7  pyside6-6.6.1-1
               python-cryptography-41.0.7-1  python-idna-3.5-1  python-nbxmpp-4.5.3-1
               python-numpy-1.26.2-1  python-pikepdf-8.10.1-1
               python-platformdirs-4.1.0-1  python-pydantic-2.5.2-1
               python-pydantic-core-1:2.14.5-1  python-setuptools-1:69.0.1-1
               python-trove-classifiers-2023.11.29-1  python-typing_extensions-4.9.0-1
               qbittorrent-4.6.2-2  qemu-guest-agent-8.1.3-1  qpdf-11.6.4-1
               qt5-base-5.15.11+kde+r148-1  qt6-base-6.6.1-2  qt6-declarative-6.6.1-1
               qt6-svg-6.6.1-1  qt6-translations-6.6.1-1  raptor-2.0.16-4
               readline-8.2.007-1  samba-4.19.3-2  shaderc-2023.7-2  shiboken6-6.6.1-1
               smbclient-4.19.3-2  snapd-2.61.1-1  snappy-1.1.10-1
               sof-firmware-2023.12-1  sord-0.16.16-1  spirv-tools-2023.5-1
               sqlite-3.44.2-2  sratom-0.6.16-1  sudo-1.9.15.p4-1  svt-av1-1.8.0-1
               systemd-254.7-1  systemd-libs-254.7-1  systemd-sysvcompat-254.7-1
               tepl-1:6.8.0-2  thin-provisioning-tools-1.0.9-2  thunderbird-115.6.0-1
               timeshift-23.12.1-1  tracker3-3.6.0-2  ttf-noto-nerd-3.1.1-1
               tumbler-4.18.2-1  update-grub-2.12-3  util-linux-2.39.3-1
               util-linux-libs-2.39.3-1  v4l-utils-1.26.1-1  vlc-3.0.20-4  vmaf-3.0.0-1
               vte-common-0.74.2-1  vte3-0.74.2-1  vulkan-headers-1:1.3.274-1
               vulkan-icd-loader-1.3.274-1  webkit2gtk-2.42.4-1  webkit2gtk-4.1-2.42.4-1
               xapp-2.8.1-1  xdg-desktop-portal-1.18.2-1  xdg-utils-1.2.0r25+g0f49cf5-1
               xfce4-cpugraph-plugin-1.2.10-1  xfce4-power-manager-4.18.3-1
               xfce4-settings-4.18.4-1  xfce4-whiskermenu-plugin-2.8.2-1
               xfsprogs-6.5.0-2  xorg-server-21.1.10-1  xorg-server-common-21.1.10-1
               zix-0.4.2-2  zsh-syntax-highlighting-0.8.0-1  zxing-cpp-2.2.1-1
Total Download Size:    844.15 MiB
Total Installed Size:  4482.00 MiB
Net Upgrade Size:        45.20 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 linux-firmware-20231...   175.1 MiB  2.73 MiB/s 01:04 [############################] 100%
 libreoffice-still-7....   149.9 MiB  3.22 MiB/s 00:47 [############################] 100%
 linux61-6.1.69-1-x86_64   138.8 MiB  2.37 MiB/s 00:59 [############################] 100%
 firefox-121.0-1-x86_64     64.7 MiB  2.82 MiB/s 00:23 [############################] 100%
 thunderbird-115.6.0-...    55.9 MiB  2.51 MiB/s 00:22 [############################] 100%
 webkit2gtk-4.1-2.42....    27.4 MiB  2003 KiB/s 00:14 [############################] 100%
 webkit2gtk-2.42.4-1-...    27.4 MiB  1514 KiB/s 00:19 [############################] 100%
 grub-2.12-3-x86_64         15.1 MiB  1415 KiB/s 00:11 [############################] 100%
 qt6-base-6.6.1-2-x86_64    13.6 MiB  1547 KiB/s 00:09 [############################] 100%
 qt5-base-5.15.11+kde...    13.1 MiB  1561 KiB/s 00:09 [############################] 100%
 vlc-3.0.20-4-x86_64        11.7 MiB  1560 KiB/s 00:08 [############################] 100%
 ffmpeg-2:6.1-3-x86_64      11.6 MiB  1556 KiB/s 00:08 [############################] 100%
 icu-74.2-1-x86_64          11.1 MiB  1537 KiB/s 00:07 [############################] 100%
 lib32-icu-74.2-1-x86_64    10.4 MiB  1275 KiB/s 00:08 [############################] 100%
 imagemagick-7.1.1.23...     8.5 MiB  1213 KiB/s 00:07 [############################] 100%
 samba-4.19.3-2-x86_64       8.4 MiB  1488 KiB/s 00:06 [############################] 100%
 gtk3-1:3.24.39-1-x86_64     7.7 MiB  1613 KiB/s 00:05 [############################] 100%
 smbclient-4.19.3-2-x...     6.7 MiB  1412 KiB/s 00:05 [############################] 100%
 openssl-3.2.0-1-x86_64      4.9 MiB   832 KiB/s 00:06 [############################] 100%
 manjaro-settings-man...     4.3 MiB   767 KiB/s 00:06 [############################] 100%
 appstream-1.0.1-1-x86_64    3.5 MiB   735 KiB/s 00:05 [############################] 100%
 glslang-13.1.1-3-x86_64     3.1 MiB   717 KiB/s 00:04 [############################] 100%
 lib32-gtk3-1:3.24.39...     2.8 MiB   736 KiB/s 00:04 [############################] 100%
 aom-3.8.0-2-x86_64          2.7 MiB   714 KiB/s 00:04 [############################] 100%
 librsvg-2:2.57.1-1-x...     2.6 MiB   718 KiB/s 00:04 [############################] 100%
 lapack-3.12.0-3-x86_64      2.6 MiB   817 KiB/s 00:03 [############################] 100%
 gst-plugins-bad-libs...     2.4 MiB   697 KiB/s 00:04 [############################] 100%
 boost-libs-1.83.0-4-...     2.3 MiB   667 KiB/s 00:03 [############################] 100%
 gst-plugins-base-lib...     2.2 MiB   604 KiB/s 00:04 [############################] 100%
 gst-plugins-good-1.2...     2.2 MiB   356 KiB/s 00:06 [############################] 100%
 svt-av1-1.8.0-1-x86_64      2.0 MiB   446 KiB/s 00:05 [############################] 100%
 lib32-openssl-1:3.2....  1996.3 KiB   954 KiB/s 00:02 [############################] 100%
 sudo-1.9.15.p4-1-x86_64  1923.5 KiB   920 KiB/s 00:02 [############################] 100%
 v4l-utils-1.26.1-1-x...  1892.6 KiB   789 KiB/s 00:02 [############################] 100%
 gstreamer-1.22.8-1-x...  1836.5 KiB   791 KiB/s 00:02 [############################] 100%
 xorg-server-21.1.10-...  1770.9 KiB   636 KiB/s 00:03 [############################] 100%
 nss-3.96.1-1-x86_64      1619.1 KiB   580 KiB/s 00:03 [############################] 100%
 hwdata-0.377-1-any       1608.0 KiB   579 KiB/s 00:03 [############################] 100%
 fltk-1.3.9-1-x86_64      1590.3 KiB   610 KiB/s 00:03 [############################] 100%
 lib32-librsvg-2:2.57...  1564.8 KiB   613 KiB/s 00:03 [############################] 100%
 kcoreaddons5-5.113.0...  1404.9 KiB   547 KiB/s 00:03 [############################] 100%
 netpbm-10.86.39-1-x86_64 1306.8 KiB   553 KiB/s 00:02 [############################] 100%
 kbd-2.6.4-1-x86_64       1278.1 KiB   549 KiB/s 00:02 [############################] 100%
 btrfs-progs-6.6.3-1-...  1217.5 KiB   654 KiB/s 00:02 [############################] 100%
 vulkan-headers-1:1.3...  1191.2 KiB   624 KiB/s 00:02 [############################] 100%
 openssh-9.6p1-1-x86_64   1155.4 KiB   552 KiB/s 00:02 [############################] 100%
 gst-plugins-bad-1.22...  1112.0 KiB   531 KiB/s 00:02 [############################] 100%
 sof-firmware-2023.12...  1079.3 KiB   580 KiB/s 00:02 [############################] 100%
 xfsprogs-6.5.0-2-x86_64  1058.2 KiB   570 KiB/s 00:02 [############################] 100%
 plymouth-22.02.122-1...  1056.7 KiB   544 KiB/s 00:02 [############################] 100%
 harfbuzz-8.3.0-2-x86_64  1008.1 KiB   617 KiB/s 00:02 [############################] 100%
 thin-provisioning-to...   996.1 KiB   711 KiB/s 00:01 [############################] 100%
 libcdr-0.1.7-7-x86_64     965.6 KiB   592 KiB/s 00:02 [############################] 100%
 qpdf-11.6.4-1-x86_64      952.5 KiB   573 KiB/s 00:02 [############################] 100%
 bluez-5.71-3-x86_64       929.8 KiB   502 KiB/s 00:02 [############################] 100%
 lib32-harfbuzz-8.3.0...   865.3 KiB   601 KiB/s 00:01 [############################] 100%
 libxml2-2.12.3-1-x86_64   843.4 KiB   605 KiB/s 00:01 [############################] 100%
 kwindowsystem5-5.113...   829.0 KiB   595 KiB/s 00:01 [############################] 100%
 python-setuptools-1:...   774.2 KiB   629 KiB/s 00:01 [############################] 100%
 tracker3-3.6.0-2-x86_64   721.2 KiB   512 KiB/s 00:01 [############################] 100%
 libe-book-0.1.3-15-x...   710.8 KiB   511 KiB/s 00:01 [############################] 100%
 libvisio-0.1.7-10-x86_64  641.3 KiB   456 KiB/s 00:01 [############################] 100%
 libical-3.0.17-2-x86_64   610.3 KiB   439 KiB/s 00:01 [############################] 100%
 zxing-cpp-2.2.1-1-x86_64  598.8 KiB   509 KiB/s 00:01 [############################] 100%
 python-pikepdf-8.10....   591.0 KiB   175 KiB/s 00:03 [############################] 100%
 kitemmodels5-5.113.0...   580.0 KiB   408 KiB/s 00:01 [############################] 100%
 lib32-libxml2-2.12.3...   571.8 KiB   487 KiB/s 00:01 [############################] 100%
 libmspub-0.1.4-15-x86_64  463.1 KiB   498 KiB/s 00:01 [############################] 100%
 libraw-0.21.2-1-x86_64    451.9 KiB   484 KiB/s 00:01 [############################] 100%
 libcmis-0.6.2-1-x86_64    406.3 KiB   435 KiB/s 00:01 [############################] 100%
 vmaf-3.0.0-1-x86_64       396.4 KiB   428 KiB/s 00:01 [############################] 100%
 libheif-1.17.6-1-x86_64   371.8 KiB   528 KiB/s 00:01 [############################] 100%
 ca-certificates-mozi...   364.3 KiB   520 KiB/s 00:01 [############################] 100%
 lua-5.4.6-3-x86_64        362.2 KiB   512 KiB/s 00:01 [############################] 100%
 gst-plugins-base-1.2...   322.2 KiB   462 KiB/s 00:01 [############################] 100%
 luajit-2.1.170223374...   322.2 KiB   434 KiB/s 00:01 [############################] 100%
 kauth5-5.113.0-1-x86_64   309.9 KiB   443 KiB/s 00:01 [############################] 100%
 libqxp-0.0.2-11-x86_64    304.6 KiB   435 KiB/s 00:01 [############################] 100%
 vte3-0.74.2-1-x86_64      295.8 KiB   423 KiB/s 00:01 [############################] 100%
 raptor-2.0.16-4-x86_64    294.2 KiB   420 KiB/s 00:01 [############################] 100%
 manjaro-settings-man...   282.0 KiB   405 KiB/s 00:01 [############################] 100%
 libde265-1.0.15-1-x86_64  270.3 KiB   571 KiB/s 00:00 [############################] 100%
 tepl-1:6.8.0-2-x86_64     251.1 KiB   534 KiB/s 00:00 [############################] 100%
 libbpf-1.3.0-1-x86_64     248.3 KiB   356 KiB/s 00:01 [############################] 100%
 blas-3.12.0-3-x86_64      230.2 KiB   330 KiB/s 00:01 [############################] 100%
 gst-plugins-ugly-1.2...   211.4 KiB   450 KiB/s 00:00 [############################] 100%
 jasper-4.1.1-1-x86_64     203.3 KiB   407 KiB/s 00:01 [############################] 100%
 cpupower-6.6-1-x86_64     202.5 KiB   431 KiB/s 00:00 [############################] 100%
 nspr-4.35-2-x86_64        197.8 KiB   424 KiB/s 00:00 [############################] 100%
 libssh-0.10.6-1-x86_64    197.7 KiB   421 KiB/s 00:00 [############################] 100%
 libsecret-0.21.2-1-x...   190.4 KiB   405 KiB/s 00:00 [############################] 100%
 pamac-gtk-11.7.1-1-x...   182.6 KiB   200 KiB/s 00:01 [############################] 100%
 libzmf-0.0.2-15-x86_64    173.0 KiB   371 KiB/s 00:00 [############################] 100%
 lib32-lcms2-2.16-1-x...   169.8 KiB   331 KiB/s 00:01 [############################] 100%
 lib32-vulkan-icd-loa...   153.8 KiB   332 KiB/s 00:00 [############################] 100%
 lib32-libdrm-2.4.118...   147.6 KiB   316 KiB/s 00:00 [############################] 100%
 vulkan-icd-loader-1....   145.0 KiB   310 KiB/s 00:00 [############################] 100%
 gspell-1.12.2-2-x86_64    121.9 KiB   488 KiB/s 00:00 [############################] 100%
 protobuf-c-1.5.0-1-x...   117.1 KiB   463 KiB/s 00:00 [############################] 100%
 lmdb-0.9.31-1-x86_64      114.1 KiB   468 KiB/s 00:00 [############################] 100%
 licenses-20231215-1-any   111.8 KiB   466 KiB/s 00:00 [############################] 100%
 gst-libav-1.22.8-1-x...    95.6 KiB   405 KiB/s 00:00 [############################] 100%
 python-idna-3.5-1-any      93.5 KiB   359 KiB/s 00:00 [############################] 100%
 bluez-libs-5.71-3-x86_64   92.4 KiB   392 KiB/s 00:00 [############################] 100%
 libgedit-amtk-5.8.0-...    89.0 KiB   338 KiB/s 00:00 [############################] 100%
 libebml-1.4.5-1-x86_64     69.8 KiB   291 KiB/s 00:00 [############################] 100%
 python-typing_extens...    66.9 KiB   268 KiB/s 00:00 [############################] 100%
 mkinitcpio-37.1-2-any      60.8 KiB   258 KiB/s 00:00 [############################] 100%
 enchant-2.6.4-2-x86_64     59.5 KiB   252 KiB/s 00:00 [############################] 100%
 cblas-3.12.0-3-x86_64      57.9 KiB   249 KiB/s 00:00 [############################] 100%
 vte-common-0.74.2-1-...    56.7 KiB   239 KiB/s 00:00 [############################] 100%
 libsynctex-2023.6698...    48.9 KiB   207 KiB/s 00:00 [############################] 100%
 zsh-syntax-highlight...    42.0 KiB   177 KiB/s 00:00 [############################] 100%
 zix-0.4.2-2-x86_64         40.0 KiB   165 KiB/s 00:00 [############################] 100%
 linux-firmware-whenc...    39.3 KiB   151 KiB/s 00:00 [############################] 100%
 gst-plugin-gtk-1.22....    36.3 KiB   153 KiB/s 00:00 [############################] 100%
 libwbclient-4.19.3-2...    36.3 KiB   155 KiB/s 00:00 [############################] 100%
 xorg-server-common-2...    31.8 KiB   134 KiB/s 00:00 [############################] 100%
 snappy-1.1.10-1-x86_64     28.3 KiB   110 KiB/s 00:00 [############################] 100%
 openresolv-3.13.2-2-any    23.4 KiB  88.1 KiB/s 00:00 [############################] 100%
 perl-http-cookies-6....    21.2 KiB  89.8 KiB/s 00:00 [############################] 100%
 manjaro-release-23.1...    19.8 KiB  85.2 KiB/s 00:00 [############################] 100%
 harfbuzz-icu-8.3.0-2...     8.0 KiB  34.3 KiB/s 00:00 [############################] 100%
 update-grub-2.12-3-x...     4.0 KiB  17.4 KiB/s 00:00 [############################] 100%
 Total (124/124)           844.2 MiB  1689 KiB/s 08:32 [############################] 100%
(216/216) checking keys in keyring                     [############################] 100%
warning: Public keyring not found; have you run 'pacman-key --init'?
downloading required keys...
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
[luna@jar-n ~]$
Maybe you can find some info with:
:mag_right: “error: keyring is not writable”
https://forum.manjaro.org/search?q=error%3A%20keyring%20is%20not%20writable
:footprints:
Thank you. I thought my screen output may pinpoint to a particular cause (in the eyes of someone knowledgeable). But if not, I’ll look into the materials you provided.
Try sudo. Or were you root when trying?
Yes. I was root. Higher authority than that, I could not think of.
I add this bit in response to bedna’s comment below (as system does not seem to like too many small comments): I tried sudo (i.e. sudo pacman-key --refresh-keys and sudo pacman-key --init). When that didn’t work, I became root.
Then I have nothing other than try with sudo instead of root.
Sudo != root
Worth a try at least. :frowning:
I usually do this to show what I mean.
As a user. Type cd in a terminal. You will move to your home.
Root’s home is /root right?
So if you sudo su > cd you will end up in /root
Now exit root and type sudo cd, that should bring you to /root right? :slight_smile:
( There’s nothing wrong with small comments. )
I am by no means knowledgeable in these things, but I am curious.
By reading the script and what it is trying to do I find:
check_keyring() {
	if [[ ! -r ${PACMAN_KEYRING_DIR}/pubring.gpg || \
			! -r ${PACMAN_KEYRING_DIR}/trustdb.gpg ]]; then
		error "$(gettext "You do not have sufficient permissions to read the %s keyring.")" "pacman"
		msg "$(gettext "Use '%s' to correct the keyring permissions.")" "pacman-key --init"
		exit 1
	fi
[ -r ] = test -r. The ! means NOT. The || means OR.
It is trying to run test -r on the files, and if it fails, it prompts the error text you see.
We can use the AUR program manly (it reads the man page for the application and filters out the flag you query) to quickly find out what -r does: (or you can just type man test to read the whole manual)
$ manly test -r
test - check file types and compare values
      -r FILE
              FILE exists and the user has read access
So what is in your directory and what credentials does the files have?
ls -l /etc/pacman.d/gnupg
I believe you meant the contents of the directory in the state of VM which cannot be updated. That goes like this.
[luna@jar-n ~]$ ls -al /etc/pacman.d/gnupg
total 2424
drwxr-xr-x 5 root root    4096 Dec 12 17:35 .
drwxr-xr-x 3 root root    4096 May  6  2023 ..
-rw-r--r-- 1 root root       0 May  6  2023 .gpg-v21-migrated
drwx------ 2 root root    4096 Jun  4  2023 crls.d
-rw-r--r-- 1 root root      17 May  6  2023 gpg-agent.conf
-rw-r--r-- 1 root root     141 May  6  2023 gpg.conf
drwx------ 2 root root    4096 May  6  2023 openpgp-revocs.d
drwx------ 2 root root    4096 May  6  2023 private-keys-v1.d
-rw-r--r-- 1 root root 1896037 Dec 12 17:29 pubring.gpg~
-rw-r--r-- 1 root root  242240 Dec 12 17:30 pubring.kbx
-rw-r--r-- 1 root root  240039 Dec 12 17:30 pubring.kbx~
-rw------- 1 root root       0 May  6  2023 secring.gpg
-rw-r--r-- 1 root root   49152 Sep 20 09:05 tofu.db
-rw-r--r-- 1 root root   18880 Dec 12 17:30 trustdb.gpg
[luna@jar-n ~]$
And the following is from the state of VM that could be and was updated. As you can see, they are not exactly the same.
total 3800
drwxr-xr-x 5 root root    4096 Dec 27 16:46 .
-rw-r--r-- 1 root root 1895866 Dec 27 16:26 pubring.gpg
-rw-r--r-- 1 root root 1895866 Dec 27 16:26 pubring.gpg~
-rw-r--r-- 1 root root   18880 Dec 27 16:26 trustdb.gpg
[luna@jar-n ~]$
This is missing in the top one, and that is probably why it fails:
Both pubring.gpg and trustdb.gpg have to exist for the script not to fail.
You might get some clarity of what to do in this old thread or if someone else has a quick fix because I do not know exactly: [SOLVED]How to verify pgp key from pacman? / Newbie Corner / Arch Linux Forums
Edit
Looking at the second ls, pubring.gpg and pubring.gpg~ are exactly the same size. Maybe try to make a copy of pubring.gpg~ naming it pubring.gpg and retry?
That was great detective work on your part, leading to something I could try. And I did (copy ubring.gpg~ to pubring.gpg and try updating again).
The result was not success, but there may be something educational in the output (to someone who can understand it).
You will see that I was asked a whole bunch of yes/no questions of these two types:
:: Import PGP key 771DF6627EDF681F, "Tobias Powalowski <tpowa@archlinux.org>"? [Y/n] y
and
error: readline: signature from "Tobias Powalowski <tpowa@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/readline-8.2.007-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
I answered yes each time.
I am leaving a note to myself for later: pacman-key is a script in /usr/bin/
The screen output from the failed update follows.
Mirror #1   OK  06:29   China          https://mirror.nyist.edu.cn/manjaro/
Mirror #2   OK  06:33   United_States  https://mirrors.sonic.net/manjaro/
Mirror #3   OK  01:41   Russia         https://mirror.kamtv.ru/manjaro/
Mirror #4   OK  06:29   Germany        https://mirror.seahost.de/manjaro/
Mirror #5   OK  05:00   Netherlands    https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
Mirror #6   OK  06:30   Mauritius      https://manjarolinux-mirror.cloud.mu/
Mirror #7   OK  06:28   Brazil         https://linorg.usp.br/manjaro/
Mirror #8   OK  00:58   Brazil         https://manjaro.c3sl.ufpr.br/
 core                      145.4 KiB  80.6 KiB/s 00:02 [############################] 100%
 extra                       8.6 MiB  1202 KiB/s 00:07 [############################] 100%
 community                  29.0   B   119   B/s 00:00 [############################] 100%
 multilib                  143.2 KiB   566 KiB/s 00:00 [############################] 100%
               manjaro-release-23.1.1-1  manjaro-settings-manager-0.5.7-20
               manjaro-settings-manager-notifier-0.5.7-20  mhwd-nvidia-545.29.06-1
Total Download Size:    843.99 MiB
Total Installed Size:  4482.30 MiB
Net Upgrade Size:        45.51 MiB
 linux-firmware-20231...   175.1 MiB  3.47 MiB/s 00:50 [############################] 100%
 libreoffice-still-7....   149.9 MiB  3.84 MiB/s 00:39 [############################] 100%
 linux61-6.1.69-1-x86_64   138.8 MiB  2.95 MiB/s 00:47 [############################] 100%
 firefox-121.0-1-x86_64     64.7 MiB  3.13 MiB/s 00:21 [############################] 100%
 thunderbird-115.6.0-...    55.9 MiB  2.54 MiB/s 00:22 [############################] 100%
 webkit2gtk-4.1-2.42....    27.4 MiB  2026 KiB/s 00:14 [############################] 100%
 webkit2gtk-2.42.4-1-...    27.4 MiB  2.28 MiB/s 00:12 [############################] 100%
 grub-2.12-3-x86_64         15.1 MiB  2.38 MiB/s 00:06 [############################] 100%
 qt6-base-6.6.1-2-x86_64    13.6 MiB  2.14 MiB/s 00:06 [############################] 100%
 qt5-base-5.15.11+kde...    13.1 MiB  1809 KiB/s 00:07 [############################] 100%
 vlc-3.0.20-4-x86_64        11.7 MiB  1482 KiB/s 00:08 [############################] 100%
 ffmpeg-2:6.1-3-x86_64      11.6 MiB  1304 KiB/s 00:09 [############################] 100%
 icu-74.2-1-x86_64          11.1 MiB  1253 KiB/s 00:09 [############################] 100%
 lib32-icu-74.2-1-x86_64    10.4 MiB  1761 KiB/s 00:06 [############################] 100%
 imagemagick-7.1.1.23...     8.5 MiB  2.06 MiB/s 00:04 [############################] 100%
 samba-4.19.3-2-x86_64       8.4 MiB  1894 KiB/s 00:05 [############################] 100%
 gtk3-1:3.24.39-1-x86_64     7.7 MiB  1632 KiB/s 00:05 [############################] 100%
 smbclient-4.19.3-2-x...     6.7 MiB  1580 KiB/s 00:04 [############################] 100%
 openssl-3.2.0-1-x86_64      4.9 MiB  1299 KiB/s 00:04 [############################] 100%
 manjaro-settings-man...     4.7 MiB  1106 KiB/s 00:04 [############################] 100%
 appstream-1.0.1-1-x86_64    3.5 MiB  1046 KiB/s 00:03 [############################] 100%
 glslang-13.1.1-3-x86_64     3.1 MiB   917 KiB/s 00:03 [############################] 100%
 lib32-gtk3-1:3.24.39...     2.8 MiB  1009 KiB/s 00:03 [############################] 100%
 aom-3.8.0-2-x86_64          2.7 MiB   846 KiB/s 00:03 [############################] 100%
 librsvg-2:2.57.1-1-x...     2.6 MiB   979 KiB/s 00:03 [############################] 100%
 lapack-3.12.0-3-x86_64      2.6 MiB   991 KiB/s 00:03 [############################] 100%
 gst-plugins-bad-libs...     2.4 MiB   834 KiB/s 00:03 [############################] 100%
 boost-libs-1.83.0-4-...     2.3 MiB  1022 KiB/s 00:02 [############################] 100%
 gst-plugins-base-lib...     2.2 MiB   892 KiB/s 00:03 [############################] 100%
 gst-plugins-good-1.2...     2.2 MiB   833 KiB/s 00:03 [############################] 100%
 svt-av1-1.8.0-1-x86_64      2.0 MiB   939 KiB/s 00:02 [############################] 100%
 lib32-openssl-1:3.2....  1996.3 KiB   878 KiB/s 00:02 [############################] 100%
 sudo-1.9.15.p4-1-x86_64  1923.5 KiB   710 KiB/s 00:03 [############################] 100%
 v4l-utils-1.26.1-1-x...  1892.6 KiB   773 KiB/s 00:02 [############################] 100%
 gstreamer-1.22.8-1-x...  1836.5 KiB   825 KiB/s 00:02 [############################] 100%
 xorg-server-21.1.10-...  1770.9 KiB   795 KiB/s 00:02 [############################] 100%
 nss-3.96.1-1-x86_64      1619.1 KiB   741 KiB/s 00:02 [############################] 100%
 hwdata-0.377-1-any       1608.0 KiB   665 KiB/s 00:02 [############################] 100%
 fltk-1.3.9-1-x86_64      1590.3 KiB   721 KiB/s 00:02 [############################] 100%
 lib32-librsvg-2:2.57...  1564.8 KiB   696 KiB/s 00:02 [############################] 100%
 kcoreaddons5-5.113.0...  1404.9 KiB   711 KiB/s 00:02 [############################] 100%
 netpbm-10.86.39-1-x86_64 1306.8 KiB   730 KiB/s 00:02 [############################] 100%
 kbd-2.6.4-1-x86_64       1278.1 KiB   641 KiB/s 00:02 [############################] 100%
 btrfs-progs-6.6.3-1-...  1217.5 KiB   810 KiB/s 00:02 [############################] 100%
 vulkan-headers-1:1.3...  1191.2 KiB   691 KiB/s 00:02 [############################] 100%
 openssh-9.6p1-1-x86_64   1155.4 KiB   577 KiB/s 00:02 [############################] 100%
 gst-plugins-bad-1.22...  1112.0 KiB   500 KiB/s 00:02 [############################] 100%
 sof-firmware-2023.12...  1079.3 KiB   490 KiB/s 00:02 [############################] 100%
 xfsprogs-6.5.0-2-x86_64  1058.2 KiB   551 KiB/s 00:02 [############################] 100%
 plymouth-22.02.122-1...  1056.7 KiB   543 KiB/s 00:02 [############################] 100%
 harfbuzz-8.3.0-2-x86_64  1008.1 KiB   504 KiB/s 00:02 [############################] 100%
 thin-provisioning-to...   996.1 KiB   577 KiB/s 00:02 [############################] 100%
 libcdr-0.1.7-7-x86_64     965.6 KiB   560 KiB/s 00:02 [############################] 100%
 qpdf-11.6.4-1-x86_64      952.5 KiB   484 KiB/s 00:02 [############################] 100%
 bluez-5.71-3-x86_64       929.8 KiB   541 KiB/s 00:02 [############################] 100%
 lib32-harfbuzz-8.3.0...   865.3 KiB   598 KiB/s 00:01 [############################] 100%
 libxml2-2.12.3-1-x86_64   843.4 KiB   562 KiB/s 00:02 [############################] 100%
 kwindowsystem5-5.113...   829.0 KiB   518 KiB/s 00:02 [############################] 100%
 python-setuptools-1:...   774.2 KiB   572 KiB/s 00:01 [############################] 100%
 tracker3-3.6.0-2-x86_64   721.2 KiB   485 KiB/s 00:01 [############################] 100%
 libe-book-0.1.3-15-x...   710.8 KiB   675 KiB/s 00:01 [############################] 100%
 libvisio-0.1.7-10-x86_64  641.3 KiB   654 KiB/s 00:01 [############################] 100%
 libical-3.0.17-2-x86_64   610.3 KiB   569 KiB/s 00:01 [############################] 100%
 zxing-cpp-2.2.1-1-x86_64  598.8 KiB   581 KiB/s 00:01 [############################] 100%
 python-pikepdf-8.10....   591.0 KiB   556 KiB/s 00:01 [############################] 100%
 kitemmodels5-5.113.0...   580.0 KiB   547 KiB/s 00:01 [############################] 100%
 lib32-libxml2-2.12.3...   571.8 KiB   465 KiB/s 00:01 [############################] 100%
 libmspub-0.1.4-15-x86_64  463.1 KiB   460 KiB/s 00:01 [############################] 100%
 libraw-0.21.2-1-x86_64    451.9 KiB   433 KiB/s 00:01 [############################] 100%
 vmaf-3.0.0-1-x86_64       396.4 KiB   504 KiB/s 00:01 [############################] 100%
 libheif-1.17.6-1-x86_64   371.8 KiB   462 KiB/s 00:01 [############################] 100%
 ca-certificates-mozi...   364.3 KiB   463 KiB/s 00:01 [############################] 100%
 lua-5.4.6-3-x86_64        362.2 KiB   466 KiB/s 00:01 [############################] 100%
 gst-plugins-base-1.2...   322.2 KiB   420 KiB/s 00:01 [############################] 100%
 luajit-2.1.170223374...   322.2 KiB   401 KiB/s 00:01 [############################] 100%
 kauth5-5.113.0-1-x86_64   309.9 KiB   391 KiB/s 00:01 [############################] 100%
 libqxp-0.0.2-11-x86_64    304.6 KiB   390 KiB/s 00:01 [############################] 100%
 vte3-0.74.2-1-x86_64      295.8 KiB   391 KiB/s 00:01 [############################] 100%
 raptor-2.0.16-4-x86_64    294.2 KiB   573 KiB/s 00:01 [############################] 100%
 manjaro-settings-man...   282.1 KiB   281 KiB/s 00:01 [############################] 100%
 libde265-1.0.15-1-x86_64  270.3 KiB   258 KiB/s 00:01 [############################] 100%
 tepl-1:6.8.0-2-x86_64     251.1 KiB   477 KiB/s 00:01 [############################] 100%
 libbpf-1.3.0-1-x86_64     248.3 KiB   328 KiB/s 00:01 [############################] 100%
 blas-3.12.0-3-x86_64      230.2 KiB   395 KiB/s 00:01 [############################] 100%
 gst-plugins-ugly-1.2...   211.4 KiB   332 KiB/s 00:01 [############################] 100%
 jasper-4.1.1-1-x86_64     203.3 KiB   324 KiB/s 00:01 [############################] 100%
 cpupower-6.6-1-x86_64     202.5 KiB   375 KiB/s 00:01 [############################] 100%
 nspr-4.35-2-x86_64        197.8 KiB   245 KiB/s 00:01 [############################] 100%
 libssh-0.10.6-1-x86_64    197.7 KiB   378 KiB/s 00:01 [############################] 100%
 libsecret-0.21.2-1-x...   190.4 KiB   342 KiB/s 00:01 [############################] 100%
 pamac-gtk-11.7.1-1-x...   182.6 KiB   240 KiB/s 00:01 [############################] 100%
 libzmf-0.0.2-15-x86_64    173.0 KiB   316 KiB/s 00:01 [############################] 100%
 lib32-lcms2-2.16-1-x...   169.8 KiB   325 KiB/s 00:01 [############################] 100%
 lib32-vulkan-icd-loa...   153.8 KiB   303 KiB/s 00:01 [############################] 100%
 lib32-libdrm-2.4.118...   147.6 KiB   294 KiB/s 00:01 [############################] 100%
 vulkan-icd-loader-1....   145.0 KiB   282 KiB/s 00:01 [############################] 100%
 gspell-1.12.2-2-x86_64    121.9 KiB   462 KiB/s 00:00 [############################] 100%
 protobuf-c-1.5.0-1-x...   117.1 KiB   404 KiB/s 00:00 [############################] 100%
 lmdb-0.9.31-1-x86_64      114.1 KiB   399 KiB/s 00:00 [############################] 100%
 licenses-20231215-1-any   111.8 KiB   368 KiB/s 00:00 [############################] 100%
 gst-libav-1.22.8-1-x...    95.6 KiB   278 KiB/s 00:00 [############################] 100%
 python-idna-3.5-1-any      93.5 KiB   295 KiB/s 00:00 [############################] 100%
 bluez-libs-5.71-3-x86_64   92.4 KiB   330 KiB/s 00:00 [############################] 100%
 libgedit-amtk-5.8.0-...    89.0 KiB   337 KiB/s 00:00 [############################] 100%
 libebml-1.4.5-1-x86_64     69.8 KiB   243 KiB/s 00:00 [############################] 100%
 python-typing_extens...    66.9 KiB   186 KiB/s 00:00 [############################] 100%
 mkinitcpio-37.1-2-any      60.8 KiB   170 KiB/s 00:00 [############################] 100%
 enchant-2.6.4-2-x86_64     59.5 KiB   234 KiB/s 00:00 [############################] 100%
 cblas-3.12.0-3-x86_64      57.9 KiB   200 KiB/s 00:00 [############################] 100%
 vte-common-0.74.2-1-...    56.7 KiB   203 KiB/s 00:00 [############################] 100%
 libsynctex-2023.6698...    48.9 KiB   181 KiB/s 00:00 [############################] 100%
 zsh-syntax-highlight...    42.0 KiB   164 KiB/s 00:00 [############################] 100%
 linux-firmware-whenc...    39.3 KiB   121 KiB/s 00:00 [############################] 100%
 gst-plugin-gtk-1.22....    36.3 KiB   142 KiB/s 00:00 [############################] 100%
 libwbclient-4.19.3-2...    36.3 KiB   140 KiB/s 00:00 [############################] 100%
 xorg-server-common-2...    31.8 KiB  49.1 KiB/s 00:01 [############################] 100%
 openresolv-3.13.2-2-any    23.4 KiB  82.8 KiB/s 00:00 [############################] 100%
 perl-http-cookies-6....    21.2 KiB  70.6 KiB/s 00:00 [############################] 100%
 manjaro-release-23.1...    19.8 KiB  65.5 KiB/s 00:00 [############################] 100%
 harfbuzz-icu-8.3.0-2...     8.0 KiB  28.0 KiB/s 00:00 [############################] 100%
 update-grub-2.12-3-x...     4.0 KiB  16.2 KiB/s 00:00 [############################] 100%
 Total (121/121)           844.0 MiB  1955 KiB/s 07:22 [############################] 100%
:: Import PGP key 150C200743ED46D8, "Mark Wagie <mark@manjaro.org>"? [Y/n] y
:: Import PGP key 76A5EF9054449A5C, "Pierre Schmitz <pierre@archlinux.org>"? [Y/n] y
:: Import PGP key 6D42BDD116E0068F, "Christian Hesse <eworm@archlinux.org>"? [Y/n] y
:: Import PGP key B02854ED753E0F1F, "Anatol Pomozov <anatolik@archlinux.org>"? [Y/n] y
:: Import PGP key F296BDE50368C6CE, "T.J. Townsend <blakkheim@archlinux.org>"? [Y/n] y
:: Import PGP key FDC3040B92ACA748, "Robin Candau <antiz@archlinux.org>"? [Y/n] y
:: Import PGP key 06096A6AD1CEDDAC, "Laurent Carlier <lordheavym@archlinux.org>"? [Y/n] y
:: Import PGP key E85B8683EB48BC95, "Daniel Bermond <dbermond@archlinux.org>"? [Y/n] y
:: Import PGP key 39E4B877E62EB915, "Sven-Hendrik Haase <svenstaro@archlinux.org>"? [Y/n] y
:: Import PGP key EA4F7B321A906AD9, "Daniel M. Capella <polyzen@archlinux.org>"? [Y/n] y
:: Import PGP key 279E7CF5D8D56EC8, "Manjaro Build Server <build@manjaro.org>"? [Y/n] y
:: Import PGP key CAA6A59611C7F07E, "Philip Müller <philm@manjaro.org>"? [Y/n] y
:: Import PGP key 9D4C5AA15426DA0A, "Frederik Schwan <freswa@archlinux.org>"? [Y/n] y
:: Import PGP key E0959FEA8B550539, "George Rawlinson <grawlinson@archlinux.org>"? [Y/n] y
:: Import PGP key 51E8B148A9999C34, "Evangelos Foutras <foutrelis@archlinux.org>"? [Y/n] y
(216/216) checking package integrity                   [############################] 100%
error: bashrc-manjaro: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/bashrc-manjaro-5.2.021-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: bash: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/bash-5.2.021-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: openssl: signature from "Pierre Schmitz <pierre@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/openssl-3.2.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: util-linux-libs: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/util-linux-libs-2.39.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: kbd: signature from "Tobias Powalowski <tpowa@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/kbd-2.6.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: hwdata: signature from "Tobias Powalowski <tpowa@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/hwdata-0.377-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libcap: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libcap-2.69-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: systemd-libs: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-libs-254.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: util-linux: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/util-linux-2.39.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libnl: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libnl-3.9.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ca-certificates-mozilla: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ca-certificates-mozilla-3.96.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: curl: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/curl-8.5.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: systemd: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-254.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: android-udev: signature from "Anatol Pomozov (Arch Linux developer account) <anatolik@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/android-udev-20231124-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: aom: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/aom-3.8.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: glib2: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/glib2-2.78.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: harfbuzz: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/harfbuzz-8.3.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: icu: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/icu-74.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libxml2: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libxml2-2.12.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libtiff: signature from "T.J. Townsend <blakkheim@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libtiff-4.6.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: librsvg: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/librsvg-2:2.57.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: appstream: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/appstream-1.0.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: archlinux-appstream-data: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/archlinux-appstream-data-20231203-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: avahi: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/avahi-1:0.8+r189+g35bb1ba-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: blas: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/blas-3.12.0-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libical: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libical-3.0.17-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: bluez: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/bluez-5.71-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: bluez-libs: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/bluez-libs-5.71-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: boost-libs: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/boost-libs-1.83.0-4-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: btrfs-progs: signature from "Tobias Powalowski <tpowa@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/btrfs-progs-6.6.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: cblas: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/cblas-3.12.0-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: cpupower: signature from "Sébastien Luttringer <seblu@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/cpupower-6.6-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: enchant: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/enchant-2.6.4-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: faad2: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/faad2-2.11.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpulse: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpulse-16.1-7-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libssh: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libssh-0.10.6-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: vulkan-icd-loader: signature from "Laurent Carlier <lordheavym@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/vulkan-icd-loader-1.3.274-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: onevpl: signature from "Daniel Bermond <dbermond@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/onevpl-2023.4.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: snappy: signature from "Anatol Pomozov (Arch Linux developer account) <anatolik@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/snappy-1.1.10-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: svt-av1: signature from "Maxime Gauduin <alucryd@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/svt-av1-1.8.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: v4l-utils: signature from "Jelle van der Waa <jelle@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/v4l-utils-1.26.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: vmaf: signature from "Daniel Bermond <dbermond@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/vmaf-3.0.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: spirv-tools: signature from "Daurnimator <daurnimator@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/spirv-tools-2023.5-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: glslang: signature from "Sven-Hendrik Haase <svenstaro@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/glslang-13.1.1-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lcms2: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lcms2-2.16-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: shaderc: signature from "Sven-Hendrik Haase <svenstaro@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/shaderc-2023.7-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: openssh: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/openssh-9.6p1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ffmpeg: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ffmpeg-2:6.1-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sqlite: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/sqlite-3.44.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: tracker3: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/tracker3-3.6.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gtk3: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gtk3-1:3.24.39-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: nspr: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/nspr-4.35-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: nss: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/nss-3.96.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: noto-fonts: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/noto-fonts-1:23.12.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: firefox: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/firefox-121.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: fltk: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/fltk-1.3.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-idna: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-idna-3.5-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-nbxmpp: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-nbxmpp-4.5.3-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-cryptography: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-cryptography-41.0.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-typing_extensions: signature from "Daniel M. Capella <polyzen@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-typing_extensions-4.9.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gajim: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gajim-1.8.4-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gettext: signature from "Tobias Powalowski <tpowa@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gettext-0.22.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libksba: signature from "Tobias Powalowski <tpowa@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libksba-1.6.5-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libsecret: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libsecret-0.21.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gnupg: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gnupg-2.4.3-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gpgme: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gpgme-1.23.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: grub: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/grub-2.12-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: update-grub: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/update-grub-2.12-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gspell: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gspell-1.12.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gstreamer: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gstreamer-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-plugins-base-libs: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-plugins-base-libs-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-libav: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-libav-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-plugins-bad-libs: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-plugins-bad-libs-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-plugin-gtk: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-plugin-gtk-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libde265: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libde265-1.0.15-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: zix: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/zix-0.4.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sord: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/sord-0.16.16-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sratom: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/sratom-0.6.16-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lilv: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lilv-0.24.22-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: zxing-cpp: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/zxing-cpp-2.2.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpipewire: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpipewire-1:1.0.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: raptor: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/raptor-2.0.16-4-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: imagemagick: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/imagemagick-7.1.1.23-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-plugins-bad: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-plugins-bad-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-plugins-base: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-plugins-base-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-plugins-good: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-plugins-good-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gst-plugins-ugly: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gst-plugins-ugly-1.22.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: harfbuzz-icu: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/harfbuzz-icu-8.3.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libibus: signature from "Campbell Jones <serebit@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libibus-1.5.29-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ibus: signature from "Campbell Jones <serebit@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ibus-1.5.29-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: jasper: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/jasper-4.1.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xdg-utils: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xdg-utils-1.2.0r25+g0f49cf5-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libwacom: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libwacom-2.9.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qt5-base: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qt5-base-5.15.11+kde+r148-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: kcoreaddons5: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/kcoreaddons5-5.113.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: kauth5: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/kauth5-5.113.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: kitemmodels5: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/kitemmodels5-5.113.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: kwindowsystem5: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/kwindowsystem5-5.113.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lapack: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lapack-3.12.0-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-openssl: signature from "Pierre Schmitz <pierre@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-openssl-1:3.2.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-curl: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-curl-8.5.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-util-linux: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-util-linux-2.39.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-glib2: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-glib2-2.78.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-harfbuzz: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-harfbuzz-8.3.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-icu: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-icu-74.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-libxml2: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-libxml2-2.12.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-libtiff: signature from "T.J. Townsend <blakkheim@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-libtiff-4.6.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-librsvg: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-librsvg-2:2.57.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-systemd: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-systemd-254.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-lcms2: signature from "Laurent Carlier <lordheavym@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-lcms2-2.16-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-libdrm: signature from "Laurent Carlier <lordheavym@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-libdrm-2.4.118-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-vulkan-icd-loader: signature from "Laurent Carlier <lordheavym@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-vulkan-icd-loader-1.3.274-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-gtk3: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-gtk3-1:3.24.39-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libdecor: signature from "Sven-Hendrik Haase <svenstaro@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libdecor-0.2.1-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-libdecor: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-libdecor-0.2.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libadwaita: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libadwaita-1:1.4.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libavif: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libavif-1.0.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libbpf: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libbpf-1.3.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libcdr: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libcdr-0.1.7-7-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: liblangtag: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/liblangtag-0.6.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libe-book: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libe-book-0.1.3-15-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libebml: signature from "Maxime Gauduin <alucryd@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libebml-1.4.5-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libgedit-amtk: signature from "Fabian Bornschein <fabiscafe@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libgedit-amtk-5.8.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libgedit-gtksourceview: signature from "Fabian Bornschein <fabiscafe@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libgedit-gtksourceview-299.0.5-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libheif: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libheif-1.17.6-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libmspub: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libmspub-0.1.4-15-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: perl: signature from "Florian Pritz <bluewind@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/perl-5.38.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpamac-11.6.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ostree: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ostree-2023.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pipewire: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/pipewire-1:1.0.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xdg-desktop-portal: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xdg-desktop-portal-1.18.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac-flatpak-plugin: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpamac-flatpak-plugin-11.6.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: snapd: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/snapd-2.61.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac-snap-plugin: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpamac-snap-plugin-11.6.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libqxp: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libqxp-0.0.2-11-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libraw: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libraw-0.21.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: poppler: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/poppler-23.12.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libvisio: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libvisio-0.1.7-10-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libcmis: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libcmis-0.6.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libzmf: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libzmf-0.0.2-15-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libreoffice-still: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libreoffice-still-7.5.9-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libsynctex: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libsynctex-2023.66984-17-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: liburing: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/liburing-2.5-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libwbclient: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libwbclient-4.19.3-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: licenses: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/licenses-20231215-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xorg-server-common: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/xorg-server-common-21.1.10-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xorg-server: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/xorg-server-21.1.10-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lightdm: signature from "Maxime Gauduin <alucryd@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lightdm-1:1.32.0-5-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux-firmware-whence: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux-firmware-whence-20231211.f2e52a1c-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux-firmware: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux-firmware-20231211.f2e52a1c-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mkinitcpio: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mkinitcpio-37.1-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux61: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux61-6.1.69-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lmdb: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lmdb-0.9.31-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lua: signature from "Caleb Maclennan <alerque@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/lua-5.4.6-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: luajit: signature from "Daurnimator <daurnimator@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/luajit-2.1.1702233742-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: vulkan-headers: signature from "Laurent Carlier <lordheavym@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/vulkan-headers-1:1.3.274-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qt6-translations: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qt6-translations-6.6.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qt6-base: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qt6-base-6.6.1-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qt6-declarative: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qt6-declarative-6.6.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: shiboken6: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/shiboken6-6.6.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pyside6: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/pyside6-6.6.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: perl-http-cookies: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/perl-http-cookies-6.11-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mhwd-nvidia: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mhwd-nvidia-545.29.06-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-hello: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-hello-0.7.1-3-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-release: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-release-23.1.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-settings-manager: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-0.5.7-20-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-settings-manager-notifier: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-notifier-0.5.7-20-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mujs: signature from "Daniel Bermond <dbermond@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/mujs-1.3.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: netpbm: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/netpbm-10.86.39-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: openresolv: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/openresolv-3.13.2-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pamac-cli: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pamac-cli-11.6.0-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pamac-gtk: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pamac-gtk-11.7.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: papirus-icon-theme: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/papirus-icon-theme-20231201-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pcsclite: signature from "Frederik Schwan <freswa@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/pcsclite-2.0.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pkcs11-helper: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/pkcs11-helper-1.30.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: plymouth: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/plymouth-22.02.122-15-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: poppler-glib: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/poppler-glib-23.12.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: protobuf-c: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/protobuf-c-1.5.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pulseaudio: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/pulseaudio-16.1-7-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pulseaudio-bluetooth: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/pulseaudio-bluetooth-16.1-7-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pulseaudio-zeroconf: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/pulseaudio-zeroconf-16.1-7-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-numpy: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-numpy-1.26.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qpdf: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qpdf-11.6.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-pikepdf: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-pikepdf-8.10.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-platformdirs: signature from "George Rawlinson <grawlinson@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-platformdirs-4.1.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-pydantic-core: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-pydantic-core-1:2.14.5-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-pydantic: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-pydantic-2.5.2-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-trove-classifiers: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-trove-classifiers-2023.11.29-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: python-setuptools: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/python-setuptools-1:69.0.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qt6-svg: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qt6-svg-6.6.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qbittorrent: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qbittorrent-4.6.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: qemu-guest-agent: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qemu-guest-agent-8.1.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: smbclient: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/smbclient-4.19.3-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: samba: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/samba-4.19.3-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sof-firmware: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/sof-firmware-2023.12-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sudo: signature from "Evangelos Foutras <foutrelis@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/sudo-1.9.15.p4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: systemd-sysvcompat: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-sysvcompat-254.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: tepl: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/tepl-1:6.8.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: thin-provisioning-tools: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/thin-provisioning-tools-1.0.9-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: thunderbird: signature from "Leonidas Spyropoulos <artafinde@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/thunderbird-115.6.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: vte-common: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/vte-common-0.74.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: vte3: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/vte3-0.74.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xapp: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xapp-2.8.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: timeshift: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/timeshift-23.12.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ttf-noto-nerd: signature from "T.J. Townsend <blakkheim@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ttf-noto-nerd-3.1.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: tumbler: signature from "Evangelos Foutras <foutrelis@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/tumbler-4.18.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: vlc: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/vlc-3.0.20-4-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: webkit2gtk: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/webkit2gtk-2.42.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: webkit2gtk-4.1: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/webkit2gtk-4.1-2.42.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xfce4-cpugraph-plugin: signature from "Evangelos Foutras <foutrelis@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xfce4-cpugraph-plugin-1.2.10-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: xfce4-power-manager: signature from "Evangelos Foutras <foutrelis@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xfce4-power-manager-4.18.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xfce4-settings: signature from "Evangelos Foutras <foutrelis@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xfce4-settings-4.18.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xfce4-whiskermenu-plugin: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xfce4-whiskermenu-plugin-2.8.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: xfsprogs: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/xfsprogs-6.5.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: zsh-syntax-highlighting: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/zsh-syntax-highlighting-0.8.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package (PGP signature))
[luna@jar-n ~]$
You have pacdiff files too.
Seems you do not follow the correct update procedures (checking the announcement thread).
Handle the pacdiff files and see if that solves anything.
I eeeh, actually searched the internet for a manjaro tutorial on pacdiff, I know there is one but have not saved it. The top link is MY question about it, read the thread and I think you will understand.
I recommend using meld instead of vimdiff to handle the pacdiffs: Support on how to use pacdiff
To me it looks like an update broke somewhere or that your system has not been updated in a loooong time.
I use pacman-mirrors followed by sudo pacman -Syu. (Between them might come sudo journalctl --vacuum-size=50M and sudo paccache -ruk0, but I believe these are optional.) Is this not correct, or are we talking about something else?
When update first failed today, the VM was as updated on Dec 10. So the pending updates were 2023-12-13, 2023-12-15, and 2023-12-23. I hope that’s not a “loooong” time.
I’ve used meld before. I am not sure I understand what I am supposed to use meld on, for this problem. Maybe when I read you link, there will be an explanation?
Anyway, I don’t have practical issue because an older snapshot saved me.
Yes, you should ALWAYS check the announcement thread. A new thread is created with each big update. Right now it is this: [Stable Update] 2023-12-23 - Kernels, Grub, Mate, Deepin, Cinnamon, ICU, KDE Frameworks
You can check the second post in the thread that contains " Known issues and solutions"
:+1:
Yes, you clearly have pacdiffs since LONG, community repository was removed a long time ago.
pacdiff -o will list the files. (it should return nothing when you are done)
The link will tell you what you have to do with them.
Good. Revert to that, handle the pacdiffs and THEN retry the update, maybe it will fix stuff.
Edit
Bumped into this thread, and this response: Keyring error while installing wine - #5 by Yochanan
Remove the directory completely:
sudo rm -r /etc/pacman.d/gnupg/
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman -Sc  # may or may not be necessary
sudo pacman -Syyu
