How to switch to Wayland?
Edited everything:
Hey Guys,
In advance: English isnt my native language so im sorry for my (maybe) poor English
What do I want to do? - I want to use Wayland on my Manjaro KDE installation (from today)
How did I trie? - I tried by switching via the select on the bottom left of the login screen
→ Results: A black screen in which I got stuck.
I hope someone can help me with my problem. Thanks in advance.
system info:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=65e3bba7-8119-4648-9572-a7565e1276e6 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Desktop Mobo: Micro-Star model: Z790 GAMING PLUS WIFI (MS-7E06) v: 3.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: H.60 date: 08/15/2024
  System RAM: total: 32 GiB available: 31.12 GiB used: 4.88 GiB (15.7%)
  Device-1: Controller0-DIMMA1 type: no module installed
  Device-2: Controller0-DIMMA2 type: DDR5 detail: synchronous size: 16 GiB
    speed: 4800 MT/s volts: curr: 1 min: 1 max: 1.35 width (bits): data: 64
    total: 64 manufacturer: G Skill Intl part-no: F5-6000J3636F16G
    serial: <filter>
  Device-3: Controller1-DIMMB1 type: no module installed
  Device-4: Controller1-DIMMB2 type: DDR5 detail: synchronous size: 16 GiB
    serial: <filter>
  Info: model: Intel Core i5-14600K bits: 64 type: MST AMCP arch: Raptor Lake
    gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12B
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 881 min/max: 800/5300:4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 881 2: 881 3: 881 4: 881 5: 881 6: 881 7: 881
    8: 881 9: 881 10: 881 11: 881 12: 881 13: 881 14: 881 15: 881 16: 881
    17: 881 18: 881 19: 881 20: 881 bogomips: 139820
    de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Micro-Star MSI
    driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
    built: 2022+ ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
    HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:a780 class-ID: 0380
  Device-2: NVIDIA AD104 [GeForce RTX 4070] vendor: Gigabyte driver: nvidia
    v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-4,DP-5,HDMI-A-5
    empty: DP-3 bus-ID: 01:00.0 chip-ID: 10de:2786 class-ID: 0300
  Device-3: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:6
    chip-ID: 045e:0810 class-ID: 0102
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3200x1080 s-dpi: 94 s-size: 865x292mm (34.06x11.50")
    s-diag: 913mm (35.94")
  Monitor-1: DP-2 pos: primary,left res: 1280x1024 hz: 85 dpi: 86
    size: 380x305mm (14.96x12.01") diag: 487mm (19.18") modes: N/A
  Monitor-2: DP-4 pos: right res: 1920x1080 dpi: 94
    size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
  Monitor-3: HDMI-0 size-res: N/A modes: N/A
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
    memory: 11.71 GiB
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4070 driver: N/A device-ID: 10de:2786
    surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: N/A device-ID: 8086:a780
    surfaces: xcb,xlib
  Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  Device-2: NVIDIA AD104 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
  Device-4: Logitech [G533 Wireless Headset Dongle]
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-5.2:7 chip-ID: 046d:0a66 class-ID: 0300
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 7.5 TiB used: 65.96 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
    fw-rev: 1B2QEXM7 temp: 43.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 40.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1ER164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC25 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 2.00
    dev-links: cdrom
  Features: speed: 94 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 65.96 GiB (28.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
    label: N/A uuid: 65e3bba7-8119-4648-9572-a7565e1276e6
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
    uuid: 5FD8-E0C2
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 2E9E-4D62
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 1.82 TiB fs: ntfs label: N/A
    uuid: 70BAA0BABAA07E6A
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 659 MiB fs: ntfs label: N/A
    uuid: 72FC468FFC464D93
  ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: SSD
    uuid: 76C04578C0453F9B
  ID-7: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ext4 label: N/A
    uuid: 9d4a88bc-39ba-4a45-a67d-378ee565dd1c
  ID-8: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: <superuser required>
  ID-9: /dev/sdc2 maj-min: 8:34 size: 1024 KiB fs: <superuser required>
  ID-10: /dev/sdc3 maj-min: 8:35 size: 127 MiB fs: <superuser required>
  Device-1: 1-2:2 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7e06 class-ID: 0300
    serial: <filter>
  Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-3: 1-5.1:5 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-5.2:7 info: Logitech [G533 Wireless Headset Dongle]
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Device-2: 1-5.3:9 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
    serial: <filter>
  Device-3: 1-11:4 info: Logitech G213 Prodigy Gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c336 class-ID: 0300 serial: <filter>
  Device-4: 1-12:6 info: Microsoft LifeCam HD-3000 type: video,audio
  Hub-4: 1-13:8 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-14:10 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Hub-6: 2-4:2 info: Genesys Logic Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 38.8 C mobo: N/A gpu: nvidia temp: 37 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 50%
  Packages: pm: pacman pkgs: 1377 libs: 379 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    3: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 437
  1: cpu: 10.8% command: steamwebhelper pid: 5465 mem: 539.9 MiB (1.6%)
  2: cpu: 9.6% command: Discord pid: 6615 mem: 569.0 MiB (1.7%)
  3: cpu: 9.0% command: firefox pid: 3271 mem: 607.3 MiB (1.9%)
  4: cpu: 8.3% command: konsole pid: 7205 mem: 176.3 MiB (0.5%)
  5: cpu: 7.8% command: steam pid: 5194 mem: 173.3 MiB (0.5%)
  Memory top: 5 of 437
  1: mem: 684.4 MiB (2.1%) command: plasmashell pid: 1044 cpu: 4.1%
  2: mem: 607.3 MiB (1.9%) command: firefox pid: 3271 cpu: 9.0%
  3: mem: 569.0 MiB (1.7%) command: Discord pid: 6615 cpu: 9.6%
  4: mem: 539.9 MiB (1.6%) command: steamwebhelper pid: 5465 cpu: 10.8%
  5: mem: 452.2 MiB (1.4%) command: ./steamwebhelper pid: 5387 cpu: 1.6%
  Processes: 437 Power: uptime: 45m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.36
Hi @Tob1nator, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hi @Tob1nator and welcome to the Manjaro community.
I’m afraid you haven’t provided much information to begin speculating about your issue.
However, there are a few items concerning black screens in recent Known Issues and Solutions and listed in every Update Announcement thread. I would look through those to see which of them might potentially affect you. There is also the forum Search that might reveal something useful.
In the meantime; and as mentioned by @Mirdarthos
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information. The Known Issues and Solutions section should generally be a first port of call before posting a request for support, in case an issue has already been addressed.
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
This Post described the exact same problem: How to switch to Wayland? Wayland does not work
But still thanks for trying to help me.
Which particular post? You only linked to the topic.
Solution removed pending some clarification; for the benefit of others finding this thread.
Did you mean this thread (linked from the thread you indicated)?
Additionally, you have no swap space configured; you might wish to attend to that when you are able:
